funfrancis
Hi
I have stacked a Teensy 3.1 with its Audio adapter and have in turn connected a Waterproof temperature sensor
The purpose is to run the temperature sensor and FFT Analsysis.....the program for which I have successfully coded and executed successfully..such that the serial monitor combines both the TEMP and FFT ANALYSIS reading in one screen
I need to log the data of the Temperature and FFT analysis individually or together in a single text file
What pin number should I select for configuring the SD card slot in the Audio board to log the data
Any sample code will be helpful if you could share it with me
