jumbodrawn
New member
Hi!
I want to hook up 4-5 buttons and use them as a keypad type device with the teensy. I want to be able to set them to commands like media keys, but if not numbers should work. I did some research, and somebody said that this library thing is good for what I want:
https://github.com/tmk/tmk_keyboard/blob/master/README.md
Any suggestions on how to do it?
Specifically, what commands should I use, and do I just load the library into the Arduino code?
I've never actually used the teensy, but I'm pretty sure you just make your program, then somehow export it as a hex file then use the teensy loader?
