Page 2 of 2 FirstFirst 1 2
Results 26 to 37 of 37
Thread: MKL02 / MKL04 Bootloader Chips Available
  1. #26
    20,593
    I've added a picture and link for the alternate reference board to the MKL02 page.
  2. #27
    I'd totally buy >=1 of them. Anyone selling? Paul, might you ever release a teensy3++, or a teensy3 with the pads as pins?
  3. #28
    Germany NRW
    5,679
    Quote Originally Posted by alialiali View Post
    You can buy it here:
    https://www.oshpark.com/shared_projects/d3J03Zeb
  4. #29
    Sorry, I mean the fully assembled and tested board. I am pretty sure I would fail to solder that.
  5. #30
    Germany NRW
    5,679
    If it is because of the underside-pads, you can use this (very cheap):
    https://oshpark.com/shared_projects/0T6ZdhhG
    Many people use it. No i don't earn any cent with it .. (no spam )
  6. #31
    9,770
    If you get solder paste - a little on each pad of Franks' OSH board when pinned in place touching with the soldering iron is very easy to make those connections clean!
    There is of course a t3++ in the pipeline : https://forum.pjrc.com/threads/34808-K66-Beta-Test
  7. #32
    I'm not even mad. That's amazing. Thank-you.
  8. #33
    Senior Member jimmayhugh's Avatar
    168
    Well done
  9. #34
    Looks like several people like OSHPARK for pcb fabrication. Anyone have any recommendations for a pcb assembler?
  10. #35
    Jul 2017
    2
    I've updated the web page with info about the plans for the debug request signal. This update will be coming in early 2016. If you design a PCB now, hopefully this will let you plan for supporting a debug port.
    Hi, did the debug request signal ever happen? I couldn't find anything one way or another, so I fear it isn't implemented.
    We're designing a PCB with a debug port, and following the suggestion to have the debug cable ground PTA3, but will that do anything?
  11. #36
    20,593
    Still not implemented. Many other projects like USB Host have come first. It's still on my list, but no solid time frame.
  12. #37
    Jul 2017
    2
    Good to know, thanks!
