/* ym2612 sound driver
rnx
Dual YM2612 hardware synthesizer Copyright 2013
For Teensy ++
code by
grybranix@netscape.net
From forum topic:
http://gendev.spritesmind.net/forum/viewtopic.php?t=1470&postdays=0&postorder=asc&start=0
#include <Encoder.h>
#include <MIDI.h>
#include <SoftwareSerial.h>
#include <LedControl.h>
#define disk1 0x51 //address of 32k eeprom chip
#define disk2 0x50 //address of 32k eeprom chip
#define INST_STRIDE 72 //size of instrument data in bytes
#define CH1 0 //magic constant for channel 1
#define CH2 1 //magic constant for channel 2
#define CH3 2 //magic constant for channel 3
#define CH4 4 //magic constant for channel 4
#define CH5 5 //magic constant for channel 5
#define CH6 6 //magic constant for channel 6
#define CH7 7 //magic constant for channel 7
#define CH8 8 //magic constant for channel 8
#define CH9 9 //magic constant for channel 9
#define CH10 11 //magic constant for channel 10
#define CH11 12 //magic constant for channel 11
#define CH12 13 //magic constant for channel 12
#define BANK1 0
#define BANK2 1
#define MODE_MONO 0
#define MODE_POLY 1
typedef struct
byte dt1;
byte mul;
byte tl;
byte rs;
byte ar;
byte ams;
byte d1r;
byte d2r;
byte d1l;
byte rr;
byte lfo;
Operator;
typedef struct
Operator op[4];
byte feedback; //AKA FL in OPM
byte algorithm; //AKA CON in OPM
Voice;
Voice voice[14];
const unsigned char CHANNEL[13] = {
0, CH1, CH2, CH3, CH4, CH5, CH6, CH7, CH8, CH9, CH10, CH11, CH12};
//typedef enum {false, true} bool;
const int LCDPin = 25; //LCD communication
const int backlight = 0; //LCD backlight
const int BUSPIN = 10; //8 data pins starting here
const int IRQPIN = 18; //timer interrupt pin
byte chctl = 0;
SoftwareSerial LCD = SoftwareSerial(0, LCDPin);
Encoder knob1(19, 20);
long knob1pos = 0;
/* Chip select. Active-low. When high, this makes the data pins
high-impedance, removing it from the bus and freeing the pins. */
const int CS2 = 45; //chip select ym2612 #1
const int CS = 40; //chip select ym2612 #2
const int AA1 = 41; //A1 bit, active high
const int AA0 = 42; //A0 bit, active high
const int RD = 43; //read bit, active low
const int WR = 44; //write bit, active low
const int SSP = 5;
const int RESET = 6; //reset bit, active low
volatile int TIMER1 = LOW;
elapsedMicros TIMER;
unsigned long DTIMER = 0;
unsigned char timerreg = 0;
LedControl matrix = LedControl(7, 8, 9, 2);
/* Primary frequency table, in fnums */
//C4 is setpitch(3, freq[1], ...)
//FIXME: calculate proper numbers by tuning with an oscope and using sethz().
const unsigned int freq[13] = {
617, 653, 692, 733, 777, 823, 872, 924, 979, 1037, 1099, 1164, 1232};
unsigned int KEYS[14] = {
0, 0, 0, 0xFFFD, 0, 0, 0, 0, 0, 0, 0xFFFC, 0, 0, 0};
unsigned int KEYFREQ[14] = {
0,0,0,0,0,0,0,0,0,0,0,0,0,0};
unsigned int KEYBLOCK[14] = {
unsigned int MODE = MODE_POLY;
/* Sets 8-bit bus to write mode. */
void output()
/*int i=BUSPIN;
for(i;i<(BUSPIN + 8);i++)
pinMode(i, OUTPUT);
DDRC = 0xFF;
/* Sets 8-bit bus to read mode */
void input()
int i=BUSPIN;
pinMode(i, INPUT);
/* Sets pin state on the 8-bit data bus. */
void writebus(unsigned char state)
output();
PORTC = state;
/* Reads pin state of the 8-bit data bus */
unsigned int readbus()
unsigned int state=0;
int i=BUSPIN;
input();
for(i;i<(i+8);i++)
if( digitalRead(i) == 1)
state = state ^ 1<<i;
return(state);
//* Selects a register "reg" in the YM2612 */
//FIXME: combine selectreg and selectreg2
void selectreg(unsigned char reg)
/*digitalWrite(CS, LOW); //40
digitalWrite(RD, HIGH); //43
digitalWrite(WR, HIGH); //44
digitalWrite(AA0, LOW); //42
digitalWrite(AA1, LOW); //41*/
PORTF = B11100000;
delayMicroseconds(2);
writebus(reg);
PORTF = B10100000;
PORTF = B11100000;
PORTF = B11100100;
/*digitalWrite(WR, LOW);
digitalWrite(CS, HIGH);*/
void selectreg2(unsigned char reg)
/* digitalWrite(CS, LOW);
digitalWrite(AA1, HIGH);*/
PORTF = B11101000;
delayMicroseconds(1);
writebus(reg);
PORTF = B10101000;
PORTF = B11101000;
PORTF = B11101100;
/* digitalWrite(WR, LOW);
//delayMicroseconds(10);
void selectreg3(unsigned char reg, unsigned int bank, unsigned int chip)
unsigned int chipselect = 0;
if ( chip == 1)
chipselect = CS;
chipselect = CS2;
digitalWrite(chipselect, LOW);
if (bank == BANK1)
else if (bank == BANK2)
writebus(reg);
digitalWrite(chipselect, HIGH);
/* Writes "state" to the currently selected register in bank 1. */
//FIXME: combine writereg and writereg2
void writereg(unsigned char state)
digitalWrite(AA0, HIGH);//42*/
PORTF = B11110000;
writebus(state);
PORTF = B10110000;
PORTF = B11110000;
PORTF = B11110100;
/* Writes "state" to the currently selected register in bank 2. */
void writereg2(unsigned char state)
digitalWrite(AA0, HIGH);*/
PORTF = B11111000;
writebus(state);
PORTF = B10111000;
PORTF = B11111000;
PORTF = B11111100;
void writereg3(unsigned char state, unsigned int bank, unsigned int chip)
if ( chip == 1)
chipselect = CS;
chipselect = CS2;
if (bank == BANK1)
writebus(state);
/* Writes "state" to the register "address" */
void reg(unsigned char address, unsigned char state, unsigned char chip)
selectreg3(address, BANK1, chip);
writereg3(state, BANK1, chip);
void reg2(unsigned char address, unsigned char state)
selectreg3(address, BANK2, 1);
writereg3(state, BANK2, 1);
void reg3(unsigned int address, unsigned int state, unsigned char channel)
unsigned char bank;
unsigned char chip;
chip = 1;
if (channel > CH6)
chip = 2;
if (channel <= CH3)
bank = BANK1;
else if (channel <= CH6)
bank = BANK2;
else if (channel <= CH9)
bank = BANK1;
else if (channel <= CH12)
bank = BANK2;
selectreg3(address, bank, chip);
writereg3(state, bank, chip);
/* Selects and loads an instrument from the EEPROM. */
void selectinst(unsigned int instrument, unsigned char channel)
unsigned int inst = instrument * INST_STRIDE;
unsigned char buf = 0;
unsigned char offset;
if (channel <= CH3)
offset = channel;
offset = channel - 4;
offset = channel - 7;
offset = channel -11;
reg3(0x28, 0x00 + channel, channel); //Mute channel before modifying it
buf = readEEPROM(disk1, inst + 36); //DT1 (3 bits)
voice[channel].op[0].dt1 = buf;
buf <<= 4;
voice[channel].op[0].mul = readEEPROM(disk1, inst + 35); //MUL (nibble)
buf += voice[channel].op[0].mul;
reg3(0x30 + offset, buf, channel); //Detune + Multiply Operator 1
buf = readEEPROM(disk1, inst + 47); //DT1
voice[channel].op[1].dt1 = buf;
buf <<= 4;
voice[channel].op[1].mul = readEEPROM(disk1, inst + 46); //MUL
buf += voice[channel].op[1].mul;
reg3(0x34 + offset, buf, channel); //Detune + Multiply Operator 2
buf = readEEPROM(disk1, inst + 58); //DT1
voice[channel].op[2].dt1 = buf;
buf <<= 4;
voice[channel].op[2].mul = readEEPROM(disk1, inst + 57); //MUL
buf += voice[channel].op[2].mul;
reg3(0x38 + offset, buf, channel); //Detune + Multiply Operator 3
buf = readEEPROM(disk1, inst + 69); //DT1
voice[channel].op[3].dt1 = buf;
buf <<= 4;
voice[channel].op[3].mul = readEEPROM(disk1, inst + 68); //MUL
buf += voice[channel].op[3].mul;
reg3(0x3C + offset, buf, channel); //Detune + Multiply Operator 4
buf = readEEPROM(disk1, inst + 33); //TL
voice[channel].op[0].tl = buf;
reg3(0x40 + offset, buf, channel); //Total Level Operator 1
buf = readEEPROM(disk1, inst + 44); //TL
voice[channel].op[1].tl = buf;
reg3(0x44 + offset, buf, channel); //Total Level Operator 2
buf = readEEPROM(disk1, inst + 55); //TL
voice[channel].op[2].tl = buf;
reg3(0x48 + offset, buf, channel); //Total Level Operator 3
buf = readEEPROM(disk1, inst + 66); //TL
voice[channel].op[3].tl = buf;
reg3(0x4C + offset, buf, channel); //Total Level Operator 4
buf = readEEPROM(disk1, inst + 34); //RS
voice[channel].op[0].rs = buf;
buf <<= 6;
voice[channel].op[0].ar = readEEPROM(disk1, inst + 28); //AR
buf += voice[channel].op[0].ar;
reg3(0x50 + offset, buf, channel); //Rate Scaling + Attack Rate Operator 1
buf = readEEPROM(disk1, inst + 45); //RS
voice[channel].op[1].rs = buf;
buf <<= 6;
voice[channel].op[1].ar = readEEPROM(disk1, inst + 39); //AR
buf += voice[channel].op[1].ar;
reg3(0x54 + offset, buf, channel); //Rate Scaling + Attack Rate Operator 2
buf = readEEPROM(disk1, inst + 56); //RS
voice[channel].op[2].rs = buf;
buf <<= 6;
voice[channel].op[2].ar = readEEPROM(disk1, inst + 50); //AR
buf += voice[channel].op[2].ar;
reg3(0x58 + offset, buf, channel); //Rate Scaling + Attack Rate Operator 3
buf = readEEPROM(disk1, inst + 67); //RS
voice[channel].op[3].rs = buf;
buf <<= 6;
voice[channel].op[3].ar = readEEPROM(disk1, inst + 61); //AR
buf += voice[channel].op[3].ar;
reg3(0x5C + offset, buf, channel); //Rate Scaling + Attack Rate Operator 4
buf = readEEPROM(disk1, inst + 38); //AMS-EN
voice[channel].op[0].ams = buf;
buf <<= 7;
voice[channel].op[0].d1r = readEEPROM(disk1, inst + 29); //D1R
buf += voice[channel].op[0].d1r;
reg3(0x60 + offset, buf, channel); //Decay rate + Amplitude Modulation, Operator 1
buf = readEEPROM(disk1, inst + 49); //AMS-EN
voice[channel].op[1].ams = buf;
buf <<= 7;
voice[channel].op[1].d1r = readEEPROM(disk1, inst + 40); //D1R
buf += voice[channel].op[1].d1r;
reg3(0x64 + offset, buf, channel); //Decay rate (keyon) Operator 2
buf = readEEPROM(disk1, inst + 60); //AMS-EN
voice[channel].op[2].ams = buf;
buf <<= 7;
voice[channel].op[2].d1r= readEEPROM(disk1, inst + 51); //D1R
buf += voice[channel].op[2].d1r;
reg3(0x68 + offset, buf, channel); //Decay rate (keyon) Operator 3
buf = readEEPROM(disk1, inst + 71); //AMS-EN
voice[channel].op[3].ams = buf;
buf <<= 7;
voice[channel].op[3].d1r = readEEPROM(disk1, inst + 62); //D1R
buf += voice[channel].op[3].d1r;
reg3(0x6C + offset, buf, channel); //Decay rate (keyon) Operator 4
buf = readEEPROM(disk1, inst + 30); //D2R (low nibble)
voice[channel].op[0].d2r = buf;
reg3(0x70 + offset, buf, channel); //Secondary decay (keyon) Operator 1
buf = readEEPROM(disk1, inst + 41); //D2R
voice[channel].op[1].d2r = buf;
reg3(0x74 + offset, buf, channel); //Secondary decay (keyon) Operator 2
buf = readEEPROM(disk1, inst + 52); //D2R
voice[channel].op[2].d2r = buf;
reg3(0x78 + offset, buf, channel); //Secondary decay (keyon) Operator 3
buf = readEEPROM(disk1, inst + 63); //D2R
voice[channel].op[3].d2r = buf;
reg3(0x7C + offset, buf, channel); //Secondary decay (keyon) Operator 4
buf = readEEPROM(disk1, inst + 32) << 4; //D1L (high nibble)
buf += readEEPROM(disk1, inst + 31); //RR (low nibble)
reg3(0x80 + offset, buf, channel); //Secondary amplitude + release rate Operator 1
buf = readEEPROM(disk1, inst + 43) << 4; //D1L (high nibble)
buf += readEEPROM(disk1, inst + 42); //RR (low nibble)
reg3(0x84 + offset, buf, channel); //Secondary amplitude/release rate Operator 2
buf = readEEPROM(disk1, inst + 54) << 4; //D1L (high nibble)
buf += readEEPROM(disk1, inst + 53); //RR (low nibble)
reg3(0x88 + offset, buf, channel); //Secondary amplitude/release rate Operator 3
buf = readEEPROM(disk1, inst + 65) << 4; //D1L (high nibble)
buf += readEEPROM(disk1, inst + 64); //RR (low nibble)
reg3(0x8C + offset, buf, channel); //Secondary amplitude/release rate Operator 4
buf = readEEPROM(disk1, inst + 22); //FL, feedback (3 bits)
voice[channel].feedback = buf;
buf <<= 3;
voice[channel].algorithm = readEEPROM(disk1, inst + 23); //CON, algorithm (3 bits)
buf += voice[channel].algorithm;
reg3(0xB0 + offset, buf, channel); //Feedback/algorithm select
reg3(0xB4 + offset, 0xC0, channel); //Both speakers on
reg3(0x28, channel, channel); //Key off
/* Selects and loads an instrument from channel 0. */
void selectvoice(unsigned char channel)
if (channel <= CH3)
offset = channel;
buf = voice[0].op[0].dt1; //DT1
buf <<= 4;
voice[channel].op[0].mul = voice[0].op[0].mul; //MUL
buf += voice[0].op[0].mul;
buf = voice[0].op[1].dt1; //DT1
buf <<= 4;
voice[channel].op[1].mul = voice[0].op[1].mul; //MUL
buf += voice[0].op[1].mul;
buf = voice[0].op[2].dt1; //DT1
buf <<= 4;
voice[channel].op[2].mul = voice[0].op[2].mul; //MUL
buf += voice[0].op[2].mul;
buf = voice[0].op[3].dt1; //DT1
buf <<= 4;
voice[channel].op[3].mul = voice[0].op[3].mul; //MUL
buf += voice[0].op[3].mul;
buf = voice[0].op[0].tl; //TL
buf = voice[0].op[1].tl; //TL
buf = voice[0].op[2].tl; //TL
buf = voice[0].op[3].tl; //TL
buf = voice[0].op[0].rs; //RS
buf <<= 6;
voice[channel].op[0].ar = voice[0].op[0].ar; //AR
buf = voice[0].op[1].rs; //RS
buf <<= 6;
voice[channel].op[1].ar = voice[0].op[1].ar; //AR
buf = voice[0].op[2].rs; //RS
buf <<= 6;
voice[channel].op[2].ar = voice[0].op[2].ar; //AR
buf = voice[0].op[3].rs; //RS
buf <<= 6;
voice[channel].op[3].ar = voice[0].op[3].ar; //AR
buf = voice[0].op[0].ams; //AMS-EN
buf <<= 7;
voice[channel].op[0].d1r = voice[0].op[0].d1r; //D1R
buf = voice[0].op[1].ams; //AMS-EN
buf <<= 7;
voice[channel].op[1].d1r = voice[0].op[1].d1r; //D1R
buf = voice[0].op[2].ams; //AMS-EN
buf <<= 7;
voice[channel].op[2].d1r= voice[0].op[2].d1r; //D1R
buf = voice[0].op[3].ams; //AMS-EN
buf <<= 7;
voice[channel].op[3].d1r = voice[0].op[3].d1r; //D1R
//RANIX
buf <<= 3;
/* Reads status information from the YM2612
Registers are READ-ONLY and you will ONLY get status.
Returns:
0: Ready to write.
Anything else: Not ready.
unsigned int readreg()
unsigned int state = 0;
digitalWrite(RD, LOW);
state = readbus();
return(state);
/* Selects a note to play. */
void setpitch(unsigned int block, unsigned int fnumber, unsigned int channel)
int i;
unsigned int state2 = 0;
unsigned int tchan = channel;
KEYFREQ[channel] = fnumber;
KEYBLOCK[channel] = block;
for(i=0; i<3; i++)
if( (block & 1<<i) != 0)
state |= 1<<(i+3);
for(i=0; i<3; i++)
if( (fnumber & 1<<(i+8)) != 0)
state |= (1<<i);
for(i=0; i<8; i++)
if( (fnumber & 1<<i) !=0)
state2 |= (1<<i);
if (tchan > CH6) tchan = channel -7;
//FIXME: comment this shit wtf
if ( channel <= CH3 )
reg3( 0xA4 + tchan, state, channel);
reg3( 0xA0 + tchan, state2, channel);
reg3( 0xA4 + tchan -4, state, channel);
reg3( 0xA0 + tchan -4, state2, channel);
else if ( channel <= CH9 )
void pitchbend(unsigned int bend, unsigned int channel)
int i;
unsigned int fnumber = KEYFREQ[channel] + bend;
unsigned int block = KEYBLOCK[channel];
for(i=0; i<3; i++)
state |= 1<<(i+3);
for(i=0; i<3; i++)
state |= (1<<i);
for(i=0; i<8; i++)
state2 |= (1<<i);
/* Selects a frequency in hz. */
void sethz(double hz)
double fnum;
int block = 3;
while(1)
fnum = hz / pow(2, block - 21) / 106666.66; //FIXME: correct this constant
if( fnum >=1250 )
block++;
else if( fnum <= 600 )
block--;
else break;
setpitch(block, fnum, CH1);
/* Plays a note on channel 1. */
//FIXME: Delete this, it's debug code
void note1()
reg(0x28, 0xF0, 1);
delay(50);
reg(0x28, 0x00, 1);
delay(50);
/* Play a note on channel 4. */
void note2()
reg(0x28, 0xF0 + CH4);
reg(0x28, CH4);
/* Press a key. */
void keyDown(int channel, int note)
int harbl, baz = 3;
unsigned int chip;
if (MODE == MODE_POLY)
for(int i=0; i<14; i++)
if (KEYS[i] == 0)
channel = i;
if(KEYS[channel] != 0) return;
KEYS[channel] = note;
harbl = note / 12;
harbl -= 1;
baz = note % 12;
setpitch(harbl, freq[baz+1], channel);
if (channel <= CH6)
chip = 1;
matrix.setColumn(1, channel +1, 0xFF);
chip = 2;
channel -=7;
matrix.setColumn(0, channel +1, 0xFF);
reg(0x28, 0xF0 + channel, chip);
/* Release a key. */
void keyUp(int channel, int note)
unsigned int chip = 0;
for(int i=0;i<14;i++)
if( (channel == 3) || (channel == 10)) continue;
if(KEYS[i] == note)
channel = i;
if(KEYS[channel] > 0)
KEYS[channel] = 0;
if (channel <= CH6)
chip = 1;
matrix.setColumn(1, channel +1, B00000);
chip = 2;
channel -= 7;
matrix.setColumn(0, channel +1, B00000);
reg(0x28, channel, chip);
/* Wipes across a range of notes. */
//FIXME: delete this, it's debug code
void wipe()
sethz(246.94);
note1();
sethz(261.63);
note1();
sethz(277.18);
note1();
sethz(293.66);
note1();
sethz(311.13);
note1();
sethz(329.63);
note1();
sethz(349.23);
note1();
sethz(369.99);
note1();
sethz(392.00);
note1();
sethz(415.30);
note1();
sethz(440.00);
note1();
sethz(466.16);
note1();
sethz(493.88);
note1();
/* Write a byte to the 32k EEPROM. */
void writeEEPROM( unsigned char prom, unsigned int eeaddress, byte data )
Wire.beginTransmission(prom);
Wire.send((int)(eeaddress >> 8)); // MSB
Wire.send((int)(eeaddress & 0xFF)); // LSB
Wire.send(data);
Wire.endTransmission();
delay(5);
/* Read a byte from the 32k EEPROM. */
byte readEEPROM(unsigned char prom, unsigned int eeaddress)
byte rdata = 0xFF;
Wire.requestFrom(disk1,1);
if (Wire.available())
rdata = Wire.receive();
return rdata;
return 0;
void writeram(unsigned short address, unsigned char *data, unsigned int count)
int i;
PORTD &= ~(1 << 5);
SPI.transfer(0x02);
SPI.transfer((address & 0xFF00) >> 8);
SPI.transfer(address & 0x00FF);
for (i=0; i<count; i++)
SPI.transfer(*data);
PORTD |= 1 << 5;
void readram(unsigned short address, byte *buffer, unsigned int count)
byte rec;
int i;
PORTD &= ~(1 << 5);
delayMicroseconds(12);
SPI.transfer(0x03);
buffer[i] = SPI.transfer(0);
PORTD |= 1 << 5;
/* Flash the 32k EEPROM with instrument data. */
void flashEEPROM()
int ibyte = 0;
int stride = 0;
Serial.begin(921600);
while(stride < 12456) //FIXME: error check this
if (Serial.available() > 0)
ibyte = Serial.read();
if (ibyte >= 0)
writeEEPROM(disk1, stride, (char)ibyte);
stride++;
void dtime(unsigned long time)
if ( TIMER < DTIMER )
DTIMER += time;
TIMER = 0;
DTIMER = time;
void vgmplay()
unsigned char ibyte = 0;
int rdy = 0;
int n = 0;
unsigned char ibyte2 = 0;
unsigned char buff[1280];
unsigned char* buf1 = buff;
unsigned char* buf = buf1;
unsigned char* buf2 = buff + 64;
byte ram[128];
byte * ram1 = ram;
unsigned short ramptr = 0;
int more = 0;
int cnt = 0;
int lize = 0;
int errcnt = 0;
int exit = 0;
LCD.print("VGM Player Mode");
lcdline2();
while(1)
if ( more == 0)
while( !(RawHID.recv(buf1, 0) > 0) );
buf = buf1;
if (buf1 >= buff + (1280 - 65))
buf1 = buff;
buf = buf1;
buf1 += 64;
buf = buf1;
more--;
exit = 0;
while (exit < 3)
//check timer, wait if necessary
while ( TIMER < DTIMER)
if ( (DTIMER > (TIMER + 50)) )
if ( (more < 18) )
if (RawHID.recv(buf2, 0) > 0)
if ( buf2 >= buff + (1280 -65))
buf2 = buff;
else buf2 += 64;
more++;
if (buf2 == buf1)
lcdinit();
LCD.print("MASSIVE ERROR");
TIMER = 0;
DTIMER = 0;
if (*buf == 39)
buf++;
if (*buf == 42)
buf++;
if (*buf == 26)
exit = 3;
continue;
buf -= 2;
buf--;
if ((*buf & 0xF0) == 0x60)
dtime((*buf &0x0F) * 22.6757);
//buf++;
//ibyte = *buf;
if (ram1 == ram + 127)
readram(ramptr, ram, 128);
ram1 = ram;
selectreg(0x2A);
writereg(*ram1);
ram1++;
ramptr++;
buf++;
continue;
switch(*buf)
case 1: //register 1 write
buf++;
ibyte = *buf;
buf++;
ibyte2 = *buf;
if(ibyte == 0x28)
if ( lize == 0) lize = 1;
if (lize == 0) delay(2);
selectreg(ibyte);
writereg(ibyte2);
case 2: //register 2 write
buf++;
ibyte = *buf;
buf++;
ibyte2 = *buf;
selectreg2(ibyte);
writereg2(ibyte2);
case 3: //incoming PCM data
buf++;
writeram(ramptr, buf, 1);
ramptr++;
case 4: //1 byte wait data
buf++;
ibyte = *buf;
dtime(ibyte * 22.6757);
case 5: //2 byte wait data
unsigned int wait;
buf++;
ibyte = *buf;
buf++;
ibyte2 = *buf;
wait = (ibyte << 8) + ibyte2;
dtime((unsigned long)(wait * 22.6757));
//case 6 is used above in a pre-switch if
case 7: //static time delay
dtime(735 * 22.6757);
case 8: //static time delay
dtime(882 * 22.6757);
case 9:
ramptr = 0;
case 10: //stream begin
lize = 0;
digitalWrite(RESET, LOW);
digitalWrite(RESET, HIGH); //Active low
ramptr = 0;
case 11:
buf++;
ramptr = *buf << 8;
buf++;
ramptr += *buf;
ram1 = ram;
default:
lcdinit();
LCD.print("MAJOR ERROR");
lcdline2();
LCD.print(String(*buf, DEC));
buf++;
void lcdinit()
LCD.write((byte)0xFE);
LCD.write((byte)0x51); //clear
LCD.write((byte)0x00);
delayMicroseconds(150);
void lcdline2()
LCD.write((byte)0x45);
LCD.write((byte)0x40);
void lcdwrite(const char* data)
LCD.print(data);
/* Initialize the Teensy and the YM2612. */
MIDI.begin(MIDI_CHANNEL_OMNI);
//Serial.begin(921600); //DEBUG
//Serial.println("MIDI Input Test");
Wire.begin();
pinMode(LCDPin, OUTPUT);
pinMode(backlight, OUTPUT);
pinMode(CS, OUTPUT);
pinMode(CS2, OUTPUT);
pinMode(RD, OUTPUT);
pinMode(WR, OUTPUT);
pinMode(AA0, OUTPUT);
pinMode(AA1, OUTPUT);
pinMode(RESET, OUTPUT);
pinMode(SSP, OUTPUT);
digitalWrite(SSP, HIGH);
SPI.begin();
SPI.setClockDivider(SPI_CLOCK_DIV2);
LCD.begin(9600);
//Always keep CS high when not writing.
digitalWrite(CS2, HIGH);
//Reset the YM2612. Power cycle is insufficient.
lcdinit();
for(int i = 0; i < matrix.getDeviceCount(); i++)
matrix.shutdown(i,false);
matrix.setIntensity(0, 8);
matrix.setIntensity(1, 8);
matrix.clearDisplay(0);
matrix.clearDisplay(1);
for(int j=0; j < 8; j++)
for(int i=0; i < 5; i++)
matrix.setLed(0, i, j, true);
matrix.setLed(1, i, j, true);
matrix.setLed(0, i, j, false);
matrix.setLed(1, i, j, false);
//flashEEPROM();
reg(0x22, 0x00); //LFO off
reg(0x27, 0x00); //Channel 3 mode normal
reg(0x28, 0x00); //Channel 1 Key Off
reg(0x28, 0x01); //Channel 2 Key Off
reg(0x28, 0x02); //Channel 3 Key Off
reg(0x28, 0x04); //Channel 4 Key Off
reg(0x28, 0x05); //Channel 5 Key Off
reg(0x28, 0x06); //Channel 6 Key Off
reg(0x2B, 0x00); //DAC off
reg(0x30, 0x71); //Detune/Multiply Ch 1 Operator 1 set
reg(0x31, 0x71); //Detune/Multiply Ch 2 Operator 1 set
reg(0x32, 0x71); //Detune/Multiply Ch 3 Operator 1 set
reg2(0x30, 0x71); //Detune/Multiply Ch 4 Operator 1 set
reg2(0x31, 0x71); //Detune/Multiply Ch 5 Operator 1 set
reg2(0x32, 0x71); //Detune/Multiply Ch 6 Operator 1 set
reg(0x34, 0x0D); //Detune/Multiply Ch 1 Operator 2 set
reg(0x35, 0x0D); //Detune/Multiply Ch 2 Operator 2 set
reg(0x36, 0x0D); //Detune/Multiply Ch 3 Operator 2 set
reg2(0x34, 0x0D); //Detune/Multiply Ch 4 Operator 2 set
reg2(0x35, 0x0D); //Detune/Multiply Ch 5 Operator 2 set
reg2(0x36, 0x0D); //Detune/Multiply Ch 6 Operator 2 set
reg(0x38, 0x33); //Detune/Multiply Ch 1 Operator 3 set
reg(0x39, 0x33); //Detune/Multiply Ch 2 Operator 3 set
reg(0x3A, 0x33); //Detune/Multiply Ch 3 Operator 3 set
reg2(0x38, 0x33); //Detune/Multiply Ch 4 Operator 3 set
reg2(0x39, 0x33); //Detune/Multiply Ch 5 Operator 3 set
reg2(0x3A, 0x33); //Detune/Multiply Ch 6 Operator 3 set
reg(0x3C, 0x01); //Detune/Multiply Ch 1 Operator 4 set
reg(0x3D, 0x01); //Detune/Multiply Ch 2 Operator 4 set
reg(0x3E, 0x01); //Detune/Multiply Ch 3 Operator 4 set
reg2(0x3C, 0x01); //Detune/Multiply Ch 4 Operator 4 set
reg2(0x3D, 0x01); //Detune/Multiply Ch 5 Operator 4 set
reg2(0x3E, 0x01); //Detune/Multiply Ch 6 Operator 4 set
reg(0x40, 0x23); //Total Level Ch 1 Operator 1 set
reg(0x41, 0x23); //Total Level Ch 2 Operator 1 set
reg(0x42, 0x23); //Total Level Ch 3 Operator 1 set
reg2(0x40, 0x23); //Total Level Ch 4 Operator 1 set
reg2(0x41, 0x23); //Total Level Ch 5 Operator 1 set
reg2(0x42, 0x23); //Total Level Ch 6 Operator 1 set
reg(0x44, 0x2D); //Total Level Ch 1 Operator 2 set
reg(0x45, 0x2D); //Total Level Ch 2 Operator 2 set
reg(0x46, 0x2D); //Total Level Ch 3 Operator 2 set
reg2(0x44, 0x2D); //Total Level Ch 4 Operator 2 set
reg2(0x45, 0x2D); //Total Level Ch 5 Operator 2 set
reg2(0x46, 0x2D); //Total Level Ch 6 Operator 2 set
reg(0x48, 0x26); //Total Level Ch 1 Operator 3 set
reg(0x49, 0x26); //Total Level Ch 2 Operator 3 set
reg(0x4A, 0x26); //Total Level Ch 3 Operator 3 set
reg2(0x48, 0x26); //Total Level Ch 4 Operator 3 set
reg2(0x49, 0x26); //Total Level Ch 5 Operator 3 set
reg2(0x4A, 0x26); //Total Level Ch 6 Operator 3 set
reg(0x4C, 0x00); //Total Level Ch 1 Operator 4 set
reg(0x4D, 0x00); //Total Level Ch 2 Operator 4 set
reg(0x4E, 0x00); //Total Level Ch 3 Operator 4 set
reg2(0x4C, 0x00); //Total Level Ch 4 Operator 4 set
reg2(0x4D, 0x00); //Total Level Ch 5 Operator 4 set
reg2(0x4E, 0x00); //Total Level Ch 6 Operator 4 set
reg(0x50, 0x5F); //Attack rate (keyon) Ch 1 Operator 1 set
reg(0x51, 0x5F); //Attack rate (keyon) Ch 2 Operator 1 set
reg(0x52, 0x5F); //Attack rate (keyon) Ch 3 Operator 1 set
reg2(0x50, 0x5F); //Attack rate (keyon) Ch 4 Operator 1 set
reg2(0x51, 0x5F); //Attack rate (keyon) Ch 5 Operator 1 set
reg2(0x52, 0x5F); //Attack rate (keyon) Ch 6 Operator 1 set
reg(0x54, 0x5F); //Attack rate (keyon) Ch 1 Operator 2 set
reg(0x55, 0x5F); //Attack rate (keyon) Ch 2 Operator 2 set
reg(0x56, 0x5F); //Attack rate (keyon) Ch 3 Operator 2 set
reg2(0x54, 0x5F); //Attack rate (keyon) Ch 4 Operator 2 set
reg2(0x55, 0x5F); //Attack rate (keyon) Ch 5 Operator 2 set
reg2(0x56, 0x5F); //Attack rate (keyon) Ch 6 Operator 2 set
reg(0x58, 0x5F); //Attack rate (keyon) Ch 1 Operator 3 set
reg(0x59, 0x5F); //Attack rate (keyon) Ch 2 Operator 3 set
reg(0x5A, 0x5F); //Attack rate (keyon) Ch 3 Operator 3 set
reg2(0x58, 0x5F); //Attack rate (keyon) Ch 4 Operator 3 set
reg2(0x59, 0x5F); //Attack rate (keyon) Ch 5 Operator 3 set
reg2(0x5A, 0x5F); //Attack rate (keyon) Ch 6 Operator 3 set
reg(0x5C, 0x94); //Attack rate (keyon) Ch 1 Operator 4 set
reg(0x5D, 0x94); //Attack rate (keyon) Ch 2 Operator 4 set
reg(0x5E, 0x94); //Attack rate (keyon) Ch 3 Operator 4 set
reg2(0x5C, 0x94); //Attack rate (keyon) Ch 4 Operator 4 set
reg2(0x5D, 0x94); //Attack rate (keyon) Ch 5 Operator 4 set
reg2(0x5E, 0x94); //Attack rate (keyon) Ch 6 Operator 4 set
reg(0x60, 5); //Decay rate (keyon) Ch 1 Operator 1 set
reg(0x61, 5); //Decay rate (keyon) Ch 2 Operator 1 set
reg(0x62, 5); //Decay rate (keyon) Ch 3 Operator 1 set
reg2(0x60, 5); //Decay rate (keyon) Ch 4 Operator 1 set
reg2(0x61, 5); //Decay rate (keyon) Ch 5 Operator 1 set
reg2(0x62, 5); //Decay rate (keyon) Ch 6 Operator 1 set
reg(0x64, 5); //Decay rate (keyon) Ch 1 Operator 2 set
reg(0x65, 5); //Decay rate (keyon) Ch 2 Operator 2 set
reg(0x66, 5); //Decay rate (keyon) Ch 3 Operator 2 set
reg2(0x64, 5); //Decay rate (keyon) Ch 4 Operator 2 set
reg2(0x65, 5); //Decay rate (keyon) Ch 5 Operator 2 set
reg2(0x66, 5); //Decay rate (keyon) Ch 6 Operator 2 set
reg(0x68, 5); //Decay rate (keyon) Ch 1 Operator 3 set
reg(0x69, 5); //Decay rate (keyon) Ch 2 Operator 3 set
reg(0x6A, 5); //Decay rate (keyon) Ch 3 Operator 3 set
reg2(0x68, 5); //Decay rate (keyon) Ch 4 Operator 3 set
reg2(0x69, 5); //Decay rate (keyon) Ch 5 Operator 3 set
reg2(0x6A, 5); //Decay rate (keyon) Ch 6 Operator 3 set
reg(0x6C, 7); //Decay rate (keyon) Ch 1 Operator 4 set
reg(0x6D, 7); //Decay rate (keyon) Ch 2 Operator 4 set
reg(0x6E, 7); //Decay rate (keyon) Ch 3 Operator 4 set
reg2(0x6C, 7); //Decay rate (keyon) Ch 4 Operator 4 set
reg2(0x6D, 7); //Decay rate (keyon) Ch 5 Operator 4 set
reg2(0x6E, 7); //Decay rate (keyon) Ch 6 Operator 4 set
reg(0x70, 2); //Secondary decay (keyon) Ch 1 Operator 1 set
reg(0x71, 2); //Secondary decay (keyon) Ch 2 Operator 1 set
reg(0x72, 2); //Secondary decay (keyon) Ch 3 Operator 1 set
reg2(0x70, 2); //Secondary decay (keyon) Ch 4 Operator 1 set
reg2(0x71, 2); //Secondary decay (keyon) Ch 5 Operator 1 set
reg2(0x72, 2); //Secondary decay (keyon) Ch 6 Operator 1 set
reg(0x74, 2); //Secondary decay (keyon) Ch 1 Operator 2 set
reg(0x75, 2); //Secondary decay (keyon) Ch 2 Operator 2 set
reg(0x76, 2); //Secondary decay (keyon) Ch 3 Operator 2 set
reg2(0x74, 2); //Secondary decay (keyon) Ch 4 Operator 2 set
reg2(0x75, 2); //Secondary decay (keyon) Ch 5 Operator 2 set
reg2(0x76, 2); //Secondary decay (keyon) Ch 6 Operator 2 set
reg(0x78, 2); //Secondary decay (keyon) Ch 1 Operator 3 set
reg(0x79, 2); //Secondary decay (keyon) Ch 2 Operator 3 set
reg(0x7A, 2); //Secondary decay (keyon) Ch 3 Operator 3 set
reg2(0x78, 2); //Secondary decay (keyon) Ch 4 Operator 3 set
reg2(0x79, 2); //Secondary decay (keyon) Ch 5 Operator 3 set
reg2(0x7A, 2); //Secondary decay (keyon) Ch 6 Operator 3 set
reg(0x7C, 2); //Secondary decay (keyon) Ch 1 Operator 4 set
reg(0x7D, 2); //Secondary decay (keyon) Ch 2 Operator 4 set
reg(0x7E, 2); //Secondary decay (keyon) Ch 3 Operator 4 set
reg2(0x7C, 2); //Secondary decay (keyon) Ch 4 Operator 4 set
reg2(0x7D, 2); //Secondary decay (keyon) Ch 5 Operator 4 set
reg2(0x7E, 2); //Secondary decay (keyon) Ch 6 Operator 4 set
reg(0x80, 0x11); //Secondary amplitude/release rate Ch 1 Oper 1 set
reg(0x81, 0x11); //Secondary amplitude/release rate Ch 2 Oper 1 set
reg(0x82, 0x11); //Secondary amplitude/release rate Ch 3 Oper 1 set
reg2(0x80, 0x11); //Secondary amplitude/release rate Ch 4 Oper 1 set
reg2(0x81, 0x11); //Secondary amplitude/release rate Ch 5 Oper 1 set
reg2(0x82, 0x11); //Secondary amplitude/release rate Ch 6 Oper 1 set
reg(0x84, 0x11); //Secondary amplitude/release rate Ch 1 Oper 2 set
reg(0x85, 0x11); //Secondary amplitude/release rate Ch 2 Oper 2 set
reg(0x86, 0x11); //Secondary amplitude/release rate Ch 3 Oper 2 set
reg2(0x84, 0x11); //Secondary amplitude/release rate Ch 4 Oper 2 set
reg2(0x85, 0x11); //Secondary amplitude/release rate Ch 5 Oper 2 set
reg2(0x86, 0x11); //Secondary amplitude/release rate Ch 6 Oper 2 set
reg(0x88, 0x11); //Secondary amplitude/release rate Ch 1 Oper 3 set
reg(0x89, 0x11); //Secondary amplitude/release rate Ch 2 Oper 3 set
reg(0x8A, 0x11); //Secondary amplitude/release rate Ch 3 Oper 3 set
reg2(0x88, 0x11); //Secondary amplitude/release rate Ch 4 Oper 3 set
reg2(0x89, 0x11); //Secondary amplitude/release rate Ch 5 Oper 3 set
reg2(0x8A, 0x11); //Secondary amplitude/release rate Ch 6 Oper 3 set
reg(0x8C, 0xA6); //Secondary amplitude/release rate Ch 1 Oper 4 set
reg(0x8D, 0xA6); //Secondary amplitude/release rate Ch 2 Oper 4 set
reg(0x8E, 0xA6); //Secondary amplitude/release rate Ch 3 Oper 4 set
reg2(0x8C, 0xA6); //Secondary amplitude/release rate Ch 4 Oper 4 set
reg2(0x8D, 0xA6); //Secondary amplitude/release rate Ch 5 Oper 4 set
reg2(0x8E, 0xA6); //Secondary amplitude/release rate Ch 6 Oper 4 set
reg(0x90, 0); //Sega doesn't know what this does
reg(0x94, 0); //Sega doesn't know what this does
reg(0x98, 0); //Sega doesn't know what this does
reg(0x9C, 0); //Sega doesn't know what this does
reg2(0x90, 0); //Sega doesn't know what this does
reg2(0x94, 0); //Sega doesn't know what this does
reg2(0x98, 0); //Sega doesn't know what this does
reg2(0x9C, 0); //Sega doesn't know what this does
reg(0xB0, 0x32); //Feedback/algorithm select, Ch 1
reg(0xB1, 0x33); //Feedback/algorithm select, Ch 2
reg(0xB2, 0x34); //Feedback/algorithm select, Ch 3
reg2(0xB0, 0x35); //Feedback/algorithm select, Ch 4
reg2(0xB1, 0x37); //Feedback/algorithm select, Ch 5
reg2(0xB2, 0x31); //Feedback/algorithm select, Ch 6
reg(0xB4, 0xC0); //Both speakers on CH1
reg(0xB5, 0xC0); //Both speakers on CH2
reg(0xB6, 0xC0); //Both speakers on CH3
reg2(0xB4, 0xC0); //Both speakers on CH4
reg2(0xB5, 0xC0); //Both speakers on CH5
reg2(0xB6, 0xC0); //Both speakers on CH6
reg(0x28, 0x00); //Key off
reg(0x28, 0x01); //Key off
reg(0x28, 0x02); //Key off
reg(0x28, 0x04); //Key off
reg(0x28, 0x05); //Key off
reg(0x28, 0x06); //Key off
/* Now we are ready to set the frequency and play a note. */
selectinst(0, CH1);
selectinst(0, CH2);
selectinst(0, CH3);
selectinst(0, CH4);
selectinst(0, CH5);
selectinst(0, CH6);
selectinst(0, CH7);
selectinst(0, CH8);
selectinst(0, CH9);
selectinst(0, CH10);
selectinst(0, CH11);
selectinst(0, CH12);
//vgmplay();
// analogWrite(backlight, 30);
LCD.print("Welcome to");
lcdline2();
LCD.print("YM2612 synth");
int type, note, velocity, channel, d1, d2;
byte ch, offset;
long pos = knob1.read();
if (pos != knob1pos)
knob1pos = pos;
if ((pos % 4 == 0) && (pos >= 0))
lcdinit();
LCD.print("YM2612 Synth --");
lcdline2();
LCD.print("Instrument: #");
LCD.print(pos/4);
selectinst(pos/4, CH1);
selectinst(pos/4, CH2);
selectinst(pos/4, CH3);
selectinst(pos/4, CH4);
selectinst(pos/4, CH5);
selectinst(pos/4, CH6);
selectinst(pos/4, CH7);
selectinst(pos/4, CH8);
selectinst(pos/4, CH9);
selectinst(pos/4, CH10);
selectinst(pos/4, CH11);
selectinst(pos/4, CH12);
for( int i=0; i<14; i++)
if( KEYS[i] < 0xFFFC)
KEYS[i] = 0;
//while(1) wipe();
if (MIDI.read())
byte type = MIDI.getType();
switch (type)
case NoteOn:
note = MIDI.getData1();
velocity = MIDI.getData2();
channel = MIDI.getChannel();
if (velocity > 0)
//Serial.println(String("Note On: ch=") + channel + ", note=" + note + ", velocity=" + velocity);
if (MODE == MODE_POLY) keyDown(CH1, note);
if(channel == 1) keyDown(CH1, note);
if(channel == 2) keyDown(CH2, note);
if(channel == 3) keyDown(CH3, note);
if(channel == 4) keyDown(CH4, note);
if(channel == 5) keyDown(CH5, note);
if(channel == 6) keyDown(CH6, note);
if(channel == 7) keyDown(CH7, note);
if(channel == 8) keyDown(CH8, note);
if(channel == 9) keyDown(CH9, note);
if(channel == 10) keyDown(CH10, note);
if(channel == 11) keyDown(CH11, note);
if(channel == 12) keyDown(CH12, note);
//Serial.println(String("Note Off: ch=") + channel + ", note=" + note);
if (MODE == MODE_POLY) keyUp(CH1, note);
if(channel == 1) keyUp(CH1, note);
if(channel == 2) keyUp(CH2, note);
if(channel == 3) keyUp(CH3, note);
if(channel == 4) keyUp(CH4, note);
if(channel == 5) keyUp(CH5, note);
if(channel == 6) keyUp(CH6, note);
if(channel == 7) keyUp(CH7, note);
if(channel == 8) keyUp(CH8, note);
if(channel == 9) keyUp(CH9, note);
if(channel == 10) keyUp(CH10, note);
if(channel == 11) keyUp(CH11, note);
if(channel == 12) keyUp(CH12, note);
case NoteOff:
//Serial.println(String("Note Off: ch=") + channel + ", note=" + note + ", velocity=" + velocity);
case ControlChange:
d1 = MIDI.getData1();
d2 = MIDI.getData2();
ch = CHANNEL[channel];
byte buf;
if (ch <= CH3)
offset = ch;
else if (ch <= CH6)
offset = ch - 4;
else if (ch <= CH9)
offset = ch - 7;
else if (ch <= CH12)
offset = ch -11;
switch (d1)
case 21:
lcdinit();
LCD.print("ALG set CH");
LCD.print(String(ch, DEC));
buf = voice[ch].feedback << 3;
buf += voice[ch].algorithm = d2;
lcdline2();
LCD.print(String(voice[ch].feedback, DEC));
LCD.print(" ");
LCD.print(String(voice[ch].algorithm, DEC));
reg3(0xB0 + offset, buf, ch);
case 22:
lcdinit();
LCD.print("LFO");
LCD.print(String(d2, DEC));
LCD.print(" ");
if (d2 == 0)
reg3(0x22, 0, ch);
reg3(0x22, d2 -1 + (1 << 3), ch);
case 50:
lcdinit();
LCD.print("FB set ");
buf = (voice[ch].feedback = d2 ) << 3;
buf += voice[ch].algorithm;
lcdline2();
LCD.print(" ");
case 42: //dt1 set
lcdinit();
LCD.print("Set DT1, CH");
LCD.print(String(channel, DEC));
lcdline2();
LCD.print("Oper(s): ");
for (int i=0; i<4; i++)
if ((chctl & (1 << i)) > 0)
LCD.print(String(i + 1, DEC));
buf = (voice[ch].op[i].dt1 = d2) << 4;
buf += voice[ch].op[i].mul;
reg3(0x30 + (i * 4) + offset, buf, ch);
case 43: //mul set
lcdinit();
LCD.print("Set MUL, CH");
lcdline2();
buf = voice[ch].op[i].dt1 << 4;
buf += voice[ch].op[i].mul = d2;
case 44: //TL set
//lcdinit();
//LCD.print("Set TL, CH");
//LCD.print(String(channel, DEC));
//lcdline2();
//LCD.print("Oper(s): ");
//LCD.print(String(i + 1, DEC));
buf = voice[ch].op[0].tl = d2;
reg3(0x40 + (i * 4) + offset, buf, ch);
case 45: //attack rate set
lcdinit();
LCD.print("Set Atk Rate, CH");
lcdline2();
buf = voice[ch].op[i].rs << 6;
buf += voice[ch].op[i].ar = d2;
reg3(0x50 + (i * 4) + offset, buf, ch);
case 49: //channel LFO sensitivity set
lcdinit();
LCD.print("LFO CH");
lcdline2();
if (d2 == 0)
/* for (int i=0; i<4; i++)
buf = voice[ch].op[i].d1r;
reg3(0x60 + (i * 4) + offset, buf, ch);
LCD.print(String(buf, DEC));
LCD.print(" ");
reg3(0xB4 + offset, 0xC0, ch);
reg3(0xB4 + offset, 0xC0 + (d2 << 4), ch);
case 59: //LFO toggle
lcdinit();
LCD.print("LFO");
buf += (voice[ch].op[i].lfo = d2) << 7;
case 51:
if (d2 == 127) chctl |= 1 << 0;
if (d2 == 0) chctl &= ~(1 << 0);
case 52:
if (d2 == 127) chctl |= 1 << 1;
if (d2 == 0) chctl &= ~(1 << 1);
case 53:
if (d2 == 127) chctl |= 1 << 2;
if (d2 == 0) chctl &= ~(1 << 2);
case 54:
if (d2 == 127) chctl |= 1 << 3;
if (d2 == 0) chctl &= ~(1 << 3);
case 58:
case ProgramChange:
lcdinit();
LCD.print("YM2612 Chan. ");
lcdline2();
LCD.print(d1);
if ( MODE == MODE_POLY)
for ( int i=0; i <= 12; i++ )
selectinst(d1, CHANNEL[i]);
selectinst(d1, CHANNEL[channel]);
case PitchBend:
pitchbend(d2 - 64, CH1);
pitchbend(d2 - 64, CH2);
pitchbend(d2 - 64, CH3);
/*default:
lcdinit();
LCD.print(String("Message, type=") + String(type, DEC));
lcdline2();
LCD.print(String("data = ") + String(d1, DEC) + " " + String(d2, DEC));
LCD.print(" ");
LCD.print(String(AfterTouchChannel, DEC));
