defragster
Senior Member+
Has anyone tried the edits to use the SD_card slot as was done on the non touch ILI9341?
PJRC touch display package came today - great delivery time! - not powered up yet. I sent a note to Robin for future QC testing - If you were lucky enough to get one from the first batch - make sure glass front is secured to PCB or you could get a rude surprise. Metal frame loops may not catch the display side ears allowing it to fall out as you rotate it. Worse yet - the metal frame on one of mine was not secured to the PCB board meaning upside down the screen would drop and swing/tug on the attaching cable. Double sided tape seems to be a fix. <and lifting the glass enough to push the metal loop in 'some'>
