Results 1 to 11 of 11
Thread: Looking for code to do a software restart with the Teensy LC
    Jun 2015
    Oakdale, CT
    37
    First, I have to say the the prjc.com site has a lot of documentation for their products. However, after reading the programming manual for Freescale MKL26Z64, I am confused. The manual says a software restart can be done. The problem is the manual refers to another document for the ARM processor. I did do a Google search for information on "Teensy LC restart" without any luck.
    I am using this code for the same function with Teensy 3.1:
    #define SCB_AIRCR (*(volatile uint32_t *)0xE000ED0C) // Application Interrupt and Reset Control location
    void softRestart(int pinUsed) {
      int test1 = HIGH;
      int test2 = LOW;
      test1 = digitalRead(pinUsed);
      delay(100); //for debounce
      test2 = digitalRead(pinUsed);
      if ((test1 == test2) && (test1 == LOW)) {
        delay(1000); //allow human to release button
        Serial.end();  //clears the serial monitor  if used
        //turn off serial for restart, it will be properly turned after restart with IDE serial monitor
        //However, microcom and putty serial connection is killed after restart with or without serial.end()!
      SCB_AIRCR = 0x05FA0004;  //write value for restart
    I suspect the same code could be used, but, with a different register location and value. Thank you in advance for any help on this one.
    Enjoy Life, Greg
    Live Well, Laugh Often, Love Much
    Aug 2013
    Gothenburg, Sweden
    419
    SCB->AIRCR or simply try NVIC_SystemReset(void)
    Jun 2015
    Oakdale, CT
    37
    Thanks, mlu! I will try NVIC_SystemReset(void). It seems the easier approach.
    Enjoy life, Greg
    Try the NVIC_SystemReset(void) and got a compilation error of "not in scope". This must be a library call, but, what library?
    Jun 2013
    So. Calif
    2,828
    Somewhere in these forums, there are other/different solutions to doing a software reset on the Teensy 3.1. May work too for the LC, or with small changes.
    It didn't use the NVIC-direct mechanism.
    24,452
    You're really not getting any results with "SCB_AIRCR = 0x05FA0004;" ??
    Jun 2015
    Oakdale, CT
    37
    Thank Paul, for the confirmation that "SCB_AIRCR = 0x05FA0004;" should work. After checking the connections and re-doing them, it now works. It is not as fast as with the Teensy 3.1, I may have to change something in the code. But, it does work. Thank you to all for the help. Maybe now, I can do something useful.
    Enjoy Life, Greg
    Jun 2015
    Oakdale, CT
    37
    Follow Up, Found Post with Information
    I was looking for some other information and found this post with Teensy Tips and Tricks:https://forum.pjrc.com/threads/25395...ips-and-Tricks
    It has provides a link to for a restart code. This is a compiler macro :
    #define RESTART_ADDR       0xE000ED0C
    #define READ_RESTART()     (*(volatile uint32_t *)RESTART_ADDR)
    #define WRITE_RESTART(val) ((*(volatile uint32_t *)RESTART_ADDR) = (val))
    To restart the program, one calls this in code:
    WRITE_RESTART(0x5FA0004);
    I have tried this and it does work with my projects. The referenced post with the tips and tricks has a lot of good information. I hope this is a help to someone.
    Enjoy life, Greg
    May 2015
    USA
    983
    I have the same question for teensy 4. I've tried various things and they all lock up the processor, but it's doesn't come back up.
    My vote is for a reboot() to be written and supported for all teensy MCUs.
    I'm also having the same experience on teensy 4, any advice on who to reboot/reset teensy4?
    24,452
    Quote Originally Posted by manatee View Post
    The soft reboot bug was recently fixed. Just update to 1.50-beta1, and then you can use SCB_AIRCR to reboot Teensy 4.0.
    https://forum.pjrc.com/threads/59297...no-1-50-Beta-1
    Apr 2019
    175
    is there a hard and a soft reboot ?
    which one is _reboot_Teensyduino_()
