Hi, I am relatively new to electronics,
but I am comfortable with programming.
I want to create a 32x32 RGB LED matrix wall,
connected to the internet (Ethernet or Wifi)
to contact a webservice for new content to display.
I was thinking about using these components:
Now, I would also like to know whether it would be possible to play raw audio files
using the Audio library together with this configuration.
I am not sure how I should connect a speaker to the Teensy,
or would I have to use the Audio Adaptor?
If so, can both the SmartMatrix SD shield and the Audio Adapter be connected?
Apart from that. The ethernet (or wifi) connection.
Do I need another shield or adaptor for that?
Is it possible?
Thanks in advance for the help.
- Teensy 3.1
- SmartMatrix SD shield
- 32x32 RGB LED matrix
Is it possible?
