iambrentiam
Hi -
I am having a problem with one of my teensy boards that I have not seen before. Unfortunately, I am not sure how it got into this state. The problem is that the teensy will not boot unless it is connected to the host computer's USB port. It will be working just fine connected. I then unplug the usb it and it still works fine (it has its own power). I press the reset button or do a hard power cycle and it gets stuck, my application does not start. After I plug the USB back in I see the Windows Teensy Boot Loader come to the foreground, the programming progress bar appears and finishes, then my program starts loading just fine.
Could I have accidentally put it in a mode that stalls the boot sequence until it is connected to USB? If so how do I reset it so that it will boot normally without the USB connected?
A little more context: I have the problem teensy connected to another teensy over a CAN bus and the second teensy works as expected. I have been debugging the problem teensy over the CAN bus to see when it boots.
Thanks!!
Brent
Thanks!!
Brent
