Page 6 of 6 FirstFirst ... 4 5 6
Results 126 to 140 of 140
Thread: Limits of delay effect in audio library
  1. #126
    Senior Member h4yn0nnym0u5e's Avatar
    Apr 2021
    Cambridgeshire, UK
    628
    Excellent news, glad we got it sorted out. It’s prompted me to improve the documentation for the PR branch (it shows up in the Design Tool), so once it’s in, things should be a bit easier for everyone.
  2. #127
    Dec 2022
    6
    Hi everyone, I would like to extend RAM on the Teensy 4.1 to make a four channel looper.
    I would like to make a new version of Frank's board for the APS6404L-3SQR-SN 8MB SPI memory chip with 8 chips on it.
    I am currently using Paul's CS42448_T4_TEST2 board.
    https://oshpark.com/shared_projects/gVFy0fWQ
    Looking at Frank's memoryboard4,
    https://oshpark.com/shared_projects/KZt5PaU7
    it looks like these two boards can be stacked, with Frank's board using pin 7 for MOSI and pin 12 for MISO on the Teensy 4.1. I guess this is possible since I think someone earlier in this thread tried it. If so, it seems to me the new board should use the same SPI pins to minimize confusion.
    To use eight memory chips, all eight outputs of the 74LCX138 need to be used. This brings up the question why Frank put the 74LCX126 on memoryboard4. Can/should it be removed to allow two more memory chips on a new board?
    Doug
  3. #128
    Feb 2018
    Corvallis, OR
    434
    While I have little experience with the audio capabilities of the T4.1, this thread does raise some interesting questions about memory management. The one that intrigues me the most is whether it would be possible to use a file on the SD card of the T4.1 to hold the audio data for later playback. With a bit of care with buffer management, it should be possible to pipe several channels of audio to the SD card for later retrieval as the echo output.
    A key question is whether a single file can be open for writing by one process and open for reading at a different location by another process (Like a Linux pipe??). If that is not possible you would need to alternate between two files, one for reading and one for writing. At appropriate times, the files would switch (easier said than done, I suppose!)
  4. #129
    Dec 2022
    6
    Hi everyone, here is the first draft of the Teensy 4.1 memory board with eight SPI memory chips.
    The MOSI and MISO connections are different than Frank's Teensy 3.x version, which seems to me to be necessary for the 4.1
    I removed the 74LCX126 buffer to obtain all eight output pins on the 74LCX138. I am not sure why the buffer is there.
    I didn't add the pulldown resistors on the digital pins DO2, 3 and 4, but perhaps I should. Is there a memory corruption concern on power up? Perhaps pulldowns are just best practice here?
    Comments and critiques welcome. My aim is to piggy back this onto Paul's CS42448_T4_TEST2 board.
    https://oshpark.com/shared_projects/gVFy0fWQ and record four channels of audio.
    I am new here. Should this be a new thread?
    Thanks,
    Doug
  5. #130
    Apr 2021
    Cambridgeshire, UK
    628
    Frank is still around, as mcu32 - maybe he’ll pipe up?
    If I were you I’d try to track for fitting pull-downs (you don’t have to fit them), and maybe some links to change the device selection lines from D2 to D4 to other pins.
    If you make enough boards I’d be interested to test one and add support to the library.
  6. #131
    Dec 2022
    6
    Okay thank you!
    I added locations for the pulldowns.
    Can you please clarify "links to change the device selection lines." Is this just a naming thing, like I should use C0/C1/C2 instead of DO2/DO3/DO4? If so, I agree. Or are you talking about moving to different pins altogether?
    Once this comes together, I will post on github and run a few copies with Osh Park.
  7. #132
    Apr 2021
    Cambridgeshire, UK
    628
    Quote Originally Posted by dougcl View Post
    I was thinking in terms of having the option to use different pins as chip select. D2-4 are also I2S2, so might well be wanted for an audio project. There aren’t many pins on a Teensy 4.0 that can’t be used for some audio function or another, but a 4.1 gives a few more options.
    Please let me know when you’re ready to run and the likely cost of a board or two, plus shipping to the UK. I can populate them myself, bare PCB is fine.
  8. #133
    Dec 2022
    6
    Okay here is the github project. Osh Park link within. I am running 12 of these. I'll let you know when they are ready.
    https://github.com/studiohsoftware/Teensy41Memory
  9. #134
    Apr 2021
    Cambridgeshire, UK
    628
    Great, thanks. One point that’s just occurred to me … as it is there’s always one PSRAM enabled, so the SPI bus can’t be used for anything else. That wasn’t an issue with only 6 of them, of course, as there are a couple of unused addresses.
  10. #135
    Dec 2022
    6
    The 74LCX138 has three pins E1,E2,E3 to enable/disable it so that more memory can be added to the same SPI bus. I did not bring them out to the board pins though. It's easy to do in the next rev, but it would consume more digital I/O.
  11. #136
    Dec 2022
    6
    Quote Originally Posted by h4yn0nnym0u5e View Post
    It turns out that all the CS lines must be able to go high because leaving one low by default corrupts the memory on that chip. I have broken out pin 4 on the 74LCX138 to Teensy 4.1 pin 5. Setting this HIGH sends all the CS lines high.
    It appears I am able to run this board successfully at 60MHz SPI clock, although maybe I am jumping to desired conclusions.
    Project has been updated to R1 on github and OSH Park.
  12. #137
    Apr 2021
    Cambridgeshire, UK
    628
    Curious, you’d think that so long as there’s no other code using the SPI bus it’d be OK (if slightly grubby) to leave a CS low.
    I think Paul S would mutter about stability over temperature and voltage extremes, but if 60MHz works for you, go for it!
  13. #138
    Feb 2018
    Corvallis, OR
    434
    I’ve just finished a test of a very long audio delay program that uses the T4.1 SD Card as buffer memory for a 105MB circular buffer. With 44.1KHz stereo input, this buffer allows delays up to about 10 minutes. It does require a bit of a hardware investment: a 128MB SanDisk ultra micro SD card which costs about $16.
    To test the delay software, I collected stereo input from the SGTL5000 line in input from music playing through the headphone output of an iPad. When I monitored the output with a pair of Sony headphones, the Beethoven symphony came through loud and clear. However, I may have missed a few glitches, as I was reading through the source code for the delay functions in the audio library. I let the music play and monitored it for about two hours. This is important, as the SD-card file serving as the extended buffer of 105.7MB (good for delays up to 10 minutes) was cycled through several times. After the first cycle through the buffer, the zeroed blocks from the initialization have been overwritten one or more times. This caused the maximum block write time to rise from about 20mSec to about 37 mSec. as the reused blocks had to be erased or swapped for other blocks. (The primary (pre-SD card) RAM buffers are good for about 80mSec of buffering during SD Writes.)
    I’ve attached the code for the demo (211 lines) and the semi-generic CircrBuff_SD (~380 lines) as a zip file. the CircBuff_SD class can be easily adapted to other applications (such as transient loggers). My tests were run with the T4.1 CPU clock at 150MHz, so I think there are plenty of CPU cycles left for more complex operations if you boost the clock rate.
    At this point, this software is a solution looking for a problem. Here are the questions I have:
    1. What are the usage scenarios for very long audio delays?
    2. What other applications might benefit from 10 to 100 minutes of circular buffer storage? I’ll be asking some friends in the oceanographic data collection business the same question. Perhaps they have a problem looking for a solution. I think they may have lots of problems looking for solutions—umm, let me rephrase that: “They may have lots of research opportunities looking for solutions.”
    2. Is this software worth the effort to convert to an audio-specialized library? I’ve looked over the source code for audioDelay_extmem, and it doesn’t seem that I would have to spend too much time building a shell around the generic Circ_buff_SD class to become compatible with the audio library conventions.
    Del10Minute_linein_CBSD.zip
  14. #139
    Nov 2014
    10
    The 74LCX126 is for level shifting, because Teensy3 is 5V, the memory chips are not. It's not needed for Teensy4.
    I am building a memory expansion board that's shorter so it fits on Teensy 4.0 footprint (also 4.1 of course) and has (6) 23LC1024 chips. It uses the same memory addressing scheme as the original Teensy 3 Memoryboard so hopefully it'll be recognized by the libraries.
  15. #140
    Apr 2021
    Cambridgeshire, UK
    628
    Quote Originally Posted by tigercat View Post
    I did wonder about that part…
    I have a PR that nearly got merged (https://github.com/PaulStoffregen/Audio/pull/433), before Paul got distracted, which allows use of a PSRAM instead of a single 23LC1024, giving 95s delay. Easier than a custom board, unless you have a compelling reason to build one anyway!
