I'm having a problem(s) that I'm not sure is software or hardware. I'm trying to use a Teensy 3.1 with FastLED 16 way parallel output.
Issue 1)
8 way parallel output works fine, but running 16 does nothing (although the onboard LED does come on). There are 14 strands of 10 LEDs each. 14*10*60 mA = 8.4 Amps. Power supply can only deliver a continuous current of 6 amps but even FastLED.setBrightness() at low values produces nothing. 16 way output also does not work with only the first 8 strands connected (that do work in 8 way output).
Issue 2)
The Teensy will not run any sketches if power cycled. The project is intended to be wearable, and has a battery connected to a power supply producing 5V 6A (Polulu). If I do not leave the battery connected to the Teensy while uploading a sketch, the Teensy will not run. So if the battery is ever removed and reinserted, the Teensy does not run.
At this point my best guess is that there is a (non-fatal) problem with the Teensy, but I'm not sure where to look.
Crossposted to the FastLED G+ community https://plus.google.com/105285457004951932723/posts/ELNeSrD2VJH
Issue 1)
Issue 2)
