I need to read some Hall effect current sensors (Allegro ACS758 series) thus I have to feed them with the same reference voltage as Teensy 3.1 ADCs. As I'm using a 2x14 pins ZIF socket for Teensy 3.1 module, I can't access the bottom side AREF pin hence I couldn't use an external reference for both Teensy and current sensors.
The only(?) solution is to use Teensy 3.3V output (used for internal ADC reference) to feed the current sensors. Anyway, I'm going to use at least 8 current sensors, each needing a max. 13.5mA supply current thus exceding the 100mA datasheet limit of that 3.3V output.
What's the best way to build a (high accuracy) voltage repeater for that 3.3V output, with enhanced current capabilities?
