Waveset chopper / repeater
This program divides the input into segments, and plays these segments back.
It could be seen as a time-domain, granular form of analysis/resynthesis.
The program contains a recording section,
which stores grains into a Data object (segment_data)
and a playback section,
which selects and plays these grains one-by-one
The grains are not enveloped;
instead the input is segmented at points where the signal is rising and crosses zero
A positive zero-crossing means that:
a: previous sample is less than zero
b: next sample is greater than zero
For pure sounds a segment corresponds to one or more wavecycles,
but for complex sounds it can be somewhat stochastic.
RECORDING:
Since waveforms rarely cross zero at an exact sample location,
the actual crossing is somewhere between a and b.
The program estimates this sub-sample crossing phase (and stores it in offset_data)
It also stores the sub-sample accurate segment length (in length_data)
The segment_data recorded includes the sample just before the first crossing,
and the sample just after the last, in order to contain both actual crossings.
I.e. each captured segment looks like [a1, b1, ... b2 a2 ... a3, b3]
When a segment finishes recording, a new segment is chosen to write into (write_segment)
PLAYBACK:
The playback section is continuously playing a segment (play_segment)
Playback includes additional calculations,
to ensure the sub-sample phase offset is used and retained between segments
When the segment playback is done (possibly after several repeats),
a new segment is selected according to the current strategy (play_mode)
Graham Wakefield 2012
// the segment storage (each segment on its own channel):
Data segment_data(10004, 64);
// the length of each segment (in samples):
Data length_data(64, 1);
// each segment is also offset slightly (sub-sample phase delay):
Data offset_data(64, 1);
// each segment also stores it's average energy (root-mean square):
Data rms_data(64, 1);
// set to zero to disable new segment capture:
Param capture(1, min=0, max=1);
// how many zero crossings per segment:
Param crossings(1, min=1);
// the minimum & maximum length of a segment:
Param max_length(10000, min=16, max=10000);
Param min_length(100, min=16, max=10000);
// how many times a segment is played back:
Param repeats(1, min=1);
// hold the current playback segment:
Param hold(0, min=0, max=1);
// choose the strategy to play back grains:
Param playmode(0, min=0, max=4);
// choose how to select playback rates/pitches:
Param pitchedmode(0, min=0, max=4);
// playback frequency for pitchedmode enabled:
Param freq(220, min=0);
// playback rate for pitchedmode not enabled:
Param rate(1, min=0);
// the segment currently being written to:
History write_segment(1);
// the number of samples since the last capture:
History write_index(0);
// the number of rising zero-crossings since the last capture:
History crossing_count(0);
// the segment currently being played:
History play_segment(0);
// the sample index of playback:
History play_index(0);
// the length of the playing segment:
History play_len(0);
// the offset of the playing segment:
History play_offset(0);
// the loudness of the playing segment:
History play_rms(0.1);
// used to create smooth overlaps
History prev_input;
// used to accumulate the segment energy total:
History energy_sum;
// the total length of all segments
History total_length;
// the number of segments:
num_segments = channels(segment_data);
// RECORDING SECTION:
// DC blocking filter used to remove bias in the input:
unbiased_input = dcblock(in1);
// accumulate energy:
energy_sum = energy_sum + unbiased_input*unbiased_input;
// update write index:
write_index = write_index + 1;
// always write input into current segment:
poke(segment_data, unbiased_input, write_index, write_segment);
// detect rising zero-crossing:
is_crossing = change(unbiased_input > 0) > 0;
// capture behavior is triggered on the rising zero-crossing:
if (is_crossing) {
// if the segment is too long,
if (write_index > max_length) {
// reset the counters
crossing_count = 0;
write_index = 0;
// count rising zero-crossings in this segment:
crossing_count = crossing_count + 1;
// decide whether the segment is complete:
// only when capture is enabled
// only when enough zero-crossings have occurred
// only when enough samples have elapsed
// only when not too many samples have elapsed
is_complete = (capture
&& crossing_count >= crossings
&& write_index >= min_length);
if (is_complete) {
// at what theoretical sample index did it cross?
// estimate as linear intersection:
offset = prev_input / (prev_input - unbiased_input);
// compare the previous offset:
prev_offset = peek(offset_data, write_segment, 0);
// store segment length:
// adjusted for the fractional component
// minus one for the extra wrapping sample (a,b,...b,a,...,a,b)
len = write_index + offset - prev_offset - 1;
// update total length:
prev_length = peek(length_data, write_segment, 0);
total_length = total_length - prev_length + len;
// store new length:
poke(length_data, len, write_segment, 0);
// store segment energy:
// (root mean square, over number of samples measured)
rms = sqrt(energy_sum / floor(len));
poke(rms_data, rms, write_segment, 0);
// reset counters:
crossing_count = 0;
energy_sum = 0;
// switch to a new segment:
write_segment = wrap(write_segment + 1, 0, num_segments);
// don't write into what is currently playing:
if (write_segment == play_segment) {
// store the new offset:
poke(offset_data, offset, write_segment, 0);
// write the previous & current (a,b) into the new segment:
poke(segment_data, prev_input, 0, write_segment);
poke(segment_data, unbiased_input, 1, write_segment);
write_index = 1;
// remember previous input:
prev_input = unbiased_input;
// PLAYBACK SECTION:
r = rate;
// update playback index:
if (pitchedmode < 1) {
// no change
} else if (pitchedmode < 2) {
// ascending:
d = play_index / play_len;
r = rate * max(1, d);
} else if (pitchedmode < 3) {
// descending:
d = ceil(play_index / play_len);
r = rate / max(1, d*d);
// try to play back at a chosen frequency
// (compensating for estimated original sample frequency)
r = freq * play_len / (samplerate * crossings);
play_index = play_index + r;
// actual play index needs to stay within len:
// (can be fun to use wrap, fold or clip here)
actual_play_index = wrap(play_index, 0, play_len);
// play the current segment waveform:
// (offset by the waveform zero-crossing position)
out1 = peek(segment_data, play_offset + actual_play_index, play_segment, interp="linear");
// switch to a new segment?
if (play_index >= play_len * floor(repeats)) {
// reset to the current actual play position
play_index = actual_play_index;
if (!hold) {
// move to a new segment
// some alternatives...
if (playmode < 1) {
// play in forward sequence
play_segment = wrap(play_segment + 1, 0, num_segments);
// caveat: don't play what is currently being written:
play_segment = wrap(write_segment + 1, 0, num_segments);
} else if (playmode < 2) {
// play in reverse sequence
play_segment = wrap(play_segment - 1, 0, num_segments);
play_segment = wrap(write_segment - 1, 0, num_segments);
} else if (playmode < 3) {
// choose direction by random walk:
direction = sign(noise());
play_segment = wrap(play_segment + direction, 0, num_segments);
play_segment = wrap(write_segment + direction, 0, num_segments);
} else if (playmode < 4) {
// choose randomly:
direction = 1 + ceil(num_segments * (noise() + 1)/2);
// play most recently recorded:
// get the new playback length
play_len = peek(length_data, play_segment, 0);
// get the new playback offset
play_offset = peek(offset_data, play_segment, 0);
// and the new playback loudness
play_rms = peek(rms_data, play_segment, 0);
// show what's actually happening:
out2 = write_segment;
out3 = play_segment;
out4 = play_len;
out5 = play_index / play_len;
out6 = play_rms;
out7 = total_length;
