cbnathanael
Hi, all!
I'm trying to find the best way to switch a SparkFun PicoBuck on and off. When the circuit is first powered, the picobuck turns on at full power on all 3 channels until the Teensy finishes it's setup routine, at which point the Teensy drops the PWM to 0. This results in a momentary flash from the LEDs the PicoBuck is driving, which is an unwanted effect.
From what I've been reading, a Darlington pair or a MOSFET would be the way to go. Unfortunately, I'm still trying to get my transistor knowledge up to snuff. It appears that a MOSFET is better suited for what I need (higher current, no need for PWM on this channel), but I'm not sure I completely understand what to look for on the datasheets. Or am I barking up the wrong tree?
