Page 3 of 3 FirstFirst 1 2 3
Results 51 to 67 of 67
Thread: Over the air updates
  1. #51
    Dec 2019
    7
    Is that in ref to post #48 code? Came working from IDE 1.8.10 install with TD 1.49b1. Yes there is 'THAT' warning about a type I didn't clean up - but it runs to T4 - that is a warning and the right thing ends up happening.
    Didn't say it was a good solution - it would need minimization - the RTC time print is DEBUG extraneous and was added just to see continuity in function and clock ticks across the process.
    To date all notes on issuing reset RESET to T4 seemed to indicate it just triggers the bootloader. If there is one that works "to call a reset register of the CPU (like Teensy 3.2) " - please post ...
    Thanks! It's working well here, after one or two tweaks (and warnings fixed). Slightly modified version is attached. Restarts as expected after a few seconds, then repeats the cycle.
    Attached Files Attached Files
  2. #52
    10,634
    Yeah - it just needed a cast to stop the warning - it was working so was ignoring that :: setSyncProvider((getExternalTime) Teensy3Clock.get);
    Odd the USB isn't good and right? That should work! No problem on IDE 1.8.10 and TD 1.49b1 or before with T4's here - in fact 11 months since Beta started lots of issues and that was not one
    You might try a 15sec Restore of your T4: start a second timer (optional). power the T4 and press button and watch about 15 seconds and the bootloader light will go off then BLIP once - release the button and it will get a reset to factory state. Maybe something in the process triggered something?
    Not sure what else changed in the code as cpp - DIFF shows lot of white space.
  3. #53
    May 2015
    USA
    329
    Interesting, this line will put a T4 into a state where the reset button won't work - only a power cycle fixes it.
    SNVS_LPCR |= (1 << 6) ; // turn off power
  4. #54
    Dec 2019
    7
    Odd the USB isn't good and right? That should work! No problem on IDE 1.8.10 and TD 1.49b1 or before with T4's here - in fact 11 months since Beta started lots of issues and that was not one You might try a 15sec Restore of your T4: start a second timer (optional). power the T4 and press button and watch about 15 seconds and the bootloader light will go off then BLIP once - release the button and it will get a reset to factory state. Maybe something in the process triggered something?
    I think it's all good. I suspect my speakers were just turned off yesterday, so I didn't hear the USB device disconnecting and reconnecting. It's pretty clear that it's supposed to do that, so I edited my post to remove that comment.
    Not much, mostly just the changes needed to work with my makefile.
    This will be really helpful in conjunction with Jon's recent progress on OTA updates. The fact that the T4 board can now reflash its own firmware and then subsequently restart itself is a bigger deal than it seems at first. Those kinds of features help turn it into a commercial-quality SBC. Awesome work all around.
  5. #55
    Yes, this is useful.
  6. #56
    Quote Originally Posted by John Miles View Post
    Too complicated for me. I will wait for a CPU reset register version.
  7. #57
    Dec 2019
    7
    Quote Originally Posted by Utak View Post
    Unfortunately I don't think that'll be possible, at least not at the application level. Would be good to be proven wrong on that.
    The SNVS_LPCR register shuts down the whole power management section, which is why it can't be rebooted by the MKL02 when you press the button. The only other global reset mechanisms I could find in the reference manual were the various watchdog registers, which apparently must now be programmed within 255 clock cycles of startup. Meaning, not from within loop()/setup()/main(), but the runtime kernel. Somebody who isn't me will have to do a lot of low-level hacking to get that to work.
  8. #58
    May 2015
    USA
    329
    Yes, there is a need for a simple reboot() in the standard libraries. A reboot is a valid response to some software detected errors.
    Locking up is often a dangerous action and a MCU should be resistant to it. I don't know, maybe that requires an external watchdog.
  9. #59
    10,634
    Good to know nothing 'tweaked' your T4 in the process! I usually have my speakers off too - especially when it sits there beeping over and over 4 times a minute - there are those times that sound is useful though.
    Just FYI: I put a blank file rtcboot.ino in that folder named rtcboot and it worked with an IDE build!
    I build from editor of choice SublimeText using Windows batch file system : github.com/Defragster/Tset Relies on TyCommander to do the programming - but the Batch file CMD line { thanks Frank B } triggers the Arduino IDE Build with the IDE closed - then uses TyCommander as SerMon.
    The system requires finding the INO to build with - but it naturally builds rtcboot.cpp since it is in the folder. Started to add #include in the INO - but then realized the IDE just includes any CPP in the directory so just put to newlines in the blank sketch file.
    I haven't seen the T4 reflash code - that does sound good. This 'reboot/reset' takes 2 secs - but it is automated and works.
    The original code was for much more - so it should refine down to essential 'Restart()' with minimal overhead. I didn't look to do that - but on the WMXZ thread is occurred to me this could be a useful abuse of it. As noted the only question is if the call to rtc_stopAlarm(); is needed in setup() to prevent the odd behavior that was reported in the other thread where this code came from.
  10. #60
    10,634
    Just triggered the overtemp detection and it seems to just halt. Other than this RTC restart that does an automated Power Off and Restart not recalling anything else worked.
    It'll work for now if not best solution - assuming somebody here can streamline the code?
  11. #61
    Dec 2019
    7
    The basic problem is that the NXP reference manual is terrible. I don't know how anyone ever got this working in the first place, given the quality of the information provided.
    For one thing, many of the accesses to LPCR and LPSR seem to involve bits marked "Reserved," so I can't even begin to tell what's important, what's not important, and what might actually cause trouble later on. I wonder if these registers are documented in an app note somewhere, or perhaps in the NDA'ed security manual?
  12. #62
    10,634
    The manual is a headache at best. That code was from @WMXZ and whatever it does works - the only oddity in that thread was that Power button shares the Low Power restart segment of the RTC - and they overlap - it seems on Power Off and On residual Sleep setting will still timeout and wake from an Off unexpectedly - that is what lead to the rtc_stopAlarm() in setup to stop that from future interference when that Low Power core is in charge. I'll post back on that thread ...
  13. #63
    May 2015
    USA
    329
    I added a rtcboot based version of "reboot()" to the flasher4 code. Seems to work.
    Would be interesting to see some testing of the RT1060 watchdog features. Not clear to me that the teensy4 is a device you could trust in an environment without the ability to power cycle it. Ideal would be if the MKL02 had an option to act as an external watchdog that could always reboot the RT1060. Should make for a more reliable system.
  14. #64
    Aug 2019
    5
    Hi jonr,
    have been reading this, but your link in the fist msg is broaken:
    >>See the flasher.* code here: https://github.com/Photosynq/Photosy...ter/multispeq1
    If the code is free do you then have a valid link ?
  15. #65
    May 2015
    USA
    329
    Here is the Teensy 4 version. Several people have used it.
  16. #66
    10
    For me flash_erase_sector(0x100000) does not return ...
    Any idea?
    Kind regards, Sebastian
  17. #67
    10
    Ok, as 0x100000 points to space not backed by storage this is not surprising. 0x60100000 works much better ...
    Kind regards,
    Sebastian
