Pardon me if these questions have been asked / answered previously. I searched but found nothing.
1 - I would like to use the spi4teensy library, but using alternate pins 8 for MISO, 7 for MOSI and 14 for SCK. I have not been able to find an example of this. In the SPI library I just use SPI.setMOSI(7) etc...
2 - Is it possible to use the spit4teensy library for one device, and the SPI library for other devices? I am trying to control a 16 bit Octal DAC using spi4teensy library, while also using the SD library to communicate with some flash memory. Has anyone gotten this to work? When I try to enable both, my teensy freezes, I have not been able to figure out a cause. I am trying to put together a smaller test case that I can post easily.
Thank you!
Thank you!
