ld returned 1 exit status
mcipjvw
New member
Hi!
Struggling through all posts related to the combiner error above I still cannot find a solution for it.
Yes, some posts did some suggestions, but they were rather old. I installed (Win8,64bit) the latest versions:
arduino-1.6.5-r2, teensyduino 1.24, Eclipse Arduino IDE V2.3
Compiling and uploading in Arduino 1.6.5 works.
Below you will find the complete error when I am building the "Blink" example:
Starting combiner
"C:/Arduino/hardware/tools/arm/bin/arm-none-eabi-gcc" -Os -Wl,--gc-sections,--relax,--defsym=__rtc_localtime= "-T/mk20dx256.ld" --specs=nano.specs -mthumb -mcpu=cortex-m4 -o "G:/svn/Teensy/Test12/Release/Test12.elf" G:/svn/Teensy/Test12/Release/arduino.ar "G:/svn/Teensy/Test12/Release/arduino.ar" "-LG:/svn/Teensy/Test12/Release" -larm_cortexM4l_math -lm
c:/arduino/hardware/tools/arm/bin/../lib/gcc/arm-none-eabi/4.8.4/../../../../arm-none-eabi/bin/ld.exe:--defsym:1: syntax error
make: *** [Test12.elf] Error 1​
I did not do specific settings, just the three private paths under preferences.
Any help is welcome! Thanks in advance. Martin
There needs to be number after "-Wl,--gc-sections,--relax,--defsym=__rtc_localtime=". Any integer will do, at least to get your code to compile.
If you try this in Arduino with File > Preferences set to show verbose output while compiling, you'll see the compiler command used by Arduino has a number in that location.
Thanks Paul for this immediate reply!
This was it indeed, but to be honest, not that trivial. This should actually be configurable somehow, with a default such that example code at least compiles.
Great job! Martin
Perhaps you should try the Arduino Eclipse IDE 2.4. The nightly builds are the most up to date. Stuff s very rarely broken in the nightly builds and when it is usually for some esoteric stuff that not so many people use. The Arduino Eclipse IDE supports really a very vast range of boards and configurations.
Al;so, if you suspect there is something wrong in the configuration of the Arduino Eclipse IDE, please post an issue on their GitHub repo.
Stuff is usually being fixed rapidly!
Hi all, I am using Arduino 1.8.0 and I do have this:
but sorry, I did not understand how to solve this..
thank you for your attention
Please take note of "Forum Rule: Always post complete source code & details to reproduce any issue! "
Not enough info has been provided here. What sketch? What was the complete associated error text leading to the error? Always helpful to know what Teensy # and version of TeensyDuino installed.
