This code uses the T3.6 onboard sd card slot, BMP stored on the card are light painted using a cheap strip of ws2811 leds using FastLed
code derived from lightpainting sketch:
[url]https://forum.pjrc.com/threads/24535-OctoWS2811-POV-reading-BMP-from-SD-card[/url]
and this post:
------> [url]https://forum.pjrc.com/threads/40871-Teensy-6-5-SDFat-BMP-file-read-fail[/url]
#include <FastLED.h>
File bmpFile;
const int chipSelect = BUILTIN_SDCARD;
// you can remove all Serial.print when you have your paint staff
// set up, this is just for debug
int bmpWidth, bmpHeight;
uint8_t bmpDepth, bmpImageoffset;
#define BUFFPIXEL 512
unsigned int Color(byte b, byte r, byte g); //placed here to avoid compiler error
// How many leds in your strip?
#define NUM_LEDS 351
#define BRIGHTNESS 64
#define DATA_PIN 2 //the pin that Led strip is attached to
CRGB leds[NUM_LEDS];
int paintSpeed = 15; //adjust this to vary image refresh rate
void setup(void) {
pinMode(7,INPUT_PULLUP);
pinMode(8,INPUT_PULLUP);
FastLED.addLeds<WS2812B, DATA_PIN, GRB>(leds, NUM_LEDS);
FastLED.setBrightness(BRIGHTNESS);
//test our led strip - you can remove this to the comment line "// if you dont get ..."
for(int x=0;x<NUM_LEDS;x++){
leds[x] = CRGB::Green;}
FastLED.show();
delay(750);
leds[x] = CRGB::Red;}
FastLED.show();
delay(750);
leds[x] = CRGB::Blue;}
FastLED.show();
delay(750);
leds[x] = CRGB::Black;}
FastLED.show();
// if you dont get all leds lighting red then going off, check your wiring
Serial.println("init");
if (!SD.begin(chipSelect)) {
Serial.println("initialization failed!");
return;
Serial.println("SD OK!");
if (digitalRead(7) == HIGH) {
Serial.println("Button is not pressed...");
Serial.println("Button pressed!!!");
bmpDraw("penguin.bmp");//example filename
//bmpDraw("DWARFS.bmp");
//bmpDraw("ISLA.bmp");
FastLED.show();
//////////////////Function to read BMP and send to Led strip a row at a time/////////////////////
void bmpDraw(char* filename){
File bmpFile;
int bmpWidth, bmpHeight; // W+H in pixels
uint8_t bmpDepth; // Bit depth (currently must report 24)
uint32_t bmpImageoffset; // Start of image data in file
uint32_t rowSize; // Not always = bmpWidth; may have padding
uint8_t sdbuffer[3*BUFFPIXEL]; // pixel in buffer (R+G+B per pixel)
uint32_t povbuffer[BUFFPIXEL]; // pixel out buffer (16-bit per pixel)//////mg/////this needs to be 24bit per pixel////////
uint32_t buffidx = sizeof(sdbuffer); // Current position in sdbuffer
boolean goodBmp = false; // Set to true on valid header parse
boolean flip = true; // BMP is stored bottom-to-top
int w, h, row, col;
int r, g, b;
uint32_t pos = 0, startTime = millis();
uint8_t povidx = 0;
boolean first = true;
// Open requested file on SD card
bmpFile = SD.open(filename);
Serial.println(filename);
// Parse BMP header
if(read16(bmpFile) == 0x4D42) { // BMP signature
Serial.print("File size: ");
Serial.println(read32(bmpFile));
(void)read32(bmpFile); // Read & ignore creator bytes
bmpImageoffset = read32(bmpFile); // Start of image data
Serial.print("Image Offset: ");
Serial.println(bmpImageoffset, DEC);
// Read DIB header
Serial.print("Header size: ");
bmpWidth = read32(bmpFile);
bmpHeight = read32(bmpFile);
if(read16(bmpFile) == 1) { // # planes -- must be '1'
bmpDepth = read16(bmpFile); // bits per pixel
Serial.print("Bit Depth: "); Serial.println(bmpDepth);
if((bmpDepth == 24) && (read32(bmpFile) == 0)) { // 0 = uncompressed
goodBmp = true; // Supported BMP format -- proceed!
Serial.print("Image size: ");
Serial.print(bmpWidth);
Serial.print('x');
Serial.println(bmpHeight);
// BMP rows are padded (if needed) to 4-byte boundary
rowSize = (bmpWidth * 3 + 3) & ~3;
// If bmpHeight is negative, image is in top-down order.
// This is not canon but has been observed in the wild.
if(bmpHeight < 0) {
bmpHeight = -bmpHeight;
flip = false;
w = bmpWidth;
h = bmpHeight;
for (row=0; row<h; row++) {
if(flip) // Bitmap is stored bottom-to-top order (normal BMP)
pos = bmpImageoffset + (bmpHeight - 1 - row) * rowSize;
else // Bitmap is stored top-to-bottom
pos = bmpImageoffset + row * rowSize;
if(bmpFile.position() != pos) { // Need seek?
bmpFile.seek(pos);
buffidx = sizeof(sdbuffer); // Force buffer reload
for (col=0; col<w; col++) { // For each column...
// read more pixel data
if (buffidx >= sizeof(sdbuffer)) {
povidx = 0;
bmpFile.read(sdbuffer, sizeof(sdbuffer));
buffidx = 0; // Set index to beginning
// set pixel
r = sdbuffer[buffidx++];
g = sdbuffer[buffidx++];
b = sdbuffer[buffidx++];
//Serial.print(r);Serial.print(" ");Serial.print(g);Serial.print(" ");Serial.println(b);
//we need to output GRB 24bit colour//
povbuffer[povidx++] =(g<<16) + (r<<8) +b; //original code is b r g, should be g r b?
for(int i=0;i<NUM_LEDS;i++){
leds[i]=povbuffer[i];}
FastLED.show();
delay(paintSpeed);// change the delay time depending effect required
} // end scanline
} // end goodBmp
}//end of IF BMP
bmpFile.close();
//*************Support Funcitons****************//
// These read 16- and 32-bit types from the SD card file.
// BMP data is stored little-endian, Arduino is little-endian too.
// May need to reverse subscript order if porting elsewhere.
uint16_t read16(File& f) {
uint16_t result;
((uint8_t *)&result)[0] = f.read(); // LSB
((uint8_t *)&result)[1] = f.read(); // MSB
return result;
uint32_t read32(File& f) {
uint32_t result;
((uint8_t *)&result)[2] = f.read();
((uint8_t *)&result)[3] = f.read(); // MSB
return result;
