Using some of the OneWire Teensy3 code in my project, DIRECT_MODE_OUTPUT is not working. I'm using a Teensy 3.1 and OneWire from the Arduino 1.65 release, but the DIRECT_MODE_OUTPUT macro has not changed in quit a while. To test I extracted the macros into a simple sketch and tested against pinMode (pin, OUTPUT). Here is my test sketch. flag controls the 3 scenarios // 0 = digital write, 1 = OneWire w/DIRECT_MODE_OUTPUT, 2 = OneWire w/pinMode. Is it me or the macro?
* I extracted the Onewire code line for the Teensy3 and included them here.
* If pinMode OUTPUT is used in OneW, pin 13 lights the LED
* DIRECT_MODE_OUTPUT the LED does not light
#define flag 1 // 0 = digital write, 1 = OneWire w/DIRECT_MODE_OUTPUT, 2 = OneWire w/pinMode
uint8_t pinA = 13;
//oneWire.h extracted to here
#define PIN_TO_BASEREG(pin) (portOutputRegister(pin))
#define PIN_TO_BITMASK(pin) (1)
#define IO_REG_TYPE uint8_t
#define IO_REG_ASM
#define DIRECT_READ(base, mask) (*((base)+512))
#define DIRECT_MODE_INPUT(base, mask) (*((base)+640) = 0)
#define DIRECT_MODE_OUTPUT(base, mask) (*((base)+640) = 1)
#define DIRECT_WRITE_LOW(base, mask) (*((base)+256) = 1)
#define DIRECT_WRITE_HIGH(base, mask) (*((base)+128) = 1)
IO_REG_TYPE bitmask;
volatile IO_REG_TYPE *baseReg;
IO_REG_TYPE mask = bitmask;
baseReg = PIN_TO_BASEREG(pinA);
bitmask = PIN_TO_BITMASK(pinA);
#if flag == 1
DIRECT_MODE_OUTPUT(baseReg, bitmask); //1
OneW();
#elif flag == 2
pinMode (pinA,OUTPUT); //2
OneW();
#else
dig();
void dig(void){
digitalWrite(pinA,HIGH);
delay(2);
digitalWrite(pinA,LOW);
void OneW(void){
DIRECT_WRITE_HIGH(baseReg, bitmask);
DIRECT_WRITE_LOW(baseReg, bitmask);
