Results 1 to 12 of 12
Thread: I2c wire emulation-changing the I2C bus speed
    Hi all,
    I have a complex split I2C bus with 20 devices on it.
    The communication with all devices works ok with with Teensy 3.1 at 100KHz, emulating the wire library.
    I wasn't able to make it run with newest i2c_t3 library because the leak of examples I found, perhaps I didn't set everything right.
    I want to increase the I2C bus speed to 400KHz or 1MHz, using the wire library.
    Since I do not understand the emulation concept even I've looked to the twi and wire files, do I have to modify the twi.h file (arduino1.6.5r2/hardware/tensy/avr/libraries/wire/utility/twi.h) ?
    #ifndef TWI_FREQ
    #define TWI_FREQ 100000L // 400000L for 400KHz, 1000000L for 1MHz?
    However, the TWBR emulation code from wire.h looks like 400KHz is maximum accepted while the "TwoWire::setClock(uint32_t frequency)" routine from wire.ccp shows that 1MHz I2C is possible.
    How do I set the I2C wire for 400KHz or 1MHz speed in a proper way, without altering the library ?
    thx,
    Vasile
    1,408
    The likely problem is bus capacitance and the length of the wires involved. Longer wires either require additional circuitry or lower clock speeds. How long are the connections?
    Quote Originally Posted by Constantin View Post
    "The communication with all devices works ok with with Teensy 3.1 at 100KHz, emulating the wire library"
    I do not have any hardware problem, I don't know to setup the wire library for 400KHz or 1MHz I2C bus frequency.
    thx,
    966
    Please post schematics and links to device specifications. As constantin has already explained the ( electrical) limitation to bus speed is the overall bus capacitance that cannot exceed 400pF.
    The i2c_t3 library is really a drop in replacement for the Wire library. You just need to change the includes from wire.h to i2c_t3.h
    The thread for the library explains how to change the bus frequency and many other things:
    https://forum.pjrc.com/threads/21680...ghlight=i2c_t3
    Without additional hardware you'll not get to raise the bus frequency above 400MHz. Devices for over 400MHz are FM+ devices (Fast Mode +) and you'll need a bus buffer at least for the Teensy. The FM+ specification deals with the negative effects of the bus capacitance by raising the max current that can be sunk by I2C pins from 3mA to 30MA and allows a max bus capacitance of 4000pF.
    I use the PCA9600 from NXP in my LED lighting systems ( trippylighting.com) with 11 I2C devices on the bus over 14ft of CAT5 Ethernet cable at 1MHz. Works like a charm.
    Please also explain how you've split the bus as that also usually requires additional devices such as as said bus buffers.
    Quote Originally Posted by Headroom View Post
    I read this post. Simple replacement of the includes does not work for me.
    I don't understand which is the 400MHz bus you are talking about, this is impossible on any I2C bus or perhaps you are talking about something else. I do not have any hardware problems on the I2c bus as I already said.
    In this moment I want to use the wire library and not the i2c_t3. Can anyone tell me how to set the wire lib for 1MHz I2C?
    Assuming the datasheet of MK20DX256, Teensy does not need any I2C buffer for 400KHz or 1MHz I2C bus as long the bus met the specification. I have a short one, timings looks quite ok on my Tek MSO4000.
    966
    Sorry, I meant 400KHz of course
    Of course you don't have any problems as you still running at 100KHz.
    Maybe you won't have any at 400KHz either or even at 1MHz
    I can't help with the wire library as I use the i2c_t3 library where setting the bus frequency is easy.
    If you don't get responses that help you with this, perhaps post your code so we can figure out why the i2c_t3 library is not working for you.
    966
    Found it in Wire.cpp
    In order to use 400KHz or 1MHz you need to edit Wire.cpp. With Arduino 1.6.x the Teensyduino libraries are not in .../Java/Libraries/Wire/ but in .../Java/hardware/teensy/avr/libraries/Wire
    Then in Wire.cpp comment/un-comment the obvious lines
    void TwoWire::setClock(uint32_t frequency)
    #if F_BUS == 60000000
    	if (frequency < 400000) {
    		I2C0_F = 0x2C;	// 104 kHz
    	} else if (frequency < 1000000) {
    		I2C0_F = 0x1C; // 416 kHz
    		I2C0_F = 0x12; // 938 kHz
    	I2C0_FLT = 4;
    #elif F_BUS == 56000000
    		I2C0_F = 0x2B;	// 109 kHz
    		I2C0_F = 0x1C; // 389 kHz
    		I2C0_F = 0x0E; // 1 MHz
    	I2C0_FLT = 4;
    #elif F_BUS == 48000000
    		I2C0_F = 0x27;	// 100 kHz
    		I2C0_F = 0x1A; // 400 kHz
    		I2C0_F = 0x0D; // 1 MHz
    	I2C0_FLT = 4;
    #elif F_BUS == 40000000
    		I2C0_F = 0x29;	// 104 kHz
    		I2C0_F = 0x19; // 416 kHz
    		I2C0_F = 0x0B; // 1 MHz
    	I2C0_FLT = 3;
    #elif F_BUS == 36000000
    		I2C0_F = 0x28;	// 113 kHz
    		I2C0_F = 0x19; // 375 kHz
    		I2C0_F = 0x0A; // 1 MHz
    	I2C0_FLT = 3;
    #elif F_BUS == 24000000
    		I2C0_F = 0x1F; // 100 kHz
    		I2C0_F = 0x12; // 375 kHz
    		I2C0_F = 0x02; // 1 MHz
    	I2C0_FLT = 2;
    #elif F_BUS == 16000000
    		I2C0_F = 0x20; // 100 kHz
    		I2C0_F = 0x07; // 400 kHz
    		I2C0_F = 0x00; // 800 MHz
    	I2C0_FLT = 1;
    #elif F_BUS == 8000000
    		I2C0_F = 0x14; // 100 kHz
    		I2C0_F = 0x00; // 400 kHz
    	I2C0_FLT = 1;
    		I2C0_F = 0x07; // 100 kHz
    		I2C0_F = 0x00; // 200 kHz
    	I2C0_FLT = 1;
    #elif F_BUS == 2000000
    	I2C0_F = 0x00; // 100 kHz
    	I2C0_FLT = 1;
    #else
    #error "F_BUS must be 60, 56, 48, 40, 36, 24, 16, 8, 4 or 2 MHz"
    Let us know how that works.
    Edit: no commenting / un-commenting needed.
    in Wire.cpp change
    setClock(100000);
    to your preferred I2C bus speed.
    Headroom (maybe you'll tell me your real name)
    this is the answer I wanted.
    setClock (400000); Teensy3.1 at 48MHz gives a real I2C clock of about 280KHz
    setClock (1000000); Teensy3.1 at 48MHz gives a real I2C clock of about 540KHz
    The F_BUS probably is computed when you set the board, however there is a difference when change directly
    the I2C0_F = 0x0D; // 1 MHz and I2C0_FLT = 4; for a 48MHz bus compared when you let the library to set it in the if-then else part.
    Sometimes, quite randomly, the I2C pins are not intialized. Please do not ask me if I have pull-ups on the I2C clk and sda.
    Boston, MA, USA
    1,107
    Do you have external pullup resistors for the I2C and if so, of what value?
    Quote Originally Posted by Nantonos View Post
    Yes I have, everything seems almost ok now, both with wire and with i2c_t3 library.
    The i2c_t3 does work for me only with internal pullups. The external pull-up is 1k5, the real I2C clock around 700KHz.
    I also have a 5KV I2C isolator (which I've designed) on the bus between the MK20 and the slaves....
    Not the pull-up was the problem for me, thanks for asking...
    20,544
    Quote Originally Posted by vsurducan View Post
    Those speeds might be bugs. The Wire.setClock() function is relatively new, so maybe some if it needs tuning?
    As a general rule, I only investigate bugs when a complete test program is posted. In this case, it ought to be fairly trivial. Still, a complete test program is essential, so I know I'm testing the exact same program you used. Sometime small, seemingly insignificant details turn out to matter.
    Any chance you could post the (hopefully small) program you used for testing these speeds?
    Hi Paul,
    I don't think are bugs, almost the same bus speed I see with i2c_t3 too, perhaps a little bit more accurate.
    I'll try to do a simple i2C clk speed measurement with a single i2c device, to be easier for testing, but I can't right now, I'm a little bit busy.
    However, the i2c_t3 library to be fully compatible with arduino wire, it seems the I2C mode should be set to I2C_OP_MODE_IMM and not I2C_OP_MODE_ISR as written in the github documentation:
    "Wire.setOpMode(opMode); - this configures operating mode of the I2C as either Immediate, ISR, or DMA. By default Arduino-style begin() calls will initialize to ISR mode. "
    thank you all for your support!
