Results 1 to 8 of 8
Thread: Teensy LC pull-up
    Aug 2015
    11
    Teensy LC pull-up
    Gents.
    Do I need to wire in a pull-up resistor for a button press, or is there a command which can be used so I can run from wire to button without a resistor.
    Regards Not Bart
    Senior Member Davidelvig's Avatar
    Aug 2015
    Wisconsin
    234
    As I understand it, and have used it, teensy supports the arduino pinmode arguments at
    https://www.arduino.cc/en/Reference/PinMode
    That web page, and it's links talk about enlisting an internal resistor with pinmode of INPUT_PULLUP
    Does that help?
    20,305
    Yes, pinMode(pin, INPUT_PULLUP) works great on Teensy-LC. No need for a real resistor.
    May 2018
    Brisbane, Australia
    4
    Hi Paul
    Does this hold true for the Teensy LC's D0 (which I'm using as a serial receive RX1)?
    Quote Originally Posted by vk4ghz View Post
    Yes, all the digital pins can do internal pullup or pulldown.
    If you are using the Serial interface(s) the function Serial.Begin() will override the pin direction though. No need to specify pin direction with serial.
    Oct 2015
    Roma (IT, EU)
    193
    Don't want to sound picky, but it's Serial1.begin() for the hardware serial (D0/D1). Serial.begin() is for USB-serial.
    May 2018
    Brisbane, Australia
    4
    Quote Originally Posted by jacky4566 View Post
    Thank you for the answer.
    I'm aware of the pin direction being set when used as a serial port.
    It's whether the RX port was going to be left floating, or not, when D0 was being used as serial port.
    ie; some unexpected behavior traps in different modes.
    Some of the Teensy documentation is very outdated (refers only to Teensy 1.0 and Teensy 2.0), so I'd thought I'd check.
    https://www.pjrc.com/teensy/td_digital.html
    May 2018
    Brisbane, Australia
    4
    Follow up.
    When used as a serial RX, there is no need for specifying an internal pull-up.
    In my case D0 (RX1).
    ie: pinMode(0, INPUT_PULLUP)
    In fact, having this causes the serial RX to stop working.
