Has anyone heard of a bootloader or program that would allow the user to show an SPI connected microSD card to show up as a USB disk in Windows on Teensy 3.1?
Goal would be to drag and drop files in file explorer so user could add/remove files from SD card without removing card from device... If so, would it use up a ton of flash space or would it need to be setup as a bootloader instead?
Note, I would still want to be able to run other controller code, but be able to switch to USB disk mode at startup or on special command as needed.
