Page 1 of 2 1 2 LastLast
Results 1 to 25 of 48
Thread: Teensyduino 1.26 Beta #1 Available
    Administrator Paul's Avatar
    Oct 2012
    338
    Here is a first beta test for Teensyduino 1.26.
    The main changes are fixes for Macintosh. USB Serial is fixed for El Capitan.
    The installer and Teensy Loader should now work if you have Security & Privacy configured to only allow applications from the mac store and identified developers (which is the default setting). However, you *must* run Arduino at least once before the Teensyduino installer modifies it.
    Edit: old beta test linkes removed. Full non-beta release is here:
    http://www.pjrc.com/teensy/td_download.html
    Here's a complete list of the changes since 1.25:
    • Fix USB Serial on Macintosh 10.11 El Capitan
    • Partially fix Mac signatures (still must run Arduino once before installing)
    • AnalogWriteFrequency supports extremely low speeds (thanks Theremingenieur)
    • Improve tone() changing frequency while running
    • Update libraries: AltSoftSerial, FastLED, ILI9341_t3
    • Add XPT2046_Touchscreen library
    • Improve Ethernet library W5200 reset handling
    • Update SD library examples
    • Add I2S 2-port register bitfield names
    • Initial work on MTP Disk (incomplete)
    Feb 2014
    Colmar, France
    2,534
    Install and quick compile test went without problems (Mac OS X 10.11.1 El Capitan).
    Thank you for mentioning my tiny contribution to analogWriteFrequency(), but I'd prefer to be mentioned with my forum pseudo (Theremingenieur), rather than with the github name (universpharmacie). That github account belongs to my day job's employer and I had to use it for the pull request since the github GUI tool for OS X is not capable to handle more than one single account...
    If I find a few minutes during the upcoming weekend, I will still write a little about the extended functionality, so that the table on the website which relates analogWrite frequencies and resolution can be extended.
    Oct 2012
    338
    I've updated the list of changes.
    Feb 2014
    Colmar, France
    2,534
    Thank you, Paul!
    9,737
    Posting Beta note on web? :: http://www.pjrc.com/teensy/td_download.html
    9,737
    Installing 1.26b1 on 2nd Win10 machine - both okay - but the second I closed the IDE's and left Teensy open - then after all the clicks to get there is just aborts - would be nice if it detected open Teensy Loader up front and said to close before it got all fatal like - or if it gave a back button to retry.
    Thank you Paul !!!! Its all working !
    Dec 2014
    Oklahoma City, OK
    10
    I know I'm behind the curve, but what version of Arduino IDE will the new software work with?
    20,579
    Quote Originally Posted by mjhilger View Post
    1.0.6, 1.6.1, 1.6.3 and 1.6.5.
    Every installer always shows a list of the Arduino versions it knows. Admittedly, that info is hidden in the middle of the intro page nobody reads.... but it's always there if you know where to look.
    20,579
    Support was dropped for Arduino 1.6.0, 1.6.2 and 1.6.4, because those versions had serious bugs.
    1.6.0 and 1.6.2 were quickly replaced by 1.6.1 and 1.6.3, because the bugs were so serious.
    1.6.4 was available for quite some time, but it had a really unpleasant bug where libraries using templates and other advanced C++ features wouldn't compile. FastLED was one of the popular libraries impacted.
    HELP!!
    My mac can't even see any Teensy 3.1 on USB since El Capitan update on friday to 10.11.1.
    I have a important test goning on in 1 our with some prototypes buld up with the Teensy and I can't load anything on the Teensy right now!!!
    20,579
    So far, all El Capitan problems have been related to USB Serial mode. I personally tested 1.26-beta1 with El Capitan. It works.
    If your Teensy is already programmed as USB Serial (from an older Teensyduino before this issue was fixed), first unplug it. Make sure Teensy Loader is running. Use the Teensy > About menu to make sure it's 1.26-beta1. Turn off auto mode. Then hold the button while plugging the cable back in. Holding the button will prevent Teensy from running any code that was previously loaded. When you release the button, you should see Teensy Loader recognize the Teensy. If you turned off auto mode, it won't immediately reprogram. Then you can run Arduino with the new Teensyduino and program it with the updated USB code that works properly with El Capitan.
    Did this with one Teensy and afterwards all others got recognised, too.
    Thank you for your always fast answers!!!
    Oct 2015
    2
    Hi Paul. Thanks. The verify/upload process is definitely working better now, under 10.11, with this. I have a slightly different issue, but I believe it is 10.11 (10.11.2, specifically) related. When I upload the standard firmata sketch... I get the customary blinky-blinky.. but am unable to connect via firmata to the board... coincidentally, after that first connection attempt, all usb/serial communication stops working (although I do see the device listed under dev, ie. /dev/tty.usbmodem935591)! The board stops responding, regardless of pushing reset, disconnecting, etc. and the entire USB system goes to heck. At this point I can't even view the USB section in System Profiler (see below). My only option at this point is to restart. Once back up, everything is fine, i believe, until again trying to connect to the firmata device (a teensy 3.1 in my case). Any advice?
Name:	Screen Shot 2015-10-29 at 12.35.06 PM.png
    Oct 2015
    1
    Teensy3.1 USB serial no response after multiple connection in El Capitan 10.11.1.
    Hi Paul, I reinstalled 1.26-beta1, and programmed 'EchoBoth' firmware to teensy3.1 according your method. Then I use CoolTerm to test. I clicked 'Connect' button, sent '81' and can receive 'USB received:129', it is great!But I do many times like 'Disconnect' - 'Connect' - sent 81, sometimes USB serial no response just after I 'Connect' then sent '81'. The funny thing is if I sent '81' three times, USB serial will give me a correct response, then data transfer is normal. I test many times, if usb serial no response after I 'Connect' and sent '81', always sending '81' three times will activate usb serial. I test this for the self test of my EKG system, the code in OS X Yosemite is fine, but in El Captain, it can not go through. I do not know what was wrong? Could you please give me some advice?
Name:	Screenshot 2015-10-29 20.57.52.jpg
    Nov 2015
    1
    Does running this 'add-on' also for working with the Arduino Software with the UNO Board ? Nowadays a can't use the UNO because my iMac (El Capitan) can not communicate with the board because of wrong USB driver. I write about my problem here (last post)
    https://forum.arduino.cc/index.php?topic=354969.0
    Aug 2014
    7
    USB Serial reading on El Capitan
    Hi Paul,
    Here's another El Captian serial issue:
    When I run the code below on 10.11.1 using Arduino 1.6.6 and Teensyduino 1.26, and watch the console, I get the occasional clobbering in random places - some data gets overwritten by data following it.
    /dev/cu.usbmodem does not appear to have this problem, but pyserial (2.7) with python (2.7.10) show a similar same loss of data. Previous OSX versions did not do this noticeably. Any suggestions?
    The output:
    123456789:;<=>?@ABCDEFGHIJKLMNOPQRSTUVWXYZ0123456789:;<=>?@ABCD
    123456789:;<=>?@123456789:;<=>?@ABCDEFGHIJKLMNOPQRSTUVWXYZ0123456789:;<=>?@ABCD
    The sketch:
    byte count = 0;
    const byte BUFSIZE = 64;
    byte buffer[BUFSIZE] = {0};
      count = '1';
      for(int i = 0; i < BUFSIZE; i++) {
        buffer[i] = count++;
        if (count > 'Z') {count = '0';}
      buffer[63] = '\n';
     // while (!Serial.available()) {};
      Serial.write(buffer, 64);
    20,579
    Does this problem appear if I just watch the data arrive in the Arduino Serial Monitor? Or do I have to use pyserial somehow?
    I guess my main question is what exactly do I actually run with El Capitan to see the problem?
    How frequently does this occur? Should I expect to see it within seconds, or do have I to collect data for hours, days, or weeks?
    9,737
    FYI - in case it relates - the SerialMon of IDE 1.6.6 is worse than ever on Windows 10. It is Ctrl-R de-activated during compile and never comes back.
    After each compile the IDE (USB) SerMon window must be closed and re-opened on my system as the old one sits there 'grayed' out showing nothing.
    It probably doesn't relate as not only is this windows but the above issues don't seem to call out the IDE SerMon - but just in case. I'm going back to TYQT to see if it has developed any new odd behavior. Besides I've got two active Teensy display units and SerMon is one port only.
    Aug 2014
    7
    It shows up randomly, about once a second, in the Arduino Serial Monitor.
    They are easy to spot because the lines stick out (all the ones I've seen so far).
    I can make a PySerial test as well, if that helps.
    Aug 2014
    7
    Still dropping data on El Capitan
    Hello Paul,
    I've written a little sketch and a python program to easily demonstrate this problem.
    On El Capitan, I get 14-15% of dropped/mangled 64 byte blocks consistently.
    On Yosemite, I get 0% dropped consistently.
    I am using Teensyduino 1.26 and Arduino 1.1.6.
    I'd be happy to help fix this in any way
    Output:
    python ./readbackTest.rb
    Getting Port
    Found Teensy at /dev/cu.usbmodem1346771.
    Opening port
    Starting to read
    Last error:
    Expected: 444444444444444444444444444444444444444444444444444444444444444
    Received: 4444444444444444444444444444444444444444444444444444444666666666666666666666666666666666666666666666666666666666666666
    OK: 8506, Error: 1494, Error rate 14.94%
    Sketch:
    int i = 0;
    const int MAXBUF = 10;
    const int USB_BUFSIZE = 65; // 64 + 0 termination
    char sprintbuf[MAXBUF][USB_BUFSIZE];
    bool send_now = false;
      // Prepare some data
      for (i=0; i< MAXBUF; i++) {
        int j = i*111111;
        sprintf(sprintbuf[i], "%06d%06d%06d%06d%06d%06d%06d%06d%06d%05d%04d\n", j,j,j,j,j,j,j,j,j,i*11111,i*1111);
      Serial.flush();
      if (Serial.available() > 0) {
        char command = Serial.read();
        if (command == 'b') {
          send_now = true;
        if (command == 'e') {
          send_now = false;
      if (send_now) {
          // Send 64 bytes as fast as possible.
          Serial.print(sprintbuf[i]);
    Python script (uses pyserial):
    #!/usr/bin/python
    import serial
    import time
    # Find the port the teensy is at, for convenience
    def getTeensyPort():
        import serial.tools.list_ports as lp
        for portDict in lp.comports():
            if any("VID:PID".lower() in s.lower() for s in portDict):
                #pull out the VID and PID numbers
                start = portDict[2].find('=')
                middle = start + portDict[2][start:-1].find(':')
                end = middle + portDict[2][middle:-1].find(' ')
                VID = int(portDict[2][start+1:middle], 16) #convert hex string to int
                PID = int(portDict[2][middle+1:end], 16)
                if VID == 5824 and PID == 1155:
                    print "Found Teensy at {}.".format(portDict[0])
                    return portDict[0]
        # If we have found and returned none, it is an issue.
        raise Exception("Unable to find a Teensy board in USB enumeration.")
    print "Getting Port"
    port = getTeensyPort()
    print "Opening port"
    ser = serial.Serial(port)
    time.sleep(0.01)
    ser.write("b\n") # begin to send
    ser.flush()
    ok_count    = 0
    error_count = 0
    lastError = "No Error"
    print "Starting to read"
    while (ok_count + error_count < 10000): #
        line = ser.readline()
        expected = (line[0] * 63)
        if (line.rstrip() != expected.rstrip()):
            lastError =  "Expected: {}\nReceived: {}".format(expected,line)
            error_count = error_count + 1
        else:
            ok_count = ok_count + 1
    ser.write("e\n") # finish sending
    ser.flush()
    print "Last error:\n{}\n".format(lastError)
    print "OK: {}, Error: {}, Error rate {}%".format(ok_count, error_count, 1.0*int(10000.0*(1.0*error_count/(error_count + ok_count)))/100)
    serial_speed_straight.ino
    readbackTest.rb.txt
    Last edited by retospect; 12-09-2015 at 09:22 PM. Reason: Clarified script language.
    Dec 2015
    1
    I have run the test script on Windows 7 64 bit and I also get 0% dropped. It looks like the issue is with El Capitan
    Dec 2015
    1
    I ran the script on a 64-bit windows 10 laptop and got:
    C:\sourcecode\Sketchbook\serial_speed_straight>ver
    Microsoft Windows [Version 10.0.10586]
    C:\sourcecode\Sketchbook\serial_speed_straight>python readbackTest.py
    Getting Port
    Found Teensy at COM5.
    Opening port
    Starting to read
    Last error:
    No Error
    OK: 10000, Error: 0, Error rate 0.0%
    No errors.
    Dec 2015
    1
    I ran the test script on Linux, Fedora22 (64bit) with no errors:
    $ python serialdebug.py
    Getting Port
    Found Teensy at /dev/ttyACM0.
    Opening port
    Starting to read
    Last error:
    No Error
    20,579
    I'm working on this now. I've got a Teensy and USB protocol analyzer connected to an El Capitan machine and it's reproducing the problem. Teensy appears to be sending properly. There's no corrupted or incomplete packets, so this is really starting to look like a bug in El Capitan. I have hunch about the bug (based purely on guesswork about what Apple might be doing), and I have a couple ideas for a workaround.
