joe_prince
I'm eventually going to make a flight controller board for a quadcopter using the BNO055 for inertial measurement, and will have to solder the components to the board myself. The BNO055 is a 0.5mm pitch LGA chip (http://www.mouser.com/ProductDetail/Bosch-Sensortec/BNO055/?qs=QhAb4EtQfbV8Z2YmISucWw==), and so I will be using a hot air rework station to solder it (I don't own a reflow oven).
I have soldered TQFP chips in the past, by hand and with the hot air rework station, and it is visibly easy to see if there are any solder bridges or bad solder joints that need to be fixed. However, for an LGA chip the solder joints underneath aren't visible, so how would one go about testing whether the solder joints are good, no bridges have formed, etc.?
I suppose I can just "assume" everything went well, and give it power and see if the chip is behaving as it should, but I would like to be able to fix issues before potentially frying the board and components.
