Hello i have a question about encoder library i mounted dual bipolar hall effect switch (allegro A1230) on top of motor shaft housing
Motor shaft has 4 magnets mounted N S N S about every 90 degrees. However output is not exactly grey code (not shifted by 90 degrees ).
So my question is: can the library still reliably count rotations or it will not be able to do so. I tried to check and it looks like it is working fine but just want to make sure.
Here is output from logic analyzer
