Results 1 to 2 of 2
Thread: Teensy 3.1 as USB midi interface and USB -> DMX converter
    Hi everyone,
    I use my teensy 3.1 as a midi controller and I am wondering if it is possible to use it also as a usb to open dmx interface.
    Is it possible to declare the teensy as a midi device AND a usbDMX device
    If it is not, maybe it is possible to declare it as a teensy to computer midi device and comuter to teensy openDMX interface ?
    thanks a lot !
    21,857
    I'm not familiar with OpenDMX, but I did make a project a couple years ago which emulated a subset of the Entec DMX USB Pro (just enough for Vixen). It played a sequence stored on a SD card, but allowed any USB communication to stop the automatic playing and take control of the lights.
    Here is that code:
    https://github.com/PaulStoffregen/Li...y/CorePlay.ino
    Assuming OpenDMX also needs USB serial, and you want USB MIDI at the same time, perhaps these threads can help?
    https://forum.pjrc.com/threads/23942...-the-same-time
    https://forum.pjrc.com/threads/27660...-the-same-time
    https://forum.pjrc.com/threads/28775-Midi-and-Serial
    If OpenDMX needs other USB support, maybe you could explain or link to the tech info....
