I am using The Teensy Audio Adapter board (https://www.pjrc.com/store/teensy3_audio.html) for my project. However, I also this Teensy work as a slave device and communicate with another Teensy through I2C. I tried doing that and it didn't work. I was able to set the Teensy up as a slave device and it would work fine. However, as soon as I plug in the Teensy Audio Adapter board and start using "Audio.h", it stops working.
Is there any way I can use both the Teensy Audio Adapter board and allow it to talk with other devices on the I2C?
I tried using the other I2C bus, but that requires the use of the I2C_t3 library. I couldn't get it working with the Audio.h library.
Any idea on how I can solve my problem would be appreciated.
