Dear Paul:
I obtained the following sensors that I need to controlled with Teensy. Unfortunately, all info I’ve got is associated to Arduino, however I’d think Teensy is able to do it well:
Sensors:
SI1145 Digital UV Index / IR / Visible Light / Proximity Sensor (https://www.adafruit.com/products/1777)
SHT10 Soil Temperature/Moisture Sensor (https://www.adafruit.com/products/1298)
Liquid Flow Meter - Plastic 1/2" NPS Threaded (https://www.adafruit.com/products/828)
Actuators:
By the way I have to control the following:
Light intensity: About 4 relays/dimmers associated (at 220V). I mean relays/dimmers able to get voltage graduated programmatically. (???)
Water sewer: Plastic Water Solenoid Valve - 12V - 1/2” Nominal (https://www.adafruit.com/products/997)
Display:
Graphic ST7565 Negative LCD (128x64) with RGB backlight (https://www.adafruit.com/products/438)
Communication:
Adafruit HUZZAH CC3000 WiFi Breakout with Onboard Antenna (https://www.adafruit.com/products/1469)
Paul, can you tell me how Teensy could get all this stuff working together?
Thanks in advance.
Sensors:
Actuators:
Display:
Communication:
Thanks in advance.
