Page 6 of 6 FirstFirst ... 4 5 6
Results 126 to 132 of 132
Thread: Dual channel 16bit dac PT8211
  1. #126
    I am having trouble getting hold of this chip reliably. It seems perfect for my use though - package, functionality, size, price. Any similar alternatives that someone can recommend please?
  2. #127
    Feb 2014
    Colmar, France
    1,624
    I read somewhere that this chip is becoming obsolete soon (or is already) and should not be used for new developments.
  3. #128
    Senior Member bmillier's Avatar
    Apr 2016
    Halifax, N.S. Canada
    130
    I have not found any other audio DACs in SOIC8 and DIP8 that are cheap, run on 3.3V, work with PJRC audio library and are still available- if those are the features you are looking for.
    I bought a batch of 10 from a Chinese vendor on eBay a few months back for about $5 as I recall. I only needed 1 at the time, and it worked fine when I wired it up. That was before I found out the Paul at PJRC sells them in a kit with PCB and a few passive parts for about $5. I would have gone that route had I known. Unless you need large quantities, PJRC is the way to go.
  4. #129
    Quote Originally Posted by alialiali View Post
    Try eBay: "35 results for PT8211"
  5. #130
    6,435
    https://www.pjrc.com/store/pt8211_kit.html :: looks like $2.65 for chip with PCB and connection parts
  6. #131
    Thanks, I ordered the chip from ebay/china. My worry is that it won't be available in 1000s. But if I ever sell 1000 units, I guess I'll be happy to have that problem. Since my device is primarily MIDI, and the audio output is just on board for monitoring when not connected to a real synth, I guess I can fall back to the built-in DAC.
  7. #132
    17,595
    The chip is so cheap, you could probably just buy 1000 of them anytime. Just store in a sealed bag, maybe with a desiccant pack to keep any moisture from causing long-term storage issues.
