Page 15 of 16 FirstFirst ... 5 13 14 15 16 LastLast
Results 351 to 375 of 394
Thread: Teensy APA102 POV Poi / Pixel Poi Build. Tutorial
  1. #351
    Senior Member mortonkopf's Avatar
    Apr 2013
    London, uk
    912
    Quote Originally Posted by bhammy187 View Post
    Looks like it's difficult to purchase authentic APA102C 5050 144/m strips these days, unless you pay $50 + tax + shipping to Adafruit.
    I buy regularly from chinese stores on Alibaba. the led strips have been fine, but occasionally I have had to pay duty / tax.
    I see that the apa102 2020 strips are just starting to be produced. It may be worth seeing if these become cheaper over the next few months
    Regarding what the best guide is, well, I guess the best one is the one you understand best and results in what you want to achieve. Also, some of the guides require more skill, such as the work that Po Ting has been doing. I think that there are some very good improvements on this thread to the original poi posted. The addition of the IR remote is a particularly good idea. The use of the onboard SD card of 3.5 and 3.6 allows for fast use of pixel data stored on the card and moved to buffer on chip giving a much wider range of images to use / store. My preference is for the battery weight to be at the handle / swivel end, and not at the tip.
  2. #352
    Feb 2019
    3
    I was lucky and scored (2) 1 meter rolls of the APA102C 5050 144 leds/m locally off craigslist for a steal, so Iím good on LEDís for my first build.
    Planning to use a blend of your guide and two other guides, to hopefully create a working set of POI sticks. If that works out, Iíll attempt something with the 2020 sized LEDís and a Teensy 3.6
    Iím sure Iíll have more questions, glad to have found this thread, and the PJRC forum in general.
    Cheers!
  3. #353
    Sep 2015
    Taiwan, Asai. (Traditional Chinese)
    161
    Not sure if 2020 strips were available yet but I did source mine here. Last year they seems to be on tesing and not widely available.
    You can also find details of Fritzing apa102 LEDS on this post
    "http://forum.fritzing.org/t/part-request-to-apa102-2020/4437/56?u=alanchen"
    the footprint and pinouts were prototyped to be usable, hope they can help
  4. #354
    Nov 2018
    17
    Hi Guys,
    i have one problem i went thruu all codes on this forum and nothing works... the best i get is that first five leds are blinking in chaotic manner.. i have common ground (i know this could be a problem). The only change in code was data and clock pin and added picture.
    Board is teensy 3.2.
    Dotstar rainbow test sketch is working fine.
    First who solves my problem gets 2 WAWES or 15 XRP for beer
    // Matthew Kavanagh (Kavanet.co.uk)
    // Orbit POI
    // Orbit.ino
    // 2018
    #include <FastLED.h>
    #include <stdlib.h>
    #define totalLEDs 72 // Change this depending on how many LEDs you have
    #define LEDBrightness 100
    #define powerLED 11
    #define data 13 // yellow
    #define clock 11 // green
    #define OFF LOW
    #define ON HIGH
    #define redVal 0
    #define greenVal 1
    #define blueVal 2
    #define width(array) sizeof(array) / sizeof(array[0])
    CRGB currentLED[totalLEDs]; // RGB colour space
    void drawImage(unsigned long time, const char pattern[][totalLEDs][3], int pictureWidth);
    const char Image[][totalLEDs][3] = {{{0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}}, {{0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}}, {{0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}}, {{0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}}, {{0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}}, {{0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}}, {{0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {204, 102, 51}, {213, 103, 43}, {213, 101, 45}, {213, 103, 42}, {214, 100, 44}, {216, 101, 46}, {217, 101, 43}, {213, 99, 43}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}}, {{0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {191, 64, 64}, {215, 98, 44}, {214, 102, 44}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 44}, {213, 101, 44}, {219, 102, 44}, {191, 128, 64}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}}, {{0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {209, 93, 46}, {213, 101, 44}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 101, 45}, {214, 102, 45}, {212, 99, 42}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}}, {{0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {215, 101, 40}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {215, 101, 45}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}}, {{0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {221, 102, 43}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {223, 96, 32}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}}, {{0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {170, 85, 0}, {213, 101, 44}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 44}, {213, 100, 45}, {213, 85, 43}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}}, {{0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {213, 101, 44}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 44}, {214, 101, 45}, {214, 103, 44}, {213, 104, 47}, {214, 104, 46}, {216, 100, 44}, {216, 103, 44}, {215, 99, 43}, {214, 102, 43}, {215, 102, 44}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}}, {{0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {255, 128, 0}, {215, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {217, 102, 51}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}}, {{0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {215, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {215, 101, 44}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}}, {{0, 0, 0}, {0, 0, 0}, {213, 85, 43}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {212, 101, 44}, {128, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}}, {{0, 0, 0}, {0, 0, 0}, {214, 102, 44}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 101, 45}, {215, 101, 45}, {170, 85, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}}, {{0, 0, 0}, {170, 85, 0}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {215, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 99, 41}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}}, {{0, 0, 0}, {220, 106, 44}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 101, 44}, {213, 99, 43}, {211, 101, 44}, {214, 103, 46}, {214, 101, 44}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 44}, {214, 101, 44}, {215, 102, 45}, {213, 103, 45}, {213, 101, 44}, {215, 102, 44}, {214, 102, 44}, {215, 101, 43}, {128, 128, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {255, 128, 0}, {216, 98, 39}, {211, 100, 44}, {213, 102, 43}, {216, 100, 46}, {216, 100, 46}, {213, 102, 43}, {211, 100, 44}, {213, 106, 43}, {255, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}}, {{0, 0, 0}, {217, 100, 42}, {214, 102, 45}, {214, 102, 45}, {216, 98, 39}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {198, 85, 28}, {214, 101, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {215, 102, 45}, {214, 102, 45}, {213, 106, 43}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {213, 102, 43}, {213, 100, 44}, {213, 101, 45}, {214, 102, 45}, {214, 102, 45}, {215, 102, 45}, {215, 102, 45}, {215, 102, 45}, {215, 102, 45}, {214, 102, 45}, {215, 102, 45}, {213, 102, 44}, {212, 98, 43}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}}, {{0, 0, 0}, {214, 101, 45}, {214, 102, 45}, {204, 102, 51}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {210, 105, 45}, {213, 102, 47}, {215, 102, 45}, {214, 101, 45}, {214, 102, 45}, {214, 102, 45}, {214, 101, 44}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {213, 102, 45}, {214, 102, 45}, {214, 101, 44}, {213, 100, 43}, {216, 101, 44}, {214, 100, 43}, {215, 102, 44}, {213, 102, 45}, {215, 102, 46}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {215, 102, 45}, {216, 102, 44}, {219, 109, 36}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}}, {{0, 0, 0}, {214, 102, 44}, {214, 102, 41}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {227, 85, 28}, {219, 91, 36}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {213, 101, 45}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}}, {{201, 94, 40}, {215, 101, 45}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {204, 102, 51}, {215, 102, 44}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 101, 45}, {214, 102, 43}, {255, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}}, {{209, 93, 46}, {220, 93, 46}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {214, 99, 41}, {215, 100, 45}, {214, 101, 44}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {216, 101, 45}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}}, {{0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {219, 91, 36}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {213, 102, 44}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}}, {{0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {214, 96, 41}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {207, 96, 40}, {0, 0, 0}, {0, 0, 0}}, {{0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {216, 98, 46}, {214, 101, 44}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {213, 102, 44}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {215, 102, 45}, {219, 109, 36}, {0, 0, 0}}, {{0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {200, 91, 36}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {213, 102, 45}, {214, 102, 44}, {214, 100, 44}, {214, 99, 46}, {213, 85, 43}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {220, 97, 44}, {211, 100, 44}, {214, 101, 44}, {214, 102, 45}, {214, 102, 45}, {215, 102, 45}, {0, 0, 0}}, {{0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {213, 106, 43}, {214, 102, 44}, {215, 103, 45}, {214, 102, 45}, {214, 101, 45}, {214, 102, 45}, {214, 101, 44}, {214, 101, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 44}, {214, 102, 45}, {219, 109, 36}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {204, 102, 51}, {213, 102, 44}, {214, 102, 45}, {196, 98, 39}}, {{0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {213, 99, 42}, {213, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 44}, {213, 100, 44}, {204, 102, 51}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}}, {{0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {211, 100, 44}, {215, 102, 46}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 101, 45}, {213, 85, 43}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}}, {{0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {213, 100, 42}, {214, 102, 45}, {214, 101, 45}, {214, 102, 45}, {213, 101, 44}, {216, 98, 39}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {216, 100, 44}, {213, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 101, 43}, {227, 113, 57}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}}, {{0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {213, 85, 43}, {214, 102, 44}, {215, 102, 44}, {214, 102, 44}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 101, 44}, {213, 102, 45}, {214, 101, 44}, {214, 103, 45}, {214, 101, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {215, 102, 45}, {214, 102, 43}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}}, {{0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {206, 98, 39}, {213, 101, 43}, {255, 0, 0}, {0, 0, 0}, {170, 85, 0}, {212, 101, 43}, {213, 102, 44}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {215, 104, 44}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}}, {{0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {255, 0, 0}, {204, 102, 26}, {219, 109, 36}, {215, 103, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {213, 100, 42}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}}, {{0, 0, 0}, {213, 103, 43}, {210, 96, 40}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {213, 128, 43}, {214, 101, 43}, {214, 101, 44}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 101, 45}, {212, 99, 42}, {219, 109, 36}, {204, 102, 51}, {255, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}}, {{0, 0, 0}, {209, 93, 46}, {214, 101, 44}, {209, 104, 35}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {218, 98, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {215, 102, 45}, {214, 102, 45}, {215, 102, 45}, {214, 101, 45}, {214, 101, 45}, {213, 99, 43}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}}, {{0, 0, 0}, {0, 0, 0}, {214, 101, 43}, {215, 102, 45}, {213, 100, 45}, {170, 85, 0}, {0, 0, 0}, {0, 0, 0}, {220, 106, 44}, {215, 102, 45}, {214, 102, 44}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 101, 45}, {214, 101, 44}, {216, 100, 39}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}}, {{0, 0, 0}, {0, 0, 0}, {223, 96, 48}, {214, 102, 45}, {214, 102, 45}, {215, 102, 46}, {214, 102, 45}, {214, 101, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 44}, {215, 98, 44}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}}, {{0, 0, 0}, {0, 0, 0}, {255, 0, 0}, {213, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 101, 44}, {217, 102, 43}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}}, {{0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {216, 100, 39}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {213, 96, 43}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}}, {{0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {213, 102, 44}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 44}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}}, {{0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {213, 99, 43}, {214, 102, 44}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {212, 103, 43}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}}, {{0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {215, 101, 44}, {214, 101, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {217, 103, 43}, {214, 102, 41}, {200, 91, 36}, {221, 102, 51}, {216, 100, 46}, {213, 99, 43}, {214, 102, 44}, {213, 102, 44}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}}, {{0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {214, 100, 43}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 103, 45}, {214, 101, 45}, {210, 98, 38}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {208, 101, 40}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}}, {{0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {214, 101, 43}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {215, 102, 45}, {214, 101, 45}, {210, 100, 40}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}}, {{0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {207, 104, 40}, {214, 101, 45}, {215, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {213, 85, 21}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}}, {{0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {230, 102, 51}, {212, 100, 42}, {214, 101, 44}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {214, 102, 45}, {213, 102, 44}, {213, 101, 44}, {215, 107, 40}, {255, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}}, {{0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {191, 64, 64}, {211, 102, 44}, {215, 101, 45}, {213, 101, 46}, {214, 102, 45}, {215, 101, 43}, {216, 103, 44}, {211, 100, 44}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}}, {{0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}}, {{0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}}, {{0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}}, {{0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}}, {{0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}}, {{0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}}};
    delay(200);
    FastLED.addLeds<APA102, data, clock, BGR >(currentLED, totalLEDs);
    FastLED.setBrightness(LEDBrightness);
    pinMode(powerLED, OUTPUT);
    digitalWrite(powerLED, ON);
    drawImage(30, Image, width(Image));
    unsigned long currentTime = millis();
    while (millis() < currentTime + (time * 1000))
    for(int slice = 0; slice < pictureWidth; slice ++)
    for(int LED = totalLEDs-1; LED > -1; LED --) // LED number
    currentLED[LED].setRGB(pattern[slice] [LED] [redVal],
    pattern[slice] [LED] [greenVal],
    pattern[slice] [LED] [blueVal]);
    FastLED.show();
    delayMicroseconds(800); // How wide the image is
    delayMicroseconds(1000); // Gap between images
  5. #355
    Nov 2018
    17
    Code from Adafruit https://learn.adafruit.com/supernova-poi/code-1 is working fine..
    but i have no luck with Invisibug code or with mortonkopf code.. im smashing my head what could be wrong.
  6. #356
    Sep 2015
    161
    Where did you went wrong, does it compile?
    or just not showing intended picture at all?
    you have a working example so the hardware should be fine I guess,
    however your example from adafruit doesn't use FASTLED.
    I guess you should define your SPI clock speed as I didn't see it above ?
    FastLED.addLeds<APA102, 11, 13, BGR, DATA_RATE_MHZ(8)>(leds, NUM_LEDS);
    SPIing too fast does chaos to APA102 (over 20Mhz is enough to make something wrong, over a chain of 80LEDS)
  7. #357
    Nov 2018
    17
    Quote Originally Posted by Po Ting View Post
    i dont know how to incorporate this in code, i tried but it not worked. Then i changed teensy frequency on 24mhz and it is working i dont know if this is good way to do it but sure Po Ting you are right that too fast SPI is making leds crazy
    Post that QR code so i can pay you a beer
  8. #358
    Sep 2015
    161
    glad it worked,
    switch your line from
    to
    FastLED.addLeds<APA102, data, clock, BGR, DATA_RATE_MHZ(8)>(currentLED, totalLEDs);
    should do the job, otherwise update your FASTLED library?
    I don't know what QR code could let beer reaches me :\ wonder if there's that kind of e-wallet app here in TW.
    so thanks is enough
    you can show off your job when you're complete
  9. #359
    Nov 2018
    17
    glad it worked,
    to
    so thanks is enough
    if i put your part of code then i get no light
    but it is working nice at 24mhz.. if i set this in arduino IDE
    we use https://wirexapp.com/ alot it is free crypto account with free visa card. If you will try i will send XRP or Waves crypto for beer one step futher to making world united
  10. #360
    Feb 2018
    18
    Thanks for the question MasterSlave.
    If you'd like to read more about APA102 data rates check out this article
    Cheers
    InvisiBug
  11. #361
    Nov 2018
    17
    Thank you all guys for help.
    Final result: https://m.youtube.com/watch?v=XK_9Lk...ature=youtu.be
    I need to make some minor corrections on 3d design (place for wires) and then i will upload it if anyone wants to make kungfu POV staff 😀
  12. #362
    Hi everyone. Nice project, I like it. Thanks for the information.
  13. #363
    Jun 2019
    11
    Hello all!
    Just planning to start working on this build with a few modifications. I will keep updated on my progress, but I am just in the ordering/planning stage right now and have a few questions. Please excuse my noobishness, this is my first go at a POV LED project and have very limited experience.
    My main question at this point is about the necessity of the charger in the circuit. I plan to use these solely at festivals and will not have access to charge them via USB with any reliability. Therefore, I will only be able to continue use by swapping batteries regularly.
    My thoughts here are to hold all electronics in the handle I plan to fabricate (think short lightsaber handle) and then use an 18650 sled so that I can unscrew the bottom of the handle and slide the sled out to swap the battery quick. I will never really need to charge the batteries in the device. This seems like it would reduce some of the hassle of wiring and fitment as well as make it so that I can easily use the original Teensy port for updating patterns etc..without any modification to the board.
    So, does the charger have any other function besides that? Protection? Regulation? I plan to use protected cells so I don't think I will need the former...
    Any thoughts you can share would be greatly appreciated.
    Also, any advice on sourcing APA102 or APA107s would be a dream. I have probably inquired with a dozen Chinese manufacturers and done 1000 google searches to no avail. I see that Adafruit sells APA102C's but I am not certain that they will have the same functionality for this project from reading the conflicting information online.
  14. #364
    Apr 2013
    London, uk
    912
    Hi, enjoy build the POV. you don't need to use the charging circuit, you can use a battery sled. I used one on an earlier version when testing, it was 4 AAA rechargeable (but recharging using a stand alone charger). These come out at about 4 x 1.2v when charged. You might want to use 3 non rechargeable 1.5v. all this changed to keep the weight down, hence the single cell built in recharge option, but yes, put a single cell in a sled, should not be problem.
    HOWEVER - cut the trace between underside pads as directed here for using external power. https://www.pjrc.com/teensy/external_power.html
    Also, when uploading after this set up, you will have to power the teensy from your battery source, as it will not receive power from the usb connection.
  15. #365
    Jun 2019
    11
    Quote Originally Posted by mortonkopf View Post
    Thanks so much for the quick reply! And I appreciate the build guide. Using it as a base is super helpful. Just want to get the basic structure/mechanics figured out and then it's into deep water for me with programming/coding and all of that. I have some really cool ideas for making it look professional.
    To be clear, I will just be cutting that trace to separate the two power sources, but I will still be able to have it powered by the battery and then use the plug on the board for serial connection and uploading patterns etc.. is that right? And then I can always add the charger later if I wanted to I suppose.
    Also, I have some 1 1/4in polycarbonate tube with an 1/8in wall, so 1in inside diameter. Is there any reason not to use this? Polycarbonate is expensive to order online and no good suppliers nearby me.
    Another question, does there need to be a gap between the strip holding the lights and the edge of the tube or can it fit snug against the sides? I plan to use a black metal strip and try to replicate the look of the Ignis pixel poi. It appears theirs doesn't have much of a gap there is any, so I assume my idea is viable, but am worried that I am missing something.
    Thanks again, I really appreciate how responsive you still are even though this project is older. Have you made any big improvements on this or redone anything that you thought needed improving? Any ideas you have to make it even better would be awesome!
    For example I like the idea of SD card that's getting thrown around, but am a bit worried I don't have the technical skill on the software end to implement it. How difficult was this for you?
  16. #366
    Jun 2019
    11
    Sorry for an additional message, I can't figure out how to edit my previous post.
    Can I use the Teensy 3.6 running it with an 18650 and a 5V strip?
    I just realized after ordering them that the digital pins aren't 5V tolerant like the 3.5... is that going to be an issue running the strip? I know I can run the VIN with the battery up to 6V. But do I need to step down to the 3.5 in order to run the data to the strip without messing up the board?
  17. #367
    Apr 2013
    London, uk
    912
    regarding voltage for lef strips, there have been a lot of different experiences from users here on the forum. I successfully run the 5v led strips from a single. IT seems to be the difference in voltage to the led strip compared to the data logic voltage that sometimes causes an issue. I.e the data line being at 3.3v and the less being at 5v, but I have not personally come across this issue. Its may be led strip manufacturer variation, but I would just hook it up and test.
    No need to worry about the pins being 5v tolerant for your application as the power source, your battery connections, should not be going anywhere near your data pins. If you connect the power leads to the data pins, then yes, problems. Only connect the battery source to the power pins. I would not use a 6v battery, Try sourcing a lower voltage so that the gap between data logic V and power V are closer together.
    Teensy 3.6 dimensions: https://forum.pjrc.com/threads/50122-3-6-3-5-Dimensions
    there are a lot of discussion on the forum about usb upload while using battery power, eg, https://forum.pjrc.com/threads/42487...l-power-recap?
    https://forum.pjrc.com/threads/55199...-at-same-time?
  18. #368
    Jun 2019
    11
    Thanks, I'll get a bit further into the project and then ask more questions probably. Getting everything but the light strips early next week. Still having trouble finding a source who can get them to me quick.
    Are APA102C's from adafruit the same for POV projects like this?
    Thanks again, really appreciate it.
  19. #369
    Jun 2019
    11
    Thanks again for your help.
    Do you have a donate link for this project or Paypal?
    Most guides online I've seen and am using for ideas followed your lead so I think you deserve the donate.
    Let me know, thanks!
  20. #370
    Sep 2015
    161
    Quote Originally Posted by abrownmn View Post
    apa102c and apa102 (or sk9812 from China clone)
    those use SPI wires are probably all usable with FASTLED library with apa102 setup,
    if you were looking for a source, I know the origin company contact of the Intellectual design in Taiwan.
  21. #371
    Jun 2019
    11
    Thanks! Yes, if you could share the contact I'd appreciate it. I am in a bit of a hurry to get it done and know it will take some time so I just ordered off Adafruit for now, but I plan to make more projects.
    Have you had any experience with using apa107? I am curious since they are built in a similar style as the APA102 series if they can be used with FastLED library as well.
  22. #372
    Apr 2013
    London, uk
    912
    oh, nope, its all cool as is its all for sharing, but thanks for the offer. It s been a collaborative effort by a lot people on this thread / forum...
  23. #373
    Jun 2019
    11
    Well Thanks, I cant express how much I appreciate it.
    So, I got my stuff together and I am using an image converter and all settings seem to be right, newest libraries, teensyloader, teensyduino and all of that fresh.
    When I run the code I get a quick flash of what appears to be the image I've uploaded and then it blinks out right away. Also, Doesnt seem to be grabbing the correct amount of LEDs even when it holds for a few seconds.
    No error messages pop up, so nothing to go on for me there.
    Any thoughts on what that may be?
  24. #374
    Feb 2018
    18
    Please post your code so we can look it over for mistakes.
  25. #375
    Jun 2019
    11
    Quote Originally Posted by InvisiBug View Post
    Here is what I have in there right now, just one array.. lots of pink. I got it to light up all of the LEDs on a single strip now for testing purposes. It flashes for a second or two and then stays solid. Maybe I am misunderstanding how it works, but it seems like it should continue flashing in order to create the image when spun up? It's too delicate of a state to spin up at the moment. Code is fully loading through and there is a mix of solid pink/purple/white LEDs.
    What do I do to maybe test a loop between two different images and make sure it's bouncing back and forth? And do most images continue to flash/blink like I expect or do I have that all wrong?
    I am totally new to this programming arduino, but it seems super simple the way you guys have it written up already and it's just like there's a key piece of info I am missing or misunderstanding...
    Perhaps you have a new, known piece of code that will act in a way that you know to prove functionality without spinning it up?
    Also worth noting that I am running a teensy 3.6, but using the same circuit as your Orbit v2..haven't added the switch or charger to the circuit yet.
    Thoughts?
    // Orbit POI
    // Orbit.ino
    // 2018
    #include <stdlib.h>
    #define LEDBrightness 50
    #define powerLED 13
    #define data 11 // yellow
    #define clock 13 // green
    #define OFF LOW
    #define ON HIGH
    #define redVal 0
    #define greenVal 1
    #define blueVal 2
    const char Image[][totalLEDs][3] = {{{0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {4, 15, 6}, {6, 17, 9}, {9, 10, 11}, {5, 12, 9}, {12, 21, 12}, {5, 5, 5}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}}, {{0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {6, 0, 0}, {6, 0, 0}, {10, 10, 10}, {19, 13, 23}, {23, 10, 12}, {6, 5, 15}, {19, 17, 20}, {23, 12, 9}, {2, 8, 5}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}}, {{0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 5, 5}, {0, 0, 12}, {29, 11, 12}, {201, 100, 95}, {224, 93, 88}, {218, 83, 95}, {213, 101, 118}, {128, 64, 80}, {33, 0, 11}, {16, 0, 0}, {0, 0, 0}, {0, 6, 0}, {6, 0, 7}, {6, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 7}, {0, 6, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 6, 0}, {6, 0, 0}, {0, 0, 6}, {0, 0, 0}, {6, 0, 0}, {6, 0, 0}, {6, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {6, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 6, 0}, {0, 6, 0}, {0, 0, 0}, {2, 0, 0}, {7, 0, 0}, {6, 0, 7}, {6, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}}, {{3, 7, 0}, {0, 0, 11}, {0, 0, 8}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {24, 17, 12}, {58, 2, 5}, {228, 85, 73}, {225, 30, 81}, {211, 0, 87}, {217, 8, 94}, {226, 0, 87}, {224, 1, 84}, {229, 8, 83}, {193, 21, 73}, {213, 68, 108}, {175, 55, 92}, {58, 3, 25}, {21, 0, 2}, {14, 5, 4}, {13, 6, 1}, {16, 8, 7}, {17, 1, 14}, {4, 4, 8}, {6, 6, 6}, {12, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 3, 0}, {0, 0, 0}, {6, 0, 0}, {13, 18, 18}, {31, 1, 19}, {2, 15, 18}, {25, 1, 0}, {69, 13, 20}, {58, 14, 18}, {49, 2, 17}, {44, 1, 7}, {35, 0, 14}, {26, 2, 2}, {27, 0, 8}, {24, 1, 8}, {17, 0, 0}, {13, 0, 0}, {14, 0, 14}, {13, 0, 15}, {8, 3, 10}, {1, 12, 15}, {7, 0, 0}, {8, 12, 10}, {1, 12, 11}, {8, 12, 8}, {19, 9, 6}, {1, 12, 1}, {7, 7, 7}, {10, 0, 8}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}}, {{9, 1, 29}, {4, 0, 15}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {5, 5, 16}, {221, 134, 135}, {218, 22, 85}, {167, 0, 84}, {115, 4, 85}, {66, 0, 68}, {74, 0, 73}, {86, 0, 79}, {93, 0, 82}, {114, 0, 85}, {148, 16, 101}, {189, 0, 105}, {193, 5, 98}, {170, 6, 85}, {159, 38, 97}, {142, 54, 100}, {87, 14, 53}, {57, 8, 26}, {42, 5, 18}, {23, 2, 6}, {1, 12, 0}, {0, 0, 0}, {0, 0, 0}, {0, 3, 0}, {0, 0, 0}, {6, 0, 1}, {26, 13, 12}, {58, 19, 15}, {208, 108, 110}, {224, 104, 97}, {222, 102, 84}, {219, 90, 64}, {236, 88, 87}, {236, 73, 84}, {242, 73, 87}, {232, 58, 74}, {243, 79, 89}, {230, 75, 81}, {240, 91, 95}, {228, 93, 103}, {226, 103, 106}, {226, 110, 111}, {227, 117, 118}, {217, 120, 115}, {180, 93, 94}, {110, 39, 42}, {74, 13, 21}, {51, 1, 11}, {29, 16, 17}, {26, 8, 13}, {15, 1, 1}, {1, 9, 4}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}}, {{26, 45, 119}, {27, 29, 101}, {5, 7, 46}, {7, 13, 20}, {15, 8, 17}, {6, 7, 13}, {9, 7, 4}, {3, 9, 14}, {8, 5, 15}, {0, 0, 10}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {21, 0, 0}, {221, 65, 95}, {177, 0, 106}, {63, 0, 79}, {21, 2, 77}, {17, 0, 65}, {18, 0, 68}, {17, 0, 69}, {15, 0, 71}, {18, 3, 70}, {17, 7, 65}, {29, 0, 53}, {54, 0, 55}, {70, 0, 62}, {67, 1, 60}, {112, 0, 72}, {163, 0, 92}, {185, 16, 94}, {209, 26, 96}, {200, 43, 96}, {60, 0, 19}, {35, 4, 9}, {36, 2, 7}, {30, 15, 16}, {49, 4, 15}, {76, 12, 14}, {227, 111, 123}, {180, 63, 83}, {44, 14, 39}, {20, 10, 40}, {55, 0, 33}, {231, 91, 76}, {239, 58, 84}, {241, 15, 87}, {234, 0, 95}, {234, 3, 94}, {236, 0, 89}, {235, 0, 84}, {246, 0, 85}, {251, 4, 96}, {248, 0, 84}, {251, 0, 91}, {253, 12, 90}, {241, 25, 80}, {247, 40, 82}, {239, 38, 87}, {251, 53, 107}, {236, 53, 86}, {233, 83, 95}, {217, 85, 92}, {185, 95, 96}, {109, 32, 43}, {54, 5, 11}, {28, 17, 12}, {15, 17, 10}, {10, 6, 15}, {19, 3, 14}}, {{14, 2, 25}, {5, 16, 54}, {29, 53, 128}, {27, 38, 136}, {13, 19, 80}, {12, 6, 35}, {14, 9, 18}, {17, 10, 12}, {3, 3, 10}, {0, 0, 11}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {18, 11, 2}, {214, 28, 82}, {104, 0, 79}, {24, 8, 67}, {7, 1, 57}, {13, 1, 68}, {10, 0, 75}, {11, 4, 77}, {11, 2, 83}, {11, 7, 80}, {10, 1, 75}, {9, 2, 72}, {9, 3, 67}, {21, 2, 64}, {10, 8, 58}, {11, 0, 51}, {50, 0, 61}, {88, 0, 72}, {147, 0, 93}, {188, 0, 90}, {213, 6, 82}, {234, 46, 94}, {240, 60, 94}, {232, 70, 89}, {236, 67, 91}, {231, 52, 94}, {165, 13, 61}, {24, 16, 41}, {31, 0, 48}, {15, 10, 50}, {28, 8, 58}, {174, 93, 82}, {220, 34, 101}, {203, 0, 122}, {169, 0, 132}, {151, 0, 153}, {130, 0, 165}, {120, 0, 153}, {135, 0, 143}, {148, 0, 149}, {152, 0, 143}, {144, 0, 146}, {154, 0, 157}, {160, 0, 152}, {158, 0, 147}, {177, 0, 145}, {210, 10, 149}, {210, 0, 130}, {218, 0, 110}, {220, 9, 102}, {223, 28, 92}, {227, 32, 74}, {231, 25, 68}, {241, 80, 103}, {166, 74, 74}, {71, 6, 5}, {14, 18, 7}}, {{2, 8, 17}, {14, 9, 20}, {23, 5, 18}, {10, 1, 20}, {10, 18, 64}, {31, 56, 140}, {21, 35, 114}, {14, 22, 55}, {9, 2, 18}, {0, 0, 13}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {6, 6, 6}, {16, 21, 7}, {240, 36, 110}, {85, 0, 74}, {16, 0, 59}, {10, 0, 72}, {17, 11, 107}, {17, 13, 109}, {19, 17, 113}, {16, 14, 114}, {17, 18, 112}, {14, 17, 108}, {12, 20, 102}, {13, 13, 95}, {12, 13, 81}, {9, 0, 69}, {12, 12, 67}, {20, 0, 69}, {23, 2, 74}, {78, 0, 98}, {116, 0, 100}, {162, 0, 100}, {187, 1, 103}, {227, 28, 111}, {222, 11, 87}, {212, 18, 88}, {178, 1, 81}, {83, 10, 27}, {204, 76, 58}, {201, 81, 77}, {113, 48, 57}, {12, 15, 68}, {171, 71, 111}, {145, 31, 135}, {101, 25, 177}, {51, 21, 168}, {28, 27, 173}, {31, 23, 173}, {21, 20, 173}, {28, 19, 188}, {27, 16, 170}, {25, 20, 160}, {25, 14, 166}, {25, 6, 168}, {27, 3, 173}, {39, 3, 177}, {44, 36, 191}, {40, 23, 176}, {50, 22, 179}, {45, 0, 159}, {68, 3, 154}, {109, 24, 165}, {124, 7, 151}, {161, 1, 133}, {202, 2, 120}, {233, 22, 127}, {233, 33, 89}, {245, 100, 114}}, {{0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {19, 4, 16}, {5, 0, 38}, {13, 32, 88}, {38, 46, 110}, {79, 32, 54}, {70, 0, 5}, {71, 33, 30}, {19, 1, 1}, {19, 0, 11}, {25, 8, 19}, {30, 5, 5}, {226, 2, 97}, {45, 13, 73}, {14, 0, 71}, {7, 10, 63}, {20, 21, 121}, {18, 9, 147}, {18, 26, 139}, {20, 26, 142}, {21, 24, 132}, {15, 12, 116}, {21, 0, 113}, {23, 0, 109}, {19, 0, 108}, {18, 0, 86}, {20, 0, 87}, {14, 0, 77}, {14, 0, 74}, {32, 0, 71}, {48, 0, 80}, {83, 0, 100}, {97, 0, 110}, {145, 0, 118}, {168, 0, 119}, {156, 0, 103}, {96, 10, 23}, {190, 89, 70}, {214, 84, 65}, {219, 91, 75}, {202, 97, 83}, {25, 5, 45}, {152, 84, 111}, {114, 24, 158}, {68, 43, 175}, {24, 16, 158}, {20, 28, 167}, {21, 0, 145}, {21, 0, 128}, {17, 1, 124}, {22, 10, 128}, {21, 13, 118}, {27, 0, 104}, {24, 0, 96}, {27, 7, 93}, {30, 0, 97}, {35, 0, 84}, {23, 0, 101}, {15, 0, 107}, {17, 5, 109}, {19, 1, 129}, {21, 0, 128}, {23, 18, 142}, {25, 34, 160}, {35, 5, 150}, {83, 14, 152}, {141, 2, 149}, {207, 0, 125}}, {{0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {8, 4, 19}, {4, 12, 11}, {69, 21, 19}, {195, 94, 73}, {234, 92, 75}, {236, 89, 77}, {238, 69, 85}, {223, 61, 88}, {240, 108, 138}, {127, 18, 44}, {202, 30, 77}, {205, 20, 119}, {48, 0, 73}, {11, 2, 74}, {10, 0, 68}, {16, 1, 94}, {32, 19, 165}, {21, 27, 166}, {19, 23, 158}, {21, 22, 148}, {16, 16, 136}, {19, 23, 136}, {23, 12, 132}, {26, 12, 125}, {24, 2, 118}, {24, 14, 100}, {15, 0, 101}, {18, 0, 112}, {14, 10, 101}, {29, 0, 76}, {57, 4, 55}, {117, 42, 59}, {149, 57, 86}, {114, 32, 57}, {181, 83, 106}, {208, 79, 98}, {175, 60, 70}, {172, 63, 75}, {159, 65, 63}, {173, 100, 100}, {23, 1, 43}, {171, 69, 99}, {126, 9, 117}, {88, 2, 101}, {136, 59, 128}, {83, 16, 73}, {99, 29, 87}, {141, 65, 120}, {182, 98, 138}, {143, 66, 96}, {89, 35, 63}, {127, 38, 89}, {117, 49, 80}, {116, 26, 51}, {89, 10, 65}, {106, 29, 71}, {98, 33, 70}, {47, 10, 46}, {49, 11, 63}, {74, 33, 116}, {42, 3, 80}, {35, 21, 84}, {18, 1, 80}, {17, 1, 104}, {32, 21, 144}, {21, 10, 150}, {47, 28, 162}}, {{9, 10, 0}, {7, 6, 8}, {16, 10, 13}, {21, 5, 6}, {10, 4, 0}, {6, 17, 17}, {61, 9, 23}, {231, 115, 93}, {233, 64, 82}, {235, 22, 88}, {225, 3, 80}, {218, 9, 110}, {194, 8, 100}, {200, 6, 111}, {207, 15, 107}, {243, 3, 85}, {113, 0, 85}, {36, 2, 77}, {11, 0, 74}, {18, 0, 84}, {24, 0, 91}, {86, 39, 176}, {29, 34, 192}, {29, 24, 166}, {36, 12, 164}, {46, 9, 146}, {47, 0, 126}, {88, 4, 134}, {103, 2, 106}, {88, 4, 102}, {87, 15, 73}, {159, 84, 136}, {102, 38, 90}, {101, 26, 63}, {197, 92, 89}, {221, 95, 82}, {206, 87, 85}, {189, 76, 82}, {182, 69, 98}, {141, 32, 91}, {110, 16, 80}, {146, 42, 99}, {122, 34, 75}, {158, 71, 83}, {149, 78, 93}, {67, 22, 38}, {201, 96, 97}, {185, 79, 130}, {170, 59, 108}, {124, 19, 79}, {157, 55, 102}, {83, 32, 99}, {118, 23, 113}, {87, 5, 69}, {179, 80, 116}, {94, 24, 53}, {103, 26, 102}, {108, 10, 57}, {195, 63, 87}, {126, 18, 57}, {62, 18, 67}, {131, 40, 74}, {121, 49, 95}, {102, 53, 105}, {98, 33, 93}, {133, 41, 99}, {133, 56, 68}, {80, 9, 66}, {63, 5, 69}, {76, 25, 100}, {72, 35, 108}, {69, 30, 131}}, {{20, 10, 7}, {13, 13, 4}, {22, 12, 4}, {54, 0, 8}, {74, 0, 19}, {59, 7, 17}, {204, 90, 90}, {227, 49, 93}, {231, 3, 99}, {214, 0, 115}, {160, 0, 93}, {136, 0, 106}, {116, 1, 116}, {108, 1, 137}, {225, 67, 143}, {206, 18, 95}, {55, 0, 71}, {9, 5, 77}, {9, 7, 78}, {12, 7, 85}, {20, 7, 90}, {123, 23, 146}, {91, 0, 161}, {115, 0, 147}, {167, 15, 129}, {180, 32, 99}, {184, 50, 88}, {213, 68, 92}, {231, 75, 95}, {228, 73, 78}, {131, 33, 65}, {83, 28, 77}, {151, 66, 82}, {214, 97, 87}, {203, 90, 72}, {167, 66, 68}, {139, 48, 78}, {140, 31, 114}, {113, 3, 117}, {115, 0, 114}, {141, 15, 110}, {131, 47, 98}, {108, 32, 75}, {155, 72, 95}, {111, 53, 74}, {167, 93, 106}, {168, 49, 71}, {136, 41, 100}, {127, 28, 80}, {105, 9, 62}, {194, 76, 89}, {97, 26, 63}, {63, 18, 69}, {135, 46, 116}, {182, 71, 111}, {128, 47, 61}, {61, 6, 52}, {94, 22, 63}, {123, 14, 60}, {79, 2, 53}, {73, 6, 79}, {54, 8, 70}, {72, 6, 75}, {85, 0, 60}, {76, 31, 59}, {75, 3, 81}, {90, 5, 79}, {111, 2, 71}, {78, 15, 75}, {103, 52, 102}, {150, 66, 119}, {113, 18, 75}}, {{9, 13, 5}, {56, 15, 25}, {198, 64, 110}, {216, 19, 98}, {241, 34, 115}, {192, 12, 71}, {231, 3, 94}, {223, 2, 102}, {181, 0, 104}, {138, 2, 100}, {118, 0, 87}, {100, 0, 91}, {85, 0, 115}, {76, 3, 180}, {217, 74, 135}, {182, 4, 107}, {49, 5, 79}, {32, 0, 81}, {17, 0, 75}, {22, 0, 85}, {47, 0, 92}, {202, 21, 114}, {201, 23, 106}, {228, 59, 101}, {234, 93, 90}, {243, 104, 95}, {230, 87, 70}, {217, 88, 68}, {219, 93, 102}, {122, 28, 59}, {69, 24, 59}, {60, 9, 65}, {159, 82, 125}, {208, 96, 93}, {158, 58, 66}, {121, 28, 70}, {127, 28, 112}, {94, 0, 104}, {78, 5, 105}, {109, 24, 121}, {124, 15, 101}, {110, 7, 84}, {113, 22, 97}, {133, 41, 103}, {50, 0, 43}, {197, 86, 98}, {204, 97, 89}, {137, 12, 70}, {175, 67, 124}, {121, 28, 87}, {165, 52, 97}, {129, 40, 103}, {111, 31, 94}, {178, 75, 137}, {85, 6, 88}, {77, 13, 82}, {47, 5, 81}, {136, 15, 68}, {147, 34, 74}, {216, 62, 92}, {206, 94, 118}, {194, 90, 128}, {174, 73, 113}, {164, 58, 85}, {198, 87, 69}, {101, 24, 63}, {156, 70, 116}, {172, 53, 112}, {89, 7, 58}, {171, 72, 111}, {87, 13, 65}, {87, 3, 63}}, {{83, 3, 29}, {167, 51, 135}, {128, 2, 131}, {191, 7, 152}, {205, 33, 151}, {227, 32, 125}, {231, 0, 112}, {168, 0, 104}, {128, 0, 96}, {98, 0, 89}, {104, 0, 96}, {88, 0, 92}, {84, 0, 122}, {85, 0, 154}, {183, 50, 125}, {188, 32, 108}, {59, 1, 93}, {44, 0, 85}, {29, 5, 89}, {21, 20, 86}, {153, 31, 91}, {229, 60, 92}, {245, 99, 92}, {205, 76, 59}, {188, 94, 89}, {192, 76, 105}, {204, 109, 132}, {109, 7, 54}, {136, 21, 83}, {188, 37, 116}, {191, 100, 150}, {84, 26, 72}, {47, 6, 82}, {181, 97, 117}, {160, 48, 73}, {103, 27, 86}, {135, 49, 137}, {94, 5, 111}, {75, 0, 106}, {91, 3, 98}, {106, 6, 90}, {138, 19, 116}, {153, 20, 119}, {94, 5, 83}, {57, 11, 54}, {142, 17, 27}, {236, 107, 110}, {195, 69, 113}, {154, 39, 100}, {114, 2, 70}, {184, 66, 109}, {89, 4, 64}, {111, 6, 87}, {130, 25, 70}, {195, 59, 111}, {219, 85, 111}, {105, 26, 70}, {226, 66, 114}, {152, 21, 80}, {174, 65, 91}, {182, 47, 93}, {63, 0, 55}, {60, 0, 58}, {143, 39, 108}, {153, 1, 53}, {120, 45, 96}, {110, 14, 100}, {116, 19, 93}, {125, 26, 88}, {165, 49, 77}, {102, 15, 48}, {161, 35, 101}}, {{170, 0, 131}, {118, 22, 171}, {44, 43, 157}, {104, 26, 182}, {113, 4, 103}, {215, 0, 102}, {169, 0, 107}, {119, 0, 104}, {90, 0, 89}, {84, 0, 88}, {96, 0, 95}, {114, 0, 112}, {141, 0, 126}, {144, 9, 141}, {167, 34, 120}, {211, 78, 103}, {173, 28, 89}, {133, 18, 103}, {109, 16, 83}, {217, 98, 119}, {232, 112, 93}, {170, 52, 66}, {180, 73, 129}, {103, 28, 85}, {128, 24, 94}, {92, 5, 70}, {78, 7, 99}, {77, 0, 96}, {110, 49, 113}, {99, 12, 66}, {114, 28, 109}, {109, 2, 79}, {86, 26, 95}, {139, 57, 76}, {184, 79, 102}, {108, 5, 78}, {127, 42, 128}, {84, 0, 89}, {109, 8, 109}, {102, 0, 100}, {89, 0, 98}, {93, 13, 93}, {138, 2, 91}, {158, 70, 137}, {71, 10, 49}, {158, 58, 73}, {135, 19, 84}, {162, 37, 123}, {137, 0, 85}, {174, 27, 101}, {220, 42, 88}, {188, 86, 88}, {159, 68, 130}, {161, 25, 120}, {142, 29, 120}, {140, 34, 88}, {206, 69, 129}, {108, 3, 66}, {232, 89, 117}, {192, 22, 60}, {147, 33, 99}, {119, 43, 113}, {103, 16, 64}, {209, 67, 130}, {188, 9, 70}, {124, 11, 69}, {177, 78, 106}, {63, 5, 74}, {103, 12, 97}, {93, 7, 71}, {67, 1, 73}, {73, 1, 89}}, {{105, 0, 126}, {70, 40, 152}, {61, 51, 183}, {22, 54, 187}, {177, 35, 143}, {176, 0, 107}, {97, 1, 94}, {82, 0, 88}, {74, 0, 86}, {97, 0, 91}, {131, 0, 110}, {147, 0, 129}, {170, 2, 122}, {187, 5, 98}, {211, 42, 105}, {201, 58, 93}, {212, 78, 85}, {236, 96, 98}, {212, 105, 106}, {170, 42, 91}, {106, 15, 80}, {85, 3, 92}, {132, 35, 115}, {189, 88, 148}, {56, 15, 85}, {104, 11, 101}, {98, 1, 74}, {121, 18, 75}, {134, 42, 95}, {125, 7, 120}, {148, 40, 136}, {107, 16, 81}, {76, 7, 89}, {82, 27, 62}, {111, 27, 70}, {90, 0, 94}, {116, 6, 110}, {111, 3, 108}, {156, 7, 116}, {146, 21, 116}, {87, 0, 97}, {93, 1, 99}, {102, 2, 92}, {130, 21, 105}, {85, 9, 49}, {204, 88, 75}, {219, 113, 124}, {206, 43, 81}, {198, 64, 98}, {170, 54, 121}, {189, 27, 105}, {190, 41, 107}, {49, 7, 76}, {80, 6, 75}, {91, 14, 71}, {144, 38, 112}, {190, 73, 120}, {183, 74, 141}, {253, 69, 126}, {253, 66, 71}, {243, 92, 94}, {102, 4, 76}, {166, 27, 116}, {197, 59, 102}, {90, 3, 33}, {177, 40, 91}, {243, 87, 84}, {207, 94, 114}, {51, 9, 83}, {80, 0, 83}, {113, 15, 96}, {171, 40, 112}}, {{34, 1, 92}, {54, 27, 137}, {30, 43, 169}, {51, 24, 166}, {165, 26, 125}, {118, 0, 111}, {85, 0, 92}, {97, 0, 88}, {144, 28, 103}, {145, 4, 91}, {169, 23, 118}, {200, 40, 127}, {207, 39, 94}, {231, 60, 86}, {237, 92, 72}, {235, 109, 85}, {205, 115, 114}, {142, 53, 96}, {87, 11, 75}, {116, 52, 127}, {59, 6, 57}, {159, 19, 91}, {108, 20, 89}, {134, 29, 134}, {136, 34, 104}, {215, 83, 160}, {72, 12, 83}, {38, 4, 74}, {117, 15, 116}, {106, 26, 74}, {194, 78, 131}, {102, 0, 92}, {110, 35, 141}, {45, 12, 87}, {175, 84, 112}, {120, 1, 94}, {128, 22, 118}, {62, 11, 100}, {84, 0, 95}, {73, 1, 103}, {73, 0, 98}, {110, 0, 111}, {116, 0, 112}, {153, 24, 110}, {86, 12, 44}, {212, 101, 87}, {247, 105, 74}, {208, 99, 99}, {115, 7, 97}, {111, 4, 77}, {183, 36, 88}, {138, 20, 94}, {118, 17, 75}, {97, 9, 48}, {70, 0, 75}, {129, 8, 93}, {230, 83, 117}, {137, 2, 89}, {218, 22, 111}, {252, 66, 100}, {246, 85, 88}, {162, 55, 90}, {125, 0, 81}, {242, 69, 115}, {123, 0, 77}, {149, 0, 79}, {224, 51, 95}, {237, 91, 108}, {59, 0, 63}, {127, 20, 93}, {188, 83, 120}, {109, 16, 80}}, {{14, 27, 106}, {35, 34, 136}, {20, 39, 157}, {66, 4, 131}, {134, 3, 110}, {96, 0, 103}, {121, 14, 103}, {137, 24, 100}, {133, 11, 89}, {160, 32, 90}, {191, 49, 81}, {219, 65, 76}, {241, 94, 86}, {236, 106, 92}, {178, 67, 82}, {126, 18, 68}, {110, 21, 97}, {156, 42, 99}, {88, 11, 43}, {97, 14, 77}, {187, 40, 111}, {103, 9, 79}, {68, 11, 88}, {101, 22, 95}, {117, 30, 114}, {113, 9, 92}, {147, 31, 120}, {159, 21, 102}, {225, 63, 122}, {82, 26, 71}, {76, 3, 88}, {51, 0, 86}, {117, 10, 118}, {99, 12, 115}, {161, 101, 128}, {169, 35, 100}, {117, 34, 109}, {85, 18, 109}, {125, 5, 121}, {98, 12, 117}, {144, 6, 109}, {203, 32, 135}, {169, 0, 111}, {218, 36, 120}, {195, 68, 113}, {179, 99, 103}, {217, 81, 98}, {193, 34, 81}, {219, 63, 133}, {151, 15, 110}, {214, 49, 116}, {171, 38, 100}, {237, 67, 93}, {253, 79, 80}, {235, 106, 130}, {116, 9, 93}, {230, 35, 118}, {153, 14, 75}, {213, 51, 119}, {211, 65, 104}, {234, 110, 118}, {185, 89, 110}, {81, 13, 78}, {110, 1, 67}, {103, 7, 73}, {137, 0, 72}, {188, 30, 90}, {196, 56, 89}, {59, 7, 48}, {147, 48, 95}, {226, 70, 119}, {177, 78, 128}}, {{45, 47, 137}, {36, 34, 127}, {20, 34, 138}, {94, 1, 126}, {109, 0, 99}, {123, 11, 101}, {124, 10, 92}, {151, 42, 99}, {167, 56, 95}, {203, 70, 79}, {228, 96, 89}, {231, 101, 84}, {176, 69, 79}, {139, 26, 73}, {178, 82, 151}, {100, 20, 90}, {185, 72, 145}, {131, 36, 84}, {113, 25, 85}, {129, 33, 86}, {143, 39, 107}, {94, 0, 78}, {231, 67, 142}, {200, 57, 114}, {73, 9, 93}, {75, 2, 77}, {182, 49, 121}, {164, 36, 96}, {188, 24, 112}, {123, 15, 85}, {175, 66, 132}, {194, 73, 143}, {127, 25, 105}, {119, 28, 104}, {126, 98, 126}, {153, 33, 101}, {90, 0, 111}, {90, 0, 106}, {133, 0, 102}, {130, 15, 111}, {193, 14, 120}, {223, 15, 120}, {243, 49, 131}, {194, 2, 92}, {210, 46, 117}, {71, 5, 47}, {200, 64, 89}, {197, 23, 103}, {165, 6, 109}, {183, 22, 109}, {236, 52, 118}, {131, 0, 85}, {196, 30, 99}, {255, 66, 94}, {241, 81, 85}, {140, 37, 66}, {163, 57, 121}, {144, 17, 100}, {153, 6, 109}, {139, 0, 104}, {137, 22, 111}, {81, 18, 88}, {38, 9, 85}, {88, 22, 114}, {80, 9, 107}, {122, 19, 122}, {138, 12, 120}, {139, 60, 130}, {32, 15, 72}, {71, 3, 73}, {119, 0, 98}, {143, 39, 128}}, {{44, 6, 105}, {37, 1, 112}, {47, 0, 125}, {114, 0, 126}, {131, 7, 123}, {149, 45, 122}, {159, 59, 112}, {184, 74, 102}, {186, 56, 73}, {226, 97, 98}, {196, 84, 90}, {156, 55, 117}, {111, 1, 86}, {106, 14, 93}, {99, 14, 86}, {138, 44, 110}, {151, 64, 126}, {174, 54, 124}, {145, 31, 85}, {78, 5, 78}, {103, 0, 98}, {174, 38, 102}, {117, 7, 85}, {143, 3, 95}, {142, 8, 78}, {199, 28, 83}, {161, 22, 92}, {72, 1, 87}, {130, 10, 110}, {117, 15, 87}, {185, 34, 121}, {191, 39, 116}, {110, 9, 80}, {71, 5, 75}, {44, 9, 107}, {106, 50, 116}, {143, 9, 104}, {149, 0, 119}, {147, 1, 118}, {109, 0, 106}, {193, 39, 137}, {220, 34, 140}, {217, 1, 111}, {196, 2, 93}, {216, 17, 104}, {82, 1, 45}, {253, 113, 135}, {220, 64, 96}, {174, 0, 94}, {225, 40, 121}, {239, 48, 114}, {133, 5, 82}, {179, 10, 92}, {239, 72, 138}, {228, 32, 101}, {178, 45, 101}, {58, 0, 128}, {61, 0, 130}, {64, 0, 121}, {82, 0, 94}, {169, 30, 93}, {176, 62, 126}, {248, 93, 145}, {220, 31, 104}, {130, 24, 89}, {172, 35, 91}, {132, 31, 75}, {63, 7, 76}, {197, 82, 145}, {139, 21, 97}, {206, 85, 117}, {215, 80, 140}}, {{34, 22, 118}, {71, 0, 116}, {154, 25, 137}, {154, 2, 101}, {137, 33, 97}, {147, 44, 84}, {172, 67, 100}, {205, 79, 101}, {203, 92, 109}, {217, 89, 136}, {153, 43, 110}, {130, 23, 101}, {73, 1, 81}, {111, 5, 97}, {126, 5, 100}, {145, 43, 129}, {167, 45, 118}, {140, 5, 72}, {127, 28, 109}, {84, 11, 85}, {122, 7, 79}, {208, 22, 124}, {88, 15, 95}, {173, 53, 125}, {157, 30, 95}, {195, 21, 123}, {177, 20, 85}, {217, 91, 151}, {183, 26, 90}, {226, 59, 108}, {126, 3, 69}, {193, 87, 150}, {93, 7, 83}, {21, 1, 103}, {24, 0, 93}, {64, 13, 78}, {191, 12, 122}, {229, 27, 149}, {219, 46, 150}, {101, 0, 103}, {98, 0, 94}, {149, 19, 102}, {195, 15, 124}, {252, 63, 167}, {218, 7, 97}, {182, 58, 123}, {236, 85, 114}, {250, 67, 69}, {254, 73, 82}, {173, 16, 76}, {119, 0, 79}, {234, 122, 187}, {161, 12, 107}, {153, 26, 124}, {165, 0, 112}, {114, 0, 96}, {29, 0, 96}, {45, 0, 103}, {49, 0, 105}, {113, 19, 123}, {147, 19, 82}, {133, 8, 125}, {133, 1, 94}, {143, 0, 78}, {225, 62, 147}, {251, 49, 89}, {251, 88, 92}, {235, 115, 143}, {127, 0, 115}, {104, 16, 103}, {143, 3, 95}, {115, 8, 75}}, {{77, 3, 136}, {127, 0, 123}, {164, 0, 109}, {170, 50, 112}, {185, 74, 104}, {188, 62, 91}, {224, 106, 114}, {171, 44, 93}, {148, 46, 116}, {159, 19, 111}, {118, 10, 85}, {98, 11, 86}, {192, 49, 138}, {124, 2, 96}, {141, 36, 130}, {223, 84, 162}, {131, 4, 95}, {169, 37, 128}, {138, 9, 90}, {243, 81, 148}, {153, 5, 97}, {203, 37, 141}, {177, 50, 132}, {218, 51, 123}, {121, 19, 87}, {60, 1, 93}, {143, 13, 108}, {201, 18, 100}, {157, 4, 55}, {241, 10, 70}, {217, 62, 117}, {45, 0, 79}, {58, 0, 104}, {29, 11, 93}, {70, 29, 104}, {177, 86, 140}, {215, 64, 154}, {255, 67, 185}, {242, 49, 152}, {131, 0, 110}, {133, 0, 93}, {194, 0, 114}, {202, 15, 125}, {193, 0, 101}, {237, 44, 131}, {181, 44, 129}, {119, 22, 71}, {247, 75, 76}, {253, 99, 83}, {255, 92, 120}, {71, 15, 98}, {97, 31, 112}, {115, 13, 99}, {198, 69, 144}, {193, 18, 91}, {205, 58, 115}, {169, 11, 112}, {188, 27, 68}, {234, 80, 101}, {153, 45, 81}, {107, 13, 108}, {184, 50, 118}, {255, 72, 101}, {234, 77, 125}, {166, 22, 103}, {253, 70, 106}, {255, 76, 95}, {253, 76, 105}, {134, 0, 90}, {212, 12, 108}, {246, 72, 124}, {137, 20, 105}}, {{124, 0, 124}, {150, 13, 108}, {171, 48, 102}, {172, 64, 97}, {182, 56, 82}, {223, 99, 132}, {202, 65, 125}, {195, 47, 147}, {155, 34, 104}, {180, 87, 149}, {85, 14, 85}, {202, 46, 131}, {110, 1, 74}, {165, 50, 139}, {178, 43, 138}, {153, 4, 79}, {125, 3, 110}, {159, 9, 111}, {140, 36, 135}, {171, 0, 118}, {123, 0, 108}, {215, 47, 146}, {168, 11, 99}, {244, 34, 131}, {208, 27, 117}, {103, 0, 90}, {114, 7, 101}, {171, 15, 104}, {173, 44, 129}, {171, 19, 93}, {190, 10, 83}, {179, 54, 122}, {47, 4, 90}, {33, 11, 107}, {132, 36, 103}, {179, 55, 121}, {226, 94, 177}, {179, 0, 140}, {176, 0, 119}, {147, 0, 118}, {161, 0, 125}, {213, 36, 148}, {216, 4, 122}, {252, 12, 125}, {234, 27, 104}, {196, 75, 156}, {81, 10, 59}, {254, 112, 104}, {231, 52, 98}, {239, 23, 109}, {68, 0, 76}, {219, 83, 143}, {142, 5, 96}, {99, 0, 105}, {150, 4, 118}, {164, 2, 79}, {174, 20, 112}, {249, 84, 124}, {255, 88, 90}, {255, 77, 95}, {208, 85, 131}, {102, 11, 94}, {228, 51, 130}, {211, 42, 98}, {197, 24, 89}, {232, 50, 95}, {226, 67, 92}, {249, 104, 102}, {182, 81, 120}, {194, 81, 140}, {224, 69, 133}, {209, 76, 139}}, {{160, 32, 120}, {163, 70, 112}, {174, 75, 119}, {196, 83, 99}, {202, 81, 131}, {172, 55, 125}, {133, 15, 128}, {116, 11, 97}, {142, 37, 130}, {122, 11, 111}, {123, 4, 99}, {145, 45, 125}, {130, 29, 109}, {220, 54, 148}, {174, 40, 125}, {151, 14, 94}, {195, 32, 132}, {234, 49, 161}, {146, 9, 115}, {155, 6, 120}, {97, 7, 81}, {128, 9, 80}, {120, 5, 108}, {158, 20, 126}, {208, 42, 116}, {222, 70, 130}, {255, 36, 108}, {243, 81, 136}, {167, 33, 113}, {192, 41, 122}, {174, 7, 75}, {198, 56, 122}, {49, 2, 88}, {51, 7, 79}, {235, 70, 121}, {235, 73, 142}, {167, 15, 120}, {182, 13, 124}, {255, 61, 169}, {255, 46, 146}, {248, 57, 166}, {252, 31, 120}, {251, 44, 133}, {216, 0, 93}, {216, 57, 103}, {181, 91, 147}, {116, 18, 59}, {236, 83, 94}, {215, 24, 128}, {213, 34, 140}, {63, 0, 93}, {144, 52, 150}, {107, 0, 137}, {188, 23, 117}, {254, 65, 130}, {242, 51, 120}, {170, 7, 144}, {239, 44, 108}, {250, 78, 95}, {255, 77, 100}, {255, 95, 116}, {108, 15, 47}, {197, 83, 140}, {205, 82, 143}, {183, 32, 109}, {166, 28, 86}, {175, 53, 83}, {203, 77, 106}, {78, 15, 80}, {27, 4, 93}, {78, 3, 100}, {139, 8, 118}}, {{154, 70, 108}, {183, 81, 104}, {203, 89, 120}, {168, 30, 112}, {141, 15, 114}, {121, 5, 117}, {142, 20, 126}, {141, 17, 109}, {110, 16, 112}, {128, 20, 109}, {133, 26, 111}, {172, 69, 157}, {109, 4, 98}, {147, 9, 106}, {211, 79, 177}, {188, 36, 130}, {184, 42, 149}, {105, 3, 118}, {131, 5, 121}, {189, 23, 122}, {151, 13, 82}, {254, 64, 115}, {212, 70, 150}, {113, 18, 117}, {232, 54, 143}, {178, 26, 110}, {251, 47, 139}, {228, 41, 128}, {129, 3, 111}, {158, 16, 108}, {246, 26, 110}, {211, 66, 133}, {27, 8, 89}, {192, 75, 136}, {252, 62, 140}, {221, 22, 133}, {215, 34, 125}, {191, 19, 120}, {202, 10, 117}, {242, 41, 141}, {238, 49, 153}, {254, 29, 126}, {253, 44, 110}, {252, 73, 111}, {206, 61, 115}, {68, 7, 103}, {172, 44, 83}, {217, 53, 66}, {231, 58, 127}, {167, 7, 130}, {108, 24, 141}, {146, 34, 97}, {123, 0, 100}, {153, 0, 126}, {211, 13, 129}, {231, 62, 152}, {204, 37, 146}, {244, 45, 115}, {244, 60, 90}, {255, 107, 122}, {254, 111, 97}, {128, 15, 66}, {84, 13, 132}, {126, 1, 132}, {157, 22, 134}, {163, 11, 117}, {176, 35, 132}, {166, 51, 118}, {141, 52, 103}, {199, 64, 112}, {196, 64, 133}, {223, 41, 95}}, {{165, 78, 101}, {187, 80, 136}, {162, 40, 137}, {181, 66, 157}, {141, 21, 137}, {178, 53, 172}, {171, 46, 146}, {121, 12, 102}, {124, 7, 105}, {124, 9, 108}, {106, 1, 99}, {131, 5, 91}, {181, 41, 113}, {118, 2, 87}, {211, 48, 153}, {222, 66, 164}, {224, 29, 138}, {157, 13, 127}, {108, 0, 95}, {185, 20, 106}, {117, 10, 91}, {161, 11, 95}, {243, 54, 135}, {190, 14, 89}, {228, 48, 95}, {179, 54, 111}, {151, 2, 104}, {164, 5, 112}, {219, 87, 169}, {200, 53, 129}, {226, 29, 100}, {127, 35, 98}, {90, 43, 91}, {231, 85, 147}, {213, 28, 140}, {170, 0, 121}, {230, 35, 153}, {235, 37, 141}, {255, 49, 142}, {255, 50, 139}, {159, 0, 106}, {236, 33, 121}, {255, 76, 136}, {255, 69, 121}, {247, 76, 140}, {48, 17, 87}, {250, 128, 155}, {255, 101, 105}, {232, 52, 93}, {167, 12, 95}, {203, 46, 101}, {254, 84, 117}, {252, 104, 123}, {212, 78, 143}, {139, 1, 124}, {138, 13, 134}, {113, 4, 78}, {191, 46, 124}, {202, 1, 110}, {228, 21, 126}, {223, 19, 108}, {149, 66, 119}, {110, 48, 119}, {76, 0, 115}, {83, 0, 131}, {150, 43, 129}, {134, 34, 109}, {60, 0, 104}, {147, 22, 141}, {219, 88, 176}, {149, 0, 85}, {177, 9, 61}}, {{150, 68, 135}, {150, 40, 145}, {130, 0, 111}, {152, 25, 136}, {141, 5, 128}, {141, 6, 102}, {125, 11, 117}, {133, 27, 142}, {144, 17, 122}, {94, 7, 100}, {124, 4, 81}, {210, 65, 153}, {165, 42, 128}, {174, 16, 100}, {245, 80, 159}, {132, 19, 102}, {145, 15, 106}, {175, 19, 107}, {227, 65, 128}, {245, 52, 138}, {95, 0, 108}, {136, 0, 111}, {212, 37, 121}, {162, 0, 74}, {243, 59, 118}, {234, 54, 137}, {164, 26, 118}, {151, 5, 84}, {253, 80, 166}, {177, 0, 90}, {255, 40, 108}, {167, 51, 107}, {116, 28, 57}, {211, 63, 127}, {201, 12, 132}, {205, 25, 146}, {179, 1, 105}, {208, 10, 103}, {251, 23, 114}, {255, 51, 151}, {206, 54, 140}, {237, 52, 149}, {243, 54, 135}, {223, 40, 109}, {235, 72, 146}, {46, 0, 81}, {248, 97, 142}, {243, 85, 107}, {194, 31, 97}, {162, 4, 100}, {253, 70, 135}, {255, 64, 115}, {252, 77, 111}, {255, 94, 121}, {227, 101, 137}, {162, 58, 134}, {135, 24, 107}, {132, 6, 112}, {169, 8, 124}, {154, 11, 110}, {147, 1, 89}, {206, 75, 131}, {228, 109, 129}, {218, 91, 120}, {223, 102, 169}, {194, 64, 98}, {242, 127, 130}, {136, 19, 81}, {112, 0, 107}, {197, 46, 102}, {246, 106, 115}, {253, 114, 113}}, {{124, 0, 101}, {147, 15, 111}, {159, 40, 142}, {121, 10, 138}, {143, 18, 145}, {164, 26, 170}, {107, 2, 115}, {225, 112, 216}, {91, 0, 122}, {111, 12, 110}, {208, 79, 158}, {102, 3, 109}, {127, 1, 84}, {130, 2, 92}, {215, 13, 127}, {191, 28, 116}, {123, 6, 83}, {247, 81, 155}, {144, 0, 106}, {213, 10, 126}, {227, 80, 165}, {254, 93, 180}, {189, 21, 94}, {195, 56, 125}, {198, 23, 118}, {156, 5, 122}, {84, 0, 105}, {154, 7, 120}, {207, 57, 138}, {179, 4, 116}, {246, 91, 147}, {61, 0, 104}, {155, 70, 140}, {243, 80, 154}, {237, 36, 161}, {222, 28, 137}, {253, 65, 153}, {252, 57, 150}, {254, 80, 154}, {247, 78, 182}, {211, 22, 146}, {192, 0, 145}, {199, 36, 147}, {204, 47, 114}, {163, 26, 141}, {57, 0, 97}, {237, 90, 102}, {254, 105, 105}, {253, 94, 120}, {185, 0, 125}, {198, 0, 125}, {248, 64, 122}, {240, 65, 109}, {255, 97, 130}, {251, 95, 129}, {121, 3, 137}, {117, 0, 163}, {131, 0, 131}, {162, 22, 102}, {232, 78, 150}, {203, 39, 115}, {233, 73, 105}, {222, 62, 107}, {178, 9, 80}, {178, 28, 68}, {255, 127, 116}, {255, 118, 94}, {255, 126, 93}, {218, 94, 87}, {167, 33, 122}, {217, 57, 116}, {254, 93, 120}}, {{175, 37, 147}, {148, 20, 139}, {170, 48, 165}, {137, 0, 144}, {172, 26, 157}, {123, 0, 94}, {184, 44, 155}, {112, 18, 138}, {150, 40, 144}, {230, 88, 197}, {140, 26, 160}, {175, 35, 141}, {198, 35, 113}, {160, 22, 114}, {141, 0, 108}, {223, 28, 106}, {248, 76, 154}, {254, 48, 111}, {189, 27, 119}, {144, 2, 132}, {217, 59, 151}, {254, 47, 151}, {243, 64, 134}, {153, 0, 95}, {254, 78, 168}, {248, 95, 162}, {215, 51, 132}, {253, 84, 161}, {128, 4, 93}, {133, 54, 138}, {120, 9, 95}, {51, 0, 125}, {203, 120, 174}, {241, 61, 147}, {200, 2, 132}, {226, 36, 159}, {254, 84, 162}, {254, 73, 143}, {252, 98, 163}, {221, 39, 154}, {171, 0, 176}, {170, 0, 178}, {165, 4, 167}, {212, 80, 167}, {58, 0, 116}, {99, 0, 101}, {254, 92, 123}, {248, 112, 129}, {248, 77, 116}, {213, 8, 122}, {230, 43, 142}, {242, 68, 116}, {246, 72, 123}, {232, 53, 110}, {249, 100, 117}, {119, 36, 114}, {91, 36, 129}, {196, 41, 123}, {225, 42, 108}, {226, 82, 148}, {140, 10, 121}, {147, 3, 109}, {171, 0, 101}, {169, 16, 81}, {242, 81, 125}, {254, 105, 104}, {255, 101, 109}, {254, 111, 97}, {250, 112, 103}, {196, 70, 103}, {99, 0, 120}, {176, 2, 109}}, {{121, 10, 146}, {105, 0, 135}, {130, 0, 144}, {153, 14, 143}, {160, 25, 166}, {150, 18, 143}, {135, 9, 119}, {119, 16, 114}, {229, 53, 159}, {196, 49, 151}, {184, 51, 143}, {230, 68, 152}, {125, 11, 104}, {149, 8, 110}, {143, 8, 103}, {204, 21, 109}, {129, 1, 86}, {222, 12, 113}, {204, 20, 130}, {170, 0, 106}, {159, 13, 103}, {175, 58, 180}, {253, 92, 209}, {211, 31, 182}, {171, 17, 137}, {189, 0, 121}, {222, 26, 134}, {255, 40, 113}, {252, 49, 109}, {103, 13, 100}, {113, 0, 126}, {96, 0, 138}, {183, 73, 147}, {255, 78, 144}, {255, 70, 172}, {226, 35, 165}, {253, 79, 161}, {250, 81, 168}, {255, 55, 153}, {250, 52, 191}, {163, 0, 164}, {172, 0, 171}, {237, 66, 162}, {205, 78, 150}, {31, 0, 155}, {160, 44, 115}, {253, 130, 136}, {240, 101, 134}, {205, 20, 98}, {235, 82, 135}, {197, 45, 119}, {252, 93, 130}, {254, 99, 145}, {244, 62, 157}, {241, 101, 146}, {73, 0, 113}, {36, 0, 126}, {130, 0, 142}, {157, 6, 102}, {193, 32, 125}, {222, 65, 136}, {249, 93, 144}, {255, 100, 138}, {177, 31, 120}, {175, 41, 130}, {240, 113, 117}, {255, 92, 109}, {255, 115, 109}, {250, 108, 99}, {243, 118, 123}, {73, 11, 85}, {128, 15, 105}}, {{124, 0, 149}, {142, 6, 165}, {177, 38, 178}, {214, 86, 227}, {131, 6, 154}, {209, 74, 204}, {115, 11, 139}, {180, 60, 171}, {136, 0, 136}, {143, 2, 130}, {183, 13, 131}, {242, 94, 187}, {194, 74, 156}, {197, 3, 106}, {200, 44, 127}, {246, 42, 119}, {228, 61, 158}, {190, 0, 104}, {214, 17, 120}, {242, 60, 150}, {251, 63, 150}, {135, 0, 123}, {118, 0, 155}, {163, 0, 141}, {254, 57, 154}, {255, 66, 151}, {187, 0, 116}, {254, 63, 139}, {254, 56, 148}, {183, 30, 150}, {58, 0, 125}, {58, 3, 136}, {167, 75, 145}, {249, 90, 144}, {245, 62, 166}, {190, 39, 137}, {245, 77, 167}, {239, 45, 162}, {222, 20, 147}, {206, 11, 118}, {232, 75, 147}, {223, 72, 128}, {255, 120, 171}, {202, 107, 193}, {105, 54, 154}, {249, 133, 138}, {251, 114, 99}, {254, 102, 103}, {255, 116, 129}, {249, 126, 155}, {207, 66, 173}, {152, 1, 139}, {224, 77, 168}, {245, 86, 192}, {252, 150, 192}, {146, 94, 170}, {183, 132, 212}, {167, 82, 175}, {135, 0, 109}, {158, 18, 123}, {173, 43, 87}, {248, 61, 108}, {255, 67, 113}, {234, 118, 181}, {244, 76, 151}, {253, 78, 126}, {245, 104, 112}, {255, 99, 109}, {247, 106, 102}, {253, 125, 123}, {169, 93, 128}, {53, 3, 98}}, {{137, 7, 146}, {154, 16, 164}, {122, 1, 137}, {100, 7, 132}, {172, 50, 157}, {96, 8, 126}, {131, 1, 143}, {162, 1, 142}, {123, 1, 141}, {189, 40, 143}, {210, 54, 154}, {188, 41, 152}, {120, 2, 115}, {177, 7, 125}, {149, 19, 110}, {236, 42, 148}, {139, 2, 127}, {171, 6, 135}, {243, 76, 174}, {193, 20, 131}, {207, 4, 113}, {232, 63, 170}, {122, 0, 133}, {124, 0, 137}, {183, 0, 121}, {199, 3, 125}, {187, 16, 147}, {179, 0, 135}, {197, 0, 159}, {173, 0, 114}, {185, 68, 150}, {64, 1, 96}, {90, 16, 110}, {246, 108, 155}, {234, 52, 156}, {190, 30, 146}, {192, 1, 145}, {225, 64, 186}, {218, 78, 161}, {239, 57, 137}, {137, 1, 116}, {164, 6, 142}, {165, 8, 175}, {54, 5, 150}, {174, 86, 138}, {240, 86, 106}, {255, 102, 112}, {255, 111, 138}, {255, 96, 125}, {255, 94, 137}, {120, 19, 133}, {83, 0, 132}, {147, 55, 165}, {148, 42, 160}, {112, 3, 95}, {132, 25, 94}, {103, 19, 143}, {142, 33, 143}, {251, 142, 182}, {255, 148, 150}, {157, 22, 39}, {209, 68, 114}, {228, 36, 113}, {202, 48, 122}, {247, 77, 146}, {229, 62, 108}, {251, 83, 111}, {250, 90, 107}, {249, 83, 95}, {248, 109, 100}, {136, 39, 76}, {71, 18, 115}}, {{172, 69, 183}, {170, 34, 158}, {121, 12, 131}, {169, 25, 131}, {164, 37, 155}, {152, 19, 167}, {199, 79, 177}, {161, 20, 143}, {127, 5, 127}, {159, 27, 122}, {131, 19, 138}, {185, 0, 131}, {189, 4, 125}, {254, 79, 174}, {243, 89, 188}, {154, 0, 139}, {167, 10, 141}, {154, 3, 123}, {164, 12, 129}, {135, 4, 113}, {145, 11, 127}, {179, 12, 125}, {185, 14, 124}, {185, 12, 120}, {254, 70, 117}, {249, 95, 162}, {164, 0, 124}, {182, 0, 138}, {167, 12, 141}, {239, 79, 162}, {205, 47, 118}, {184, 16, 103}, {58, 7, 88}, {221, 110, 135}, {246, 96, 141}, {200, 50, 150}, {154, 5, 130}, {123, 0, 186}, {134, 0, 185}, {124, 0, 148}, {126, 3, 141}, {188, 0, 150}, {121, 16, 123}, {68, 3, 112}, {249, 145, 180}, {253, 102, 132}, {255, 84, 119}, {254, 75, 130}, {255, 72, 134}, {249, 98, 119}, {200, 101, 175}, {115, 19, 152}, {161, 53, 139}, {210, 63, 133}, {201, 45, 153}, {216, 25, 151}, {142, 5, 145}, {150, 20, 90}, {255, 137, 138}, {255, 143, 134}, {255, 121, 116}, {251, 137, 114}, {180, 66, 74}, {144, 2, 71}, {191, 23, 107}, {250, 108, 144}, {249, 83, 124}, {244, 60, 114}, {231, 68, 90}, {249, 115, 119}, {221, 135, 170}, {172, 116, 172}}, {{193, 57, 172}, {218, 76, 185}, {206, 64, 171}, {210, 73, 186}, {136, 10, 134}, {140, 7, 126}, {193, 14, 176}, {126, 12, 129}, {140, 6, 122}, {210, 30, 143}, {159, 14, 133}, {151, 1, 107}, {194, 30, 118}, {200, 57, 184}, {207, 25, 173}, {160, 8, 124}, {223, 42, 176}, {248, 52, 134}, {248, 65, 131}, {123, 2, 112}, {133, 3, 137}, {158, 5, 100}, {239, 84, 149}, {154, 1, 102}, {253, 67, 136}, {254, 72, 141}, {203, 2, 122}, {206, 34, 157}, {163, 14, 161}, {201, 28, 131}, {250, 80, 169}, {120, 9, 96}, {102, 1, 143}, {132, 71, 110}, {249, 109, 140}, {225, 63, 169}, {138, 0, 162}, {140, 0, 180}, {120, 3, 167}, {173, 70, 197}, {162, 47, 129}, {240, 145, 195}, {65, 1, 134}, {123, 0, 100}, {238, 92, 116}, {251, 135, 155}, {252, 114, 141}, {232, 48, 116}, {234, 29, 135}, {208, 44, 114}, {254, 118, 161}, {193, 56, 134}, {140, 5, 117}, {244, 124, 171}, {228, 91, 183}, {234, 127, 198}, {228, 113, 176}, {236, 114, 126}, {255, 107, 131}, {255, 115, 148}, {255, 129, 117}, {255, 133, 115}, {255, 137, 112}, {244, 126, 123}, {180, 68, 94}, {184, 0, 119}, {225, 74, 147}, {206, 54, 101}, {255, 127, 155}, {203, 93, 131}, {57, 10, 95}, {26, 19, 113}}, {{148, 27, 131}, {111, 0, 119}, {189, 64, 168}, {138, 2, 133}, {159, 3, 153}, {233, 87, 195}, {178, 39, 160}, {197, 41, 154}, {218, 82, 164}, {199, 60, 156}, {157, 7, 106}, {213, 51, 142}, {239, 36, 143}, {173, 29, 167}, {105, 9, 151}, {186, 4, 140}, {181, 11, 147}, {244, 70, 170}, {251, 52, 135}, {136, 1, 107}, {118, 0, 135}, {147, 0, 111}, {236, 63, 161}, {139, 0, 110}, {251, 59, 154}, {229, 26, 146}, {140, 0, 117}, {136, 0, 150}, {198, 23, 151}, {253, 75, 133}, {255, 102, 152}, {169, 35, 134}, {103, 11, 119}, {164, 81, 162}, {180, 82, 144}, {208, 46, 181}, {156, 12, 178}, {191, 77, 200}, {131, 0, 153}, {116, 13, 182}, {228, 126, 232}, {107, 0, 121}, {84, 9, 127}, {244, 127, 151}, {221, 75, 120}, {241, 80, 137}, {177, 34, 87}, {219, 84, 157}, {245, 117, 179}, {254, 86, 158}, {232, 73, 151}, {207, 87, 182}, {177, 91, 194}, {202, 131, 185}, {125, 0, 134}, {162, 82, 206}, {91, 19, 129}, {108, 0, 104}, {250, 88, 128}, {255, 110, 137}, {255, 115, 118}, {255, 114, 102}, {255, 122, 107}, {246, 122, 98}, {124, 26, 32}, {198, 91, 139}, {176, 16, 101}, {222, 80, 149}, {204, 56, 121}, {55, 7, 86}, {19, 11, 91}, {93, 60, 129}}, {{153, 3, 129}, {132, 6, 140}, {192, 66, 189}, {170, 63, 188}, {84, 0, 126}, {161, 29, 155}, {117, 3, 129}, {189, 33, 146}, {242, 50, 156}, {179, 29, 143}, {170, 19, 137}, {173, 35, 119}, {174, 1, 145}, {238, 60, 185}, {217, 45, 161}, {199, 31, 136}, {243, 75, 168}, {134, 4, 113}, {188, 16, 137}, {184, 26, 133}, {131, 7, 125}, {209, 71, 164}, {145, 8, 105}, {198, 66, 159}, {179, 0, 146}, {198, 0, 154}, {86, 0, 134}, {126, 0, 164}, {125, 0, 145}, {172, 0, 133}, {208, 0, 156}, {152, 29, 126}, {163, 86, 164}, {76, 2, 132}, {77, 25, 87}, {239, 143, 203}, {144, 1, 127}, {218, 73, 177}, {251, 68, 161}, {210, 88, 142}, {173, 87, 141}, {156, 83, 167}, {199, 84, 116}, {255, 126, 140}, {255, 124, 122}, {255, 142, 161}, {164, 39, 146}, {146, 10, 135}, {172, 54, 168}, {243, 124, 221}, {182, 6, 142}, {147, 9, 140}, {181, 17, 157}, {242, 89, 187}, {255, 63, 160}, {246, 86, 160}, {139, 18, 137}, {205, 76, 194}, {202, 52, 140}, {253, 81, 118}, {254, 105, 121}, {249, 113, 112}, {248, 113, 104}, {249, 120, 91}, {254, 148, 153}, {100, 31, 89}, {181, 48, 138}, {163, 70, 135}, {172, 106, 170}, {104, 57, 127}, {152, 147, 208}, {139, 144, 189}}, {{132, 2, 132}, {230, 104, 209}, {110, 0, 128}, {164, 55, 164}, {72, 12, 109}, {203, 51, 166}, {172, 6, 165}, {254, 88, 179}, {161, 18, 137}, {182, 24, 130}, {150, 5, 102}, {204, 48, 137}, {105, 0, 138}, {180, 3, 136}, {220, 53, 158}, {212, 31, 150}, {255, 79, 152}, {249, 78, 189}, {175, 26, 141}, {179, 12, 122}, {238, 78, 163}, {251, 53, 112}, {254, 83, 132}, {242, 83, 156}, {126, 14, 135}, {108, 15, 124}, {77, 5, 98}, {145, 0, 107}, {200, 39, 148}, {238, 74, 133}, {218, 87, 150}, {214, 104, 176}, {49, 5, 82}, {126, 52, 109}, {96, 4, 79}, {196, 57, 169}, {195, 31, 169}, {222, 102, 191}, {225, 113, 197}, {147, 31, 171}, {37, 0, 149}, {104, 13, 121}, {250, 124, 120}, {254, 119, 93}, {255, 115, 115}, {251, 120, 124}, {194, 77, 161}, {137, 31, 135}, {111, 8, 130}, {143, 14, 119}, {255, 147, 211}, {254, 96, 180}, {249, 83, 159}, {254, 86, 162}, {249, 68, 115}, {252, 68, 156}, {136, 38, 172}, {173, 19, 134}, {201, 48, 145}, {230, 80, 141}, {250, 108, 117}, {244, 109, 139}, {243, 117, 111}, {245, 108, 103}, {239, 127, 140}, {144, 94, 158}, {217, 184, 219}, {49, 10, 135}, {32, 6, 118}, {204, 177, 204}, {52, 29, 99}, {132, 100, 161}}, {{215, 70, 170}, {124, 3, 118}, {112, 0, 160}, {106, 4, 138}, {111, 12, 111}, {167, 0, 166}, {187, 8, 181}, {188, 1, 158}, {120, 0, 133}, {221, 82, 162}, {178, 34, 130}, {233, 39, 141}, {93, 0, 125}, {135, 0, 140}, {209, 46, 183}, {187, 16, 152}, {194, 2, 140}, {171, 0, 166}, {151, 0, 133}, {237, 77, 153}, {174, 10, 161}, {249, 70, 168}, {230, 43, 99}, {243, 80, 142}, {146, 10, 103}, {197, 90, 181}, {253, 97, 200}, {255, 88, 174}, {255, 105, 164}, {255, 93, 145}, {233, 74, 112}, {228, 60, 93}, {155, 70, 91}, {69, 17, 85}, {105, 18, 138}, {164, 78, 170}, {106, 0, 108}, {203, 92, 192}, {133, 0, 188}, {50, 0, 156}, {95, 19, 91}, {252, 151, 136}, {251, 103, 100}, {242, 91, 121}, {232, 58, 124}, {255, 79, 132}, {255, 110, 167}, {134, 47, 173}, {102, 16, 147}, {212, 121, 206}, {173, 0, 124}, {211, 49, 157}, {188, 28, 123}, {253, 112, 180}, {252, 58, 164}, {255, 73, 152}, {211, 63, 215}, {225, 87, 186}, {209, 31, 125}, {179, 28, 99}, {249, 120, 181}, {206, 68, 141}, {222, 96, 133}, {246, 138, 139}, {254, 145, 162}, {235, 153, 219}, {57, 0, 136}, {98, 56, 133}, {212, 178, 240}, {59, 0, 99}, {243, 81, 131}, {144, 17, 106}}, {{227, 88, 175}, {81, 4, 133}, {177, 41, 155}, {139, 47, 148}, {178, 72, 175}, {188, 11, 147}, {238, 71, 179}, {169, 3, 170}, {190, 33, 186}, {226, 70, 155}, {156, 14, 121}, {102, 0, 132}, {82, 0, 112}, {89, 0, 133}, {112, 0, 141}, {147, 4, 172}, {119, 0, 169}, {114, 0, 168}, {148, 0, 177}, {176, 0, 140}, {187, 13, 161}, {212, 60, 152}, {192, 17, 126}, {223, 59, 165}, {228, 73, 162}, {165, 8, 130}, {196, 13, 128}, {201, 47, 148}, {176, 45, 132}, {254, 85, 132}, {232, 76, 120}, {255, 105, 131}, {253, 80, 111}, {79, 22, 66}, {136, 44, 139}, {76, 12, 138}, {135, 37, 133}, {151, 56, 111}, {109, 28, 166}, {108, 10, 80}, {254, 140, 144}, {212, 101, 99}, {253, 131, 156}, {255, 142, 198}, {241, 106, 196}, {250, 108, 177}, {243, 76, 155}, {81, 58, 191}, {178, 186, 247}, {54, 4, 108}, {191, 110, 175}, {160, 80, 137}, {196, 90, 173}, {160, 36, 124}, {158, 0, 134}, {193, 0, 159}, {141, 0, 173}, {121, 0, 190}, {190, 84, 171}, {244, 147, 184}, {165, 47, 133}, {238, 102, 193}, {183, 14, 118}, {211, 55, 118}, {208, 88, 156}, {122, 113, 226}, {92, 30, 113}, {184, 158, 230}, {61, 11, 104}, {109, 18, 91}, {251, 117, 177}, {251, 137, 182}}, {{123, 0, 118}, {198, 39, 151}, {251, 105, 187}, {93, 2, 119}, {199, 93, 186}, {189, 36, 138}, {171, 0, 157}, {102, 0, 164}, {170, 34, 194}, {205, 55, 179}, {158, 0, 126}, {218, 131, 171}, {216, 69, 153}, {228, 67, 156}, {250, 104, 155}, {208, 54, 169}, {106, 5, 171}, {156, 25, 171}, {197, 50, 174}, {207, 69, 156}, {205, 43, 145}, {185, 40, 119}, {120, 8, 107}, {113, 6, 141}, {149, 2, 130}, {194, 32, 136}, {255, 85, 164}, {243, 74, 167}, {182, 40, 156}, {239, 89, 139}, {235, 71, 131}, {233, 62, 125}, {243, 106, 146}, {96, 15, 62}, {75, 27, 107}, {97, 34, 113}, {107, 41, 113}, {62, 0, 125}, {193, 92, 139}, {252, 128, 135}, {255, 144, 132}, {235, 133, 149}, {227, 113, 163}, {183, 17, 136}, {225, 43, 180}, {211, 44, 167}, {215, 61, 148}, {129, 134, 228}, {44, 59, 167}, {179, 155, 234}, {107, 12, 118}, {110, 44, 112}, {137, 68, 172}, {128, 45, 160}, {103, 13, 155}, {202, 102, 203}, {131, 37, 174}, {88, 0, 158}, {141, 47, 146}, {186, 101, 164}, {218, 165, 204}, {237, 133, 185}, {203, 74, 142}, {225, 59, 143}, {134, 1, 85}, {95, 44, 165}, {236, 168, 225}, {236, 143, 179}, {245, 136, 160}, {241, 117, 135}, {255, 132, 160}, {238, 79, 130}}, {{192, 35, 169}, {195, 69, 143}, {231, 80, 166}, {110, 0, 144}, {204, 71, 156}, {246, 67, 141}, {215, 41, 173}, {191, 37, 190}, {200, 52, 176}, {147, 11, 149}, {31, 6, 128}, {241, 119, 168}, {249, 105, 199}, {183, 11, 158}, {252, 72, 143}, {246, 74, 164}, {136, 37, 152}, {129, 6, 120}, {217, 56, 171}, {200, 46, 104}, {247, 83, 133}, {249, 90, 119}, {223, 66, 152}, {145, 41, 150}, {90, 3, 125}, {163, 47, 182}, {138, 0, 122}, {160, 29, 146}, {173, 52, 154}, {185, 49, 125}, {187, 60, 153}, {165, 38, 147}, {170, 70, 156}, {169, 111, 168}, {105, 32, 107}, {151, 99, 174}, {91, 15, 72}, {244, 135, 141}, {253, 132, 155}, {249, 128, 161}, {226, 68, 137}, {231, 104, 172}, {210, 114, 145}, {180, 90, 135}, {121, 17, 85}, {175, 85, 147}, {207, 65, 152}, {36, 92, 191}, {65, 120, 214}, {65, 38, 173}, {186, 83, 145}, {209, 87, 160}, {177, 58, 139}, {215, 124, 183}, {168, 96, 160}, {183, 51, 157}, {181, 29, 132}, {186, 38, 135}, {204, 33, 105}, {202, 46, 119}, {105, 7, 102}, {191, 129, 199}, {254, 111, 152}, {242, 120, 171}, {163, 120, 174}, {197, 154, 193}, {232, 120, 157}, {255, 124, 150}, {248, 97, 138}, {252, 120, 165}, {240, 91, 128}, {255, 119, 150}}, {{217, 92, 166}, {255, 109, 169}, {161, 26, 129}, {119, 5, 169}, {201, 65, 132}, {220, 30, 136}, {149, 0, 170}, {194, 42, 196}, {186, 25, 163}, {230, 47, 195}, {65, 0, 121}, {227, 119, 167}, {144, 39, 165}, {182, 30, 183}, {221, 50, 156}, {224, 90, 177}, {74, 0, 110}, {198, 78, 194}, {255, 103, 178}, {207, 80, 145}, {175, 31, 103}, {219, 61, 131}, {179, 36, 94}, {135, 66, 126}, {64, 10, 91}, {174, 94, 187}, {195, 104, 192}, {202, 100, 177}, {161, 45, 123}, {133, 14, 141}, {128, 45, 201}, {66, 2, 123}, {105, 14, 117}, {87, 13, 136}, {158, 72, 128}, {249, 133, 152}, {253, 121, 160}, {224, 98, 188}, {121, 3, 158}, {203, 98, 225}, {115, 25, 112}, {189, 106, 186}, {187, 99, 183}, {220, 121, 218}, {201, 103, 180}, {209, 77, 155}, {227, 47, 166}, {218, 98, 197}, {193, 63, 171}, {148, 34, 150}, {189, 52, 118}, {253, 127, 147}, {244, 103, 130}, {125, 24, 84}, {126, 74, 144}, {236, 174, 219}, {189, 96, 167}, {236, 124, 178}, {199, 70, 140}, {245, 95, 162}, {247, 117, 134}, {193, 62, 129}, {193, 61, 188}, {125, 75, 157}, {124, 98, 199}, {149, 74, 142}, {252, 93, 115}, {250, 82, 132}, {241, 89, 126}, {255, 116, 145}, {250, 105, 117}, {250, 113, 123}}, {{255, 107, 164}, {241, 80, 143}, {86, 0, 130}, {111, 0, 124}, {160, 16, 114}, {209, 21, 131}, {207, 42, 173}, {243, 69, 176}, {246, 74, 180}, {116, 39, 137}, {188, 88, 121}, {238, 124, 151}, {240, 112, 170}, {249, 123, 177}, {125, 1, 97}, {92, 20, 127}, {59, 9, 150}, {91, 30, 157}, {143, 49, 140}, {169, 72, 177}, {96, 9, 125}, {98, 0, 125}, {131, 46, 164}, {130, 37, 135}, {83, 21, 109}, {59, 0, 98}, {68, 0, 123}, {69, 2, 107}, {119, 48, 127}, {125, 19, 104}, {223, 126, 195}, {190, 66, 163}, {212, 62, 180}, {206, 60, 134}, {241, 114, 148}, {238, 83, 133}, {219, 56, 126}, {181, 25, 143}, {186, 88, 207}, {129, 10, 115}, {178, 67, 125}, {231, 79, 112}, {241, 114, 132}, {122, 22, 142}, {101, 0, 209}, {117, 2, 169}, {216, 97, 236}, {205, 37, 147}, {237, 99, 177}, {224, 88, 150}, {255, 123, 138}, {254, 118, 122}, {252, 130, 167}, {135, 13, 133}, {152, 24, 148}, {238, 139, 205}, {191, 69, 139}, {239, 106, 144}, {254, 127, 182}, {243, 97, 137}, {253, 132, 123}, {249, 136, 140}, {93, 57, 183}, {68, 11, 166}, {139, 73, 160}, {242, 96, 138}, {253, 83, 149}, {244, 82, 140}, {250, 111, 163}, {236, 69, 118}, {245, 83, 113}, {255, 107, 128}}, {{239, 91, 123}, {247, 93, 164}, {125, 2, 124}, {176, 42, 135}, {214, 101, 137}, {228, 65, 133}, {233, 110, 189}, {247, 106, 177}, {177, 39, 128}, {180, 91, 155}, {229, 105, 122}, {247, 98, 150}, {214, 73, 147}, {245, 96, 151}, {213, 61, 120}, {197, 82, 132}, {169, 15, 118}, {186, 60, 148}, {219, 95, 151}, {188, 64, 134}, {213, 101, 186}, {138, 37, 149}, {160, 37, 158}, {169, 25, 132}, {245, 111, 153}, {250, 96, 172}, {95, 4, 113}, {124, 39, 125}, {215, 82, 137}, {246, 103, 134}, {185, 13, 68}, {242, 99, 168}, {176, 53, 125}, {149, 23, 77}, {238, 112, 153}, {253, 91, 139}, {252, 117, 153}, {172, 34, 143}, {147, 25, 171}, {174, 38, 157}, {185, 64, 137}, {255, 113, 154}, {255, 121, 152}, {243, 107, 149}, {81, 0, 161}, {51, 17, 227}, {131, 3, 157}, {229, 108, 192}, {218, 88, 182}, {240, 98, 145}, {254, 110, 131}, {254, 113, 134}, {232, 92, 125}, {135, 18, 125}, {158, 34, 157}, {195, 76, 156}, {252, 117, 205}, {212, 57, 117}, {255, 147, 185}, {255, 108, 126}, {250, 121, 111}, {255, 134, 115}, {118, 38, 94}, {56, 40, 190}, {182, 68, 113}, {205, 37, 98}, {215, 70, 143}, {211, 96, 148}, {145, 20, 92}, {254, 124, 187}, {209, 60, 119}, {248, 95, 138}}, {{252, 97, 132}, {174, 60, 135}, {128, 38, 141}, {169, 64, 145}, {228, 92, 133}, {151, 3, 131}, {105, 0, 141}, {141, 29, 144}, {124, 40, 124}, {249, 159, 167}, {229, 86, 137}, {198, 64, 124}, {168, 23, 92}, {163, 26, 139}, {205, 68, 152}, {217, 79, 126}, {244, 87, 152}, {137, 7, 123}, {207, 65, 120}, {255, 92, 136}, {212, 51, 129}, {223, 97, 196}, {179, 17, 116}, {251, 114, 163}, {239, 80, 109}, {242, 91, 131}, {157, 51, 170}, {212, 106, 165}, {250, 107, 137}, {250, 86, 130}, {255, 86, 138}, {248, 105, 183}, {207, 54, 125}, {158, 40, 72}, {205, 62, 136}, {243, 85, 141}, {254, 104, 157}, {146, 42, 152}, {143, 24, 132}, {207, 99, 175}, {234, 57, 159}, {251, 78, 131}, {255, 96, 140}, {255, 119, 131}, {220, 122, 163}, {63, 14, 146}, {198, 35, 140}, {208, 61, 161}, {181, 43, 156}, {139, 1, 129}, {203, 40, 134}, {210, 53, 123}, {225, 91, 154}, {203, 80, 192}, {113, 13, 139}, {204, 39, 143}, {252, 93, 151}, {252, 105, 159}, {253, 98, 139}, {255, 114, 128}, {255, 127, 116}, {255, 130, 123}, {250, 147, 181}, {184, 91, 165}, {250, 136, 129}, {209, 93, 138}, {232, 139, 196}, {236, 150, 191}, {136, 25, 93}, {165, 50, 111}, {214, 99, 165}, {196, 60, 117}}, {{216, 88, 130}, {130, 8, 115}, {121, 1, 93}, {240, 137, 167}, {250, 120, 164}, {236, 87, 193}, {220, 73, 175}, {160, 55, 155}, {161, 62, 114}, {253, 153, 165}, {180, 33, 133}, {253, 126, 184}, {246, 88, 136}, {195, 40, 131}, {185, 52, 147}, {226, 86, 167}, {249, 111, 174}, {137, 2, 99}, {246, 108, 159}, {253, 80, 132}, {246, 72, 127}, {172, 2, 77}, {215, 68, 150}, {170, 47, 125}, {205, 49, 139}, {209, 73, 127}, {143, 23, 95}, {252, 129, 152}, {255, 80, 126}, {247, 95, 133}, {246, 77, 120}, {233, 65, 115}, {251, 114, 143}, {239, 112, 171}, {129, 17, 106}, {161, 24, 113}, {163, 24, 99}, {180, 66, 146}, {213, 86, 156}, {228, 100, 173}, {255, 109, 173}, {240, 77, 136}, {255, 109, 144}, {255, 127, 139}, {229, 112, 138}, {252, 154, 234}, {238, 96, 118}, {168, 0, 104}, {167, 11, 88}, {193, 64, 187}, {208, 96, 156}, {171, 35, 119}, {160, 49, 129}, {157, 18, 130}, {207, 83, 150}, {248, 137, 181}, {250, 125, 180}, {255, 104, 158}, {254, 118, 147}, {255, 119, 140}, {247, 118, 110}, {254, 132, 122}, {253, 137, 132}, {214, 111, 125}, {249, 156, 152}, {246, 138, 158}, {134, 29, 98}, {194, 116, 182}, {124, 24, 122}, {231, 130, 192}, {161, 39, 104}, {215, 92, 124}}, {{211, 84, 125}, {144, 30, 145}, {127, 13, 91}, {255, 142, 147}, {214, 74, 137}, {208, 46, 144}, {216, 81, 164}, {93, 30, 109}, {247, 152, 195}, {217, 65, 117}, {204, 62, 136}, {252, 130, 164}, {248, 122, 148}, {218, 93, 143}, {191, 33, 138}, {170, 36, 141}, {223, 80, 135}, {248, 120, 182}, {254, 107, 157}, {253, 108, 162}, {255, 97, 151}, {197, 23, 84}, {200, 55, 124}, {182, 42, 145}, {227, 81, 125}, {228, 87, 135}, {234, 99, 142}, {253, 116, 121}, {251, 81, 124}, {255, 85, 126}, {255, 109, 136}, {251, 96, 136}, {239, 77, 123}, {229, 114, 138}, {189, 48, 113}, {208, 62, 139}, {157, 22, 90}, {179, 48, 128}, {198, 78, 141}, {236, 100, 175}, {253, 110, 164}, {249, 89, 154}, {252, 109, 141}, {250, 120, 133}, {236, 130, 143}, {245, 129, 221}, {253, 126, 154}, {147, 19, 97}, {170, 39, 139}, {177, 72, 196}, {234, 98, 162}, {232, 117, 170}, {197, 106, 166}, {213, 97, 182}, {236, 107, 178}, {239, 139, 201}, {252, 121, 170}, {251, 87, 136}, {246, 86, 126}, {255, 113, 144}, {255, 128, 124}, {254, 126, 113}, {255, 139, 140}, {229, 140, 182}, {250, 161, 178}, {245, 134, 151}, {165, 43, 138}, {182, 104, 180}, {177, 100, 185}, {145, 0, 89}, {189, 29, 112}, {246, 147, 160}}, {{239, 111, 128}, {93, 6, 81}, {85, 0, 94}, {200, 101, 157}, {230, 87, 147}, {128, 0, 159}, {101, 0, 129}, {110, 22, 132}, {161, 62, 95}, {245, 128, 120}, {196, 49, 115}, {241, 116, 182}, {209, 55, 125}, {214, 74, 178}, {184, 44, 140}, {237, 83, 150}, {250, 94, 152}, {138, 13, 147}, {247, 120, 162}, {241, 90, 120}, {248, 85, 137}, {163, 1, 99}, {198, 39, 135}, {239, 101, 158}, {252, 116, 150}, {188, 50, 95}, {163, 47, 178}, {251, 155, 193}, {250, 102, 142}, {247, 82, 122}, {249, 80, 114}, {242, 110, 168}, {209, 65, 155}, {165, 68, 123}, {216, 57, 113}, {246, 84, 106}, {240, 85, 116}, {179, 53, 164}, {126, 17, 141}, {241, 133, 199}, {244, 80, 140}, {253, 74, 122}, {254, 108, 134}, {255, 129, 117}, {231, 112, 158}, {114, 7, 177}, {202, 60, 160}, {176, 60, 161}, {184, 66, 178}, {130, 21, 136}, {176, 35, 115}, {197, 107, 153}, {207, 69, 152}, {188, 86, 202}, {206, 104, 224}, {148, 1, 129}, {253, 72, 143}, {250, 99, 150}, {249, 78, 128}, {254, 97, 137}, {253, 112, 123}, {255, 123, 116}, {184, 76, 132}, {207, 104, 162}, {238, 126, 150}, {255, 165, 192}, {173, 59, 135}, {172, 104, 157}, {122, 7, 110}, {229, 138, 177}, {210, 99, 176}, {243, 142, 177}}, {{241, 105, 123}, {168, 36, 105}, {155, 49, 169}, {181, 64, 135}, {225, 96, 131}, {138, 3, 100}, {165, 56, 155}, {221, 98, 155}, {134, 46, 111}, {204, 120, 145}, {225, 97, 123}, {182, 66, 132}, {224, 87, 202}, {234, 90, 189}, {209, 51, 132}, {156, 9, 67}, {227, 57, 135}, {188, 42, 150}, {208, 56, 119}, {237, 84, 130}, {204, 26, 101}, {189, 48, 160}, {169, 13, 115}, {239, 70, 137}, {237, 75, 116}, {224, 75, 131}, {138, 3, 159}, {185, 70, 163}, {218, 88, 143}, {213, 51, 112}, {255, 98, 173}, {161, 7, 114}, {194, 61, 177}, {172, 82, 125}, {240, 93, 127}, {254, 90, 146}, {252, 69, 138}, {159, 15, 122}, {148, 12, 154}, {146, 23, 120}, {208, 79, 140}, {243, 116, 142}, {255, 134, 125}, {243, 113, 141}, {129, 1, 167}, {152, 33, 230}, {148, 1, 184}, {186, 55, 177}, {192, 63, 160}, {232, 86, 135}, {255, 109, 139}, {248, 85, 124}, {216, 85, 117}, {141, 11, 137}, {155, 10, 142}, {179, 49, 146}, {214, 71, 136}, {238, 90, 150}, {254, 105, 158}, {255, 94, 125}, {255, 117, 119}, {255, 134, 129}, {148, 63, 139}, {118, 20, 157}, {200, 75, 105}, {175, 60, 81}, {230, 166, 206}, {214, 131, 206}, {224, 125, 196}, {229, 108, 164}, {251, 131, 207}, {230, 71, 128}}, {{246, 93, 114}, {176, 26, 114}, {105, 0, 144}, {108, 4, 122}, {228, 101, 172}, {239, 74, 163}, {211, 90, 177}, {229, 59, 142}, {181, 54, 131}, {81, 16, 108}, {246, 156, 150}, {246, 131, 152}, {215, 73, 129}, {255, 74, 117}, {197, 20, 98}, {159, 20, 145}, {142, 34, 128}, {183, 86, 173}, {119, 27, 102}, {159, 58, 120}, {162, 50, 160}, {138, 51, 166}, {106, 1, 116}, {117, 30, 118}, {156, 59, 145}, {112, 6, 100}, {97, 0, 134}, {138, 44, 173}, {172, 57, 118}, {174, 65, 146}, {173, 47, 127}, {252, 136, 209}, {193, 47, 137}, {186, 37, 100}, {194, 60, 121}, {195, 47, 102}, {207, 56, 129}, {157, 37, 142}, {106, 8, 144}, {143, 16, 148}, {165, 37, 124}, {241, 113, 152}, {254, 127, 130}, {143, 9, 135}, {162, 6, 197}, {216, 37, 202}, {197, 25, 185}, {212, 60, 165}, {180, 18, 129}, {235, 77, 167}, {250, 106, 129}, {248, 104, 132}, {254, 96, 152}, {152, 7, 118}, {167, 7, 137}, {207, 32, 143}, {162, 23, 118}, {253, 142, 174}, {204, 47, 128}, {254, 99, 145}, {255, 98, 122}, {247, 148, 187}, {67, 31, 215}, {147, 95, 186}, {179, 61, 129}, {250, 102, 124}, {221, 90, 155}, {194, 93, 178}, {179, 56, 140}, {197, 38, 109}, {255, 104, 151}, {255, 110, 135}}, {{202, 19, 81}, {251, 92, 144}, {83, 4, 114}, {129, 0, 136}, {249, 98, 148}, {97, 5, 119}, {100, 0, 151}, {155, 16, 151}, {195, 43, 176}, {113, 17, 126}, {65, 14, 85}, {237, 144, 132}, {168, 51, 81}, {147, 7, 77}, {105, 2, 118}, {94, 46, 134}, {82, 0, 166}, {154, 29, 139}, {169, 41, 137}, {174, 57, 133}, {168, 57, 125}, {122, 14, 87}, {125, 45, 125}, {104, 56, 137}, {43, 3, 98}, {55, 3, 113}, {119, 58, 150}, {81, 5, 114}, {155, 70, 160}, {103, 14, 114}, {82, 6, 103}, {106, 36, 143}, {114, 33, 141}, {136, 41, 155}, {116, 4, 105}, {238, 92, 160}, {224, 64, 129}, {247, 121, 180}, {137, 14, 108}, {180, 61, 144}, {157, 24, 123}, {179, 38, 115}, {189, 47, 145}, {216, 76, 149}, {250, 134, 176}, {158, 42, 82}, {203, 82, 147}, {86, 9, 127}, {171, 61, 170}, {141, 25, 122}, {204, 64, 145}, {255, 126, 173}, {253, 115, 129}, {230, 107, 185}, {179, 49, 150}, {240, 118, 173}, {188, 30, 143}, {187, 34, 124}, {230, 98, 170}, {213, 53, 129}, {247, 114, 190}, {166, 34, 154}, {109, 13, 168}, {118, 82, 162}, {177, 125, 181}, {251, 145, 171}, {255, 84, 132}, {240, 76, 154}, {249, 88, 166}, {255, 97, 152}, {246, 80, 124}, {253, 74, 123}}, {{159, 11, 110}, {213, 51, 102}, {115, 4, 134}, {138, 3, 126}, {183, 18, 119}, {173, 2, 159}, {167, 0, 165}, {134, 1, 126}, {208, 38, 143}, {194, 65, 160}, {40, 8, 136}, {220, 130, 156}, {192, 80, 136}, {232, 84, 139}, {240, 76, 142}, {172, 35, 134}, {131, 16, 151}, {186, 55, 147}, {184, 26, 138}, {149, 9, 101}, {236, 70, 108}, {242, 66, 108}, {188, 76, 155}, {84, 34, 144}, {77, 0, 120}, {158, 17, 157}, {185, 13, 112}, {184, 5, 128}, {182, 65, 148}, {203, 85, 140}, {163, 34, 93}, {196, 51, 134}, {209, 47, 153}, {186, 86, 179}, {64, 27, 123}, {57, 3, 109}, {91, 23, 111}, {189, 39, 164}, {218, 60, 116}, {255, 130, 140}, {245, 97, 116}, {251, 129, 131}, {255, 137, 128}, {213, 96, 125}, {233, 111, 205}, {183, 69, 171}, {150, 50, 159}, {95, 89, 210}, {37, 56, 171}, {98, 88, 214}, {120, 21, 156}, {139, 28, 151}, {141, 35, 145}, {165, 49, 147}, {132, 15, 106}, {109, 2, 114}, {127, 48, 150}, {160, 17, 153}, {186, 74, 142}, {150, 63, 148}, {148, 89, 170}, {162, 56, 140}, {246, 107, 159}, {143, 55, 124}, {158, 101, 145}, {217, 154, 188}, {248, 116, 145}, {233, 69, 109}, {250, 102, 176}, {255, 74, 145}, {255, 89, 146}, {245, 74, 135}}, {{189, 33, 141}, {196, 52, 115}, {139, 22, 135}, {152, 10, 138}, {218, 31, 144}, {251, 72, 182}, {65, 13, 159}, {106, 0, 143}, {130, 2, 108}, {182, 31, 151}, {135, 6, 140}, {220, 113, 145}, {215, 74, 124}, {192, 12, 117}, {255, 75, 137}, {204, 63, 144}, {162, 42, 143}, {211, 51, 147}, {236, 79, 160}, {204, 59, 127}, {233, 92, 125}, {174, 40, 85}, {60, 0, 106}, {145, 32, 184}, {203, 45, 159}, {235, 55, 150}, {238, 54, 127}, {240, 51, 154}, {170, 25, 145}, {231, 85, 125}, {237, 62, 111}, {251, 79, 137}, {252, 87, 143}, {161, 46, 128}, {46, 3, 130}, {73, 26, 133}, {148, 104, 184}, {52, 0, 101}, {91, 3, 118}, {213, 60, 128}, {254, 120, 132}, {253, 127, 103}, {226, 81, 131}, {187, 27, 114}, {225, 102, 201}, {240, 108, 190}, {208, 118, 200}, {79, 85, 200}, {157, 151, 236}, {66, 54, 187}, {141, 67, 168}, {144, 68, 142}, {127, 37, 139}, {123, 48, 148}, {142, 79, 161}, {120, 72, 176}, {48, 20, 153}, {59, 26, 164}, {111, 48, 152}, {154, 79, 158}, {193, 121, 168}, {210, 125, 147}, {210, 105, 134}, {193, 43, 108}, {146, 88, 164}, {189, 143, 198}, {222, 156, 185}, {235, 96, 141}, {227, 59, 118}, {244, 83, 153}, {237, 93, 143}, {241, 74, 140}}, {{124, 24, 112}, {168, 25, 130}, {194, 61, 170}, {137, 12, 126}, {123, 0, 124}, {110, 0, 137}, {165, 23, 159}, {131, 11, 111}, {162, 4, 107}, {243, 44, 136}, {146, 22, 109}, {202, 82, 140}, {231, 100, 159}, {198, 73, 150}, {207, 52, 155}, {80, 0, 132}, {56, 0, 170}, {71, 0, 148}, {109, 0, 155}, {132, 0, 136}, {168, 24, 143}, {196, 65, 128}, {197, 52, 148}, {209, 43, 146}, {183, 18, 125}, {127, 0, 125}, {217, 48, 169}, {190, 29, 155}, {151, 1, 99}, {253, 100, 148}, {242, 80, 110}, {255, 102, 130}, {252, 115, 134}, {93, 15, 88}, {105, 69, 180}, {68, 2, 123}, {77, 14, 141}, {132, 37, 141}, {154, 47, 150}, {129, 56, 147}, {177, 39, 124}, {251, 140, 135}, {254, 104, 116}, {241, 91, 129}, {229, 64, 142}, {240, 73, 132}, {246, 153, 207}, {113, 78, 178}, {38, 24, 182}, {78, 30, 197}, {90, 4, 158}, {114, 15, 163}, {192, 81, 169}, {201, 52, 161}, {155, 0, 141}, {156, 39, 143}, {85, 73, 186}, {88, 67, 186}, {198, 134, 159}, {213, 119, 124}, {181, 80, 122}, {147, 54, 137}, {188, 79, 153}, {243, 86, 133}, {132, 61, 139}, {129, 94, 196}, {36, 18, 110}, {58, 52, 148}, {75, 0, 111}, {158, 26, 99}, {206, 47, 125}, {138, 42, 120}}, {{150, 1, 105}, {137, 38, 123}, {164, 1, 128}, {142, 17, 114}, {194, 16, 172}, {130, 1, 126}, {224, 78, 166}, {162, 0, 126}, {72, 0, 114}, {138, 10, 124}, {197, 44, 165}, {223, 40, 150}, {108, 1, 123}, {84, 10, 137}, {108, 0, 129}, {162, 61, 148}, {104, 0, 138}, {112, 0, 153}, {183, 0, 150}, {248, 34, 144}, {164, 1, 117}, {217, 43, 113}, {249, 64, 127}, {232, 49, 150}, {135, 1, 124}, {218, 80, 182}, {236, 65, 139}, {232, 57, 126}, {255, 83, 171}, {255, 74, 132}, {248, 60, 97}, {255, 100, 136}, {163, 28, 91}, {108, 29, 112}, {73, 1, 126}, {130, 23, 150}, {142, 32, 139}, {183, 96, 172}, {99, 4, 89}, {109, 0, 108}, {75, 7, 121}, {185, 40, 145}, {254, 113, 105}, {255, 114, 112}, {254, 116, 127}, {255, 150, 155}, {95, 0, 104}, {107, 0, 138}, {75, 0, 122}, {100, 4, 129}, {199, 73, 171}, {235, 110, 195}, {255, 131, 197}, {251, 123, 153}, {252, 98, 132}, {161, 45, 153}, {90, 86, 189}, {165, 29, 111}, {162, 18, 105}, {178, 40, 124}, {209, 97, 158}, {189, 70, 129}, {228, 73, 110}, {251, 97, 93}, {235, 151, 170}, {56, 32, 138}, {109, 90, 181}, {59, 48, 125}, {72, 54, 135}, {221, 109, 182}, {211, 46, 142}, {86, 49, 135}}, {{100, 9, 121}, {165, 6, 133}, {135, 5, 148}, {137, 15, 124}, {183, 0, 186}, {160, 34, 186}, {202, 34, 149}, {215, 75, 157}, {75, 0, 112}, {130, 13, 128}, {210, 42, 113}, {244, 48, 141}, {64, 1, 109}, {155, 2, 123}, {226, 41, 146}, {156, 0, 112}, {253, 69, 144}, {181, 4, 117}, {172, 43, 153}, {158, 6, 102}, {151, 5, 115}, {245, 43, 140}, {251, 45, 118}, {219, 59, 125}, {148, 0, 141}, {168, 35, 147}, {133, 0, 137}, {141, 3, 106}, {160, 45, 123}, {242, 77, 168}, {160, 23, 98}, {148, 4, 105}, {160, 18, 149}, {146, 16, 130}, {120, 37, 139}, {148, 49, 143}, {124, 0, 139}, {130, 23, 141}, {177, 23, 114}, {164, 12, 98}, {86, 0, 93}, {142, 46, 129}, {245, 121, 183}, {244, 96, 97}, {255, 117, 111}, {212, 52, 97}, {134, 0, 100}, {171, 61, 169}, {125, 24, 126}, {203, 45, 158}, {170, 0, 118}, {175, 13, 144}, {221, 51, 156}, {246, 76, 128}, {254, 101, 157}, {108, 36, 144}, {218, 75, 160}, {203, 20, 106}, {220, 71, 123}, {177, 8, 101}, {238, 81, 135}, {250, 95, 124}, {255, 100, 82}, {255, 116, 90}, {118, 24, 102}, {152, 100, 138}, {128, 81, 174}, {71, 44, 152}, {41, 8, 103}, {90, 56, 117}, {149, 124, 186}, {154, 141, 202}}, {{109, 2, 124}, {130, 1, 117}, {167, 42, 169}, {84, 0, 125}, {230, 56, 165}, {111, 7, 134}, {144, 14, 161}, {108, 6, 104}, {191, 40, 161}, {102, 16, 119}, {155, 14, 126}, {141, 38, 149}, {153, 1, 152}, {153, 13, 138}, {191, 11, 129}, {245, 74, 172}, {255, 49, 135}, {231, 54, 160}, {109, 0, 119}, {156, 27, 132}, {113, 12, 113}, {162, 15, 106}, {165, 7, 107}, {198, 59, 146}, {187, 4, 122}, {215, 0, 154}, {152, 0, 144}, {131, 7, 150}, {97, 0, 127}, {110, 0, 123}, {214, 2, 142}, {239, 69, 164}, {215, 43, 146}, {158, 25, 154}, {137, 43, 173}, {130, 0, 152}, {180, 72, 212}, {91, 0, 128}, {114, 0, 113}, {161, 24, 144}, {122, 15, 127}, {132, 40, 146}, {126, 26, 138}, {240, 75, 138}, {252, 134, 126}, {209, 36, 112}, {173, 20, 93}, {160, 48, 143}, {157, 5, 131}, {211, 25, 123}, {208, 66, 154}, {154, 52, 157}, {126, 25, 130}, {174, 45, 149}, {164, 44, 119}, {141, 26, 109}, {94, 0, 107}, {213, 29, 117}, {241, 82, 123}, {234, 77, 115}, {235, 73, 95}, {240, 85, 86}, {253, 89, 89}, {253, 117, 97}, {184, 105, 139}, {131, 19, 136}, {215, 107, 183}, {142, 32, 127}, {165, 86, 168}, {70, 49, 151}, {55, 46, 120}, {124, 91, 150}}, {{122, 13, 123}, {121, 0, 111}, {163, 1, 137}, {65, 7, 123}, {194, 26, 143}, {158, 16, 136}, {165, 15, 159}, {146, 35, 148}, {224, 70, 158}, {98, 5, 151}, {199, 39, 158}, {204, 57, 160}, {220, 2, 136}, {116, 5, 105}, {132, 7, 121}, {139, 10, 118}, {188, 0, 107}, {178, 1, 127}, {182, 12, 148}, {95, 0, 112}, {113, 0, 107}, {229, 19, 134}, {187, 11, 125}, {200, 37, 125}, {254, 79, 136}, {249, 12, 134}, {157, 14, 156}, {117, 0, 165}, {158, 0, 128}, {238, 25, 132}, {251, 41, 138}, {148, 3, 125}, {246, 65, 153}, {104, 10, 118}, {198, 84, 202}, {155, 3, 162}, {109, 0, 157}, {95, 0, 156}, {114, 9, 131}, {151, 46, 171}, {205, 99, 179}, {165, 60, 138}, {92, 45, 130}, {172, 66, 133}, {247, 110, 94}, {249, 114, 121}, {240, 70, 128}, {166, 0, 110}, {168, 13, 124}, {244, 104, 179}, {150, 2, 105}, {180, 32, 149}, {169, 16, 110}, {180, 31, 136}, {195, 74, 165}, {176, 56, 127}, {237, 101, 139}, {252, 83, 108}, {255, 92, 118}, {252, 77, 100}, {255, 102, 117}, {254, 114, 105}, {252, 95, 91}, {204, 87, 107}, {87, 2, 115}, {155, 33, 117}, {216, 92, 156}, {194, 69, 93}, {175, 48, 77}, {67, 5, 78}, {32, 19, 136}, {43, 16, 93}}, {{136, 6, 114}, {211, 74, 175}, {155, 38, 138}, {133, 17, 134}, {106, 0, 137}, {179, 20, 137}, {81, 3, 105}, {137, 29, 140}, {136, 5, 122}, {123, 7, 137}, {212, 46, 154}, {157, 14, 123}, {225, 61, 151}, {99, 0, 116}, {124, 0, 143}, {219, 38, 172}, {231, 54, 165}, {194, 0, 124}, {250, 31, 126}, {167, 7, 118}, {120, 0, 104}, {196, 42, 134}, {149, 0, 99}, {248, 35, 142}, {253, 37, 104}, {254, 63, 142}, {96, 0, 153}, {132, 1, 157}, {195, 15, 157}, {228, 30, 125}, {243, 70, 168}, {182, 0, 117}, {222, 72, 165}, {150, 28, 174}, {193, 42, 179}, {207, 73, 189}, {155, 32, 147}, {129, 11, 132}, {136, 0, 144}, {125, 0, 150}, {157, 0, 121}, {240, 42, 152}, {151, 41, 109}, {55, 13, 119}, {240, 116, 148}, {244, 79, 93}, {226, 48, 94}, {229, 54, 89}, {223, 35, 117}, {203, 64, 139}, {54, 0, 137}, {135, 26, 155}, {201, 32, 119}, {223, 53, 122}, {183, 43, 114}, {126, 0, 117}, {148, 29, 76}, {251, 86, 87}, {255, 85, 107}, {255, 105, 114}, {254, 93, 94}, {253, 81, 80}, {224, 108, 132}, {86, 8, 93}, {218, 121, 162}, {153, 28, 115}, {174, 13, 107}, {242, 91, 154}, {209, 55, 108}, {214, 121, 105}, {107, 53, 96}, {132, 88, 136}}, {{180, 49, 171}, {141, 4, 135}, {160, 72, 167}, {177, 54, 140}, {83, 4, 102}, {123, 9, 123}, {122, 5, 130}, {139, 3, 148}, {208, 56, 168}, {152, 23, 132}, {67, 0, 127}, {122, 2, 101}, {149, 1, 142}, {213, 25, 156}, {206, 13, 155}, {128, 0, 130}, {222, 54, 163}, {235, 61, 148}, {212, 24, 112}, {146, 10, 101}, {130, 28, 111}, {221, 52, 135}, {228, 65, 157}, {195, 29, 116}, {210, 30, 127}, {136, 2, 116}, {98, 0, 141}, {192, 9, 140}, {211, 36, 151}, {203, 41, 145}, {249, 81, 168}, {227, 81, 165}, {116, 4, 134}, {186, 71, 155}, {205, 44, 168}, {152, 0, 184}, {152, 0, 166}, {154, 22, 118}, {205, 87, 163}, {175, 15, 132}, {149, 0, 116}, {185, 20, 127}, {177, 11, 132}, {114, 57, 145}, {152, 20, 62}, {255, 101, 107}, {249, 96, 127}, {243, 69, 101}, {253, 92, 104}, {150, 19, 67}, {117, 62, 165}, {80, 26, 120}, {149, 12, 96}, {196, 73, 138}, {236, 101, 149}, {147, 9, 105}, {138, 26, 136}, {239, 81, 121}, {245, 78, 86}, {255, 83, 102}, {254, 78, 105}, {181, 55, 104}, {89, 11, 75}, {78, 4, 99}, {147, 1, 140}, {228, 47, 125}, {254, 119, 129}, {215, 54, 92}, {220, 54, 100}, {204, 78, 108}, {161, 77, 127}, {125, 49, 83}}, {{115, 2, 136}, {121, 0, 148}, {145, 19, 170}, {141, 21, 140}, {130, 12, 129}, {128, 26, 154}, {225, 85, 187}, {61, 0, 99}, {211, 71, 207}, {166, 17, 142}, {118, 0, 136}, {164, 16, 150}, {147, 3, 110}, {231, 16, 118}, {157, 18, 111}, {127, 0, 133}, {102, 14, 117}, {122, 0, 118}, {154, 12, 113}, {142, 20, 109}, {181, 0, 113}, {166, 0, 116}, {123, 1, 123}, {95, 0, 115}, {128, 0, 111}, {188, 0, 128}, {133, 0, 148}, {161, 4, 131}, {177, 0, 115}, {198, 25, 146}, {235, 80, 187}, {109, 34, 137}, {82, 0, 165}, {194, 44, 179}, {196, 31, 157}, {155, 0, 132}, {185, 1, 159}, {197, 0, 173}, {193, 0, 135}, {212, 52, 141}, {176, 50, 117}, {252, 96, 177}, {233, 94, 162}, {141, 38, 114}, {162, 63, 118}, {255, 103, 102}, {255, 88, 89}, {245, 81, 87}, {211, 65, 95}, {126, 5, 74}, {116, 14, 86}, {95, 9, 94}, {127, 0, 126}, {152, 7, 96}, {187, 74, 137}, {46, 31, 114}, {19, 0, 121}, {82, 10, 120}, {131, 25, 74}, {239, 118, 144}, {180, 14, 118}, {197, 55, 100}, {246, 92, 139}, {123, 0, 105}, {205, 56, 141}, {213, 72, 107}, {234, 81, 92}, {246, 85, 88}, {255, 106, 101}, {255, 121, 112}, {109, 11, 51}, {143, 0, 92}}, {{114, 18, 122}, {155, 52, 172}, {133, 35, 147}, {85, 11, 112}, {180, 46, 155}, {122, 12, 137}, {141, 15, 117}, {170, 34, 134}, {157, 43, 151}, {169, 28, 136}, {142, 4, 113}, {135, 5, 126}, {87, 4, 126}, {148, 19, 139}, {156, 29, 141}, {162, 0, 143}, {131, 0, 115}, {231, 44, 148}, {250, 38, 131}, {204, 23, 100}, {255, 59, 134}, {221, 31, 114}, {97, 1, 91}, {130, 7, 106}, {235, 11, 126}, {205, 48, 124}, {144, 0, 111}, {234, 37, 131}, {255, 33, 147}, {182, 15, 167}, {60, 0, 159}, {24, 0, 110}, {67, 0, 145}, {217, 54, 192}, {197, 5, 171}, {189, 44, 163}, {204, 22, 165}, {208, 0, 143}, {244, 42, 167}, {163, 9, 150}, {105, 0, 121}, {168, 37, 142}, {236, 8, 129}, {153, 16, 114}, {29, 0, 93}, {255, 107, 131}, {255, 111, 101}, {198, 14, 62}, {201, 30, 85}, {167, 43, 97}, {192, 35, 99}, {153, 18, 84}, {225, 90, 159}, {182, 52, 71}, {207, 95, 95}, {41, 3, 57}, {20, 3, 85}, {90, 2, 107}, {126, 0, 96}, {129, 18, 111}, {213, 94, 128}, {251, 99, 121}, {250, 82, 102}, {190, 17, 109}, {170, 34, 90}, {241, 93, 93}, {254, 73, 96}, {249, 77, 90}, {253, 69, 84}, {231, 80, 119}, {102, 16, 83}, {168, 13, 93}}, {{136, 32, 141}, {86, 0, 127}, {97, 0, 139}, {131, 13, 143}, {131, 30, 154}, {181, 69, 181}, {115, 18, 132}, {180, 21, 129}, {82, 3, 107}, {193, 74, 190}, {189, 14, 129}, {214, 54, 158}, {128, 0, 122}, {215, 44, 152}, {230, 33, 146}, {245, 52, 153}, {176, 48, 142}, {153, 16, 126}, {217, 35, 135}, {227, 25, 118}, {241, 62, 127}, {190, 71, 146}, {183, 46, 122}, {172, 16, 118}, {208, 29, 135}, {235, 74, 166}, {252, 59, 158}, {255, 21, 116}, {246, 26, 104}, {132, 8, 110}, {90, 1, 149}, {43, 4, 134}, {92, 9, 137}, {219, 52, 168}, {220, 48, 186}, {160, 1, 134}, {221, 41, 144}, {229, 39, 146}, {226, 18, 140}, {165, 0, 137}, {138, 0, 149}, {127, 0, 131}, {129, 0, 128}, {119, 0, 116}, {45, 0, 108}, {211, 77, 122}, {229, 71, 76}, {230, 68, 85}, {253, 105, 126}, {180, 16, 74}, {218, 62, 117}, {234, 63, 120}, {209, 40, 87}, {228, 78, 95}, {225, 93, 80}, {47, 0, 62}, {33, 2, 82}, {156, 22, 97}, {206, 15, 98}, {145, 1, 113}, {101, 6, 96}, {120, 4, 91}, {170, 39, 82}, {180, 65, 104}, {195, 52, 78}, {246, 62, 92}, {247, 52, 68}, {249, 80, 83}, {248, 73, 63}, {135, 25, 83}, {103, 4, 115}, {180, 0, 110}}, {{100, 9, 133}, {109, 0, 137}, {123, 26, 169}, {100, 0, 133}, {107, 13, 143}, {106, 17, 138}, {116, 12, 135}, {63, 3, 113}, {188, 46, 163}, {119, 0, 116}, {91, 3, 117}, {146, 29, 133}, {143, 0, 103}, {211, 63, 164}, {205, 21, 145}, {169, 3, 114}, {166, 2, 153}, {127, 1, 123}, {103, 0, 108}, {118, 1, 97}, {215, 26, 126}, {145, 0, 98}, {210, 62, 132}, {186, 9, 119}, {188, 27, 133}, {244, 56, 156}, {193, 39, 134}, {219, 38, 134}, {152, 1, 99}, {122, 4, 92}, {159, 32, 122}, {50, 11, 117}, {78, 22, 124}, {210, 72, 167}, {184, 24, 132}, {193, 25, 147}, {212, 9, 132}, {207, 4, 122}, {218, 40, 150}, {170, 4, 138}, {162, 0, 146}, {156, 0, 145}, {161, 0, 134}, {183, 8, 140}, {120, 24, 133}, {92, 7, 60}, {243, 69, 98}, {250, 67, 114}, {231, 38, 101}, {168, 29, 87}, {189, 25, 80}, {234, 46, 79}, {219, 48, 72}, {237, 77, 83}, {225, 88, 89}, {94, 46, 106}, {43, 10, 88}, {117, 5, 82}, {205, 49, 103}, {187, 27, 93}, {152, 3, 71}, {177, 56, 117}, {223, 88, 137}, {188, 50, 124}, {232, 60, 133}, {241, 30, 79}, {251, 60, 83}, {255, 88, 94}, {218, 80, 111}, {77, 2, 49}, {153, 26, 96}, {165, 9, 79}}, {{62, 0, 93}, {108, 14, 125}, {87, 4, 133}, {75, 1, 115}, {94, 7, 128}, {71, 2, 109}, {117, 3, 116}, {105, 12, 129}, {132, 20, 116}, {172, 46, 161}, {113, 5, 124}, {140, 1, 116}, {217, 48, 152}, {100, 3, 106}, {184, 26, 175}, {145, 0, 134}, {224, 0, 107}, {225, 53, 157}, {125, 13, 108}, {141, 5, 91}, {176, 10, 88}, {192, 0, 104}, {255, 4, 94}, {237, 49, 138}, {88, 0, 116}, {106, 0, 116}, {83, 13, 94}, {184, 10, 108}, {199, 34, 133}, {142, 2, 98}, {212, 2, 110}, {177, 81, 171}, {85, 22, 129}, {185, 47, 140}, {213, 50, 142}, {202, 34, 151}, {201, 22, 141}, {159, 0, 132}, {140, 4, 104}, {181, 42, 131}, {166, 0, 131}, {170, 0, 142}, {204, 6, 142}, {227, 16, 137}, {122, 0, 120}, {70, 14, 99}, {233, 67, 93}, {247, 76, 121}, {240, 70, 132}, {209, 35, 115}, {241, 60, 91}, {233, 87, 84}, {253, 82, 95}, {251, 95, 97}, {122, 16, 44}, {84, 11, 87}, {85, 17, 97}, {86, 1, 84}, {94, 20, 70}, {151, 13, 75}, {210, 53, 102}, {228, 68, 111}, {231, 50, 103}, {128, 4, 78}, {228, 116, 143}, {237, 72, 101}, {232, 64, 125}, {98, 9, 72}, {37, 23, 123}, {87, 19, 100}, {206, 25, 82}, {216, 65, 84}}, {{143, 57, 93}, {76, 6, 77}, {156, 63, 174}, {100, 9, 140}, {92, 1, 119}, {130, 41, 150}, {85, 0, 117}, {85, 3, 119}, {133, 58, 151}, {171, 40, 140}, {165, 28, 126}, {102, 0, 114}, {156, 12, 137}, {136, 0, 134}, {162, 0, 155}, {151, 0, 136}, {171, 38, 123}, {130, 8, 80}, {181, 40, 133}, {187, 15, 110}, {218, 48, 134}, {162, 17, 110}, {210, 15, 105}, {139, 7, 84}, {184, 64, 146}, {114, 3, 79}, {127, 40, 133}, {189, 37, 122}, {155, 4, 75}, {216, 41, 118}, {255, 32, 129}, {164, 31, 110}, {80, 23, 102}, {158, 40, 124}, {171, 4, 142}, {167, 5, 148}, {162, 1, 143}, {168, 0, 138}, {238, 18, 154}, {137, 2, 91}, {228, 64, 154}, {243, 19, 139}, {246, 38, 150}, {234, 0, 128}, {105, 0, 115}, {53, 1, 103}, {229, 73, 106}, {249, 80, 111}, {251, 67, 143}, {184, 42, 111}, {240, 80, 118}, {223, 65, 78}, {225, 88, 100}, {119, 29, 71}, {99, 27, 54}, {201, 123, 149}, {135, 44, 83}, {124, 28, 66}, {137, 9, 55}, {127, 3, 40}, {174, 83, 97}, {162, 105, 160}, {81, 18, 87}, {55, 11, 88}, {87, 2, 97}, {86, 0, 95}, {44, 0, 118}, {33, 5, 119}, {40, 0, 128}, {118, 10, 111}, {202, 40, 96}, {235, 50, 100}}, {{180, 71, 69}, {213, 100, 144}, {84, 12, 101}, {69, 4, 114}, {92, 23, 131}, {101, 5, 121}, {85, 8, 126}, {79, 1, 115}, {128, 44, 143}, {91, 1, 99}, {189, 54, 154}, {134, 12, 115}, {157, 14, 158}, {152, 0, 124}, {235, 84, 192}, {83, 0, 112}, {147, 0, 119}, {211, 53, 156}, {209, 13, 118}, {250, 25, 130}, {138, 0, 75}, {108, 0, 113}, {201, 51, 136}, {206, 24, 137}, {182, 25, 116}, {252, 51, 144}, {102, 0, 85}, {137, 10, 107}, {190, 41, 159}, {154, 5, 109}, {150, 0, 98}, {117, 16, 122}, {31, 7, 93}, {181, 83, 137}, {159, 22, 132}, {168, 0, 149}, {211, 45, 181}, {166, 1, 126}, {182, 0, 113}, {190, 3, 114}, {247, 38, 139}, {238, 22, 114}, {253, 28, 123}, {216, 2, 117}, {102, 0, 115}, {23, 0, 99}, {207, 94, 145}, {238, 70, 104}, {217, 12, 135}, {151, 0, 111}, {60, 0, 90}, {42, 6, 90}, {79, 24, 103}, {55, 0, 71}, {131, 1, 89}, {211, 59, 94}, {129, 11, 53}, {171, 28, 68}, {173, 17, 47}, {182, 20, 74}, {190, 77, 75}, {39, 14, 80}, {47, 0, 96}, {85, 0, 95}, {104, 0, 100}, {100, 0, 93}, {100, 9, 96}, {90, 45, 112}, {38, 0, 109}, {80, 0, 72}, {170, 31, 100}, {206, 57, 98}}, {{115, 32, 96}, {199, 74, 90}, {191, 75, 90}, {88, 0, 86}, {101, 32, 141}, {94, 11, 125}, {103, 20, 121}, {106, 24, 130}, {76, 9, 90}, {166, 46, 143}, {97, 0, 129}, {182, 50, 160}, {136, 1, 138}, {105, 3, 139}, {159, 8, 115}, {222, 67, 143}, {105, 1, 98}, {182, 31, 127}, {155, 10, 98}, {197, 24, 116}, {122, 2, 83}, {195, 49, 150}, {168, 33, 117}, {217, 51, 131}, {242, 26, 121}, {248, 44, 140}, {174, 55, 135}, {154, 16, 117}, {128, 16, 135}, {116, 6, 131}, {197, 35, 141}, {190, 44, 129}, {26, 0, 87}, {160, 50, 131}, {177, 55, 116}, {207, 67, 153}, {228, 69, 182}, {178, 9, 124}, {214, 8, 106}, {194, 9, 114}, {189, 1, 110}, {251, 25, 130}, {240, 35, 129}, {157, 32, 115}, {114, 1, 113}, {31, 0, 101}, {139, 19, 94}, {234, 47, 106}, {224, 5, 120}, {228, 15, 121}, {82, 0, 81}, {43, 2, 108}, {68, 12, 77}, {74, 10, 71}, {223, 50, 99}, {232, 62, 88}, {142, 26, 72}, {199, 12, 78}, {241, 48, 72}, {230, 75, 60}, {236, 113, 91}, {83, 30, 79}, {88, 2, 97}, {107, 4, 95}, {150, 0, 111}, {174, 0, 100}, {182, 2, 90}, {172, 53, 84}, {69, 0, 89}, {197, 54, 112}, {239, 48, 130}, {222, 48, 108}}, {{31, 1, 103}, {112, 17, 98}, {193, 89, 95}, {183, 62, 72}, {117, 22, 86}, {98, 3, 114}, {82, 0, 113}, {105, 9, 124}, {124, 21, 127}, {94, 6, 108}, {153, 52, 157}, {73, 0, 112}, {122, 13, 108}, {115, 9, 101}, {102, 9, 115}, {135, 0, 109}, {141, 35, 151}, {124, 6, 106}, {147, 6, 110}, {206, 41, 131}, {147, 6, 81}, {223, 7, 118}, {146, 3, 99}, {105, 0, 113}, {152, 0, 103}, {229, 24, 142}, {199, 23, 130}, {233, 15, 107}, {229, 45, 131}, {210, 58, 144}, {150, 36, 111}, {120, 5, 99}, {40, 0, 118}, {61, 13, 86}, {188, 61, 127}, {206, 58, 143}, {164, 38, 134}, {144, 0, 129}, {165, 0, 120}, {197, 2, 127}, {144, 0, 122}, {136, 0, 121}, {82, 1, 112}, {106, 0, 118}, {127, 0, 102}, {161, 106, 164}, {97, 9, 76}, {235, 32, 96}, {235, 8, 102}, {236, 6, 80}, {176, 43, 105}, {72, 3, 89}, {218, 78, 118}, {130, 15, 93}, {101, 1, 67}, {139, 24, 66}, {166, 36, 101}, {234, 53, 93}, {245, 60, 61}, {246, 81, 69}, {106, 18, 57}, {80, 9, 82}, {115, 7, 61}, {142, 0, 80}, {215, 65, 121}, {228, 62, 116}, {216, 32, 72}, {228, 75, 78}, {83, 11, 38}, {78, 0, 52}, {107, 15, 75}, {169, 9, 91}}, {{17, 0, 94}, {57, 0, 102}, {120, 24, 80}, {191, 69, 89}, {194, 68, 85}, {202, 85, 126}, {118, 22, 119}, {92, 19, 118}, {114, 19, 118}, {116, 24, 126}, {79, 3, 107}, {100, 16, 105}, {86, 2, 101}, {137, 16, 115}, {168, 41, 140}, {118, 14, 125}, {171, 43, 146}, {216, 59, 140}, {113, 4, 91}, {192, 42, 139}, {160, 13, 100}, {217, 23, 118}, {148, 34, 121}, {110, 11, 122}, {160, 6, 104}, {173, 2, 104}, {248, 28, 146}, {254, 10, 117}, {156, 4, 98}, {143, 19, 91}, {149, 13, 106}, {127, 53, 120}, {32, 0, 101}, {18, 3, 93}, {157, 76, 142}, {178, 49, 132}, {139, 8, 108}, {212, 60, 159}, {205, 30, 141}, {212, 0, 125}, {125, 0, 110}, {110, 0, 106}, {97, 0, 115}, {159, 1, 122}, {182, 9, 143}, {63, 5, 99}, {122, 38, 75}, {238, 64, 75}, {255, 86, 86}, {244, 75, 75}, {151, 34, 83}, {76, 0, 102}, {91, 0, 93}, {119, 16, 86}, {186, 55, 121}, {220, 80, 117}, {134, 2, 63}, {237, 51, 101}, {243, 98, 123}, {117, 16, 60}, {81, 4, 76}, {156, 0, 67}, {240, 61, 82}, {133, 4, 84}, {177, 34, 107}, {231, 1, 95}, {244, 47, 69}, {250, 83, 74}, {89, 8, 31}, {125, 16, 76}, {162, 7, 83}, {183, 22, 91}}, {{13, 2, 97}, {29, 0, 104}, {69, 0, 112}, {152, 43, 97}, {191, 66, 87}, {199, 70, 82}, {204, 78, 107}, {106, 6, 77}, {117, 14, 111}, {104, 9, 116}, {93, 1, 111}, {144, 34, 125}, {84, 11, 98}, {89, 0, 94}, {118, 7, 108}, {159, 44, 143}, {73, 0, 100}, {155, 31, 132}, {152, 16, 111}, {183, 12, 112}, {81, 2, 86}, {176, 16, 118}, {118, 5, 79}, {195, 47, 138}, {145, 0, 106}, {143, 23, 128}, {124, 14, 114}, {161, 0, 89}, {229, 20, 143}, {192, 4, 98}, {255, 83, 159}, {116, 19, 100}, {40, 17, 110}, {20, 8, 107}, {42, 0, 81}, {166, 62, 130}, {142, 0, 106}, {209, 6, 121}, {233, 15, 132}, {224, 34, 130}, {179, 12, 123}, {131, 0, 108}, {117, 4, 120}, {126, 5, 123}, {171, 32, 128}, {25, 20, 87}, {161, 44, 86}, {250, 74, 86}, {254, 101, 87}, {242, 93, 81}, {175, 58, 75}, {102, 0, 106}, {96, 0, 98}, {120, 0, 102}, {91, 6, 93}, {56, 6, 58}, {28, 11, 84}, {40, 0, 79}, {18, 0, 72}, {57, 0, 78}, {88, 12, 81}, {204, 39, 94}, {238, 70, 77}, {164, 19, 89}, {121, 0, 64}, {254, 20, 101}, {239, 73, 62}, {243, 96, 81}, {55, 0, 33}, {178, 14, 115}, {221, 60, 103}, {103, 2, 83}}, {{12, 6, 82}, {14, 0, 104}, {31, 0, 126}, {80, 0, 107}, {170, 59, 106}, {164, 68, 90}, {184, 64, 67}, {220, 79, 81}, {193, 84, 119}, {126, 10, 128}, {145, 37, 150}, {99, 0, 89}, {76, 0, 83}, {87, 0, 92}, {105, 13, 104}, {161, 45, 137}, {126, 3, 111}, {103, 0, 110}, {120, 5, 104}, {160, 15, 107}, {116, 8, 100}, {150, 23, 117}, {129, 0, 98}, {197, 42, 137}, {125, 26, 116}, {103, 28, 124}, {124, 0, 121}, {164, 4, 111}, {199, 37, 131}, {185, 17, 122}, {255, 0, 98}, {203, 56, 116}, {37, 3, 73}, {28, 9, 84}, {15, 0, 109}, {105, 44, 110}, {141, 3, 90}, {216, 1, 116}, {243, 29, 136}, {119, 0, 98}, {181, 58, 157}, {179, 42, 127}, {182, 45, 144}, {199, 40, 149}, {206, 4, 123}, {41, 2, 74}, {242, 104, 127}, {248, 74, 82}, {242, 80, 85}, {140, 38, 65}, {119, 1, 80}, {218, 115, 133}, {172, 8, 94}, {147, 1, 90}, {184, 18, 98}, {93, 20, 73}, {20, 7, 96}, {24, 0, 89}, {34, 0, 80}, {136, 0, 74}, {139, 41, 98}, {100, 11, 57}, {150, 5, 64}, {177, 33, 83}, {206, 25, 96}, {223, 52, 72}, {231, 71, 66}, {113, 17, 43}, {64, 12, 72}, {187, 15, 100}, {205, 28, 98}, {76, 1, 55}}, {{12, 0, 87}, {18, 1, 104}, {40, 2, 131}, {64, 0, 152}, {105, 0, 130}, {148, 32, 105}, {150, 45, 80}, {193, 71, 90}, {210, 76, 72}, {204, 83, 93}, {96, 0, 81}, {84, 0, 105}, {92, 0, 115}, {104, 17, 107}, {114, 28, 115}, {90, 16, 99}, {122, 13, 97}, {88, 8, 80}, {81, 3, 81}, {126, 46, 124}, {143, 1, 115}, {182, 29, 143}, {87, 1, 102}, {97, 0, 118}, {118, 3, 108}, {183, 35, 123}, {168, 31, 119}, {128, 25, 118}, {178, 35, 147}, {146, 17, 96}, {153, 3, 85}, {155, 54, 121}, {86, 12, 70}, {74, 10, 78}, {58, 0, 90}, {24, 0, 73}, {70, 2, 114}, {110, 0, 145}, {86, 0, 120}, {119, 0, 146}, {131, 0, 130}, {122, 0, 107}, {147, 20, 118}, {148, 1, 94}, {194, 43, 141}, {38, 0, 62}, {229, 71, 108}, {197, 35, 93}, {122, 0, 76}, {142, 23, 91}, {245, 55, 128}, {92, 1, 86}, {160, 13, 74}, {223, 58, 97}, {223, 62, 92}, {164, 63, 101}, {32, 4, 84}, {47, 0, 80}, {66, 1, 76}, {114, 1, 71}, {164, 46, 93}, {164, 59, 105}, {179, 35, 85}, {202, 70, 89}, {123, 34, 123}, {129, 21, 74}, {106, 7, 54}, {56, 9, 58}, {88, 11, 93}, {90, 6, 56}, {102, 6, 64}, {174, 42, 85}}, {{21, 14, 133}, {24, 19, 141}, {30, 18, 147}, {35, 0, 124}, {64, 0, 118}, {123, 19, 125}, {154, 40, 104}, {150, 38, 64}, {185, 54, 67}, {211, 73, 75}, {196, 80, 90}, {147, 47, 77}, {100, 15, 102}, {136, 50, 150}, {88, 3, 95}, {92, 2, 99}, {95, 2, 95}, {140, 26, 118}, {99, 0, 91}, {137, 54, 125}, {146, 49, 132}, {100, 10, 94}, {100, 11, 96}, {176, 38, 142}, {182, 64, 163}, {121, 14, 97}, {141, 6, 89}, {192, 40, 125}, {177, 19, 113}, {86, 1, 78}, {174, 31, 131}, {191, 16, 120}, {108, 1, 81}, {181, 12, 104}, {179, 88, 132}, {28, 20, 64}, {87, 35, 106}, {62, 0, 110}, {85, 0, 111}, {155, 0, 132}, {189, 32, 150}, {104, 0, 109}, {152, 3, 104}, {167, 18, 100}, {104, 21, 88}, {37, 4, 40}, {191, 55, 99}, {169, 22, 110}, {110, 1, 83}, {167, 21, 97}, {209, 54, 100}, {83, 0, 69}, {183, 19, 95}, {236, 16, 82}, {228, 64, 76}, {146, 12, 80}, {105, 44, 112}, {105, 8, 79}, {134, 9, 78}, {149, 4, 82}, {146, 31, 61}, {134, 89, 106}, {32, 10, 63}, {47, 6, 76}, {90, 20, 86}, {127, 0, 86}, {169, 10, 93}, {183, 33, 91}, {153, 20, 75}, {138, 39, 71}, {108, 15, 56}, {113, 10, 54}}, {{13, 14, 98}, {10, 0, 81}, {16, 15, 124}, {26, 0, 102}, {29, 0, 111}, {55, 0, 116}, {115, 2, 115}, {139, 26, 99}, {173, 50, 104}, {179, 53, 81}, {199, 66, 81}, {212, 72, 74}, {219, 91, 112}, {106, 12, 66}, {68, 1, 87}, {66, 5, 90}, {67, 0, 70}, {83, 13, 71}, {82, 18, 85}, {128, 31, 102}, {103, 41, 103}, {76, 23, 84}, {130, 28, 113}, {134, 39, 119}, {73, 8, 92}, {75, 0, 83}, {164, 17, 119}, {115, 0, 73}, {207, 12, 106}, {163, 32, 110}, {161, 26, 112}, {194, 32, 123}, {148, 16, 99}, {183, 16, 116}, {73, 5, 60}, {71, 9, 36}, {98, 23, 77}, {76, 0, 112}, {112, 17, 125}, {111, 5, 94}, {154, 33, 131}, {127, 0, 107}, {195, 2, 128}, {159, 16, 117}, {58, 6, 74}, {137, 63, 86}, {196, 58, 76}, {174, 9, 85}, {156, 31, 110}, {140, 8, 94}, {192, 27, 95}, {161, 30, 95}, {229, 51, 89}, {217, 60, 82}, {225, 80, 116}, {90, 0, 95}, {209, 38, 108}, {102, 0, 90}, {158, 8, 87}, {200, 13, 61}, {223, 72, 75}, {201, 97, 92}, {154, 67, 93}, {151, 40, 89}, {161, 48, 95}, {224, 79, 104}, {216, 70, 81}, {222, 85, 90}, {147, 69, 75}, {90, 0, 29}, {111, 31, 61}, {130, 11, 49}}, {{9, 3, 75}, {11, 0, 82}, {24, 21, 134}, {46, 14, 138}, {33, 0, 105}, {38, 0, 104}, {59, 0, 110}, {108, 0, 106}, {137, 13, 107}, {137, 9, 82}, {158, 46, 98}, {178, 57, 85}, {196, 65, 74}, {214, 92, 72}, {204, 97, 99}, {110, 8, 57}, {98, 9, 89}, {76, 1, 56}, {97, 17, 93}, {81, 5, 72}, {138, 21, 98}, {66, 5, 78}, {48, 0, 68}, {115, 36, 98}, {111, 15, 103}, {132, 23, 113}, {117, 17, 112}, {104, 2, 83}, {158, 38, 118}, {88, 5, 73}, {105, 36, 79}, {97, 1, 64}, {30, 2, 61}, {22, 0, 66}, {60, 20, 60}, {137, 53, 100}, {108, 6, 75}, {201, 71, 146}, {113, 24, 98}, {95, 0, 100}, {99, 5, 113}, {79, 0, 97}, {104, 2, 105}, {124, 0, 109}, {89, 15, 102}, {169, 91, 104}, {217, 92, 92}, {213, 78, 92}, {102, 12, 72}, {71, 1, 87}, {102, 0, 60}, {91, 3, 91}, {131, 23, 75}, {80, 12, 56}, {59, 0, 62}, {127, 24, 90}, {209, 8, 91}, {72, 6, 73}, {170, 0, 86}, {233, 31, 98}, {227, 79, 81}, {155, 53, 70}, {155, 38, 72}, {198, 45, 91}, {77, 0, 64}, {202, 37, 91}, {229, 53, 70}, {223, 78, 74}, {118, 7, 41}, {184, 40, 98}, {63, 2, 55}, {162, 4, 75}}, {{15, 12, 88}, {21, 1, 107}, {22, 0, 142}, {47, 3, 140}, {67, 0, 82}, {49, 0, 99}, {34, 0, 109}, {57, 0, 117}, {92, 0, 117}, {109, 0, 111}, {116, 0, 117}, {119, 3, 92}, {132, 19, 80}, {182, 57, 90}, {211, 73, 61}, {227, 98, 60}, {203, 74, 83}, {91, 0, 49}, {58, 6, 69}, {70, 19, 87}, {65, 2, 62}, {81, 0, 73}, {102, 21, 90}, {82, 7, 71}, {64, 6, 83}, {109, 0, 90}, {101, 29, 93}, {74, 7, 79}, {97, 10, 109}, {100, 0, 93}, {154, 2, 86}, {177, 68, 106}, {45, 5, 38}, {45, 15, 56}, {199, 77, 102}, {156, 0, 78}, {181, 0, 107}, {176, 6, 94}, {94, 9, 75}, {114, 42, 119}, {66, 1, 105}, {80, 0, 128}, {96, 1, 112}, {114, 5, 104}, {74, 2, 60}, {184, 81, 82}, {221, 70, 104}, {214, 91, 87}, {140, 4, 60}, {128, 34, 98}, {146, 37, 96}, {153, 0, 92}, {142, 38, 86}, {86, 4, 74}, {138, 25, 102}, {94, 1, 61}, {90, 9, 46}, {160, 65, 115}, {208, 26, 90}, {228, 64, 79}, {209, 60, 69}, {65, 15, 43}, {174, 46, 94}, {161, 46, 76}, {71, 32, 62}, {208, 32, 79}, {224, 55, 72}, {220, 83, 75}, {105, 11, 55}, {131, 31, 70}, {95, 12, 50}, {139, 8, 64}}, {{51, 0, 83}, {38, 0, 110}, {28, 16, 138}, {62, 12, 155}, {110, 12, 99}, {60, 0, 105}, {24, 0, 80}, {43, 5, 97}, {50, 0, 98}, {78, 0, 106}, {97, 0, 116}, {93, 0, 120}, {95, 0, 130}, {99, 0, 114}, {112, 0, 90}, {159, 41, 79}, {207, 69, 62}, {202, 70, 49}, {194, 75, 89}, {81, 10, 62}, {72, 14, 70}, {59, 8, 82}, {88, 21, 96}, {85, 0, 71}, {106, 7, 101}, {66, 8, 84}, {79, 10, 83}, {123, 50, 108}, {78, 9, 67}, {49, 0, 68}, {78, 1, 79}, {31, 10, 60}, {94, 17, 62}, {183, 82, 97}, {188, 41, 117}, {175, 29, 139}, {172, 19, 125}, {83, 0, 83}, {65, 0, 95}, {57, 0, 80}, {85, 1, 88}, {134, 43, 121}, {136, 30, 110}, {125, 4, 89}, {96, 0, 90}, {172, 65, 82}, {215, 88, 71}, {144, 24, 73}, {206, 67, 129}, {94, 5, 79}, {162, 16, 79}, {183, 9, 55}, {214, 94, 107}, {84, 0, 54}, {82, 0, 75}, {108, 15, 86}, {197, 35, 101}, {207, 46, 110}, {170, 63, 113}, {143, 10, 70}, {46, 12, 34}, {95, 0, 79}, {119, 28, 88}, {153, 66, 98}, {157, 1, 59}, {177, 43, 87}, {164, 46, 83}, {63, 6, 38}, {87, 11, 74}, {89, 0, 26}, {159, 39, 63}, {104, 18, 48}}, {{187, 25, 93}, {104, 1, 94}, {89, 0, 116}, {92, 11, 137}, {176, 49, 133}, {111, 0, 97}, {45, 0, 84}, {53, 0, 94}, {52, 0, 97}, {44, 0, 104}, {58, 0, 108}, {66, 0, 114}, {67, 0, 120}, {67, 0, 110}, {124, 2, 114}, {200, 31, 101}, {165, 36, 78}, {182, 62, 72}, {213, 70, 62}, {202, 70, 60}, {204, 90, 108}, {98, 3, 56}, {87, 3, 73}, {86, 14, 92}, {90, 5, 81}, {93, 22, 87}, {58, 0, 73}, {53, 10, 74}, {75, 10, 65}, {151, 73, 159}, {91, 31, 97}, {45, 0, 74}, {57, 11, 59}, {195, 62, 76}, {158, 18, 71}, {149, 48, 111}, {78, 0, 92}, {98, 23, 116}, {82, 0, 90}, {83, 1, 86}, {139, 0, 109}, {155, 13, 118}, {38, 25, 79}, {118, 33, 106}, {60, 23, 57}, {159, 50, 83}, {173, 39, 76}, {97, 3, 78}, {165, 72, 121}, {109, 28, 73}, {193, 31, 88}, {222, 66, 86}, {192, 86, 124}, {113, 18, 92}, {140, 38, 82}, {137, 46, 118}, {160, 23, 95}, {166, 27, 79}, {60, 3, 50}, {79, 18, 73}, {87, 13, 73}, {144, 4, 84}, {124, 23, 70}, {149, 40, 82}, {155, 33, 76}, {97, 9, 62}, {122, 47, 65}, {60, 10, 23}, {116, 40, 66}, {154, 57, 98}, {189, 69, 98}, {109, 31, 46}}, {{170, 72, 89}, {227, 1, 79}, {178, 0, 86}, {141, 5, 123}, {147, 14, 90}, {171, 1, 81}, {130, 0, 106}, {105, 0, 96}, {95, 0, 97}, {65, 0, 99}, {59, 0, 97}, {69, 0, 108}, {70, 0, 112}, {84, 0, 98}, {209, 35, 96}, {114, 3, 87}, {20, 0, 66}, {17, 8, 64}, {31, 5, 53}, {127, 31, 55}, {220, 60, 66}, {222, 60, 77}, {218, 72, 88}, {204, 68, 85}, {151, 34, 79}, {86, 1, 60}, {75, 17, 60}, {98, 29, 90}, {55, 13, 77}, {44, 15, 72}, {49, 13, 69}, {90, 47, 114}, {74, 22, 58}, {172, 37, 74}, {106, 4, 75}, {97, 1, 81}, {107, 6, 63}, {178, 64, 131}, {102, 13, 87}, {73, 0, 83}, {95, 0, 107}, {52, 0, 76}, {118, 1, 102}, {101, 0, 94}, {78, 4, 80}, {177, 62, 86}, {175, 73, 103}, {101, 13, 70}, {110, 8, 60}, {93, 5, 70}, {89, 0, 66}, {71, 8, 59}, {74, 16, 87}, {85, 18, 91}, {82, 7, 77}, {155, 36, 102}, {223, 43, 88}, {197, 69, 104}, {83, 11, 61}, {125, 56, 90}, {106, 8, 55}, {180, 23, 59}, {185, 69, 90}, {96, 16, 47}, {139, 32, 61}, {132, 19, 47}, {179, 56, 63}, {91, 8, 47}, {66, 7, 70}, {81, 7, 66}, {136, 34, 71}, {85, 23, 48}}, {{31, 3, 12}, {188, 85, 96}, {225, 38, 79}, {224, 14, 79}, {188, 17, 57}, {197, 28, 72}, {177, 0, 94}, {154, 0, 97}, {138, 0, 100}, {128, 0, 99}, {94, 0, 96}, {86, 0, 96}, {87, 0, 102}, {176, 45, 103}, {189, 22, 59}, {42, 0, 80}, {13, 20, 88}, {11, 13, 84}, {12, 0, 83}, {23, 2, 42}, {117, 23, 97}, {142, 0, 86}, {189, 7, 79}, {198, 25, 74}, {212, 54, 83}, {210, 68, 86}, {206, 77, 103}, {112, 36, 67}, {59, 0, 51}, {73, 25, 74}, {69, 19, 90}, {56, 7, 83}, {116, 20, 61}, {167, 46, 68}, {147, 48, 85}, {157, 28, 94}, {91, 2, 77}, {89, 7, 77}, {98, 8, 80}, {128, 43, 101}, {101, 51, 90}, {67, 14, 74}, {74, 6, 82}, {116, 7, 90}, {124, 47, 104}, {173, 95, 147}, {146, 57, 84}, {106, 16, 69}, {106, 15, 75}, {200, 66, 110}, {162, 87, 107}, {62, 9, 72}, {56, 4, 66}, {118, 12, 99}, {97, 11, 80}, {105, 29, 95}, {105, 13, 77}, {80, 11, 81}, {59, 4, 75}, {118, 29, 93}, {97, 20, 78}, {178, 39, 80}, {73, 5, 53}, {61, 1, 69}, {158, 22, 85}, {109, 3, 51}, {99, 28, 73}, {42, 9, 54}, {75, 17, 71}, {119, 30, 77}, {98, 34, 72}, {41, 10, 43}}, {{11, 17, 12}, {20, 9, 15}, {40, 10, 13}, {52, 2, 12}, {54, 7, 9}, {216, 90, 89}, {205, 0, 74}, {189, 0, 102}, {180, 0, 100}, {151, 0, 93}, {142, 21, 91}, {114, 0, 88}, {103, 0, 96}, {157, 29, 81}, {197, 69, 70}, {51, 2, 72}, {14, 15, 73}, {15, 6, 51}, {5, 0, 43}, {13, 12, 41}, {47, 23, 116}, {45, 5, 127}, {51, 1, 119}, {52, 4, 113}, {78, 0, 108}, {92, 0, 103}, {99, 5, 80}, {138, 12, 78}, {155, 18, 77}, {172, 57, 98}, {134, 43, 89}, {81, 8, 87}, {125, 37, 106}, {188, 45, 69}, {161, 36, 62}, {149, 26, 62}, {160, 59, 102}, {141, 47, 79}, {132, 44, 76}, {128, 24, 109}, {127, 12, 102}, {127, 36, 87}, {139, 65, 122}, {113, 24, 77}, {131, 63, 100}, {85, 28, 81}, {145, 45, 76}, {165, 76, 127}, {185, 33, 110}, {212, 26, 99}, {102, 13, 73}, {144, 30, 109}, {88, 4, 72}, {140, 23, 88}, {157, 36, 85}, {126, 54, 105}, {129, 34, 104}, {113, 17, 92}, {115, 13, 77}, {136, 47, 82}, {63, 2, 59}, {105, 16, 70}, {126, 33, 74}, {90, 17, 46}, {65, 16, 53}, {81, 17, 58}, {94, 33, 83}, {55, 8, 56}, {84, 13, 65}, {105, 41, 70}, {77, 30, 60}, {57, 11, 60}}, {{17, 1, 15}, {14, 5, 15}, {15, 8, 18}, {11, 13, 18}, {19, 18, 21}, {125, 71, 61}, {207, 50, 56}, {201, 19, 70}, {194, 0, 72}, {188, 0, 82}, {184, 0, 89}, {172, 2, 80}, {146, 9, 64}, {149, 19, 51}, {194, 82, 63}, {109, 35, 73}, {19, 0, 50}, {9, 6, 39}, {9, 11, 47}, {12, 5, 43}, {36, 23, 111}, {36, 19, 124}, {29, 9, 103}, {35, 6, 101}, {32, 10, 96}, {33, 8, 95}, {31, 0, 83}, {28, 1, 82}, {24, 3, 97}, {34, 0, 73}, {52, 0, 74}, {148, 69, 120}, {165, 61, 76}, {196, 88, 77}, {198, 79, 70}, {185, 88, 74}, {198, 91, 92}, {199, 101, 77}, {186, 83, 89}, {169, 68, 98}, {167, 76, 133}, {103, 18, 71}, {110, 32, 82}, {119, 21, 61}, {177, 80, 90}, {72, 13, 61}, {170, 100, 119}, {114, 12, 63}, {138, 37, 89}, {125, 26, 87}, {74, 11, 78}, {110, 38, 87}, {87, 11, 84}, {168, 4, 100}, {197, 65, 125}, {69, 3, 54}, {159, 63, 131}, {111, 11, 81}, {179, 58, 105}, {128, 52, 86}, {103, 51, 106}, {77, 4, 57}, {159, 50, 107}, {105, 18, 65}, {123, 36, 85}, {138, 40, 88}, {100, 27, 80}, {59, 18, 77}, {76, 16, 73}, {42, 2, 79}, {57, 15, 93}, {69, 0, 78}}, {{6, 5, 16}, {0, 0, 13}, {17, 0, 17}, {15, 5, 9}, {6, 0, 17}, {20, 3, 42}, {164, 77, 101}, {209, 78, 65}, {208, 62, 58}, {211, 59, 62}, {208, 68, 63}, {210, 87, 93}, {188, 117, 121}, {47, 2, 4}, {191, 88, 76}, {136, 30, 67}, {55, 4, 59}, {10, 1, 38}, {9, 0, 40}, {5, 0, 35}, {30, 16, 102}, {14, 19, 99}, {11, 16, 91}, {15, 17, 93}, {11, 15, 86}, {10, 14, 82}, {17, 17, 84}, {18, 18, 85}, {16, 9, 74}, {10, 3, 85}, {80, 52, 109}, {40, 0, 53}, {33, 0, 38}, {48, 0, 38}, {72, 0, 26}, {145, 56, 77}, {162, 67, 98}, {145, 39, 82}, {102, 0, 56}, {120, 23, 78}, {185, 68, 120}, {181, 60, 102}, {147, 41, 58}, {185, 82, 100}, {198, 94, 104}, {74, 27, 74}, {74, 21, 66}, {113, 39, 85}, {128, 55, 119}, {88, 20, 85}, {84, 10, 80}, {127, 35, 105}, {156, 73, 137}, {152, 40, 106}, {110, 3, 61}, {89, 16, 70}, {107, 33, 88}, {87, 0, 81}, {133, 54, 97}, {66, 25, 92}, {62, 24, 88}, {113, 54, 117}, {63, 0, 69}, {86, 23, 88}, {102, 29, 103}, {69, 11, 91}, {58, 24, 104}, {62, 21, 112}, {80, 0, 97}, {114, 0, 112}, {163, 0, 114}, {196, 2, 106}}, {{11, 11, 0}, {0, 14, 15}, {0, 9, 17}, {17, 25, 72}, {26, 33, 131}, {45, 54, 150}, {10, 15, 63}, {47, 5, 5}, {65, 16, 14}, {54, 18, 15}, {38, 5, 19}, {28, 0, 18}, {17, 4, 20}, {12, 15, 25}, {119, 46, 52}, {181, 24, 67}, {83, 0, 58}, {9, 1, 32}, {7, 2, 34}, {12, 5, 42}, {22, 15, 71}, {7, 18, 72}, {11, 18, 76}, {21, 24, 78}, {15, 20, 69}, {14, 18, 66}, {16, 14, 69}, {17, 15, 71}, {17, 12, 61}, {7, 10, 64}, {8, 10, 62}, {14, 13, 55}, {18, 4, 56}, {16, 6, 58}, {46, 0, 70}, {99, 0, 86}, {162, 40, 126}, {147, 6, 84}, {154, 10, 100}, {154, 13, 114}, {136, 33, 108}, {118, 16, 67}, {203, 84, 116}, {205, 78, 88}, {181, 74, 95}, {49, 22, 81}, {91, 48, 114}, {80, 31, 126}, {51, 27, 131}, {55, 34, 129}, {66, 36, 128}, {64, 7, 117}, {61, 28, 124}, {50, 37, 120}, {54, 34, 120}, {61, 33, 120}, {62, 38, 118}, {54, 27, 130}, {101, 32, 137}, {68, 26, 132}, {77, 39, 144}, {99, 35, 153}, {101, 27, 142}, {110, 1, 119}, {139, 5, 115}, {160, 0, 111}, {183, 0, 110}, {201, 0, 104}, {197, 2, 81}, {201, 7, 66}, {211, 39, 71}, {191, 68, 68}}, {{13, 16, 55}, {28, 27, 91}, {28, 24, 95}, {7, 0, 57}, {12, 14, 26}, {16, 12, 19}, {17, 8, 3}, {0, 3, 17}, {8, 6, 1}, {11, 0, 0}, {17, 3, 4}, {5, 7, 3}, {0, 8, 4}, {18, 11, 12}, {55, 12, 17}, {172, 14, 51}, {97, 6, 54}, {20, 1, 30}, {8, 7, 32}, {11, 8, 38}, {19, 5, 52}, {8, 3, 56}, {7, 11, 61}, {15, 14, 69}, {11, 7, 60}, {13, 14, 58}, {18, 15, 58}, {17, 15, 63}, {10, 14, 70}, {9, 17, 59}, {4, 16, 50}, {19, 3, 68}, {46, 3, 88}, {90, 6, 102}, {125, 22, 109}, {183, 52, 125}, {207, 65, 127}, {216, 81, 107}, {194, 74, 87}, {188, 42, 80}, {188, 28, 108}, {143, 24, 110}, {97, 15, 72}, {200, 99, 123}, {131, 69, 101}, {26, 24, 104}, {99, 27, 111}, {125, 4, 133}, {127, 8, 132}, {125, 11, 136}, {127, 12, 146}, {114, 2, 135}, {140, 33, 151}, {137, 24, 136}, {145, 21, 137}, {159, 0, 126}, {168, 8, 124}, {151, 7, 128}, {181, 1, 127}, {189, 0, 128}, {185, 14, 118}, {197, 8, 109}, {205, 0, 102}, {213, 0, 92}, {214, 8, 83}, {222, 35, 82}, {217, 51, 72}, {224, 71, 77}, {201, 80, 74}, {180, 99, 83}, {113, 59, 52}, {38, 12, 21}}, {{15, 10, 67}, {4, 10, 29}, {5, 8, 12}, {8, 7, 13}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 1}, {17, 4, 14}, {43, 7, 9}, {194, 11, 51}, {141, 0, 60}, {70, 17, 57}, {38, 1, 48}, {14, 7, 38}, {8, 2, 35}, {15, 4, 53}, {15, 13, 56}, {19, 26, 59}, {22, 20, 62}, {27, 22, 71}, {27, 30, 78}, {34, 20, 78}, {44, 19, 90}, {60, 0, 79}, {91, 5, 88}, {103, 0, 100}, {144, 5, 101}, {187, 27, 107}, {198, 51, 109}, {177, 50, 103}, {184, 56, 105}, {190, 72, 94}, {203, 75, 105}, {205, 76, 96}, {209, 66, 95}, {181, 21, 83}, {108, 0, 79}, {31, 16, 69}, {34, 21, 81}, {19, 18, 75}, {111, 10, 81}, {171, 7, 108}, {181, 2, 106}, {188, 0, 104}, {203, 0, 119}, {202, 0, 115}, {203, 0, 108}, {208, 0, 101}, {212, 0, 105}, {213, 0, 99}, {218, 0, 98}, {216, 10, 95}, {196, 21, 83}, {210, 43, 97}, {222, 60, 105}, {207, 41, 82}, {210, 50, 85}, {209, 84, 79}, {197, 96, 79}, {167, 94, 75}, {144, 95, 76}, {51, 17, 15}, {36, 14, 19}, {23, 9, 16}, {18, 8, 15}, {14, 5, 15}}, {{5, 10, 2}, {10, 4, 13}, {6, 0, 14}, {6, 1, 12}, {0, 0, 11}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 1, 0}, {22, 8, 20}, {30, 9, 7}, {200, 55, 52}, {174, 1, 47}, {121, 0, 50}, {93, 1, 51}, {71, 3, 61}, {72, 14, 58}, {79, 13, 79}, {88, 4, 93}, {115, 17, 113}, {138, 26, 125}, {130, 2, 106}, {163, 18, 121}, {170, 14, 115}, {187, 8, 118}, {195, 3, 109}, {174, 22, 102}, {146, 38, 94}, {74, 7, 34}, {39, 10, 24}, {29, 15, 14}, {16, 0, 3}, {5, 13, 16}, {6, 15, 5}, {3, 13, 11}, {35, 12, 15}, {92, 14, 30}, {192, 89, 109}, {193, 43, 92}, {100, 11, 66}, {71, 6, 83}, {63, 19, 66}, {187, 80, 98}, {202, 57, 73}, {211, 52, 79}, {198, 25, 72}, {199, 22, 75}, {211, 40, 93}, {229, 67, 110}, {219, 73, 101}, {223, 81, 97}, {216, 84, 93}, {204, 79, 83}, {214, 92, 90}, {209, 95, 86}, {212, 103, 90}, {216, 110, 105}, {188, 108, 101}, {108, 58, 49}, {38, 3, 9}, {25, 7, 10}, {18, 0, 14}, {7, 5, 17}, {0, 6, 0}, {7, 2, 9}, {0, 0, 12}, {1, 0, 13}, {6, 0, 8}}, {{0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {15, 3, 13}, {31, 12, 9}, {189, 77, 66}, {211, 38, 42}, {185, 19, 63}, {171, 2, 59}, {178, 14, 80}, {185, 9, 87}, {183, 4, 98}, {173, 2, 117}, {175, 0, 128}, {179, 26, 127}, {185, 45, 128}, {159, 40, 107}, {92, 12, 46}, {46, 2, 19}, {32, 3, 17}, {13, 0, 5}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {24, 19, 16}, {99, 38, 48}, {177, 76, 93}, {175, 72, 86}, {196, 86, 85}, {204, 94, 76}, {206, 99, 78}, {211, 105, 84}, {205, 99, 75}, {208, 107, 86}, {194, 89, 70}, {203, 104, 82}, {186, 102, 75}, {191, 108, 87}, {176, 102, 86}, {169, 106, 89}, {83, 40, 26}, {37, 1, 1}, {16, 6, 11}, {6, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}}, {{0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {17, 0, 17}, {0, 19, 16}, {73, 21, 15}, {211, 94, 82}, {201, 80, 64}, {209, 93, 82}, {203, 97, 106}, {206, 86, 121}, {198, 96, 132}, {68, 10, 38}, {40, 0, 22}, {23, 0, 11}, {15, 4, 5}, {12, 0, 0}, {13, 0, 10}, {7, 12, 10}, {4, 4, 4}, {10, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {15, 10, 22}, {12, 11, 15}, {16, 10, 4}, {37, 0, 9}, {77, 29, 31}, {104, 53, 47}, {68, 26, 27}, {40, 0, 16}, {36, 5, 7}, {30, 0, 9}, {21, 0, 1}, {19, 0, 1}, {17, 0, 1}, {10, 0, 0}, {10, 5, 12}, {4, 6, 15}, {6, 0, 15}, {10, 5, 9}, {0, 0, 0}, {0, 6, 0}, {0, 6, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}}, {{0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 1, 0}, {19, 0, 3}, {3, 13, 6}, {4, 19, 7}, {39, 17, 20}, {32, 17, 14}, {29, 1, 13}, {20, 10, 18}, {20, 7, 15}, {11, 13, 12}, {4, 12, 4}, {15, 6, 16}, {7, 5, 15}, {0, 10, 17}, {4, 6, 0}, {6, 11, 1}, {14, 8, 10}, {4, 2, 3}, {0, 6, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {7, 14, 5}, {2, 12, 1}, {13, 6, 8}, {12, 3, 5}, {13, 15, 12}, {14, 1, 11}, {19, 7, 12}, {18, 4, 6}, {16, 9, 8}, {10, 4, 10}, {10, 5, 10}, {13, 5, 8}, {16, 0, 8}, {0, 0, 10}, {0, 0, 8}, {0, 0, 6}, {0, 0, 8}, {0, 8, 16}, {0, 0, 0}, {6, 0, 0}, {6, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}}, {{0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}, {0, 0, 0}}};
    delay(200);
    FastLED.addLeds<APA102, data, clock, BGR >(currentLED, totalLEDs);
    FastLED.setBrightness(LEDBrightness);
    pinMode(powerLED, OUTPUT);
    digitalWrite(powerLED, ON);
    drawImage(30, Image, width(Image));
    void drawImage(unsigned long time, const char pattern[][totalLEDs][3], int pictureWidth)
    unsigned long currentTime = millis();
    while (millis() < currentTime + (time * 1000))
    for(int slice = 0; slice < pictureWidth; slice ++)
    for(int LED = totalLEDs-1; LED > -1; LED --) // LED number
    currentLED[LED].setRGB(pattern[slice] [LED] [redVal],
    pattern[slice] [LED] [greenVal],
    pattern[slice] [LED] [blueVal]);
    FastLED.show();
    delayMicroseconds(800); // How wide the image is
    delayMicroseconds(1000); // Gap between images
