Results 1 to 2 of 2
Thread: A simple class for sub microsecond timing
    Aug 2013
    Gothenburg, Sweden
    291
    Using the elapsedMillis and elapsedMicros as template I wrote the following class elapsedCycles that uses DWT_CYCCNT as clock.
    #ifndef elapsedCycles_h
    #define elapsedCycles_h
    #ifdef __cplusplus
    #if ARDUINO >= 100
    #include "Arduino.h"
    #else
    #include "WProgram.h"
    /* Class for CPU clycle resolution timing */
    /* Conversions between cycles and nanosecons are safe up to 100 mS */
    class elapsedCycles
    private:
    	unsigned long cyccount;
    public:
    	elapsedCycles(void) { ARM_DEMCR |= ARM_DEMCR_TRCENA; ARM_DWT_CTRL |= 1; cyccount = ARM_DWT_CYCCNT; }
    	elapsedCycles(unsigned long val) { ARM_DWT_CTRL |= 1; cyccount = ARM_DWT_CYCCNT - val; }
    	elapsedCycles(const elapsedCycles &orig) { ARM_DWT_CTRL |= 1; cyccount = orig.cyccount; }
    	operator unsigned long () const { return ARM_DWT_CYCCNT - cyccount; }
    	elapsedCycles & operator = (const elapsedCycles &rhs) { cyccount = rhs.cyccount; return *this; }
    	elapsedCycles & operator = (unsigned long val) { cyccount = ARM_DWT_CYCCNT - val; return *this; }
    	elapsedCycles & operator -= (unsigned long val)      { cyccount += val ; return *this; }
    	elapsedCycles & operator += (unsigned long val)      { cyccount -= val ; return *this; }
    	elapsedCycles operator - (int val) const           { elapsedCycles r(*this); r.cyccount += val; return r; }
    	elapsedCycles operator - (unsigned int val) const  { elapsedCycles r(*this); r.cyccount += val; return r; }
    	elapsedCycles operator - (long val) const          { elapsedCycles r(*this); r.cyccount += val; return r; }
    	elapsedCycles operator - (unsigned long val) const { elapsedCycles r(*this); r.cyccount += val; return r; }
    	elapsedCycles operator + (int val) const           { elapsedCycles r(*this); r.cyccount -= val; return r; }
    	elapsedCycles operator + (unsigned int val) const  { elapsedCycles r(*this); r.cyccount -= val; return r; }
    	elapsedCycles operator + (long val) const          { elapsedCycles r(*this); r.cyccount -= val; return r; }
    	elapsedCycles operator + (unsigned long val) const { elapsedCycles r(*this); r.cyccount -= val; return r; }
    	static unsigned long ns2cycles(unsigned long ns) {return (ns*(F_CPU/8000000UL))/125UL; }
    	static unsigned long cycles2ns(unsigned long cycles) {return (cycles*125UL)/(F_CPU/8000000UL); }
    #endif // __cplusplus
    #endif // elapsedCycles_h
    To test it I wrote a very simple sketch with a function to bitbanging a WS2812 chain, yes I know there is OctoWS, but this is demo of the timing functions. An elapsedCycles object is also used to time the call to the ws2812b_send function.
    #include <elapsedCycles.h>
    int led = 13;
    int onoff = 0;
    elapsedCycles cyccnt;
    elapsedCycles loopcyc(0);
    #define WL2812PIN 12
    elapsedCycles bittime;
    #define T0H  ((350*(F_CPU/8000000UL))/125UL)
    #define T1H  ((850*(F_CPU/8000000UL))/125UL)
    #define TPER ((1250*(F_CPU/8000000UL))/125UL)
    #define TRET ((50000*(F_CPU/8000000UL))/125UL)
    void ws2812b_send(uint32_t * rgbarray, int count) {
      __disable_irq();
      for (int n = 0; n<count; n++) {
        uint32_t register rgb = rgbarray[n];
        for (int bitpos=0; bitpos<24; bitpos++) {
          bittime = 0;
          digitalWriteFast(WL2812PIN, 1);
          if (rgb & 0x800000) {
            while (bittime<T1H);
            digitalWriteFast(WL2812PIN, 0);
          else {
            while (bittime<T0H) ;
          rgb = (rgb<<1);
          while (bittime<TPER) ;
      __enable_irq();
      while(bittime<TRET) ;
    uint32_t grbarray[3];
      pinMode(led, OUTPUT);
      grbarray[0] = 0xA50F4C;
      grbarray[1] = 0x808080;
      grbarray[2] = 0x204080;
      pinMode(WL2812PIN, OUTPUT);
      delay(2000);
      Serial.println(T0H);
      Serial.println(T1H);
    int tick=0;
      /* Number of cpu cycles in 100 ms */
      uint32_t cycles_100ms = elapsedCycles::ns2cycles(100000000);
        if (loopcyc>cycles_100ms) {
          tick++;
          loopcyc -= cycles_100ms;
          if (tick==5) {
            tick = 0;
            Serial.print("ledtick: ");
            Serial.println(loopcyc);
            digitalWrite(led, onoff);
            onoff=1-onoff;
          cyccnt = 0;
          ws2812b_send(grbarray, 3);
          uint32_t cycles = cyccnt;
          Serial.print("Sending 3 WS2812 pixels in ");
          Serial.print(cycles);
          Serial.print(" clock cycles taking ");
          Serial.print(elapsedCycles::cycles2ns(cycles));
          Serial.println(" nano seconds");
    EDIT Fix some errors in the example sketch, giving wrong color values. (one rgb = (rgb<<1) shift to many )
    6,069
    Thanks - searching ARM_DWT_CYCCNT while I was thinking of writing something similar starting from elapsedMicros - and found this First test looks cleaner and runs faster.
