Results 1 to 4 of 4
Thread: class stream support?
    412
    @Paul
    Does Teensy 3.x support the class stream?
    20,588
    Yes, it does have the Stream class.
    412
    Any (serial) examples using the stream class I could examine?
    20,588
    Except for readBytes(), all the functions are nearly identical to Arduino's. Examples from Arduino should all work fine.
    The readBytes() has optimization for some devices, especially USB serial. It should work the same as Arduino, but unlike Arduino, reading blocks of data is much faster. Those optimizations were inspired by OctoWS2811. Look at the VideoDisplay example.
