Results 1 to 24 of 24
Thread: iregular shaped LED strip screen
    Jun 2015
    11
    Hello everyone, I am trying to build an LED screen shaped as a guitar. I want it to be able to display graphics as if it was a square screen.I am using WS2812 strip and a Teensy 3.1.Is there a way to map out each pixel (see picture). For example. from top left pixel nr. 5 is actually the first pixel, and pixel nr.26 is actually pixel nr. 3. would it be possible to map ot each pixel as pixel nr.1 = x5y1 and pixel nr.26 = x3y2. I am not that good at programming, so how would that look in a sketch??
    Best regards
    Colin Dahlberg
    Senior Member mortonkopf's Avatar
    Apr 2013
    London, uk
    941
    You can use a lookup array to do this, such that all of the leds forming the guitar (the blue ones?) are set out in order of receiving data such as: byte guitarArray[] = {5,6,26,27,28,29,30,31,32,49.50...}. You then access the position of theis by simply working through the array in sequence, such as: guitarArray [0] = whateverColour; This would turn the first led in the array, nr 5, whateverColour.
    In terms of referencing led x and y location, you would not need to do anything more than know its position in the array. for example, led 26 would be guiterArray[2];
    Jun 2015
    11
    Thank you very much mortonkopf, that looks like plan , would it be possible to add it to this sketch.
    #include "FastLED.h"
    #define NUM_LEDS 456
    #define COLOR_ORDER RGB
    const int dataline = 13;
    CRGB leds[NUM_LEDS];
    LEDS.addLeds<WS2812B, dataline>(leds, NUM_LEDS);
    int serialGlediator() {
    while (!Serial.available()) {}
    return Serial.read();
    while (serialGlediator() != 1) {}
    for (int i=0; i < NUM_LEDS; i++) {
    leds[i].r = serialGlediator();
    leds[i].g = serialGlediator();
    leds[i].b = serialGlediator();
    FastSPI_LED.show();
    Could you maybe give me an idea on how to put it in the sketch.
    Thank you very much :-)
    Apr 2013
    London, uk
    941
    putting it into the sketch will depend on how Glediator outputs. I have not use it. Will it be outputting as if the matrix were the guitar shape, or will it be outputting to all leds, 25 wide by however many high?
    Jun 2015
    11
    it is 24X19 leds
    Apr 2013
    London, uk
    941
    Quote Originally Posted by Dahlberg77 View Post
    it is 24X19 leds
    really sorry, I'm just not getting it. You are going to output a square array from Glediator at 24*19, and want to display this on only the guitar shape leds? Or will gladiator output only the guitar shape leds?
    Jun 2015
    11
    I want to output a square array from Glediator at 24*19, and only display the guitar shape leds.
    Apr 2013
    London, uk
    941
    one way would be to make a mask the sets all non guitarArray pixels/leds to black just before you use the update FastSPI_LED.show(); call. So in effect you send all the glediator 24*19 pixel to all the leds, but then before you call show(), set the ones you don't want to black. This will slow down the update rate a little, but should not be by too much.
    Try this:
    make an array containing the led number for those that are NOT part of the guitar;
    int notGuitar[] = {0,1,2,3,4,7,8,9,10,111,12,13,14,15,16,17,18,19,20 ,21,22,23,24,25,3,34,35,…};
    and just before the show(); do something like:
    for (int x=0;x<numberofblackoutLEDS;x++) { leds[notGuitar[x]] =0;}
    This is a bit of guess of course, and I don't have the test setup.
    FastSPI_LED.show();
    you would declare your array at the front end of your code before setup().
    int notGuitar[] = {0,1,2,3,4,7,8,9,10,111,12,13,14,15,16,17,18,19,20,21,22,23,24,25,3,34,35,…};
    Jun 2015
    11
    Thank you so much for your help mortonkopf. The Glediator is not that important. this is going to be an actual guitar. I think that if I can make an array of the LEDs on the guitar, that would do the trick, I will then just output from a square screen in 24X19 from Glediator the problem is to setup the LEDs on the guitar so they will act like a "square" screen, when graphics is displayed on to it.
    See picture. the numbers on the guitar are the numbers the LEDs would hav if it was a sqaure screen, but in reallity they are lust one long strip. So graphics will be distorted when displayed, because they are not setup for the right placements. for example number 176 and 181 will just act as if they were 176 and 177, and so on.Click image for larger version.
    Apr 2013
    London, uk
    941
    Ah, right, that is starting to make more sense now. you will need to get into some more led location coding in that case.
    one way is I think that you could fill a buffer with each frame from the a buffer array. This second buffer would then hold all led info for each frame. After filling the buffer with the led data, you then go through and assign a value from the buffer array to the second array that fits the layout you have, then you use show(). Again, this might slow things down a bit. This is the only way I can see how to select only some of the data from the incoming stream.
    A potential way would be to use the the virtual locations set of led position numbers, as if you had the 24*19 array of leds, as discussed above, and walk through that list of locations to assign the led colour value from the buffer. But its a bit of double handling, and a cant get my head around the fact that there must be a simpler, more efficient way.
    Jun 2015
    11
    wuuhuuu I actually explained something that people could understand. I have had a really hard time trying to fond a way to explain my problem. as I am a totally noob at this I wouldent knov where to start with the programming, could you maybe guide a bit. I really am totally lost and cant seem to find any info on the topic, so any help will be much appreciated.
    Best from
    Denmark
    Apr 2013
    London, uk
    941
    You could try something along the lines of the below, but it is written from memory, and without any test, so there will be a couple of errors:
    #define NUM_LEDS 456//this is the matrix size number of leds, not actual number
    int actualLeds =300;//? How many leds do you actually have
    CRGB leds[NUM_LEDS];//defines size of storage buffer for full matrix size
    int guitarLeds[] = { //this stores the position of the led colour in the incoming data
    //this is a 1D array, just set out as below for easy reading
    5,6,
    49,50,51,52,53,54,55,56,57,66,67,68,
    73,74,75,76,77,78,79,80,81,82,83,84,85,86,87,88,89,80,91,92,93,94,
    96,97,98,99,10,101,102,103,104,105,106,107,108,109,110,111,112,113,114,115,116,117,118,119
    //...etc
    char colourStore[NUM_LEDS*3]; //this will store the selected data
    for (int x=0; x < NUM_LEDS*3; x+3) { //loop through all incoming data and put into the colourStore array
    colourStore[x] = serialGlediator();//first colour byte
    colourStore [x+1] = serialGlediator();//second colour byte
    colourStore [x+2] = serialGlediator();//third colour byte
    for (int i=0; i < actualLeds; i++) {//this loops through each of the actual leds, and grabs the value //for r,g,b from colourStore at the given location value (taken from guitarLeds).
    leds[i].r = colourStore[guitarLeds[i*3]];
    leds[i].g = colourStore[guitarLeds[i*3]+1];
    leds[i].b = colourStore[guitarLeds[i*3]+2];
    FastLED.show();
    Jun 2015
    11
    One step closer. does this look right. it compiles and uploads but it comes with some errors
    int actualLeds =272;//? How many leds do you actually have
    int guitarLeds[] = {6,7,
      27,28,29,30,31,32,33,
      50,51,52,53,54,55,56,57,58,66,67,68,69,
      74,75,76,77,78,79,80,81,82,83,84,85,86,87,88,89,90,91,92,93,94,95,
      97,98,99,100,101,102,103,104,105,106,107,108,109,110,111,112,113,114,115,116,117,118,
      120,121,122,123,124,125,126,127,128,129,130,131,132,133,134,135,136,137,138,139,140,141,
      144,145,146,147,148,149,150,151,152,153,154,155,156,157,158,159,160,161,162,163,164,165,
      168,169,170,171,172,173,182,183,184,185,189,
      192,193,194,195,196,197,206,207,208,209,
      216,217,218,219,220,221,230,231,232,233,
      240,241,242,243,244,245,254,255,256,257,
      264,265,266,267,268,269,278,279,280,281,285,
      288,289,290,291,292,293,294,295,296,297,298,299,300,301,302,303,304,305,306,307,308,309,
      313,314,315,316,317,318,319,320,321,322,323,324,325,326,327,328,329,330,331,332,333,
      337,338,339,340,341,342,343,344,345,346,347,348,349,350,351,352,353,354,355,356,357,
      361,362,363,364,365,366,367,369,370,371,372,373,374,375,376,377,378,379,380,381,382,383,
      386,387,388,389,390,391,392,393,394,402,403,404,405,
      411,412,413,414,415,416,417,
        436,437,438,439};
    FastSPI_LED.show();
    and these errors
    Guitar_LED.ino: In function 'void loop()':
    Guitar_LED.ino:43:32: warning: for increment expression has no effect [-Wunused-value]
    Multiple libraries were found for "FastLED.h"
    Used: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\FastLE D
    Not used: C:\Users\Colin\Documents\Arduino\libraries\FastLED-3.0.3
    Not used: C:\Users\Colin\Documents\Arduino\libraries\FastLED-archive-FastLED2.1
    Sketch uses 14.232 bytes (5%) of program storage space. Maximum is 262.144 bytes.
    Global variables use 6.304 bytes (9%) of dynamic memory, leaving 59.232 bytes for local variables. Maximum is 65.536 bytes.
    Apr 2013
    London, uk
    941
    Ah, I think that syntax for incrementing a for loop by more than one is not x+3, but x+=3. Anyone?
    so
    should be
    for (int x=0; x < NUM_LEDS*3; x+=3) { //? hopefully this is the right syntax
    If that is not correct, it would be a simple insert of the line
    i=i+3;
    at the bottom of the for loop
    Also, you have multiple copies of FastLed in your libs,
    Jun 2015
    11
    Oh and i forgot to mention, it dos´nt output anything :-(
    But still thank you so much for your great help.
    Apr 2013
    London, uk
    941
    I'm not surprised that it doesnt output anything, there is still some work to do. I will have a test this evening if i get the time, but I am away from any kit at the moment.
    the lines below seem wrong, somehow:
    should probably read
    leds[i].g = colourStore[guitarLeds[(i*3)+1]];
    leds[i].b = colourStore[guitarLeds[(i*3)+2]];
    and
    for (int x=0; x < NUM_LEDS; x++)
    but I would need to have a better think about it.
    Jun 2015
    11
    There is still no output in Glediator, Did I put in the lines correct??
        436,437,438,439};
    for (int x=0; x < NUM_LEDS*3; x+=3) { //loop through all incoming data and put into the colourStore array
    i=i+3;
    FastSPI_LED.show();
    Apr 2013
    London, uk
    941
    we have cross posts. Probably better to continue sorting this through pm and post solution to this thread.
    Apr 2013
    London, uk
    941
    Dahlberg77, I have sent you a pm with some corrected code. pm back
    this might help
    for(int x=0;x<300;x++){//where 300 is the number of actual leds, and guitarleds[] hold the led locations in the //stream
      leds[x]= leds[guitarLeds[x]];
    FastLED.show();
    Apr 2013
    London, uk
    941
    This now works, Glediator to irregular matrix size. The below should generally work with any matrix input, such as pixelcontroller or gladiator. Dahlberg77, chip in if there are any other changes:
    #define NUM_LEDS 272 //this is the matrix input size
    int guitarLeds[] = {6,10,20,30,40,50,60,70,80,90,100,110,200 };// this is the virtual locations of your leds within the matrix from your output software
      FastLED.addLeds<WS2811, 3, RGB>(leds, NUM_LEDS);
    for(int x=0;x<13;x++){ //where 13 is the number of actual leds - the virtual location of which are in guitarLeds[]
    FastLED.show();
    Jun 2015
    11
    This is the working code I use, and mortonkopf, youre a Wizz
                                                              // chain all the led strips so they face the same
    #define NUM_LEDS 456                          //Matrix size input 24X19 pixel
    byte colourStore[NUM_LEDS *3];
    int guitarLeds[] = {6,7,                         //this is a 1D array, just set out as below for easy reading
        436,437,438,439};
    for(int x=0;x<272;x++)                    //272 is the actual led number
    FastSPI_LED.show();
    Apr 2013
    London, uk
    941
    lastly, the inclusion of "byte colourStore[NUM_LEDS *3];" can now be removed as it is no longer being used.
    4,089
    Cool
    You might want to add the const keyword in setting up guitarLeds if you don't modify it. On the ARM platforms, this puts the array into read-only program memory, instead of read-write data memory. In addition, since no value is more than 439 or so, you might want to use int16_t to save a little memory. Whether you use static or not is optional (in somethings, particularly at higher optimization levels, you can get better code if the value is declared static which limits the scope to just the current file).
    static const int16_t guitarLeds[] = {6,7,                         //this is a 1D array, just set out as below for easy reading
        436,437,438,439};
  24. #24
    Jun 2016
    2
    How can I adapt this code to save my animations to an SD card from gladiator and use it on the go?
