How to wire reset switch
doughboy
According to the schematic, the reset line is just floating.
If I want to connect a pushbutton switch, do I just add a switch to ground? No pullup or anything?
tnx
Yes, just the momentary pushbutton connection to ground is all you need to add to have 'reset' functionality in your project.
by memory the bootloader chip is using an internal pull-up on the reset line but this memory is probably flawed - doesn't matter either way, in the overall design something is pulling it up.
