Pensive
I haven't really touched my code for some time, but it used to compile just fine in Atmel Studio and the previous incarnation of Arduino IDE/Teensyduino (January 2015 era).
It is hanging after having compiled lots of libraries, it gets to Metro, and stops.
I have two audiosample .h includes after that before it even gets to my code, so it's not even getting past the include files.
verbose output below:
I don't see that there is all that much point but all my code is on github here:
https://github.com/Pensive/Beats-by-Teensy
I think my install is a bit skewiff, but Teensy examples compile just fine and teensyduino pops up ready to download.
I also have Visualmicro and Visual Studio Community 2013 installed (And apparently working, however again it doesn't compile, this could be for a multitude of reasons, so I reverted back to Arduino IDE to check the code).
So my code all parses. It's all been tried and tested in a previous version. and it doesn't seem to be my code at all (on the surface).
Any ideas, short of wipe & reinstall arduino?
Build options changed, rebuilding all
Using library Audio in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio (1.0.x format)
Using library Wire in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire (1.0.x format)
Using library SPI in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI (1.0.x format)
Using library SD in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD (1.0.x format)
Using library Bounce in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Bounce (1.0.x format)
Using library ST7565 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\ST7565 (1.0.x format)
Using library flash_spi in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\flash_spi (1.0.x format)
Using library Encoder in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Encoder
Using library Metro in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Metro (1.0.x format)
// BIG CHUNK REMOVED so the post would fit.
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-gcc -c -O -g -Wall -ffunction-sections -fdata-sections -MMD -nostdlib -mthumb -mcpu=cortex-m4 -D__MK20DX256__ -DTEENSYDUINO=123 -DARDUINO=10604 -DF_CPU=96000000 -DARDUINO_ARCH_AVR -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3 -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Bounce -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\ST7565 -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\flash_spi -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Encoder -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Metro -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\utility C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\utility\sqrt_integer.c -o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\Audio\utility\sqrt_integer.c.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-g++ -c -O -g -Wall -ffunction-sections -fdata-sections -MMD -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -D__MK20DX256__ -DTEENSYDUINO=123 -DARDUINO=10604 -DF_CPU=96000000 -DARDUINO_ARCH_AVR -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3 -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Bounce -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\ST7565 -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\flash_spi -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Encoder -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Metro -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire\utility C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire\Wire.cpp -o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\Wire\Wire.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-gcc -c -O -g -Wall -ffunction-sections -fdata-sections -MMD -nostdlib -mthumb -mcpu=cortex-m4 -D__MK20DX256__ -DTEENSYDUINO=123 -DARDUINO=10604 -DF_CPU=96000000 -DARDUINO_ARCH_AVR -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3 -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Bounce -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\ST7565 -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\flash_spi -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Encoder -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Metro -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire\utility C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire\utility\twi.c -o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\Wire\utility\twi.c.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-g++ -c -O -g -Wall -ffunction-sections -fdata-sections -MMD -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -D__MK20DX256__ -DTEENSYDUINO=123 -DARDUINO=10604 -DF_CPU=96000000 -DARDUINO_ARCH_AVR -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3 -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Bounce -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\ST7565 -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\flash_spi -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Encoder -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Metro -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI\utility C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI\SPI.cpp -o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\SPI\SPI.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-g++ -c -O -g -Wall -ffunction-sections -fdata-sections -MMD -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -D__MK20DX256__ -DTEENSYDUINO=123 -DARDUINO=10604 -DF_CPU=96000000 -DARDUINO_ARCH_AVR -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3 -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Bounce -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\ST7565 -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\flash_spi -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Encoder -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Metro -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD\utility C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD\cache_t3.cpp -o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\SD\cache_t3.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-g++ -c -O -g -Wall -ffunction-sections -fdata-sections -MMD -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -D__MK20DX256__ -DTEENSYDUINO=123 -DARDUINO=10604 -DF_CPU=96000000 -DARDUINO_ARCH_AVR -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3 -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Bounce -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\ST7565 -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\flash_spi -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Encoder -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Metro -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD\utility C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD\card_t3.cpp -o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\SD\card_t3.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-g++ -c -O -g -Wall -ffunction-sections -fdata-sections -MMD -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -D__MK20DX256__ -DTEENSYDUINO=123 -DARDUINO=10604 -DF_CPU=96000000 -DARDUINO_ARCH_AVR -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3 -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Bounce -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\ST7565 -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\flash_spi -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Encoder -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Metro -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD\utility C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD\dir_t3.cpp -o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\SD\dir_t3.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-g++ -c -O -g -Wall -ffunction-sections -fdata-sections -MMD -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -D__MK20DX256__ -DTEENSYDUINO=123 -DARDUINO=10604 -DF_CPU=96000000 -DARDUINO_ARCH_AVR -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3 -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Bounce -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\ST7565 -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\flash_spi -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Encoder -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Metro -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD\utility C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD\fat_t3.cpp -o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\SD\fat_t3.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-g++ -c -O -g -Wall -ffunction-sections -fdata-sections -MMD -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -D__MK20DX256__ -DTEENSYDUINO=123 -DARDUINO=10604 -DF_CPU=96000000 -DARDUINO_ARCH_AVR -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3 -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Bounce -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\ST7565 -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\flash_spi -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Encoder -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Metro -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD\utility C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD\File.cpp -o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\SD\File.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-g++ -c -O -g -Wall -ffunction-sections -fdata-sections -MMD -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -D__MK20DX256__ -DTEENSYDUINO=123 -DARDUINO=10604 -DF_CPU=96000000 -DARDUINO_ARCH_AVR -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3 -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Bounce -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\ST7565 -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\flash_spi -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Encoder -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Metro -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD\utility C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD\file_t3.cpp -o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\SD\file_t3.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-g++ -c -O -g -Wall -ffunction-sections -fdata-sections -MMD -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -D__MK20DX256__ -DTEENSYDUINO=123 -DARDUINO=10604 -DF_CPU=96000000 -DARDUINO_ARCH_AVR -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3 -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Bounce -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\ST7565 -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\flash_spi -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Encoder -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Metro -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD\utility C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD\init_t3.cpp -o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\SD\init_t3.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-g++ -c -O -g -Wall -ffunction-sections -fdata-sections -MMD -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -D__MK20DX256__ -DTEENSYDUINO=123 -DARDUINO=10604 -DF_CPU=96000000 -DARDUINO_ARCH_AVR -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3 -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Bounce -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\ST7565 -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\flash_spi -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Encoder -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Metro -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD\utility C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD\SD.cpp -o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\SD\SD.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-g++ -c -O -g -Wall -ffunction-sections -fdata-sections -MMD -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -D__MK20DX256__ -DTEENSYDUINO=123 -DARDUINO=10604 -DF_CPU=96000000 -DARDUINO_ARCH_AVR -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3 -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Bounce -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\ST7565 -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\flash_spi -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Encoder -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Metro -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD\utility C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD\utility\Sd2Card.cpp -o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\SD\utility\Sd2Card.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-g++ -c -O -g -Wall -ffunction-sections -fdata-sections -MMD -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -D__MK20DX256__ -DTEENSYDUINO=123 -DARDUINO=10604 -DF_CPU=96000000 -DARDUINO_ARCH_AVR -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3 -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Bounce -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\ST7565 -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\flash_spi -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Encoder -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Metro -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD\utility C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD\utility\SdFile.cpp -o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\SD\utility\SdFile.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-g++ -c -O -g -Wall -ffunction-sections -fdata-sections -MMD -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -D__MK20DX256__ -DTEENSYDUINO=123 -DARDUINO=10604 -DF_CPU=96000000 -DARDUINO_ARCH_AVR -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3 -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Bounce -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\ST7565 -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\flash_spi -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Encoder -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Metro -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD\utility C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD\utility\SdVolume.cpp -o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\SD\utility\SdVolume.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-g++ -c -O -g -Wall -ffunction-sections -fdata-sections -MMD -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -D__MK20DX256__ -DTEENSYDUINO=123 -DARDUINO=10604 -DF_CPU=96000000 -DARDUINO_ARCH_AVR -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3 -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Bounce -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\ST7565 -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\flash_spi -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Encoder -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Metro -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Bounce\utility C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Bounce\Bounce.cpp -o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\Bounce\Bounce.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-gcc -c -O -g -Wall -ffunction-sections -fdata-sections -MMD -nostdlib -mthumb -mcpu=cortex-m4 -D__MK20DX256__ -DTEENSYDUINO=123 -DARDUINO=10604 -DF_CPU=96000000 -DARDUINO_ARCH_AVR -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3 -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Bounce -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\ST7565 -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\flash_spi -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Encoder -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Metro -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\ST7565\utility C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\ST7565\glcdfont.c -o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\ST7565\glcdfont.c.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-g++ -c -O -g -Wall -ffunction-sections -fdata-sections -MMD -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -D__MK20DX256__ -DTEENSYDUINO=123 -DARDUINO=10604 -DF_CPU=96000000 -DARDUINO_ARCH_AVR -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3 -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Bounce -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\ST7565 -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\flash_spi -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Encoder -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Metro -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\ST7565\utility C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\ST7565\ST7565.cpp -o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\ST7565\ST7565.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-g++ -c -O -g -Wall -ffunction-sections -fdata-sections -MMD -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -D__MK20DX256__ -DTEENSYDUINO=123 -DARDUINO=10604 -DF_CPU=96000000 -DARDUINO_ARCH_AVR -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3 -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Bounce -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\ST7565 -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\flash_spi -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Encoder -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Metro -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\flash_spi\utility C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\flash_spi\flash_spi.cpp -o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\flash_spi\flash_spi.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-g++ -c -O -g -Wall -ffunction-sections -fdata-sections -MMD -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -D__MK20DX256__ -DTEENSYDUINO=123 -DARDUINO=10604 -DF_CPU=96000000 -DARDUINO_ARCH_AVR -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3 -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Bounce -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\ST7565 -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\flash_spi -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Encoder -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Metro -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Encoder\utility C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Encoder\Encoder.cpp -o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\Encoder\Encoder.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-g++ -c -O -g -Wall -ffunction-sections -fdata-sections -MMD -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -D__MK20DX256__ -DTEENSYDUINO=123 -DARDUINO=10604 -DF_CPU=96000000 -DARDUINO_ARCH_AVR -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3 -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Bounce -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\ST7565 -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\flash_spi -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Encoder -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Metro -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Metro\utility C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Metro\Metro.cpp -o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\Metro\Metro.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-gcc -c -O -g -Wall -ffunction-sections -fdata-sections -MMD -nostdlib -x assembler-with-cpp -mthumb -mcpu=cortex-m4 -D__MK20DX256__ -DTEENSYDUINO=123 -DARDUINO=10604 -DF_CPU=96000000 -DARDUINO_ARCH_AVR -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3 C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\memcpy-armv7m.S -o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\memcpy-armv7m.S.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-gcc -c -O -g -Wall -ffunction-sections -fdata-sections -MMD -nostdlib -mthumb -mcpu=cortex-m4 -D__MK20DX256__ -DTEENSYDUINO=123 -DARDUINO=10604 -DF_CPU=96000000 -DARDUINO_ARCH_AVR -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3 C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\analog.c -o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\analog.c.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-gcc -c -O -g -Wall -ffunction-sections -fdata-sections -MMD -nostdlib -mthumb -mcpu=cortex-m4 -D__MK20DX256__ -DTEENSYDUINO=123 -DARDUINO=10604 -DF_CPU=96000000 -DARDUINO_ARCH_AVR -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3 C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\eeprom.c -o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\eeprom.c.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-gcc -c -O -g -Wall -ffunction-sections -fdata-sections -MMD -nostdlib -mthumb -mcpu=cortex-m4 -D__MK20DX256__ -DTEENSYDUINO=123 -DARDUINO=10604 -DF_CPU=96000000 -DARDUINO_ARCH_AVR -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3 C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\keylayouts.c -o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\keylayouts.c.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-gcc -c -O -g -Wall -ffunction-sections -fdata-sections -MMD -nostdlib -mthumb -mcpu=cortex-m4 -D__MK20DX256__ -DTEENSYDUINO=123 -DARDUINO=10604 -DF_CPU=96000000 -DARDUINO_ARCH_AVR -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3 C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\math_helper.c -o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\math_helper.c.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-gcc -c -O -g -Wall -ffunction-sections -fdata-sections -MMD -nostdlib -mthumb -mcpu=cortex-m4 -D__MK20DX256__ -DTEENSYDUINO=123 -DARDUINO=10604 -DF_CPU=96000000 -DARDUINO_ARCH_AVR -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3 C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\mk20dx128.c -o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\mk20dx128.c.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-gcc -c -O -g -Wall -ffunction-sections -fdata-sections -MMD -nostdlib -mthumb -mcpu=cortex-m4 -D__MK20DX256__ -DTEENSYDUINO=123 -DARDUINO=10604 -DF_CPU=96000000 -DARDUINO_ARCH_AVR -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3 C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\nonstd.c -o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\nonstd.c.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-gcc -c -O -g -Wall -ffunction-sections -fdata-sections -MMD -nostdlib -mthumb -mcpu=cortex-m4 -D__MK20DX256__ -DTEENSYDUINO=123 -DARDUINO=10604 -DF_CPU=96000000 -DARDUINO_ARCH_AVR -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3 C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\pins_teensy.c -o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\pins_teensy.c.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-gcc -c -O -g -Wall -ffunction-sections -fdata-sections -MMD -nostdlib -mthumb -mcpu=cortex-m4 -D__MK20DX256__ -DTEENSYDUINO=123 -DARDUINO=10604 -DF_CPU=96000000 -DARDUINO_ARCH_AVR -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3 C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\serial1.c -o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\serial1.c.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-gcc -c -O -g -Wall -ffunction-sections -fdata-sections -MMD -nostdlib -mthumb -mcpu=cortex-m4 -D__MK20DX256__ -DTEENSYDUINO=123 -DARDUINO=10604 -DF_CPU=96000000 -DARDUINO_ARCH_AVR -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3 C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\serial2.c -o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\serial2.c.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-gcc -c -O -g -Wall -ffunction-sections -fdata-sections -MMD -nostdlib -mthumb -mcpu=cortex-m4 -D__MK20DX256__ -DTEENSYDUINO=123 -DARDUINO=10604 -DF_CPU=96000000 -DARDUINO_ARCH_AVR -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3 C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\serial3.c -o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\serial3.c.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-gcc -c -O -g -Wall -ffunction-sections -fdata-sections -MMD -nostdlib -mthumb -mcpu=cortex-m4 -D__MK20DX256__ -DTEENSYDUINO=123 -DARDUINO=10604 -DF_CPU=96000000 -DARDUINO_ARCH_AVR -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3 C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\ser_print.c -o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\ser_print.c.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-gcc -c -O -g -Wall -ffunction-sections -fdata-sections -MMD -nostdlib -mthumb -mcpu=cortex-m4 -D__MK20DX256__ -DTEENSYDUINO=123 -DARDUINO=10604 -DF_CPU=96000000 -DARDUINO_ARCH_AVR -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3 C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\touch.c -o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\touch.c.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-gcc -c -O -g -Wall -ffunction-sections -fdata-sections -MMD -nostdlib -mthumb -mcpu=cortex-m4 -D__MK20DX256__ -DTEENSYDUINO=123 -DARDUINO=10604 -DF_CPU=96000000 -DARDUINO_ARCH_AVR -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3 C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\usb_desc.c -o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\usb_desc.c.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-gcc -c -O -g -Wall -ffunction-sections -fdata-sections -MMD -nostdlib -mthumb -mcpu=cortex-m4 -D__MK20DX256__ -DTEENSYDUINO=123 -DARDUINO=10604 -DF_CPU=96000000 -DARDUINO_ARCH_AVR -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3 C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\usb_dev.c -o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\usb_dev.c.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-gcc -c -O -g -Wall -ffunction-sections -fdata-sections -MMD -nostdlib -mthumb -mcpu=cortex-m4 -D__MK20DX256__ -DTEENSYDUINO=123 -DARDUINO=10604 -DF_CPU=96000000 -DARDUINO_ARCH_AVR -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3 C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\usb_joystick.c -o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\usb_joystick.c.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-gcc -c -O -g -Wall -ffunction-sections -fdata-sections -MMD -nostdlib -mthumb -mcpu=cortex-m4 -D__MK20DX256__ -DTEENSYDUINO=123 -DARDUINO=10604 -DF_CPU=96000000 -DARDUINO_ARCH_AVR -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3 C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\usb_keyboard.c -o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\usb_keyboard.c.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-gcc -c -O -g -Wall -ffunction-sections -fdata-sections -MMD -nostdlib -mthumb -mcpu=cortex-m4 -D__MK20DX256__ -DTEENSYDUINO=123 -DARDUINO=10604 -DF_CPU=96000000 -DARDUINO_ARCH_AVR -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3 C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\usb_mem.c -o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\usb_mem.c.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-gcc -c -O -g -Wall -ffunction-sections -fdata-sections -MMD -nostdlib -mthumb -mcpu=cortex-m4 -D__MK20DX256__ -DTEENSYDUINO=123 -DARDUINO=10604 -DF_CPU=96000000 -DARDUINO_ARCH_AVR -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3 C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\usb_midi.c -o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\usb_midi.c.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-gcc -c -O -g -Wall -ffunction-sections -fdata-sections -MMD -nostdlib -mthumb -mcpu=cortex-m4 -D__MK20DX256__ -DTEENSYDUINO=123 -DARDUINO=10604 -DF_CPU=96000000 -DARDUINO_ARCH_AVR -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3 C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\usb_mouse.c -o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\usb_mouse.c.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-gcc -c -O -g -Wall -ffunction-sections -fdata-sections -MMD -nostdlib -mthumb -mcpu=cortex-m4 -D__MK20DX256__ -DTEENSYDUINO=123 -DARDUINO=10604 -DF_CPU=96000000 -DARDUINO_ARCH_AVR -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3 C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\usb_rawhid.c -o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\usb_rawhid.c.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-gcc -c -O -g -Wall -ffunction-sections -fdata-sections -MMD -nostdlib -mthumb -mcpu=cortex-m4 -D__MK20DX256__ -DTEENSYDUINO=123 -DARDUINO=10604 -DF_CPU=96000000 -DARDUINO_ARCH_AVR -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3 C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\usb_seremu.c -o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\usb_seremu.c.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-gcc -c -O -g -Wall -ffunction-sections -fdata-sections -MMD -nostdlib -mthumb -mcpu=cortex-m4 -D__MK20DX256__ -DTEENSYDUINO=123 -DARDUINO=10604 -DF_CPU=96000000 -DARDUINO_ARCH_AVR -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3 C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\usb_serial.c -o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\usb_serial.c.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-g++ -c -O -g -Wall -ffunction-sections -fdata-sections -MMD -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -D__MK20DX256__ -DTEENSYDUINO=123 -DARDUINO=10604 -DF_CPU=96000000 -DARDUINO_ARCH_AVR -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3 C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\AudioStream.cpp -o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\AudioStream.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-g++ -c -O -g -Wall -ffunction-sections -fdata-sections -MMD -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -D__MK20DX256__ -DTEENSYDUINO=123 -DARDUINO=10604 -DF_CPU=96000000 -DARDUINO_ARCH_AVR -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3 C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\avr_emulation.cpp -o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\avr_emulation.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-g++ -c -O -g -Wall -ffunction-sections -fdata-sections -MMD -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -D__MK20DX256__ -DTEENSYDUINO=123 -DARDUINO=10604 -DF_CPU=96000000 -DARDUINO_ARCH_AVR -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3 C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\DMAChannel.cpp -o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\DMAChannel.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-g++ -c -O -g -Wall -ffunction-sections -fdata-sections -MMD -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -D__MK20DX256__ -DTEENSYDUINO=123 -DARDUINO=10604 -DF_CPU=96000000 -DARDUINO_ARCH_AVR -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3 C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\HardwareSerial1.cpp -o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\HardwareSerial1.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-g++ -c -O -g -Wall -ffunction-sections -fdata-sections -MMD -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -D__MK20DX256__ -DTEENSYDUINO=123 -DARDUINO=10604 -DF_CPU=96000000 -DARDUINO_ARCH_AVR -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3 C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\HardwareSerial2.cpp -o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\HardwareSerial2.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-g++ -c -O -g -Wall -ffunction-sections -fdata-sections -MMD -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -D__MK20DX256__ -DTEENSYDUINO=123 -DARDUINO=10604 -DF_CPU=96000000 -DARDUINO_ARCH_AVR -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3 C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\HardwareSerial3.cpp -o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\HardwareSerial3.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-g++ -c -O -g -Wall -ffunction-sections -fdata-sections -MMD -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -D__MK20DX256__ -DTEENSYDUINO=123 -DARDUINO=10604 -DF_CPU=96000000 -DARDUINO_ARCH_AVR -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3 C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\IntervalTimer.cpp -o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\IntervalTimer.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-g++ -c -O -g -Wall -ffunction-sections -fdata-sections -MMD -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -D__MK20DX256__ -DTEENSYDUINO=123 -DARDUINO=10604 -DF_CPU=96000000 -DARDUINO_ARCH_AVR -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3 C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\IPAddress.cpp -o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\IPAddress.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-g++ -c -O -g -Wall -ffunction-sections -fdata-sections -MMD -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -D__MK20DX256__ -DTEENSYDUINO=123 -DARDUINO=10604 -DF_CPU=96000000 -DARDUINO_ARCH_AVR -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3 C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\main.cpp -o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\main.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-g++ -c -O -g -Wall -ffunction-sections -fdata-sections -MMD -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -D__MK20DX256__ -DTEENSYDUINO=123 -DARDUINO=10604 -DF_CPU=96000000 -DARDUINO_ARCH_AVR -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3 C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\new.cpp -o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\new.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-g++ -c -O -g -Wall -ffunction-sections -fdata-sections -MMD -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -D__MK20DX256__ -DTEENSYDUINO=123 -DARDUINO=10604 -DF_CPU=96000000 -DARDUINO_ARCH_AVR -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3 C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\Print.cpp -o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\Print.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-g++ -c -O -g -Wall -ffunction-sections -fdata-sections -MMD -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -D__MK20DX256__ -DTEENSYDUINO=123 -DARDUINO=10604 -DF_CPU=96000000 -DARDUINO_ARCH_AVR -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3 C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\Stream.cpp -o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\Stream.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-g++ -c -O -g -Wall -ffunction-sections -fdata-sections -MMD -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -D__MK20DX256__ -DTEENSYDUINO=123 -DARDUINO=10604 -DF_CPU=96000000 -DARDUINO_ARCH_AVR -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3 C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\Tone.cpp -o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\Tone.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-g++ -c -O -g -Wall -ffunction-sections -fdata-sections -MMD -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -D__MK20DX256__ -DTEENSYDUINO=123 -DARDUINO=10604 -DF_CPU=96000000 -DARDUINO_ARCH_AVR -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3 C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\usb_flightsim.cpp -o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\usb_flightsim.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-g++ -c -O -g -Wall -ffunction-sections -fdata-sections -MMD -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -D__MK20DX256__ -DTEENSYDUINO=123 -DARDUINO=10604 -DF_CPU=96000000 -DARDUINO_ARCH_AVR -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3 C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\usb_inst.cpp -o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\usb_inst.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-g++ -c -O -g -Wall -ffunction-sections -fdata-sections -MMD -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -D__MK20DX256__ -DTEENSYDUINO=123 -DARDUINO=10604 -DF_CPU=96000000 -DARDUINO_ARCH_AVR -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3 C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\WMath.cpp -o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\WMath.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-g++ -c -O -g -Wall -ffunction-sections -fdata-sections -MMD -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -D__MK20DX256__ -DTEENSYDUINO=123 -DARDUINO=10604 -DF_CPU=96000000 -DARDUINO_ARCH_AVR -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3 C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\WString.cpp -o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\WString.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-g++ -c -O -g -Wall -ffunction-sections -fdata-sections -MMD -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -D__MK20DX256__ -DTEENSYDUINO=123 -DARDUINO=10604 -DF_CPU=96000000 -DARDUINO_ARCH_AVR -DUSB_SERIAL -DLAYOUT_US_ENGLISH -IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3 C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3\yield.cpp -o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\yield.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-ar rcs C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp/core.a C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\memcpy-armv7m.S.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-ar rcs C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp/core.a C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\analog.c.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-ar rcs C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp/core.a C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\eeprom.c.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-ar rcs C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp/core.a C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\keylayouts.c.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-ar rcs C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp/core.a C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\math_helper.c.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-ar rcs C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp/core.a C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\mk20dx128.c.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-ar rcs C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp/core.a C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\nonstd.c.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-ar rcs C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp/core.a C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\pins_teensy.c.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-ar rcs C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp/core.a C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\serial1.c.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-ar rcs C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp/core.a C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\serial2.c.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-ar rcs C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp/core.a C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\serial3.c.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-ar rcs C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp/core.a C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\ser_print.c.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-ar rcs C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp/core.a C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\touch.c.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-ar rcs C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp/core.a C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\usb_desc.c.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-ar rcs C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp/core.a C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\usb_dev.c.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-ar rcs C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp/core.a C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\usb_joystick.c.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-ar rcs C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp/core.a C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\usb_keyboard.c.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-ar rcs C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp/core.a C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\usb_mem.c.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-ar rcs C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp/core.a C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\usb_midi.c.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-ar rcs C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp/core.a C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\usb_mouse.c.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-ar rcs C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp/core.a C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\usb_rawhid.c.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-ar rcs C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp/core.a C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\usb_seremu.c.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-ar rcs C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp/core.a C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\usb_serial.c.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-ar rcs C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp/core.a C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\AudioStream.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-ar rcs C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp/core.a C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\avr_emulation.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-ar rcs C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp/core.a C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\DMAChannel.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-ar rcs C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp/core.a C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\HardwareSerial1.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-ar rcs C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp/core.a C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\HardwareSerial2.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-ar rcs C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp/core.a C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\HardwareSerial3.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-ar rcs C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp/core.a C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\IntervalTimer.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-ar rcs C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp/core.a C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\IPAddress.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-ar rcs C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp/core.a C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\main.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-ar rcs C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp/core.a C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\new.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-ar rcs C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp/core.a C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\Print.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-ar rcs C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp/core.a C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\Stream.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-ar rcs C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp/core.a C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\Tone.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-ar rcs C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp/core.a C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\usb_flightsim.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-ar rcs C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp/core.a C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\usb_inst.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-ar rcs C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp/core.a C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\WMath.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-ar rcs C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp/core.a C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\WString.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-ar rcs C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp/core.a C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\yield.cpp.o
C:\Program Files (x86)\Arduino/hardware/tools/arm/bin/arm-none-eabi-gcc -O -Wl,--gc-sections,--relax,--defsym=__rtc_localtime=1434492459 -TC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3/mk20dx256.ld -mthumb -mcpu=cortex-m4 -o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp/beatsbyteensy.cpp.elf C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\AudioSampleMainclik.cpp.o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\AudioSampleMinrclik.cpp.o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\beatsbyteensy.cpp.o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\flash_spi.cpp.o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\play_serialflash.cpp.o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\PS2MiniPac.cpp.o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\Audio\data_ulaw.c.o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\Audio\data_waveforms.c.o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\Audio\data_windows.c.o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\Audio\analyze_fft1024.cpp.o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\Audio\analyze_fft256.cpp.o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\Audio\analyze_peak.cpp.o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\Audio\analyze_print.cpp.o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\Audio\analyze_tonedetect.cpp.o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\Audio\control_sgtl5000.cpp.o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\Audio\control_wm8731.cpp.o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\Audio\effect_bitcrusher.cpp.o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\Audio\effect_chorus.cpp.o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\Audio\effect_delay.cpp.o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\Audio\effect_envelope.cpp.o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\Audio\effect_fade.cpp.o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\Audio\effect_flange.cpp.o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\Audio\effect_multiply.cpp.o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\Audio\filter_biquad.cpp.o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\Audio\filter_fir.cpp.o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\Audio\filter_variable.cpp.o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\Audio\flash_spi.cpp.o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\Audio\input_adc.cpp.o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\Audio\input_i2s.cpp.o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\Audio\mixer.cpp.o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\Audio\output_dac.cpp.o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\Audio\output_i2s.cpp.o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\Audio\output_pwm.cpp.o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\Audio\play_memory.cpp.o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\Audio\play_queue.cpp.o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\Audio\play_sd_raw.cpp.o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\Audio\play_sd_wav.cpp.o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\Audio\record_queue.cpp.o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\Audio\spi_interrupt.cpp.o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\Audio\synth_dc.cpp.o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\Audio\synth_pinknoise.cpp.o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\Audio\synth_sine.cpp.o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\Audio\synth_tonesweep.cpp.o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\Audio\synth_waveform.cpp.o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\Audio\synth_whitenoise.cpp.o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\Audio\utility\sqrt_integer.c.o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\Wire\Wire.cpp.o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\Wire\utility\twi.c.o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\SPI\SPI.cpp.o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\SD\cache_t3.cpp.o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\SD\card_t3.cpp.o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\SD\dir_t3.cpp.o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\SD\fat_t3.cpp.o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\SD\File.cpp.o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\SD\file_t3.cpp.o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\SD\init_t3.cpp.o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\SD\SD.cpp.o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\SD\utility\Sd2Card.cpp.o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\SD\utility\SdFile.cpp.o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\SD\utility\SdVolume.cpp.o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\Bounce\Bounce.cpp.o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\ST7565\glcdfont.c.o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\ST7565\ST7565.cpp.o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\flash_spi\flash_spi.cpp.o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\Encoder\Encoder.cpp.o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp\Metro\Metro.cpp.o C:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp/core.a -LC:\Users\JONPAY~1\AppData\Local\Temp\build2647240271110547322.tmp -larm_cortexM4l_math -lm
I don't see that there is all that much point but all my code is on github here:
https://github.com/Pensive/Beats-by-Teensy
I think my install is a bit skewiff, but Teensy examples compile just fine and teensyduino pops up ready to download.
I also have Visualmicro and Visual Studio Community 2013 installed (And apparently working, however again it doesn't compile, this could be for a multitude of reasons, so I reverted back to Arduino IDE to check the code).
So my code all parses. It's all been tried and tested in a previous version. and it doesn't seem to be my code at all (on the surface).
Any ideas, short of wipe & reinstall arduino?
