Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 51 to 75 of 76
Thread: Wiki Coming - Please link worthy posts
  1. #51
    6,104
    { reminder:: link instructive things you see or do on the forum here so when the WiKi gets rolling stuff can be pulled out and covered }
    Teensy 3.2 Interrupts to Blink LED's at Different Rates :: systick_isr() timer interrupt
    https://forum.pjrc.com/threads/36778...l=1#post114681
    Link to the Newlib Library Documentation: Teensy uses:: Newlib is a C library intended for use on embedded systems.
    https://sourceware.org/newlib/
    Teensy-Internal-Reference-Voltage
    Teensy-Internal-Reference-Voltage-Question?
  2. #52
  3. #53
  4. #54
  5. #55
    6,104
    Arduino Language Reference:: Primary Arduino as well as Standard C reference info - be alert for better 32 bit ARM Teensy math or other::
    https://www.arduino.cc/en/Reference/HomePage
    Arduino Libraries Summary - some may have ported or improved Teensy code::
    Reference/Libraries
  6. #56
    Germany NRW
    4,394
  7. #57
    6,104
    Teensy 3.6 Analog Reference Card showing pin source:
    K66-Beta-Test
    Generate an assembler listing when compiling Teensy
    How-can-I-generate-an-assembler-listing-when-compiling-Teensy
    Tutorial on State machine usage - don't use delay() - watch the clock! Part 1 of 3
    adafruit.com multi-tasking-the-arduino-part-1/all-together-now
    Teensy Specific LED/DIGITAL FLASHER class sample with elapsedMicros and no delay()
    Help-with-Coding-to-get-LED-s-Working-as-I-would-Like
    Using a local DEF file to alter compile time settings [FrankB ]::
    HOWTO-Store-Projects-settings-(like-F_CPU-USB-Keyboard-layout)
    ARM MEMORY access cycles: for RAM / FLASH / EEPROM / PORTS
    Teensy-3-6-8pin-16pin-and-32pin-simultaneous-writes
  8. #58
    843
    Input capture / pulse measurements using FTM timers and DMA:
    https://github.com/tni/teensy-sample...apture_dma.ino
  9. #59
  10. #60
    Junior Member gruvin's Avatar
    Nov 2016
    New Zealand
    7
    Quote Originally Posted by Robin View Post
    I promise the Wiki is coming.
    Don't ya just hate it when life gets in the way of the fun stuff? :-P (I'm brand new around here. No offense intended.)
  11. #61
    2,629
    If this post gets answered, the answers should go in the wiki:
  12. #62
    Germany NRW
    4,394
    Teensy 3.6 startup problems with some power supplys - or - Teensy resets due to EMI on its reset line.
    - Add a capacitor ~10nF..~22nF between RESET an GND.
  13. #63
    Germany NRW
    4,394
    "Also to note that on my Windows 7 machine, it's recognized as "Teensy" while on my Windows 10 machine it's only recognized as "COM5".
    At least that part is normal.
    With Windows 10, Microsoft finally began shipping a system INF to cause their own USBSER.SYS driver to load for serial devices.
    Before Windows 10, everyone using standard serial (technically usb communication class abstract control model - one of many standard officially published by the usb organization) had to provide their own INF. Usually this is called a "driver", even though it's merely an INF that tells Windows XP, Vista, 7, 8 to load their own USBSER.SYS driver. The INF PJRC provides has "Teensy" in its description, so when you see the device appear in the Windows Device Manager, it says Teensy.
    On Windows 10, the name which appears is the generic name Microsoft put into their own INF. So it's perfectly normal to see this difference between Windows 10 and older versions of Windows.
    https://forum.pjrc.com/threads/42576...l=1#post136209
  14. #64
    Apr 2013
    1,685
    Off site series of blog posts on getting an emulated xbox controller (xinput) up and running as a new USB type
    http://www.zlittell.com/2015/07/msf-...-controller-8/
    Useful as is and as a case study in making a new USB type for Teensy
  15. #65
    2,629
    Cool Firmata-on-Teensy-3-2
    From https://forum.pjrc.com/threads/42625...-on-Tennsy-3-2:
    You'll probably need to edit Firmata's Boards.h to disallow use of pins 0 and 1. If anything in Firmata tries to access them as GPIO, the pins are no longer controlled by Serial1.
  16. #66
    6,104
    Disassemble your binary
    arm-none-eabi-objdump.exe -d --demangle ...
    To get assembly code:
    arm-none-eabi-objdump -d --demangle -C YOUR_COMPILED_SKETCH.elf > assembly.txt
    arm-none-eabi-objdump is included with the toolchain, e.g. arduino/hardware/tools/arm/bin/arm-none-eabi-objdump.exe.
  17. #67
    1,636
    Out of curiosity, I checked the 'WIKI coming soon' saga
    It started nearly 2 years ago and over 2 years ago defragster noted 'PJRC and Teensy(s) needs a Wiki' https://forum.pjrc.com/threads/28793...ll=1#post74446
    Now, where is it?
    Any update from PJRC?
  18. #68
    Administrator Robin's Avatar
    Oct 2012
    PJRC Global Headquarters
    268
    It's on the to do list, unfortunately it keeps getting pushed lower down in priority as things like Teensy 3.5, Teensy 3.6, and USB Host development get pushed up in priority. We have been working on some IT infrastructure changes that will help facilitate the creation of the Wiki. I commit to any timeline for this, but I can assure you that it has not been forgotten about.
  19. #69
    6,104
    ... I've seen notes that predate mine. What I've seen and noted about the WiKi is - they 'write themselves' - like this thread - and the forum - they just need an outlet.
    Definition of wiki
    :* a website that allows visitors to make changes, contributions, or corrections
  20. #70
    Ability to debug is key to develop quality applications. I can't see how this is surpassed by other priority items.
  21. #71
    because of the lack of proper debug support I jumped to
    http://www.nxp.com/products/microcon...s:FRDM-KEAZ128
    This comes ( if I understand it correctly) with full debug support inside a proper development env (Elclipse)
    This is not to rub it in or something: this is the dilemma you have to face when choosing a certain development board/platform
  22. #72
  23. #73
    17,030
    Here's some info about connecting more than 32 Teensy boards to a PC, shared by email from someone who wishes to remain anonymous.
    Apparently the Linux /dev/ttyACM driver has a limit of "only" 32 simultaneous devices. Apple's driver on Sierra has a limit of only 16. So far, no info about whether Windows has a similar limit.
    The info for Linux:
    So I got 64 teensies to mount on opensuse 13.2
    in /usr/src/linux/drivers/usb/class/cdc-acm.h
    there is a
    #define ACM_TTY_MINORS 32
    set that to 64 or 128. I did 256
    then borrowing heavily from
    https://forums.opensuse.org/showthre...-kernel-module
    cd /usr/src/linux
    make clean
    make oldconfig
    cp /usr/src/linux-obj/HW/NAME/Module.symvers /usr/src/linux/
    make scripts
    make prepare
    cd /usr/src/linux/drivers/usb/class
    make -C /usr/src/linux SUBDIRS=$PWD modules
    cp /usr/src/linux/drivers/usb/class/cdc-acm.ko /lib/modules/VERS/kernel/drivers/usb/class/
    shutdown -r now
    Edit: Windows 10 was tested and found to support only 16 simultaneous devices.
  24. #74
    2,629
    It has been said before, but just to link this into the page for eventual inclusion into a wiki. The Teensy 3.5 and 3.6's bootloader has a mode to wipe out the memory. You have to press and keep pressed, the program button for 13-17 seconds:
    The program wipe feature is not 20+ seconds. It's *exactly* 15 seconds. The bootloader actually looks for a press that lasts between 13 to 17 seconds, so you're allowed +/- 2 seconds. If you hold for 20 seconds or more, you'll miss that window.
    Whether or not this program wipe will help is anyone's guess. Seems very likely the hardware may just be damaged. But to even try the program wipe, you really need to look at a stopwatch or clock with seconds when pressing the button, so you can hit that 13 to 17 second window.
    This is from:
  25. #75
    6,104
    Powering Teensy with external LiPo Charger:
    Help-with-Connecting-Lipo-Battery-and-Charger-to-Teensy-3-2
