Page 12 of 16 FirstFirst ... 2 10 11 12 13 14 ... LastLast
Results 276 to 300 of 399
Thread: Teensy APA102 POV Poi / Pixel Poi Build. Tutorial
  1. #276
    Senior Member mortonkopf's Avatar
    Apr 2013
    London, uk
    917
    @Howsthe water - it looks like the four connections might be thin copper strips under a black coating of either plastic or paint. You might try scratching this off to expose the four traces, tinning them, and then soldering. I think it would be difficult and require a cooler solder iron.
  2. #277
    Feb 2018
    18
    Poi Build
    Hiya.
    I recently built a pair of these poi which turned out great here's some pictures
ID:	13106 Click image for larger version.
ID:	13107 Click image for larger version.
    I have also rewritten the code generation webpage to create a demo of what the poi will look like allong with some ways to change certain things like the number of LEDs being used. I can upload my version of the webpage somewhere if there's enough interest bit it'll take a while as it's quite a bit of work to pull it out of my personal website.
    I'm interested in porting the code to the ESP platform and will be happy to assist anyone else wanting to do the same.
    Also I was wondering what the lowest clock speed can be used and still generate the same effect, as the teensy 3.2 is quite expensive so i'd like to look at alternative controllers?
    Cheers
  3. #278
    Apr 2013
    London, uk
    917
    Amazing looking shots. what density led/m you using? great job
  4. #279
    Feb 2018
    18
    Hiya mortonkopf.
    I followed your guide almost exactly, so the same density as yours ( cant remember what it was at the moment )
    I am currently travelling but when I get back i'm planning on getting some PCBs made with 2020 SMD LEDs in a 500mm length.
  5. #280
    Apr 2013
    London, uk
    917
    yep, those 2020s look incredibly tiny. I get the feeling that there might be a call for a bulk order if you manage to get a good lightweight compact PCB design. Really looking forward to updates on that.
  6. #281
    Feb 2018
    18
    That'd definitely be something I'd be up for doing. Have you tried any other micro controllers or is the Teensy the only one good enough?
  7. #282
    Apr 2013
    London, uk
    917
    Ive stuck with Teensy as the availability of additional pins, very good library and forum support, and small form factor mean that I didnt need to go elsewhere once I finally came to Teensy. Researched and prototypes a few alternatives, but nowhere near as good. Also, I am not a great programmer so found the simple toolchain and arduino IDE just right for me.
  8. #283
    Sep 2015
    Taiwan, Asai. (Traditional Chinese)
    164
    Quote Originally Posted by InvisiBug View Post
    nice UI, I'd lack of skill in such coding, or I would also write one :\
    Teensy 3.5/3.6 can do enough speed for POV up to 200 pixel I think, (1,800 line when 72 pixel, overkill details)
    I think at least 800 frame/s when 200 pixels, pretty enough detail for most picture
    apa102 - 2020 is made in TW, I still have some plenty of them , waiting for my futher prototype, never had time to forward
    If you need some, maybe I can share some
    notice they are unable to hand-solder, I use hot air gun for success soldering them.
  9. #284
    Apr 2013
    London, uk
    917
    user @HowstheWater is also looking at working with APA 2020 size, but using strips. It would be good to collect any learning here.
    Agree that the UI looks good.
  10. #285
    Sep 2015
    164
    I had some successful prototype for the pads for apa102-2020,
    see details at floor #252 253 , though the footprint is in fritzing ,
    the working case should be easier to know since the manual of apa102s are usually chinese
  11. #286
    Have a good day tell me whether I can implement this project on arduino mini
    sorry if I do not understand it, I'm from Ukraine and I do not speak English well
  12. #287
    Apr 2013
    London, uk
    917
    Hi. Unfortunately the arduino Mini does not have enough memory for storing the graphics, and the processing power is sure to be an issue.
  13. #288
    Quote Originally Posted by mortonkopf View Post
    Thank you very much for the answer
    then you need to understand the tensi
  14. #289
    if you have any questions about programming or can i contact for help to you
  15. #290
    Apr 2013
    London, uk
    917
    if you have specific questions about the project, feel free to ask on this thread as others will often have good answers and support. From the collected experience on POV projects on this site, the Teensy is great because it is powerful, has enough memory to store image data, gets the data out fast enough for POV, can run SPI leds for a good quality display, and uses a well known interface to programme it (Arduino IDE).
  16. #291
    Sep 2015
    164
    Quote Originally Posted by Андрій View Post
    you can ask here or on a new thread I think is ok
    surely you can do POV with Mini, I did some with nano.
    But you need an additional flash/ storage device for your picture, for example SD card,
    or you have to give up your color depth in order storage in Flash.
    you need 24 bit for a pixel in .bmp , but you can as small as 1 bit if you have only black/white. I did use less like 8 bit (256 colors) with my nano project.
    also, there are limits in reading and showing your picture with mini / nano, as they are only 16Mhz and teensy are more than 120Mhz
    but you can start a slower-working code with it
  17. #292
    Quote Originally Posted by Po Ting View Post
    if you need 120 MHz then the best fit is teensy 3.6 in which 180 MHz + sd flah slot
    Is it possible to make 6 pairs and in some way synchronize them. ie, I enable the main poi and the rest together with the radiomodule
    and how to add an image correctly using your converter? are there any other ways? because our task is to strike write a script in which we can arrange different time delays between effects. everyone shines - some shine, then again, is it all possible? and can your code be used as a basis? thank you for any help
  18. #293
    Sep 2015
    164
    My friends plays with group POV and dealing those effect is mostly hard at designing( on computer etc)
    different delay between effect and even as each poi/staff are themselves individuals - to design effect,
    and they just follow the same music with intended different delays.
    I don't use a radio synchronize because lack of enough skills
    we count the time with the MCU itself and its cystall's very accurate,
    as long as you click the button altogether precisely, the consciously teamed POV could work.
    that is, they turn on the POI at the desired moment of music.
    this is a performance in my university NTHU,
    https://www.youtube.com/watch?v=MMW_FfNds2U
    and you can see the difference color/lighting interval of the group, with my designed staff.
  19. #294
    I buy teensy 3.6 and start collecting a prototype, as I finish I will ask for help with the code)
  20. #295
    how many images can be uploaded to teensy 3.2 and teensy 3.6 if there are two strips apa102 to 72 led
  21. #296
    Sep 2015
    164
    you should count the total height also, the width is 72 as you have 72 LEDs
    T3.6 assume you have 800KBytes flash rom left after program, with 24 bit image(3 bytes per pixel),
    you can have 800,000 / 3*72 ~= 3703 lines , so if a image is 72x200 than you can store about 18 pics in ROM
    notice that you have a internal SDio slot for microSD card on T3.6,
    so there's plenty of room even if you use a 64MB card(hard to find one anyway) (more than 1000 image in this case)
    For T3.2 its about 200,000/ 3*72 ~=900 lines, sorry but 4 (72x200) full-colored 24bit pics is max
  22. #297
    Hiya.
    Cheers
    yab wanted to look at your web page to me it is very interesting
  23. #298
    https://github.com/djnamaste/esp8266-supernova-attempt
    I am working on porting Adafruit's POV code to work on esp8266. Using NodeMCU this sketch works when using graphicsesp.h but it saves patterns in the working memory, not in flash. Changing the pattern file to graphics.h does not work but I believe it stores the files in the flash. Anyone able to help with file storage issue?
  24. #299
    I have added a bit more information to my request for some advice. This sketch works on esp8266 and fastled but stores all 137 patterns in RAM: https://github.com/djnamaste/POV-ESP8266-stored-in-ROM
    I want to take advantage of the flash space on the esp and add more patterns and functions. PROGMEM was used by Adafruit's code here: https://github.com/adafruit/Kinetic_POV
    Again, the code I posted works but if you change the patterns.h file and the imageinit part to read and access from flash memory, the chip reboots constantly.
  25. #300
    Apr 2013
    London, uk
    917
    on Teensy ARM you use "const" rather than PROGMEM and this will put the data into flash without using up RAM. Not sure hpw this works with esp8266 though. so you would declare an array like: const uint32_t myArray[] PROGMEM = {/* .... */} and you just access it simply rather than using pgm_read_...
