Hi Folks,
I am wanting to make an audio project that initially allows for a single audio IN (ADC) and and single audio out (DAC). While it seems that this is possible just via the teensy 3.1 most of the basic audio code examples I see seem to presume that one is using the audio shield (via the AudioControlSGTL5000 codec; statement?).
All I want to do (for now) is have the input signal function as a simple real(ish)-time frequency/amplitude modulator of an existing signal/sound which could come from memory or just via a simple sine tone generator. I've lurked all over the audio forum posts but I'm not totally clear at what point the CPU/ADC/DAC complexity of what I am trying to do is too limited for the Teensy alone and requires me to use the shield also?
Eventually, I might want to add another line-in ADC to the modulation and this will surely require to shield since I will be using 2 ADC lines, but I am just trying to understand what is possible with the equipment I have for now? Also, I am not clear whether I could just use the Teensy Pedvide ADC library to do what I am thinking of for now, and to what extent the functionality of this library overlaps with the general teensy audio library?
Any guidance would be appreciated.
Thanks so much.
Thanks so much.
