irun4fundotca
Teensy 3.1 using SSR Relays For Reflow Oven
I developed a SMD Reflow Controller Shield for a teensy using A6, A7 & A8 for SSR's using transistor switches to control the 5v for the SSR's
I was intending to use a relay8 demo to test the shield, however the teensy 3.1 ARM mcu is not supported by its library
is there a library I can use for this?
Relay8 Demo Code:
Error:
Thanks for any advice, Charles
Relay8 Demo Code:
// relay8_Demo
// Copyright (C)2015 Rinky-Dink Electronics, Henning Karlsen. All right reserved
// web: http://www.RinkyDinkElectronics.com/
// A quick demo of most of the library functions.
// Include our library
#include <relay8.h>
// Declare what pins our relays are connected to.
// relay8 supports from 1 to 8 relays.
//relay8 relay(2, 3, 4, 5, 6, 7, 8, 9);
relay8 relay(6, 7);
// Nothing special is needed here
// Switch the first relay on and off a couple of times
for (int t=0; t<3; t++)
relay.on(1);
relay.off(1);
// Switch the last relay on and off a couple of times
relay.on(relay.numberOfRelays());
relay.off(relay.numberOfRelays());
// Switch all relays on and off a couple of times
relay.allOn();
relay.allOff();
// Cycle through all relays slowly from the first to the last
// then a little faster back down again
relay.cycleUp();
relay.cycleDown(100);
// Switch on all relays in sequence then switch then all off
// again a little faster
relay.chaseUpOn(500);
relay.chaseUpOff();
// again a little faster. This time in the opposite direction
relay.chaseDownOn();
relay.chaseDownOff(100);
Error:
Arduino: 1.6.6 Hourly Build 2015/06/19 06:42 (Windows 7), Board:
"Teensy 3.1, Serial, 96 MHz optimized (overclock), US English"
In file included from relay8_Demo.ino:9:0:
C:\Arduino-1.6.5\libraries\relay8/relay8.h:41:6: error: #error
"Unsupported ARM MCU!"
#error "Unsupported ARM MCU!"
Error compiling
