I am using Pixelcontoller w/Teensy 3.2 and the Octows2811 Board for a Matrix of 35X40 (1,400 LEDs). I am not powering the Teensy with an external supply but just via the USB. On the first strip of 35 2812B pixels I have the orange wire going to the data in and the Orange/white going to ground of the strip. Should I be splitting the Orange/White to ground on each strip using the same data pin thereafter ? The first 5 strips will be using Orange and strips 6-10 using blue etc.. Basically I want to make sure I'm grounding correctly.
thanks!!
thanks!!
