I posted this in one of my other threads but it didn't really fit.
I'm using Teensy 3.2 and the octo Adapter for a Led Matrix project that will be 35x40 (1400 LEDs)
As of right now I have 35x7 (245 leds) hooked up for testing. I'm using 210 leds per strip, so i have the first 6 rows hooked up to Led Strip #1 data and the 7th row hooked up to Led Strip #2 data. When I use the BasicTest all is well and runs as it should. But when I use the code below for a program called Jinx! only the first 6 rows are working. I got the code from somewhere online when I was searching for Octows2811 and Jinx! together. Does anyone see any obvious reasons why only Led Strip #1 Data is working?
/* (C) 2014 by MSchmidl
Required Connections as defined by OctoWS2811
pin 2: LED Strip #1 OctoWS2811 drives 8 LED Strips.
pin 14: LED strip #2 All 8 are the same length.
pin 7: LED strip #3
pin 8: LED strip #4 A 100 ohm resistor should used
pin 6: LED strip #5 between each Teensy pin and the
pin 20: LED strip #6 wire to the LED strip, to minimize
pin 21: LED strip #7 high frequency ringining & noise.
pin 5: LED strip #8
pin 15 & 16 - Connect together, but do not use
pin 4 - Do not use
pin 3 - Do not use as PWM. Normal use is ok.
#include <OctoWS2811.h>
const int ledsPerStrip = 210; // adopt these value to your needs
DMAMEM int displayMemory[ledsPerStrip*6];
int drawingMemory[ledsPerStrip*6];
const int ledPin = LED_BUILTIN; // used to indicate a packet start
int pixelIndex = 0;
const int stateR = 0;
const int stateG = 1;
const int stateB = 2;
int state = stateR;
unsigned long pixelColor = 0;
const int config = WS2811_GRB | WS2811_800kHz;
OctoWS2811 leds(ledsPerStrip, displayMemory, drawingMemory, config);
pinMode(ledPin, OUTPUT);
leds.begin();
for (int i=0; i < ledsPerStrip; i++){
leds.setPixel(i, 0x0F0000); // all red
leds.show();
Serial.begin(9600); // parameter does not matter - USB is always 12 Mbit/sec
digitalWrite(ledPin, LOW); // set the LED off
if (Serial.available()) {
byte incomingByte = Serial.read(); // will not be -1
switch (incomingByte) {
case 1: // packet state indicator used be GLEDIATOR
digitalWrite(ledPin, HIGH); // set the LED on
leds.show(); // show the current data
pixelIndex = 0; // restart with new data
state = 0;
default: // all values !=1 are payload data
switch (state) {
case stateR:
pixelColor = long(incomingByte) & 0xFF;
state = stateG;
case stateG:
pixelColor <<= 8;
pixelColor |= long(incomingByte) & 0xFF;
state = stateB;
case stateB:
pixelColor <<= 8;
if (pixelIndex < ledsPerStrip) {
leds.setPixel(pixelIndex++, pixelColor);
state = stateR;
default:
state = 0;
} // switch state
} // switch incomingByte
} // if available
