Working Sketch not compiling on new computer - Arduino /Teensy 3.1
Mike_58
very cool video, thanks! Kb
I had to format my hard drive and after re-installation of all programs inclusive Arduino my sketch which was operational is now hanging - not compiling due to "class TS_Point" Adafruit_STMPE610.h and I am getting this errors:
enabled in File > Preferences.
Arduino: 1.0.6 + Td: 1.24 (Windows 7), Board: "Teensy 3.1"
In file included from Screensaver.h:8:0,
from PID_ReflowBtmpV10.ino:20:
C:\Users\MarjanHome\Documents\Arduino\libraries\Adafruit_STMPE610/Adafruit_STMPE610.h:116:7: error: redefinition of 'class TS_Point'
class TS_Point {
In file included from SplashScreen.h:8:0,
from PID_ReflowBtmpV10.ino:19:
C:\Users\MarjanHome\Documents\Arduino\libraries\Adafruit_STMPE610/Adafruit_STMPE610.h:116:7: error: previous definition of 'class TS_Point'
class TS_Point {
C:\Users\MarjanHome\Documents\Arduino\libraries\Adafruit_STMPE610/Adafruit_STMPE610.h:127:7: error: redefinition of 'class Adafruit_STMPE610'
class Adafruit_STMPE610{
C:\Users\MarjanHome\Documents\Arduino\libraries\Adafruit_STMPE610/Adafruit_STMPE610.h:127:7: error: previous definition of 'class Adafruit_STMPE610'
In file included from Button.h:8:0,
from PID_ReflowBtmpV10.ino:21:
class TS_Point {
class TS_Point {
In file included from Graph.h:8:0,
from PID_ReflowBtmpV10.ino:22:
class TS_Point {
class TS_Point {
In file included from PID_ReflowBtmpV10.ino:25:0:
class TS_Point {
class TS_Point {
Can someone give me a tip !?
Thanks,
Mike
Compile blink or some other sketches to make sure all is well with your install.
Open a new thread for this so your question doesn't get lost for you or others with a similar problem.
If you have a small code sample that reproduces the problem, post that in the new thread for your issue.
Note if you searched the forum fir similar issues.
C:\Users\MarjanHome\Documents\Arduino\libraries\Ad afruit_STMPE610/Adafruit_STMPE610.h:116:7: error: redefinition of 'class TS_Point'
class TS_Point {
C:\Users\MarjanHome\Documents\Arduino\libraries\Ad afruit_STMPE610/Adafruit_STMPE610.h:116:7: error: previous definition of 'class TS_Point'
class TS_Point {
C:\Users\MarjanHome\Documents\Arduino\libraries\Ad afruit_STMPE610/Adafruit_STMPE610.h:127:7: error: redefinition of 'class Adafruit_STMPE610'
C:\Users\MarjanHome\Documents\Arduino\libraries\Ad afruit_STMPE610/Adafruit_STMPE610.h:127:7: error: previous definition of 'class Adafruit_STMPE610'
class TS_Point {
class TS_Point {
class TS_Point {
class TS_Point {
class TS_Point {
class TS_Point {
Can someone help here or give me a tip !?
Thanks,
Mike
The file Adafruit_STMPE610.h is included from to many places, and it lacks a #ifdef Adafruit_STMPE610_h type guard against multiple inclusions.
Try to only include Adafruit_STMPE610.h from your sketch PID_ReflowBtmpV10.ino and not from any of your SplashScreen.h and similar.
Hello Mlu,
I commented out Adafruit_STMPE610.h from SplashScreen.h and I get:
In file included from PID_ReflowBtmpV10.ino:19:0:
SplashScreen.h:19: error: 'Adafruit_STMPE610' has not been declared
SplashScreen(int, int, ILI9341_t3*, Adafruit_STMPE610*);
SplashScreen.h:26: error: 'Adafruit_STMPE610' does not name a type
Adafruit_STMPE610* ptr_ctp;
class TS_Point {
class TS_Point {
class TS_Point {
class TS_Point {
class TS_Point {
class TS_Point {
PID_ReflowBtmpV10:45: error: no matching function for call to 'SplashScreen::SplashScreen(int, int, ILI9341_t3*, Adafruit_STMPE610*)'
PID_ReflowBtmpV10.ino:45:58: note: candidates are:
SplashScreen.h:19:5: note: SplashScreen::SplashScreen(int, int, ILI9341_t3*, int*)
SplashScreen.h:19:5: note: no known conversion for argument 4 from 'Adafruit_STMPE610*' to 'int*'
SplashScreen.h:17:7: note: constexpr SplashScreen::SplashScreen(const SplashScreen&)
class SplashScreen {
SplashScreen.h:17:7: note: candidate expects 1 argument, 4 provided
SplashScreen.h:17:7: note: constexpr SplashScreen::SplashScreen(SplashScreen&&)
I tried to run test sketch from Examples/Teensy /Tutorial /Blink & it works normal...
Any other tips ?
Thanks,
Mike
Without knowing where the includes of Adafruit_STMPE610.h are located exactly its hard to tell, but the error messages form the first post are clear, the library is included multiple times.
Easiest thing to do would be to edit Adafruit_STMPE610.h and at the top of the file add this:
#ifndef Adafruit_STMPE610_h
#define Adafruit_STMPE610_h
and at the bottom of the file add
Pete
Hello Pete,
I have this Code included from start :
#ifndef SPLASHSCREEN_h
#define SPLASHSCREEN_h
#include "ILI9341_t3.h"
#include "Adafruit_STMPE610.h"
#include "Configuration.h"
// Array of points which comprise the MM logo
static const uint8_t MM[] = {
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0xFE, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x11, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xB9, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x31, 0xFF, 0xF0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
public:
void drawMe(void);
private:
int xLoc;
int yLoc;
ILI9341_t3* ptr_tft;
#endif // SPLASHSCREEN_h
Mike
Mlu - can you contact me at mike.menci (at) gmail.com - I can send you Zip complete file if you can compile it ?
Thanks,
Mike
I repeat the comment from #2 but make sure to include Adafruit_STMPE610.h from your sketch PID_ReflowBtmpV10.ino BEFORE you include SplashScreen.h and similar so that the STMPE610 stuff is defined when SplashScreen.h is read, then you shouldnt have to include it from SplashScreen.h
Maybe try Arduino 1.6.5.
You'll probably hit the same error, but 1.6.5 prints much more useful info about library conflicts. You're using 1.0.6, before those improvements were added. Even if you really need 1.0.6 for something, please at least give 1.6.5 a try. It'll probably give you info about the conflict, and when you clear up the problem, maybe it'll magically work on 1.0.6 too?
This worked fine:
I edited Adafruit_STMPE610.h and at the top of the file add this:
Thanks guys and sorry for trouble coursed !
Have a great weekend
Mike
I edited LIBRARY FILE - Adafruit_STMPE610.h and at the top of the file add this:
I will upgrade now to 1.6.5 to keep Paul happy !! :)
Mike
But if I get stacked - Paul will not have a good weekend!
Mike
Hello Paul,
Here the summary after I got read of error / comiling =working on 1.05 and upgrade to 1.6.5 gives me;
C:\Users\MARJAN~1\AppData\Local\Temp\build2647348361504967730.tmp\Graph.cpp: In member function 'float Graph::plotLine(float, float)':
C:\Users\MARJAN~1\AppData\Local\Temp\build2647348361504967730.tmp\Graph.cpp:121:1: warning: no return statement in function returning non-void [-Wreturn-type]
PID_ReflowBtmpFinal0.ino: In function 'void setup()':
PID_ReflowBtmpFinal0.ino:81:29: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
PID_ReflowBtmpFinal0.ino:100:30: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
PID_ReflowBtmpFinal0.ino: In function 'void bmpDraw(char*, uint8_t, uint16_t)':
PID_ReflowBtmpFinal0.ino:126:40: warning: converting to non-pointer type 'int' from NULL [-Wconversion-null]
PID_ReflowBtmpFinal0.ino: In function 'void loop()':
PID_ReflowBtmpFinal0.ino:219:29: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
PID_ReflowBtmpFinal0.ino: In function 'void settings()':
PID_ReflowBtmpFinal0.ino:295:30: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
PID_ReflowBtmpFinal0.ino:296:32: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
PID_ReflowBtmpFinal0.ino:297:32: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
PID_ReflowBtmpFinal0.ino: In function 'void beginReflow()':
PID_ReflowBtmpFinal0.ino:319:32: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
C:\Users\MARJAN~1\AppData\Local\Temp\build2647348361504967730.tmp\SplashScreen.cpp: In member function 'void SplashScreen::drawMe()':
C:\Users\MARJAN~1\AppData\Local\Temp\build2647348361504967730.tmp\SplashScreen.cpp:17:10: warning: unused variable 'color0' [-Wunused-variable]
int16_t color0 = ptr_tft->color565( 125, 204, 204); //?? color /
C:\Users\MARJAN~1\AppData\Local\Temp\build2647348361504967730.tmp\SplashScreen.cpp:33:20: warning: iteration 180u invokes undefined behavior [-Waggressive-loop-optimizations]
if ((MM[i*23+j]&(1<<k))>0){
C:\Users\MARJAN~1\AppData\Local\Temp\build2647348361504967730.tmp\SplashScreen.cpp:28:2: note: containing loop
for (int i = 0; i < 188; i+=1){
C:\Users\MarjanHome\Documents\Arduino\libraries\Button\Button.cpp: In member function 'bool Button::isPressed()':
C:\Users\MarjanHome\Documents\Arduino\libraries\Button\Button.cpp:123:28: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
if (pressedStartTime!=-1 && !triggeredHoldEvent)
C:\Users\MarjanHome\Documents\Arduino\libraries\Button\Button.cpp: In member function 'bool Button::held(unsigned int)':
C:\Users\MarjanHome\Documents\Arduino\libraries\Button\Button.cpp:179:26: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
C:\Users\MarjanHome\Documents\Arduino\libraries\Button\Button.cpp: In member function 'unsigned int Button::holdTime() const':
C:\Users\MarjanHome\Documents\Arduino\libraries\Button\Button.cpp:271:64: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
unsigned int Button::holdTime() const { if (pressedStartTime!=-1) { return millis()-pressedStartTime; } else return 0; }
C:\Program Files\Arduino\hardware\teensy\avr\libraries\Adafruit_STMPE610\Adafruit_STMPE610.cpp: In member function 'uint16_t Adafruit_STMPE610::readRegister16(uint8_t)':
C:\Program Files\Arduino\hardware\teensy\avr\libraries\Adafruit_STMPE610\Adafruit_STMPE610.cpp:312:10: warning: 'x' may be used uninitialized in this function [-Wmaybe-uninitialized]
return x;
C:\Users\MarjanHome\Documents\Arduino\libraries\SD\utility\Sd2Card.cpp: In member function 'uint8_t Sd2Card::readData(uint32_t, uint16_t, uint16_t, uint8_t*)':
C:\Users\MarjanHome\Documents\Arduino\libraries\SD\utility\Sd2Card.cpp:470:12: warning: unused variable 'n' [-Wunused-variable]
uint16_t n;
C:\Users\MarjanHome\Documents\Arduino\libraries\SD\utility\Sd2Card.cpp: At global scope:
C:\Users\MarjanHome\Documents\Arduino\libraries\SD\utility\Sd2Card.cpp:145:13: warning: 'void spiSend(const uint8_t*, size_t)' defined but not used [-Wunused-function]
static void spiSend(const uint8_t* output, size_t len) {
C:\Users\MarjanHome\Documents\Arduino\libraries\SD\utility\SdFile.cpp: In member function 'uint8_t SdFile::rmRfStar()':
C:\Users\MarjanHome\Documents\Arduino\libraries\SD\utility\SdFile.cpp:899:40: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
if (curPosition_ != (32*(index + 1))) {
Opening Teensy Loader...
Multiple libraries were found for "ILI9341_t3.h"
Used: C:\Users\MarjanHome\Documents\Arduino\libraries\ILI9341_t3
Not used: C:\Program Files\Arduino\hardware\teensy\avr\libraries\ILI9341_t3
Used: C:\Users\MarjanHome\Documents\Arduino\libraries\SD
Not used: C:\Program Files\Arduino\hardware\teensy\avr\libraries\SD
Sketch uses 65,056 bytes (24%) of program storage space. Maximum is 262,144 bytes.
Global variables use 6,724 bytes (10%) of dynamic memory, leaving 58,812 bytes for local variables. Maximum is 65,536 bytes.
A lot of cleaning here to do...
Mike
Did you notice this part?
Arduino is using libraries from C:\Users\MarjanHome\Documents\Arduino\libraries, which are copies you've manually installed.
It's *not* using the known-good copies Teensyduino put into C:\Program Files\Arduino\hardware\teensy\avr\libraries.
But also notice, ALL of that stuff you posted is just warnings. There are NO ACTUAL ERRORS. The code compiled.
Sure, there are lots of warnings.... and again, that's all issues with the code you installed, not the vetted libraries Teensyduino provides.
Yes I did- If I delete this libraries from C:\Users\MarjanHome\Documents\Arduino\libraries\
Used: C:\Users\MarjanHome\Documents\Arduino\libraries\IL I9341_t3
Not used: C:\Program Files\Arduino\hardware\teensy\avr\libraries\ILI934 1_t3
my sketch will not compile - why ?
Mike
Paul,
With added libraries to sketch - not compiling at all:
Arduino: 1.6.5 (Windows 7), TD: 1.24, Board: "Teensy 3.1, Serial, 96 MHz optimized (overclock), US English"
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\Graph.cpp: In member function 'float Graph::plotLine(float, float)':
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\Graph.cpp:121:1: warning: no return statement in function returning non-void [-Wreturn-type]
PID_ReflowBtmpFinal0.ino:74:29: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
PID_ReflowBtmpFinal0.ino:93:30: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
PID_ReflowBtmpFinal0.ino:119:40: warning: converting to non-pointer type 'int' from NULL [-Wconversion-null]
PID_ReflowBtmpFinal0.ino:212:29: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
PID_ReflowBtmpFinal0.ino:288:30: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
PID_ReflowBtmpFinal0.ino:289:32: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
PID_ReflowBtmpFinal0.ino:290:32: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
PID_ReflowBtmpFinal0.ino:312:32: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\SplashScreen.cpp: In member function 'void SplashScreen::drawMe()':
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\SplashScreen.cpp:17:10: warning: unused variable 'color0' [-Wunused-variable]
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\SplashScreen.cpp:33:20: warning: iteration 180u invokes undefined behavior [-Waggressive-loop-optimizations]
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\SplashScreen.cpp:28:2: note: containing loop
return x;
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\ILI9341_t3\ILI9341_t3.cpp.o: In function `ILI9341_t3::getRotation()':
C:\Program Files\Arduino\hardware\teensy\avr\libraries\ILI9341_t3/ILI9341_t3.cpp:31: multiple definition of `ILI9341_t3::ILI9341_t3(unsigned char, unsigned char, unsigned char, unsigned char, unsigned char, unsigned char)'
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\ILI9341_t3.cpp.o:C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp/ILI9341_t3.cpp:31: first defined here
c:/program files/arduino/hardware/tools/arm/bin/../lib/gcc/arm-none-eabi/4.8.4/../../../../arm-none-eabi/bin/ld.exe: Disabling relaxation: it will not work with multiple definitions
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\ILI9341_t3\ILI9341_t3.cpp.o: In function `SPCRemulation::setMISO(unsigned char)':
C:\Program Files\Arduino\hardware\teensy\avr\libraries\ILI9341_t3/ILI9341_t3.cpp:49: multiple definition of `ILI9341_t3::setAddrWindow(unsigned short, unsigned short, unsigned short, unsigned short)'
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\ILI9341_t3.cpp.o:C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp/ILI9341_t3.cpp:49: first defined here
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\ILI9341_t3\ILI9341_t3.cpp.o: In function `ILI9341_t3::waitFifoNotFull()':
C:\Program Files\Arduino\hardware\teensy\avr\libraries\ILI9341_t3/ILI9341_t3.cpp:57: multiple definition of `ILI9341_t3::pushColor(unsigned short)'
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\ILI9341_t3.cpp.o:C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp/ILI9341_t3.cpp:57: first defined here
C:\Program Files\Arduino\hardware\teensy\avr\libraries\ILI9341_t3/ILI9341_t3.cpp:63: multiple definition of `ILI9341_t3::drawPixel(short, short, unsigned short)'
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\ILI9341_t3.cpp.o:C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp/ILI9341_t3.cpp:63: first defined here
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\ILI9341_t3\ILI9341_t3.cpp.o: In function `ILI9341_t3::drawFastVLine(short, short, short, unsigned short)':
C:\Program Files\Arduino\hardware\teensy\avr\libraries\ILI9341_t3/ILI9341_t3.cpp:75: multiple definition of `ILI9341_t3::drawFastVLine(short, short, short, unsigned short)'
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\ILI9341_t3.cpp.o:C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp/ILI9341_t3.cpp:75: first defined here
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\ILI9341_t3\ILI9341_t3.cpp.o: In function `ILI9341_t3::drawFastHLine(short, short, short, unsigned short)':
C:\Program Files\Arduino\hardware\teensy\avr\libraries\ILI9341_t3/ILI9341_t3.cpp:90: multiple definition of `ILI9341_t3::drawFastHLine(short, short, short, unsigned short)'
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\ILI9341_t3.cpp.o:C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp/ILI9341_t3.cpp:90: first defined here
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\ILI9341_t3\ILI9341_t3.cpp.o: In function `ILI9341_t3::fillRect(short, short, short, short, unsigned short)':
C:\Program Files\Arduino\hardware\teensy\avr\libraries\ILI9341_t3/ILI9341_t3.cpp:111: multiple definition of `ILI9341_t3::fillRect(short, short, short, short, unsigned short)'
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\ILI9341_t3.cpp.o:C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp/ILI9341_t3.cpp:111: first defined here
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\ILI9341_t3\ILI9341_t3.cpp.o: In function `ILI9341_t3::fillScreen(unsigned short)':
C:\Program Files\Arduino\hardware\teensy\avr\libraries\ILI9341_t3/ILI9341_t3.cpp:105: multiple definition of `ILI9341_t3::fillScreen(unsigned short)'
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\ILI9341_t3.cpp.o:C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp/ILI9341_t3.cpp:105: first defined here
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\ILI9341_t3\ILI9341_t3.cpp.o: In function `ILI9341_t3::setRotation(unsigned char)':
C:\Program Files\Arduino\hardware\teensy\avr\libraries\ILI9341_t3/ILI9341_t3.cpp:143: multiple definition of `ILI9341_t3::setRotation(unsigned char)'
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\ILI9341_t3.cpp.o:C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp/ILI9341_t3.cpp:143: first defined here
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\ILI9341_t3\ILI9341_t3.cpp.o: In function `ILI9341_t3::invertDisplay(bool)':
C:\Program Files\Arduino\hardware\teensy\avr\libraries\ILI9341_t3/ILI9341_t3.cpp:173: multiple definition of `ILI9341_t3::invertDisplay(bool)'
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\ILI9341_t3.cpp.o:C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp/ILI9341_t3.cpp:173: first defined here
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\ILI9341_t3\ILI9341_t3.cpp.o: In function `ILI9341_t3::readcommand8(unsigned char, unsigned char)':
C:\Program Files\Arduino\hardware\teensy\avr\libraries\ILI9341_t3/ILI9341_t3.cpp:210: multiple definition of `ILI9341_t3::readcommand8(unsigned char, unsigned char)'
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\ILI9341_t3.cpp.o:C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp/ILI9341_t3.cpp:210: first defined here
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\ILI9341_t3\ILI9341_t3.cpp.o: In function `ILI9341_t3::readPixel(short, short)':
C:\Program Files\Arduino\hardware\teensy\avr\libraries\ILI9341_t3/ILI9341_t3.cpp:265: multiple definition of `ILI9341_t3::readPixel(short, short)'
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\ILI9341_t3.cpp.o:C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp/ILI9341_t3.cpp:265: first defined here
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\ILI9341_t3\ILI9341_t3.cpp.o: In function `ILI9341_t3::readRect(short, short, short, short, unsigned short*)':
C:\Program Files\Arduino\hardware\teensy\avr\libraries\ILI9341_t3/ILI9341_t3.cpp:299: multiple definition of `ILI9341_t3::readRect(short, short, short, short, unsigned short*)'
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\ILI9341_t3.cpp.o:C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp/ILI9341_t3.cpp:299: first defined here
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\ILI9341_t3\ILI9341_t3.cpp.o: In function `ILI9341_t3::writeRect(short, short, short, short, unsigned short*)':
C:\Program Files\Arduino\hardware\teensy\avr\libraries\ILI9341_t3/ILI9341_t3.cpp:344: multiple definition of `ILI9341_t3::writeRect(short, short, short, short, unsigned short*)'
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\ILI9341_t3.cpp.o:C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp/ILI9341_t3.cpp:344: first defined here
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\ILI9341_t3\ILI9341_t3.cpp.o: In function `ILI9341_t3::begin()':
C:\Program Files\Arduino\hardware\teensy\avr\libraries\ILI9341_t3/ILI9341_t3.cpp:385: multiple definition of `ILI9341_t3::begin()'
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\ILI9341_t3.cpp.o:C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp/ILI9341_t3.cpp:385: first defined here
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\ILI9341_t3\ILI9341_t3.cpp.o: In function `ILI9341_t3::drawCircle(short, short, short, unsigned short)':
C:\Program Files\Arduino\hardware\teensy\avr\libraries\ILI9341_t3/ILI9341_t3.cpp:483: multiple definition of `ILI9341_t3::drawCircle(short, short, short, unsigned short)'
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\ILI9341_t3.cpp.o:C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp/ILI9341_t3.cpp:483: first defined here
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\ILI9341_t3\ILI9341_t3.cpp.o: In function `ILI9341_t3::drawCircleHelper(short, short, short, unsigned char, unsigned short)':
C:\Program Files\Arduino\hardware\teensy\avr\libraries\ILI9341_t3/ILI9341_t3.cpp:517: multiple definition of `ILI9341_t3::drawCircleHelper(short, short, short, unsigned char, unsigned short)'
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\ILI9341_t3.cpp.o:C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp/ILI9341_t3.cpp:517: first defined here
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\ILI9341_t3\ILI9341_t3.cpp.o: In function `ILI9341_t3::fillCircleHelper(short, short, short, unsigned char, short, unsigned short)':
C:\Program Files\Arduino\hardware\teensy\avr\libraries\ILI9341_t3/ILI9341_t3.cpp:560: multiple definition of `ILI9341_t3::fillCircleHelper(short, short, short, unsigned char, short, unsigned short)'
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\ILI9341_t3.cpp.o:C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp/ILI9341_t3.cpp:560: first defined here
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\ILI9341_t3\ILI9341_t3.cpp.o: In function `ILI9341_t3::fillCircle(short, short, short, unsigned short)':
C:\Program Files\Arduino\hardware\teensy\avr\libraries\ILI9341_t3/ILI9341_t3.cpp:553: multiple definition of `ILI9341_t3::fillCircle(short, short, short, unsigned short)'
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\ILI9341_t3.cpp.o:C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp/ILI9341_t3.cpp:553: first defined here
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\ILI9341_t3\ILI9341_t3.cpp.o: In function `ILI9341_t3::drawLine(short, short, short, short, unsigned short)':
C:\Program Files\Arduino\hardware\teensy\avr\libraries\ILI9341_t3/ILI9341_t3.cpp:593: multiple definition of `ILI9341_t3::drawLine(short, short, short, short, unsigned short)'
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\ILI9341_t3.cpp.o:C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp/ILI9341_t3.cpp:593: first defined here
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\ILI9341_t3\ILI9341_t3.cpp.o: In function `ILI9341_t3::drawRect(short, short, short, short, unsigned short)':
C:\Program Files\Arduino\hardware\teensy\avr\libraries\ILI9341_t3/ILI9341_t3.cpp:681: multiple definition of `ILI9341_t3::drawRect(short, short, short, short, unsigned short)'
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\ILI9341_t3.cpp.o:C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp/ILI9341_t3.cpp:681: first defined here
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\ILI9341_t3\ILI9341_t3.cpp.o: In function `ILI9341_t3::drawRoundRect(short, short, short, short, short, unsigned short)':
C:\Program Files\Arduino\hardware\teensy\avr\libraries\ILI9341_t3/ILI9341_t3.cpp:693: multiple definition of `ILI9341_t3::drawRoundRect(short, short, short, short, short, unsigned short)'
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\ILI9341_t3.cpp.o:C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp/ILI9341_t3.cpp:693: first defined here
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\ILI9341_t3\ILI9341_t3.cpp.o: In function `ILI9341_t3::fillRoundRect(short, short, short, short, short, unsigned short)':
C:\Program Files\Arduino\hardware\teensy\avr\libraries\ILI9341_t3/ILI9341_t3.cpp:708: multiple definition of `ILI9341_t3::fillRoundRect(short, short, short, short, short, unsigned short)'
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\ILI9341_t3.cpp.o:C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp/ILI9341_t3.cpp:708: first defined here
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\ILI9341_t3\ILI9341_t3.cpp.o: In function `ILI9341_t3::drawTriangle(short, short, short, short, short, short, unsigned short)':
C:\Program Files\Arduino\hardware\teensy\avr\libraries\ILI9341_t3/ILI9341_t3.cpp:720: multiple definition of `ILI9341_t3::drawTriangle(short, short, short, short, short, short, unsigned short)'
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\ILI9341_t3.cpp.o:C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp/ILI9341_t3.cpp:720: first defined here
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\ILI9341_t3\ILI9341_t3.cpp.o: In function `ILI9341_t3::fillTriangle(short, short, short, short, short, short, unsigned short)':
C:\Program Files\Arduino\hardware\teensy\avr\libraries\ILI9341_t3/ILI9341_t3.cpp:729: multiple definition of `ILI9341_t3::fillTriangle(short, short, short, short, short, short, unsigned short)'
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\ILI9341_t3.cpp.o:C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp/ILI9341_t3.cpp:729: first defined here
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\ILI9341_t3\ILI9341_t3.cpp.o: In function `ILI9341_t3::drawBitmap(short, short, unsigned char const*, short, short, unsigned short)':
C:\Program Files\Arduino\hardware\teensy\avr\libraries\ILI9341_t3/ILI9341_t3.cpp:806: multiple definition of `ILI9341_t3::drawBitmap(short, short, unsigned char const*, short, short, unsigned short)'
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\ILI9341_t3.cpp.o:C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp/ILI9341_t3.cpp:806: first defined here
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\ILI9341_t3\ILI9341_t3.cpp.o: In function `ILI9341_t3::drawChar(short, short, unsigned char, unsigned short, unsigned short, unsigned char)':
C:\Program Files\Arduino\hardware\teensy\avr\libraries\ILI9341_t3/ILI9341_t3.cpp:839: multiple definition of `ILI9341_t3::drawChar(short, short, unsigned char, unsigned short, unsigned short, unsigned char)'
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\ILI9341_t3.cpp.o:C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp/ILI9341_t3.cpp:839: first defined here
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\ILI9341_t3\ILI9341_t3.cpp.o: In function `ILI9341_t3::write(unsigned char)':
C:\Program Files\Arduino\hardware\teensy\avr\libraries\ILI9341_t3/ILI9341_t3.cpp:819: multiple definition of `ILI9341_t3::write(unsigned char)'
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\ILI9341_t3.cpp.o:C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp/ILI9341_t3.cpp:819: first defined here
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\ILI9341_t3\ILI9341_t3.cpp.o: In function `ILI9341_t3::setCursor(short, short)':
C:\Program Files\Arduino\hardware\teensy\avr\libraries\ILI9341_t3/ILI9341_t3.cpp:960: multiple definition of `ILI9341_t3::setCursor(short, short)'
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\ILI9341_t3.cpp.o:C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp/ILI9341_t3.cpp:960: first defined here
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\ILI9341_t3\ILI9341_t3.cpp.o: In function `ILI9341_t3::setTextSize(unsigned char)':
C:\Program Files\Arduino\hardware\teensy\avr\libraries\ILI9341_t3/ILI9341_t3.cpp:965: multiple definition of `ILI9341_t3::setTextSize(unsigned char)'
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\ILI9341_t3.cpp.o:C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp/ILI9341_t3.cpp:965: first defined here
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\ILI9341_t3\ILI9341_t3.cpp.o: In function `ILI9341_t3::setTextColor(unsigned short)':
C:\Program Files\Arduino\hardware\teensy\avr\libraries\ILI9341_t3/ILI9341_t3.cpp:971: multiple definition of `ILI9341_t3::setTextColor(unsigned short)'
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\ILI9341_t3.cpp.o:C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp/ILI9341_t3.cpp:971: first defined here
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\ILI9341_t3\ILI9341_t3.cpp.o: In function `ILI9341_t3::setTextColor(unsigned short, unsigned short)':
C:\Program Files\Arduino\hardware\teensy\avr\libraries\ILI9341_t3/ILI9341_t3.cpp:975: multiple definition of `ILI9341_t3::setTextColor(unsigned short, unsigned short)'
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\ILI9341_t3.cpp.o:C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp/ILI9341_t3.cpp:975: first defined here
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\ILI9341_t3\ILI9341_t3.cpp.o: In function `ILI9341_t3::setTextWrap(bool)':
C:\Program Files\Arduino\hardware\teensy\avr\libraries\ILI9341_t3/ILI9341_t3.cpp:980: multiple definition of `ILI9341_t3::setTextWrap(bool)'
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\ILI9341_t3.cpp.o:C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp/ILI9341_t3.cpp:980: first defined here
C:\Program Files\Arduino\hardware\teensy\avr\libraries\ILI9341_t3/ILI9341_t3.cpp:985: multiple definition of `ILI9341_t3::getRotation()'
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\ILI9341_t3.cpp.o:C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp/ILI9341_t3.cpp:985: first defined here
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\ILI9341_t3\ILI9341_t3.cpp.o:(.rodata._ZTV10ILI9341_t3+0x0): multiple definition of `vtable for ILI9341_t3'
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\ILI9341_t3.cpp.o:(.rodata._ZTV10ILI9341_t3+0x0): first defined here
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\SD\SD.cpp.o: In function `Sd2Card':
C:\Program Files\Arduino\hardware\teensy\avr\libraries\SD/SD.cpp:235: multiple definition of `callback_pathExists(SdFile&, char*, bool, void*)'
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\SD.cpp.o:C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp/SD.cpp:234: first defined here
C:\Users\MARJAN~1\AppData\Local\Temp\build2552613943067761079.tmp\SD\SD.cpp.o: In function `SdFile':
C:\Program Files\Arduino\hardware\teensy\avr\libraries\SD/SD.cpp:258: multiple definition of `callback_makeDirPath(SdFile&, char*, bool, void*
Error compiling.
Mike
MIKE!
AGAIN: PLEASE... open a new Thread.
Moderator edit: all the posts were moved to the correct thread
