Hello guys, I have a problem that my Teensy 3.2 stopped working and now I checked and the VUSB pin is shorted with the AGND pin. I was doing some test to try the ADC my Teensy is brand new please help me out I tried one simple test to use the ADC with 16 bits, I was using a simple 1K potentiometer to variate a 5V signal and read it with A0 and it worked fine. After this I removed the potentiometer I was working on another circuit to test another sensor and when I tried to load read the serial port it didnt work. Now I tried to load the basic blink program and it doesn't work either. I noticed the teensy is heating up every time i plug the USB cable but only near the usb port so I guess the regulator is the one with the problem. I cut the trace that connects VUSB with VIN and now when I plug the USB cable the board is fine but I give the external power of 5V and the board heats up inmediately. Finally I checked the pins with the multimeter and the VUSB and AGND are shorted. Is there anything I can do to fix this problem. I am extremely dissapointed because like I told you before this board is BRAND NEW! and after the second test it cannot work anymore, can I apply to some warranty or something. Plus I need this board for a very important project and if a order a new one it might be too late until it arrives to my place. Please help me out with this one.
