Results 1 to 4 of 4
Thread: Category 'Sensor' in library DallasTemperature is not valid
    Jul 2015
    2
    Hi! I'm new to Arduino (and programming in general). I'm currently working on how to connect a DS18B20 to a Moteino. I can't understand why but the category "sensor" isn't valid in the DallasTemperature library. I have tried uninstalling and re-installing it but I continue getting the same result.
    I'm sorry if this question seems unintelligent, but I'm just starting out and would appreciate any help!
    Here is my code:
    #include <OneWire.h>
    #include <DallasTemperature.h>
    #define ONE_WIRE_BUS 14
    // Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
    OneWire
    oneWire(ONE_WIRE_BUS);
    DallasTemperature sensors(&oneWire);
    void setup(void)
    Serial.println("Dallas Temperature IC Control Library Demo");
    sensors.begin(); // IC Default 9 bit. If you have troubles consider upping it 12. Ups the delay giving the IC more time to process the temperature measurement
    void loop(void)
    Serial.print("Requesting temperatures...");
    sensors.requestTemperatures(); // Send the command to get temperatures
    Serial.println("DONE");
    Serial.print("Temperature for Device 1 is: ");
    Serial.print(sensors.getTempCByIndex(0)); //
    Aug 2013
    Gothenburg, Sweden
    291
    The warning about category "sensors" is just a minor issue with the library manager.
    But your code needs an opening brace after "void setup(void)"
    it should be
    void setup(void)
    Jul 2015
    2
    thank you! any other errors?
    Quote Originally Posted by mlu View Post
    it should be
    void setup(void)
    Thank you so much! DId you happen to see any other problems with the code?
    16,231
    Since you're using a Moteino board, maybe post here:
    https://lowpowerlab.com/forum/index.php?board=1.0
Tags for this Thread
