Results 1 to 5 of 5
Thread: Extending USB to external connector
    139
    I've got a design that doesn't allow access to the onboard micro USB but has a micro USB connector on the motherboard that the Teensy 3.1 is soldered to.
    This thread demonstrates how I could extend the USB:
    https://forum.pjrc.com/threads/19336...-USB-connector
    So I was thinking small jumper wires from the Teensy USB pads to the PCB directly under them. Then PCB traces, about 6" in length, to the connector. I don't have the room to put a PCB mounted micro USB plug into the Teensy.
    What I'd like to hear are the downfalls of this; am I likely to run into issues with noise & impedance? How can I increase my chance of success? I'm intending to use a 2 layer PCB.
    Has anyone done this?
    Feb 2013
    179
    Depending on the final goals for this project (are you planning to sell it? as a kit or a 'finished device'?) you might be fine and it might be terrible.
    USB can be finicky - if you do use jumper wires from the pads, make sure they're all *Exactly* (or very, very close) to the same length. USB is a differential (I think that's the right word) serial connection - it sends the signal on one trace, and the inverse of that signal on the other, for noise reduction reasons. If the two signal traces are different lengths, you can get mismatched signals and nothing will work (the positive and negative signals get out of sync with each other).
    Every USB application note and design doc I've seen (which, granted, is not that many) has said a 4-layer board is a minimum requirement, with the layer closest to the USB traces being a ground plane. Again, those neg/pos signals can be affected by a lot of weird stuff, and anything that knocks one of those traces around (strange board capacitance, crosstalk, etc) can render the USB signal useless. Also, make sure you USB signal traces on the board are the exact same length, follow the same path, and are the same distance from each other at all times - avoid vias if at all possible (USB signal traces should be as straight a shot as you can make them).
    If you're planning to sell this as a finished product, and you're in the US/Canada/UK, you'll most likely need to do an FCC declaration of conformity - which involves some very specific tests with a radio antenna and a very nice oscilloscope (IE, you'll need to take it to an RF test lab, unless you happen to have about $50k of test equipment laying around). For the UK (CE cert) you'll also need to do immunity testing, which is where they fire radio noise and frequencies at your device to see if it breaks. I mention all this because USB is noisy as hell, and you'll likely see loud peaks at 12, 24, 48, 96, 480, and 960MHz (and probably more in between), if you're not VERY careful about the EMC design of your board. I had to use a common mode choke on the data signals to clean out some USB noise from my device - which is already a 6 layer board with good ground planes, decoupling, and a grounded chassis acting as a faraday cage. USB is noisy as hell.
    Keep the USB traces far, far away from any crystals or anything else that would have a 'loud' oscillating frequency - ESPECIALLY a frequency near the USB rates (12Mhz and multiples thereof). Avoid anything running parallel to the USB lines on other layers. Keep the USB traces as short as possible.
    If I think of anything else I'll pop my head back in. Honestly if it's just a one-off thing, the simplest solution is to find a USB cable that you can plug in, because they're (hopefully) shielded and all the wires are the same length. If you're planning to make a lot of them, and have a bunch of other SMD components that'll need to be machine placed anyway, it can be better to just build the teensy onto the board itself as a custom design, buying the bootloader chips from Paul.
    Aug 2013
    Gothenburg, Sweden
    295
    Yes careful cabling and trace layout is important, but I have installed any number of USB brackets sending the USB signals from the proper USB connector through a 5 to 10 inch cable to a pin header on the motherboard. And these have in general worked quite well, so it cannot be that impossible.
    139
    Quote Originally Posted by MuShoo View Post
    Thank you very much for this really informative response, you've given me a lot to think about. It wasn't my intention to turn my project into a product but I'm not excluding this possibility.
    I think for the prototypes, at least, it might be better to solder a shielded cable onto the teensy and glue it to my PCB along the 6" length to the other socket.
    (In terms of number of soldering operations - very little difference between jumper wires and a full length shielded cable)
    21,473
    For a one-off project, I wouldn't worry too much about the minor details. 12 Mbit/sec USB is pretty easy. Just make sure you keep the 2 data wires and ground running together.
    For course, for something you're going to mass produce and sell, careful design is a good idea. But if you're looking to solder a Teensy onto your own PCB that's large enough for 6 inch traces... I'm guessing this isn't something you're planning to mass produce?
