odd Audio Library mixer.gain behaviour.
Cosford
Hi guys,
Working on something at the moment with two audio channels being fed into a mixer. One is background music, one is an announcement or sound effect.
These two channels are mixed in a mixer4 and output via the T3.1 DAC.
My audio objects are defined as follows:
AudioPlaySdWav		sound_player;
AudioPlaySdWav		music_player;
AudioOutputAnalog	dac;
AudioMixer4			mixer;
AudioConnection		sound_to_mixer(sound_player, 0, mixer, 0);
AudioConnection		music_to_mixer(music_player, 0, mixer, 1);
AudioConnection		mixer_to_output(mixer, 0, dac, 0);
Initialisation:
	AudioMemory(10);
	dac.analogReference(INTERNAL);
	mixer.gain(0, 1.0);
	mixer.gain(1, 1.0);
	if (SD.begin(6))			//Hardcoded!
		audioInitialised = true;
		audioInitialised = false;
Now, the structure of my 'play' functions is:
void playSound() {
	sound_player.play("test.wav");
	if (music_player.isPlaying())
		mixer.gain(1, 0.1);		//quiet music volume if sound effect is playing.
My loop function looks like this:
elapsedMillis timer = 0;
//do some unrelated stuff.
	if (!(sound_player.isPlaying())) {
		mixer.gain(1, 1.0);
		Serial.println("Not playing!");
	else Serial.println("Playing");
if(timer > 5000) {
timer = 0;
playSound();
Now, the behaviour I'm getting, is that the volume of channel 1 of the mixer (music) is never returned to 1.0, despite isPlaying() working as intended. (Note the Serial.println() calls to verify this).
However, adding a small delay to the end of the loop seems to resolve it.
EG
		mixer.gain(1, 1.0);
if(timer > 5000) {
timer = 0;
playSound();
delay(50);
Any ideas? Sorry this wasn't very clear; struggling to understand it myself, let alone explain it. Of course, I'm aware that I'm asking it to continuously update the gain of the channel (unnecessarily 90% of the time) and that there are likely better ways of doing this, but it just seems odd?
On further investigation, it seems that my issue may be caused by (isPlaying()) returning false, immediately upon starting to play a track. I guess I need to allow an interrupt to happen and update the isPlaying() function before calling it?
Any ideas how I can prevent isPlaying() being called and read before it's had a chance to be updated, without using a delay()?
EDIT: Eventually solved by using a couple of booleans.
bool soundStarted = false;
bool soundPlaying = false;
if(soundStarted && sound_player.isPlaying()) {    //Make sure we're actually playing.
soundPlaying = true;
if(soundPlaying && !sound_player.isPlaying()) {   //Now we're sure that we WERE playing, we can be sure we've actually stopped.
//correct our volumes.
Unfortunately, you can't. It's a fundamental problem with the way the SD player is currently implemented, where it parses the WAV header inside the audio update.
I probably will redesign the player object someday. But before I even think about that, the SD library rewrite needs to move from experimental read-only to actually replacing the limited SD library we have today. So much more will become possible once we have a proper caching, thread-safe SD library.
