Results 1 to 13 of 13
Thread: Teensy 3.1 and I2c pins 16 & 17
    Hello All,
    I've recently started a GPS logger project that interfaces to the Teensy 3.1 and I'm having problems communicating with the i2c bus on pins 16 & 17. Are these valid i2c pins? If so, what is the trick to get them operational?
    Thanks,
    Kelly
    12,398
    Those are grayed as if they should be usable when you can't use the primaries. Do you have ~4.7K pullups on the I2C lines? Good power and the right pins specified in software? Valid address to the I2C hardware?
    Can you temporarily use the primaries to test?
    22,746
    By default, pins 18 and 19 will be used.
    EDIT: see message #6 below for correct code. This one has a mistake...
    To switch to the alternates, try this:
    Wire.begin();
    CORE_PIN18_BIT = 0;  // turn off primary pins before enable alternates
    CORE_PIN19_BIT = 0;
    CORE_PIN16_BIT = PORT_PCR_MUX(2)|PORT_PCR_ODE|PORT_PCR_SRE|PORT_PCR_DSE;
    CORE_PIN17_BIT = PORT_PCR_MUX(2)|PORT_PCR_ODE|PORT_PCR_SRE|PORT_PCR_DSE;
    Also, remember that real pullup resistors are always required for I2C with Teensy 3.1.
    Yup, I have pull-up resistors on both lines tied to 3.3V. I'm actually using 2.2k ohm. I'll try the code for switching to the alternate i2c pins. Thanks!
    Oct 2015
    2
    Wire.begin();
    CORE_PIN19_BIT = 0;
    Hi Paul,
    I've tried this and it doesn't compile, I've tested this on Arduino 1.0.6 and Arduino 1.6.5 with teensyduino 1.25
    Are there any other methods I could try to change the i2c to 16 & 17 without using the alternative i2c library.
    The code I'm using is the adafruit libaray example file https://github.com/adafruit/Adafruit...sm9doftest.ino
    and I'm adding that additional bit of code to line 70 of this file https://github.com/adafruit/Adafruit...SM9DS0.cpp#L70
    Regards
    Arran
    22,746
    Oh, opps, my mistake. Here's the right way:
      Wire.begin();
      CORE_PIN18_CONFIG = 0;  // turn off primary pins before enable alternates
      CORE_PIN19_CONFIG = 0;
      CORE_PIN16_CONFIG = PORT_PCR_MUX(2)|PORT_PCR_ODE|PORT_PCR_SRE|PORT_PCR_DSE;
      CORE_PIN17_CONFIG = PORT_PCR_MUX(2)|PORT_PCR_ODE|PORT_PCR_SRE|PORT_PCR_DSE;
    That should solve the "lvalue required" error.
    Jan 2015
    SF Bay Area
    255
    how do I use SCL1 and SDA1 on pins 29 and 30?
    or do I need to use the other i2c library to use it?
    22,746
    You need another library. The normal Wire library only accesses the main I2C port.
    Oct 2015
    2
    Thanks Paul that worked perfectly
    Member javiernicola's Avatar
    Apr 2018
    Madrid
    20
    It works for me
    Quote Originally Posted by doughboy View Post
    Change every "Wire." for "Wire1."
    Apr 2018
    Madrid
    20
      Wire.begin();
    Hello Paul, im trying this with a teensy 3.2(because pin18 SDA is burnt) .
    Is the same code for teensy 3.1 and teensy 3.2?
    So far i had no luck, could i have burned the periferic down if i still see a correct SCL signal?
    My setup:
    Serial.begin(57600);
    pinMode(LED_NARANJA_PIN, OUTPUT); digitalWrite(LED_NARANJA_PIN, HIGH);
    Wire.begin(I2C_HARD_ADDR); // join i2c bus with address #I2C_HARD_ADDR
    CORE_PIN16_CONFIG = PORT_PCR_MUX(2) | PORT_PCR_ODE | PORT_PCR_SRE | PORT_PCR_DSE;
    CORE_PIN17_CONFIG = PORT_PCR_MUX(2) | PORT_PCR_ODE | PORT_PCR_SRE | PORT_PCR_DSE;
    Wire.onRequest(hard_i2c_event); // register event
    Feb 2014
    Colmar, France
    2,584
    You could simply try with another Teensy. Such "oooops" moments where something get's shorted, burnt, or broken happen to every developer. That's why I strongly recommend to order Teensys in batches of 3, so that you have always one or two spares in the drawer to allow a differential diagnose.
    Apr 2018
    Madrid
    20
    i did order 6, but sadly i need them all , i was trying to work around my BURNT SDA0 pin with no major changes in code.
    Im already using the alternative SDA1
