I have been writing a program and at the same time am wondering about whether I will need to speed it up with fixed point or other things. To test the speed of some specific functions I created a little program to perform the timing of some of the operations. The results show that integer multiplies are about as fast as integer adds and subtracts. Floating point operations take longer as expected. Float and double variables also take the same time as expected, as I understand they are both 32 bit numbers on the teensy. My program does do some trig operations so I implemented a lookup table for the sine function and used it for cosine and tangent as well. Surprisingly it is slower it down by a factor of 4 as compared to the built-in sine function. However a rational approximation for the arctangent function was significantly faster but not as accurate. I looked at my code and did some hand optimization in the source file, and was surprised that using brackets to eliminate dividing by constants improved the speed. I thought compiler optimization would take care of easy things like that.
Any comments on why the lookup table is soooo slow.
The calling program is: (I hope I posted this correctly)
with the header file:
and the table lookup file that I called sinCosTanTable, the table values are more precise than required, but I assume that there will not be a hit in performance for that.
#include "debug.h"
int n, time1, dummy;
float floaty;
byte timerNumber = 10;
delay(800); // wait for above command to finish, 500 gives intermittant operation
Serial.print("Starting Timer ");
Serial.println(timerNumber);
time1 = micros();
for(n=0; n<1000; n++)
dummy = 5 + n;
Serial.print("Addition Time ");
Serial.println(micros() - time1);
time1 = micros();
dummy = 5 - n;
Serial.print("Subtraction Time ");
time1 = micros();
dummy = 5 * n;
Serial.print("Integer Multiply Time ");
time1 = micros();
floaty = 5.0 * (float) n;
Serial.print("Float Multiply Time ");
time1 = micros();
floaty = 5.0 / (float) n;
Serial.print("Float Divide Time ");
time1 = micros();
floaty = sin((float) n/ 100);
Serial.print("Sine Evaluation Time ");
time1 = micros();
floaty = sint((float) n/ 100); Serial.print("Sin Table Lookup Time ");
time1 = micros();
floaty = atan((float) n/ 100);
Serial.print("Arctangent Time ");
time1 = micros();
floaty = atanb((float) n/ 100);
Serial.print("Rational Approximation B Arctangent Time ");
time1 = micros();
floaty = atanc((float) n/ 100);
Serial.print("Rational Approximation C Arctangent Time ");
// #include <Arduino.h>
// table lookup and rational approximation of trig functions
double interpolate(double x, double x1, double y1, double x2, double y2);
double sinTableBasic(double x);
double sint(double x);
double cost(double x);
double tant(double x);
double atana(double x);
double atanb(double x);
double atanc(double x);
double atana2(double y, double x);
//#include <stdio.h>
//#include <stdarg.h>
//#include <Arduino.h>
//#include <stdlib.h>
#include <math.h>
#include "debug.h"
#define PI M_PI
#define N 1024
// function to perform a linear interpolation of values
double interpolate(double x, double x1, double y1, double x2, double y2) {
return(y1 + (x - x1)/(x2 - x1) * (y2 - y1));
// Sin lookup table valid from 0 <= x <= PI/2
// Values generated from transcendentalFunctionGenerator.m
double sinTableBasic(double x) {
double sinTable[(int) N + 1] = {
0,0.001533980186285,0.003067956762966,0.004601926120449,0.006135884649154,0.007669828739531,0.00920375478206,0.01073765916726,
0.01227153828572,0.01380538852806,0.01533920628499,0.01687298794728,0.0184067299058,0.01994042855151,0.02147408027547,0.02300768146884,
0.02454122852291,0.0260747178291,0.02760814577897,0.02914150876419,0.03067480317664,0.0322080254083,0.03374117185138,0.03527423889821,
0.03680722294136,0.03834012037355,0.03987292758774,0.04140564097708,0.04293825693494,0.04447077185494,0.04600318213091,0.04753548415696,
0.04906767432742,0.0505997490369,0.05213170468028,0.05366353765273,0.05519524434969,0.05672682116691,0.05825826450044,0.05978957074664,
0.06132073630221,0.06285175756416,0.06438263092986, 0.065913352797,0.06744391956366,0.06897432762827,0.07050457338961,0.07203465324689,
0.07356456359967,0.07509430084792,0.07662386139203,0.07815324163279,0.07968243797143,0.08121144680959,0.08274026454938,0.08426888759332,
0.08579731234444,0.08732553520619,0.08885355258252,0.09038136087786,0.09190895649713,0.09343633584575,0.09496349532964,0.09649043135525,
0.09801714032956,0.09954361866007,0.1010698627548,0.1025958690224,0.1041216338721,0.1056471537134,0.1071724249568,0.1086974440131,
0.1102222072939,0.1117467112111,0.1132709521776,0.1147949266065,0.1163186309119,0.1178420615083, 0.119365214811,0.1208880872358,
0.1224106751992,0.1239329751185,0.1254549834115,0.1269766964969,0.1284981107938,0.1300192227222,0.1315400287029,0.1330605251571,
0.1345807085071,0.1361005751757,0.1376201215865,0.1391393441638,0.1406582393328,0.1421768035194,0.1436950331503,0.1452129246528,
0.1467304744554,0.1482476789869,0.1497645346773,0.1512810379573,0.1527971852584, 0.154312973013,0.1558283976543,0.1573434556162,
0.1588581433339,0.1603724572429,0.1618863937801, 0.163399949383, 0.16491312049,0.1664259035405,0.1679382949747, 0.169450291234,
0.1709618887603,0.1724730839968,0.1739838733875,0.1754942533773,0.1770042204121, 0.178513770939,0.1800229014057,0.1815316082611,
0.1830398879551,0.1845477369386,0.1860551516634,0.1875621285825,0.1890686641498,0.1905747548203,0.1920803970499,0.1935855872958,
0.1950903220161,0.1965945976701, 0.198098410718,0.1996017576211,0.2011046348421,0.2026070388444,0.2041089660928,0.2056104130531,
0.2071113761922,0.2086118519783,0.2101118368805,0.2116113273692,0.2131103199161,0.2146088109938,0.2161067970762,0.2176042746385,
0.2191012401569,0.2205976901089,0.2220936209732,0.2235890292298,0.2250839113598,0.2265782638456,0.2280720831709,0.2295653658205,
0.2310581082807,0.2325503070388,0.2340419585835, 0.235533059405,0.2370236059944,0.2385135948443,0.2400030224487,0.2414918853029,
0.2429801799033,0.2444679027478,0.2459550503358,0.2474416191678,0.2489276057457, 0.250413006573,0.2518978181542,0.2533820369956,
0.2548656596045,0.2563486824899,0.2578311021622,0.2593129151329,0.2607941179153,0.2622747070239,0.2637546789748,0.2652340302855,
0.2667127574749,0.2681908570634,0.2696683255729,0.2711451595268,0.2726213554499,0.2740969098687, 0.275571819311,0.2770460803061,
0.2785196893851,0.2799926430803,0.2814649379258,0.2829365704571,0.2844075372113,0.2858778347271,0.2873474595447, 0.288816408206,
0.2902846772545, 0.291752263235,0.2932191626943,0.2946853721805,0.2961508882436,0.2976157074351, 0.299079826308,0.3005432414173,
0.3020059493192, 0.303467946572,0.3049292297354,0.3063897953709,0.3078496400415,0.3093087603123,0.3107671527496,0.3122248139218,
0.3136817403989,0.3151379287525,0.3165933755562, 0.318048077385, 0.319502030816,0.3209552324279,0.3224076788011,0.3238593665179,
0.3253102921623,0.3267604523201,0.3282098435791,0.3296584625286,0.3311063057599, 0.332553369866, 0.333999651442,0.3354451470845,
0.3368898533922,0.3383337669655,0.3397768844068,0.3412192023203, 0.342660717312,0.3441014259899, 0.345541324964,0.3469804108459,
0.3484186802494,0.3498561297901,0.3512927560856,0.3527285557552,0.3541635254205,0.3555976617048,0.3570309612334,0.3584634206337,
0.359895036535,0.3613258055685,0.3627557243674,0.3641847895671,0.3656129978048,0.3670403457198,0.3684668299534,0.3698924471489,
0.3713171939518,0.3727410670095,0.3741640629715,0.3755861784892,0.3770074102164,0.3784277548088,0.3798472089241,0.3812657692222,
0.3826834323651,0.3841001950169,0.3855160538439,0.3869310055144,0.3883450466988,0.3897581740699,0.3911703843023, 0.392581674073,
0.393992040061,0.3954014789478,0.3968099874167,0.3982175621534,0.3996241998456,0.4010298971836,0.4024346508594,0.4038384575677,
0.405241314005,0.4066432168704, 0.408044162865,0.4094441486923,0.4108431710579,0.4122412266699,0.4136383122384,0.4150344244761,
0.4164295600976,0.4178237158202,0.4192168883632,0.4206090744484,0.4220002707998,0.4233904741438,0.4247796812091,0.4261678887268,
0.4275550934303,0.4289412920553,0.4303264813401,0.4317106580251,0.4330938188532,0.4344759605697,0.4358570799223, 0.437237173661,
0.4386162385385,0.4399942713096,0.4413712687317,0.4427472275646,0.4441221445704, 0.445496016514,0.4468688401624,0.4482406122852,
0.4496113296546,0.4509809890451,0.4523495872338,0.4537171210002,0.4550835871263,0.4564489823969,0.4578133035989,0.4591765475219,
0.4605387109582,0.4618997907025,0.4632597835519,0.4646186863062, 0.465976495768, 0.467333208742,0.4686888220358,0.4700433324596,
0.471396736826,0.4727490319503,0.4741002146505,0.4754502817472,0.4767992300633,0.4781470564248,0.4794937576602,0.4808393306003,
0.4821837720791,0.4835270789329,0.4848692480008,0.4862102761245,0.4875501601484,0.4888888969198,0.4902264832883,0.4915629161065,
0.4928981922298, 0.494232308516,0.4955652618258,0.4968970490227,0.4982276669728,0.4995571125451,0.5008853826112,0.5022124740457,
0.5035383837257,0.5048631085313,0.5061866453452, 0.507508991053,0.5088301425431,0.5101500967068, 0.511468850438,0.5127864006336,
0.5141027441932,0.5154178780195,0.5167317990176, 0.518044504096,0.5193559901656,0.5206662541404,0.5219752929372,0.5232831034757,
0.5245896826785,0.5258950274711,0.5271991347819,0.5285020015422,0.5298036246863,0.5311040011513,0.5324031278772,0.5337010018072,
0.5349976198871, 0.536292979066,0.5375870762956, 0.538879908531,0.5401714727299,0.5414617658531,0.5427507848645,0.5440385267309,
0.545324988422,0.5466101669108,0.5478940591731,0.5491766621877,0.5504579729366,0.5517379884047, 0.55301670558,0.5542941214536,
0.5555702330196,0.5568450372752,0.5581185312206,0.5593907118591,0.5606615761973,0.5619311212447,0.5631993440138,0.5644662415205,
0.5657318107836,0.5669960488251,0.5682589526701,0.5695205193469, 0.570780745887,0.5720396293248, 0.573297166698,0.5745533550477,
0.5758081914178,0.5770616728557,0.5783137964117,0.5795645591394,0.5808139580958,0.5820619903408,0.5833086529377, 0.584553942953,
0.5857978574564,0.5870403935209,0.5882815482226,0.5895213186411,0.5907597018589, 0.591996694962,0.5932322950398,0.5944664991847,
0.5956993044924,0.5969307080622,0.5981607069963,0.5993892984006,0.6006164793839,0.6018422470586,0.6030665985403,0.6042895309482,
0.6055110414043,0.6067311270345,0.6079497849678,0.6091670123365,0.6103828062763,0.6115971639265,0.6128100824294, 0.614021558931,
0.6152315905806,0.6164401745309,0.6176473079378, 0.618852987961,0.6200572117633,0.6212599765111,0.6224612793741,0.6236611175257,
0.6248594881424,0.6260563884043,0.6272518154951,0.6284457666018,0.6296382389149,0.6308292296284,0.6320187359398,0.6332067550501,
0.6343932841636,0.6355783204886,0.6367618612363,0.6379439036218,0.6391244448638,0.6403034821842,0.6414810128086,0.6426570339662,
0.6438315428898,0.6450045368155,0.6461760129833,0.6473459686365,0.6485144010221,0.6496813073907,0.6508466849964, 0.652010531097,
0.6531728429538,0.6543336178318,0.6554928529996,0.6566505457294,0.6578066932971, 0.658961292982,0.6601143420674, 0.66126583784,
0.6624157775902, 0.663564158612,0.6647109782033,0.6658562336655,0.6669999223036,0.6681420414265,0.6692825883466,0.6704215603802,
0.671558954847,0.6726947690708,0.6738290003788, 0.674961646102,0.6760927035753,0.6772221701372,0.6783500431299,0.6794763198994,
0.6806009977955,0.6817240741716,0.6828455463852,0.6839654117973,0.6850836677727, 0.68620031168,0.6873153408918,0.6884287527841,
0.6895405447371,0.6906507141345,0.6917592583642,0.6928661748174,0.6939714608897, 0.69507511398,0.6961771314915,0.6972775108309,
0.698376249409,0.6994733446403,0.7005687939432,0.7016625947402,0.7027547444572,0.7038452405245,0.7049340803759,0.7060212614493,
0.7071067811865,0.7081906370332,0.7092728264389,0.7103533468571,0.7114321957452,0.7125093705647,0.7135848687808,0.7146586878628,
0.7157308252838,0.7168012785211,0.7178700450557,0.7189371223728,0.7200025079614,0.7210661993145,0.7221281939292,0.7231884893065,
0.7242470829515,0.7253039723731,0.7263591550843,0.7274126286024,0.7284643904482, 0.729514438147,0.7305627692278,0.7316093812239,
0.7326542716724,0.7336974381147, 0.734738878096,0.7357785891657,0.7368165688774,0.7378528147885,0.7388873244606,0.7399200954595,
0.740951125355,0.7419804117208,0.7430079521351,0.7440337441799,0.7450577854415,0.7460800735101,0.7471006059802,0.7481193804504,
0.7491363945235,0.7501516458062,0.7511651319097, 0.752176850449,0.7531867990436,0.7541949753169,0.7552013768965,0.7562060014144,
0.7572088465065, 0.758209909813,0.7592091889784,0.7602066816512,0.7612023854843,0.7621962981346,0.7631884172634,0.7641787405361,
0.7651672656225,0.7661539901963,0.7671389119358,0.7681220285234,0.7691033376456,0.7700828369933,0.7710605242618,0.7720363971504,
0.7730104533627,0.7739826906068,0.7749531065949,0.7759216990434,0.7768884656732,0.7778534042095,0.7788165123815, 0.779777787923,
0.7807372285721,0.7816948320711,0.7826505961666,0.7836045186096,0.7845565971556,0.7855068295641,0.7864552135991, 0.787401747029,
0.7883464276266,0.7892892531689,0.7902302214373,0.7911693302177,0.7921065773002,0.7930419604794,0.7939754775543,0.7949071263282,
0.7958369046089,0.7967648102084,0.7976908409434,0.7986149946348,0.7995372691079,0.8004576621926,0.8013761717231,0.8022927955381,
0.8032075314806,0.8041203773983, 0.805031331143,0.8059403905712,0.8068475535438,0.8077528179262,0.8086561815882,0.8095576424041,
0.8104571982526,0.8113548470171,0.8122505865852,0.8131444148493,0.8140363297059,0.8149263290565,0.8158144108067,0.8167005728668,
0.8175848131516,0.8184671295803,0.8193475200768,0.8202259825694,0.8211025149911,0.8219771152792,0.8228497813758,0.8237205112274,
0.824589302785,0.8254561540044,0.8263210628457,0.8271840272737,0.8280450452578,0.8289041147719,0.8297612337945,0.8306164003088,
0.8314696123025,0.8323208677679,0.8331701647019, 0.834017501106,0.8348628749864,0.8357062843538,0.8365477272235,0.8373872016157,
0.8382247055548,0.8390602370703, 0.839893794196,0.8407253749705,0.8415549774369,0.8423825996432,0.8432082396418,0.8440318954901,
0.8448535652497,0.8456732469873,0.8464909387741,0.8473066386859,0.8481203448033,0.8489320552116,0.8497417680009,0.8505494812656,
0.8513551931053,0.8521589016239,0.8529606049304,0.8537603011381,0.8545579883654,0.8553536647352,0.8561473283752,0.8569389774178,
0.8577286100003,0.8585162242644, 0.859301818357,0.8600853904294,0.8608669386378,0.8616464611431, 0.862423956111,0.8631994217121,
0.8639728561216,0.8647442575195,0.8655136240906,0.8662809540245,0.8670462455157,0.8678094967633,0.8685707059713,0.8693298713486,
0.8700869911087,0.8708420634701, 0.871595086656,0.8723460588944,0.8730949784183,0.8738418434654,0.8745866522782,0.8753294031041,
0.8760700941954,0.8768087238091,0.8775452902073,0.8782797916565,0.8790122264286, 0.8797425928,0.8804708890522,0.8811971134712,
0.8819212643484,0.8826433399796,0.8833633386657,0.8840812587126,0.8847970984309,0.8855108561362,0.8862225301489,0.8869321187943,
0.8876396204029,0.8883450333096,0.8890483558547,0.8897495863831,0.8904487232448,0.8911457647946,0.8918407093923,0.8925335554028,
0.8932243011955,0.8939129451452,0.8945994856314,0.8952839210386,0.8959662497562,0.8966464701787,0.8973245807054,0.8980005797407,
0.898674465694,0.8993462369793,0.9000158920162,0.9006834292286, 0.901348847046,0.9020121439025,0.9026733182373,0.9033323684945,
0.9039892931234,0.9046440905782,0.9052967593181,0.9059472978073,0.9065957045149,0.9072419779153,0.9078861164877,0.9085281187163,
0.9091679830905,0.9098057081047,0.9104412922581,0.9110747340552,0.9117060320054,0.9123351846233,0.9129621904284,0.9135870479453,
0.9142097557035,0.9148303122379,0.9154487160883,0.9160649657993, 0.916679059921,0.9172909970084,0.9179007756214,0.9185083943252,
0.9191138516901,0.9197171462912,0.9203182767091,0.9209172415292, 0.921514039342,0.9221086687433,0.9227011283339,0.9232914167195,
0.9238795325113,0.9244654743253,0.9250492407827,0.9256308305099,0.9262102421383,0.9267874743046,0.9273625256504,0.9279353948226,
0.9285060804732,0.9290745812593,0.9296408958432,0.9302050228922, 0.930766961079,0.9313267090812,0.9318842655817,0.9324396292685,
0.9329927988347,0.9335437729788,0.9340925504043,0.9346391298197,0.9351835099389,0.9357256894811,0.9362656671703,0.9368034417359,
0.9373390119126, 0.93787237644,0.9384035340631,0.9389324835321,0.9394592236022, 0.939983753034,0.9405060705933,0.9410261750509,
0.941544065183, 0.942059739771,0.9425731976014,0.9430844374661, 0.943593458162,0.9441002584913,0.9446048372615,0.9451071932853,
0.9456073253805,0.9461052323704,0.9466009130833,0.9470943663528,0.9475855910177,0.9480745859223,0.9485613499157,0.9490458818527,
0.949528180593,0.9500082450018,0.9504860739495,0.9509616663116, 0.951435020969,0.9519061368079,0.9523750127198,0.9528416476012,
0.9533060403542, 0.953768189886,0.9542280951091,0.9546857549413,0.9551411683058,0.9555943341308, 0.95604525135,0.9564939189024,
0.9569403357322, 0.957384500789,0.9578264130275, 0.958266071408,0.9587034748959,0.9591386224618, 0.959571513082,0.9600021457377,
0.9604305194156,0.9608566331077,0.9612804858113,0.9617020765291, 0.962121404269,0.9625384680444,0.9629532668737, 0.963365799781,
0.9637760657954,0.9641840639517,0.9645897932898,0.9649932528549,0.9653944416977,0.9657933588741,0.9661900034454,0.9665843744783,
0.9669764710449,0.9673662922223,0.9677538370935,0.9681391047464,0.9685220942744,0.9689028047764,0.9692812353565,0.9696573851243,
0.9700312531945,0.9704028386876, 0.970772140729,0.9711391584497,0.9715038909863,0.9718663374803,0.9722264970789,0.9725843689347,
0.9729399522056,0.9732932460547,0.9736442496508, 0.973992962168,0.9743393827856,0.9746835106885, 0.975025345067,0.9753648851167,
0.9757021300385, 0.976037079039, 0.97636973133,0.9767000861287,0.9770281426578,0.9773539001452,0.9776773578245,0.9779985149346,
0.9783173707196,0.9786339244294,0.9789481753191,0.9792601226491,0.9795697656854,0.9798771036995,0.9801821359681,0.9804848617735,
0.9807852804032,0.9810833911505,0.9813791933138, 0.981672686197,0.9819638691096,0.9822527413663,0.9825393022874,0.9828235511987,
0.9831054874312,0.9833851103216,0.9836624192117,0.9839374134492,0.9842100923869,0.9844804553832,0.9847485018019,0.9850142310122,
0.9852776423889,0.9855387353122,0.9857975091676,0.9860539633462,0.9863080972446,0.9865599102648,0.9868094018142,0.9870565713058,
0.9873014181579,0.9875439417944,0.9877841416446,0.9880220171433,0.9882575677307,0.9884907928527,0.9887216919603,0.9889502645103,
0.9891765099648,0.9894004277914,0.9896220174632,0.9898412784588,0.9900582102623,0.9902728123632,0.9904850842565,0.9906950254427,
0.9909026354278,0.9911079137233,0.9913108598461,0.9915114733187,0.9917097536691,0.9919057004306,0.9920993131422,0.9922905913483,
0.9924795345987,0.9926661424489,0.9928504144599,0.9930323501979,0.9932119492348,0.9933892111481,0.9935641355206,0.9937367219407,
0.9939069700024,0.9940748793049,0.9942404494532,0.9944036800577,0.9945645707343,0.9947231211043,0.9948793307948,0.9950331994381,
0.9951847266722,0.9953339121405,0.9954807554919, 0.995625256381,0.9957674144677,0.9959072294174,0.9960447009013,0.9961798285957,
0.9963126121828, 0.99644305135,0.9965711457906,0.9966968952029,0.9968202992912, 0.996941357765,0.9970600703395,0.9971764367353,
0.9972904566787,0.9974021299013,0.9975114561403,0.9976184351385,0.9977230666442,0.9978253504111,0.9979252861986,0.9980228737715,
0.9981181129001,0.9982110033605,0.9983015449339,0.9983897374073,0.9984755805733,0.9985590742298,0.9986402181803,0.9987190122339,
0.9987954562052,0.9988695499143,0.9989412931869,0.9990106858541,0.9990777277526,0.9991424187248,0.9992047586184,0.9992647472866,
0.9993223845883, 0.999377670388,0.9994306045555,0.9994811869662,0.9995294175011,0.9995752960467,0.9996188224952, 0.999659996744,
0.9996988186962,0.9997352882606,0.9997694053512,0.9998011698879,0.9998305817958,0.9998576410058,0.9998823474542,0.9999047010829,
0.9999247018391, 0.999942349676, 0.999957644552, 0.999970586431,0.9999811752826,0.9999894110819,0.9999952938096,0.9999988234517,
1};
int nlow = (int) (x * (2.0/PI) * (double) N);
double xtemp1 = PI/(2.0*N);
double x1 = (double) nlow * xtemp1;
double x2 = (double) (nlow + 1) * xtemp1;
double y1 = sinTable[nlow];
double y2 = sinTable[nlow+1];
double y = interpolate(x, x1, y1, x2, y2);
return(y);
double sint(double x) {
// put into range of 0 <x < 2*pi
double y;
double num = floor(x / (2.0*PI));
x = x - num * 2.0*PI;
if (x <= PI/2.0)
y = (sinTableBasic(x));
else if (x <= PI)
y = (sinTableBasic(PI - x));
else if (x <= 1.5*PI)
y = (-sinTableBasic(x - PI));
else //if (x <= 2.0*PI)
y = (-sinTableBasic(2.0*PI - x));
//else
//Serial.print("sin range error");
return(y);
double cost(double x) {
double y;
if (x <= PI/2.0)
y = (sinTableBasic(PI/2.0-x));
else if (x <= PI)
y = (-sinTableBasic(x - PI/2.0));
y = (-sinTableBasic(1.5*PI - x));
y = (sinTableBasic(x - 1.5*PI));
// else
// Serial.print("sin range error");
return(y);
double tant(double x) {
return(sint(x)/cost(x));
// Rational Approximation from Abramovitch & Stegun eq'n 4.4.48
// Error <= 5E-3 for -1 <= x <= 1
double atana(double x) {
return(x/(1 + 0.28*x*x));
// from the internet errorMax = 0.162 degrees, valid x >= 0 without if statement
double atanb(double x) {
double angle, B = 0.596227;
if (x < 0) {
x = -x;
angle = -(PI/2.0 * (B + x)*x / (1.0 + (2.0*B + x)*x));
angle = (PI/2.0 * (B + x)*x / (1.0 + (2.0*B + x)*x));
return(angle);
// from the internet errorMax = 0.00811 degree, valid x >= 0 without if statement
double atanc(double x) {
double angle, C = (1 + sqrt(17)) / 8.0;
if (x < 0) {
x = -x;
angle = -(PI/2.0 * (x*(C + x*(1.0 + x))) / (1 + x*((C +1) + x*((C+1) + x))));
angle = (PI/2.0 * (x*(C + x*(1.0 + x))) / (1 + x*((C +1) + x*((C+1) + x))));
//angle = (PI/2.0 * (x*(C + x*(1.0 + x))) / (1 + (C +1)*x + (C+1)*x*x + x*x*x));
return(angle);
// use the atanb approximation as a faster and accurate enough approximation
// returns a value between - Pi & PI
double atana2(double y, double x) {
double angle;
if (x==0.0)
angle = PI/2;
angle = atanb(y/x);
// printf("%9.6f ",angle);
if(x < 0 && y >= 0)
angle = PI + angle;
else if (x < 0 && y < 0)
angle = -PI + angle;
else if (x >= 0 && y < 0)
angle = angle;
else if (x >= 0 && y >= 0)
angle = angle;
//else
//Serial.print("Problems determining angle in atana2 function!");
return(angle);
// main is for testing purposes to confirm that the function is working correctly in a PC environment
int main(void) {
int i;
double x, y;
printf("x \t sint(x) \t sin(x) \t cost(x) \t cos(x) \t tant(x) \t tan(x) \t atana(x) \t atan(x)\n");
// testing sin, cos, tan functions
for (i=0; i<=100; i++) {
x = (double) i/25.0 -1.0;
printf("%9.6f\t%9.6f\t%9.6f\t%9.6f\t%9.6f\t%9.6f\t%9.6f\n",
x, sint(x), sin(x), cost(x), cos(x), tant(x), tan(x));
// testing the atan functions
x = (double) i/15.0 -3.0;
printf("%9.6f\t%9.6f\t%9.6f\t%9.6f\t%9.6f\n",
x, atan(x), atana(x), atanb(x), atanc(x));
// testing the atan2 function
for (x=-10; x< 20; x=x+2) {
for (y=-10; y < 25; y=y+2) {
printf("%9.6f\t%9.6f\t%9.6f\t%9.6f\n",
x, y, atan2(y,x), atana2(y,x));
return(0);
