At the CCC we took some time to play around with the Teensy3.1, an OctoWS2811 adapter, and a WIZ820io alongside with the Adapter sold at the pjrc shop.
Utilizing TCP we were able to drive 1k LED with insane frame rates, well above 100. The possible fading smoothness is just amazing.
We were also pondering to use the SD slot (which we could not try yet for the lack of a card), but I did find the time to do some research.
As it seems there is a potential double usage of pin 4.
Also, in the Octo code there is a reference to pin 3, but not in the documentation.
Both seem to be used internally to generate the actual output to the led stripe pins by pwm.
The SDReader code mentions pin 3 as necessary, but Electrical Connections asks for pin 4.
Can someone clarify this confusion?
This picture seems related:
Would it be feasable to move the pwm-pins of the octo to pin 25 and 32, because breaking them out would not do much good to anyone?
