I am running Arduino IDE 1.6.5 with Teensyduino 1.2.4 on 64 bit Linux. I am having a strange problem with dividing a defined variable with another defined variable. When I add, subtract or multiply the two variables there is not a problem. When I put the defined variables into other variables, the divide works fine.
I thought I would try to resolved the problem by updating to Teensyduino 1.2.5 Beta, by downloading it from page https://forum.pjrc.com/threads/29508-Teensyduino-1-25-Beta-1-Available and try it before posting here. Its download size is 53.9 MB compared to 67.6 MB for 1.24. And I cannot get it to execute to install so am working with 1.24.
The offending code is on line 52, commented out below
. If I replace the divide with +, -, or * then it works as expected, but with the / it results in 0.00. The replacement lines 49 to 51
works as expected.
I will appreciate your comments and help, on both the divide problem and updating to 1.25.
//fanJerkTime = FAN_ALPHA_MAX / FAN_JERK;
float num = FAN_ALPHA_MAX;
float denom = FAN_JERK;
fanJerkTime = num / denom;
// See fanSpeedCurve.xmcd for the derivation
#define FAN_OMEGA_MAX 12000/60.0 // Max fan RPM converted to Hz
#define FAN_OMEGA_OPERATING 10000/60.0 // Operating fan RPM converted to Hz
#define FAN_OMEGA_TOLERANCE 100/60.0 // fan speed between FAN_OMEAGA_MAX and FAN_OMEGA_TOLERANCE
#define FAN_ALPHA_MAX FAN_OMEGA_MAX/12.0 // Max fan rotational acceleration (denom is time)
#define FAN_JERK FAN_ALPHA_MAX/2.0 // Max fan jerk (rate of change of acceleration) (denom is time)
// following are already is DooleyHouse.h
#define PWM_WRITE_FREQUENCY 1464 // multiple of 732? check with Kevin for ideal frequency for him
#define PWM_WRITE_RESOLUTION 12 // bits resolution (up to 16)
#define PWM_REF_VOLTAGE 3.3 // PWM output voltage
boolean fanOn;
unsigned int timeCurrent, timeOld;
float fanDeltaTime, fanJerkTime;
float fanSpeed, fanAccel;
float fanSpeedUpperThreshold, fanSpeedLowerThreshold; // beyond this speed the acceleration rate starts changing
float PWMscaling;
Serial.begin(9600); // for debugging or datalogging
delay(800);
Serial.println("Starting Serial Port");
// setup the PWM output for the fan speed
analogWriteResolution(PWM_WRITE_RESOLUTION); // set in dooleyHouse.h
PWMscaling = (powf(2.0f, PWM_WRITE_RESOLUTION) - 1.0f) / PWM_REF_VOLTAGE;
Serial.println(PWM_WRITE_RESOLUTION);
// pins 5, 6, 9, 10, 20, 21, 22 & 23 are grouped together on teensy 3.1
analogWriteFrequency(20, PWM_WRITE_FREQUENCY); // main fan rotational speed
analogWriteFrequency(21, PWM_WRITE_FREQUENCY); // extractor fan rotational speed
Serial.print(FAN_OMEGA_MAX);
Serial.print(" ");
Serial.print(FAN_OMEGA_OPERATING);
Serial.print(" ");
Serial.print(FAN_OMEGA_TOLERANCE);
Serial.print(" ");
Serial.print(FAN_ALPHA_MAX);
Serial.print(" ");
Serial.print(FAN_JERK);
Serial.print(" ");
Serial.print(PWM_REF_VOLTAGE);
Serial.println(" ");
fanOn = true;
//fanJerkTime = (float) FAN_ALPHA_MAX / (float) FAN_JERK;
fanSpeedUpperThreshold = FAN_OMEGA_OPERATING - (FAN_ALPHA_MAX - FAN_JERK*fanJerkTime)*fanJerkTime;
fanSpeedLowerThreshold = 0 - (-FAN_ALPHA_MAX + FAN_JERK*fanJerkTime)*fanJerkTime;
fanSpeed = 0;
fanAccel = 0;
Serial.print(fanJerkTime);
Serial.print(" ");
Serial.print(fanSpeedUpperThreshold);
Serial.print(" ");
Serial.print(fanSpeedLowerThreshold);
Serial.print(" ");
Serial.print(fanSpeed);
Serial.print(" ");
Serial.print(fanAccel);
Serial.print(" ");
Serial.print(PWMscaling);
timeCurrent = micros();
timeOld = timeCurrent;
fanDeltaTime = (timeCurrent - timeOld) * 1e-6;
if (fanOn) { // fan is on
if (fanSpeed < fanSpeedLowerThreshold) {
fanSpeed = fanSpeed + (fanAccel + FAN_JERK/2*fanDeltaTime)*fanDeltaTime;
fanAccel = fanAccel * FAN_JERK*fanDeltaTime;
Serial.println("1st S-curve");
else if (fanSpeed >= fanSpeedLowerThreshold && fanSpeed < fanSpeedUpperThreshold) {
fanSpeed = fanSpeed + fanAccel*fanDeltaTime;
else if (fanSpeed <= fanSpeedUpperThreshold && fanSpeed < FAN_OMEGA_OPERATING) {
fanSpeed = fanSpeed - (fanAccel + FAN_JERK/2*fanDeltaTime)*fanDeltaTime;
fanAccel = fanAccel * -FAN_JERK*fanDeltaTime;
else if (fanSpeed > FAN_OMEGA_OPERATING + FAN_OMEGA_TOLERANCE) {
fanSpeed = fanSpeed - (FAN_ALPHA_MAX / 1000)*fanDeltaTime;
Serial.print(fanDeltaTime*1e6);
Serial.print(" ");
Serial.print(" ");
/*else { // fan is off
