Results 1 to 8 of 8
Thread: OctoWS2811 and CAN bus
    Nov 2015
    Rochester, MN
    2
    Is it possible to move pins 3 & 4 in my local OctoWS2811 library to free up the pins for use with a CAN bus?
    It looks like there is a dependency between FTM1 and pins 3 & 4, so a different timer would need to be used at a minimum. I'm not sure what other dependencies there may be, if any. I have a Teensy 3.1 and the OctoWS2811 adapter.
    I didn't find other forum posts related to this but if there is a reference you can point me to, that would be great.
    - Kerry
    Feb 2014
    10
    I had the same problem. I wanted to use FlexCAN + OctoWS2811 + SD-Card(with hardware-SPI) + attachInterrupt(Pin xy)
    But OctoWS2811 is excusivly using Pin 4, which can't be used by FlexCAN anymore.
    I modified the OctoWS2811 to use only the 8 Output pins. The DMA trigger is done with FTM0 timer and its compare registers. The disadvantage is, that the PWM output functionality for 3 pins are occupied and the PWM frequency is fixed to 800kHz for many, but not every PWM output.
    But no external pins are used, no PORTx_IRQ is used, no jitter of 1..2us at ".show" and even better: I don't need to disable IRQs at all.
    I've checked the signal with an oscilloscope and it looks good. I've tested it with Teensy 3.2 at 96MHz and 48MHz and WS2812B at 800kHz.
    OctoWS2811.cpp:
    /*  OctoWS2811 - High Performance WS2811 LED Display Library
        http://www.pjrc.com/teensy/td_libs_OctoWS2811.html
        Copyright (c) 2013 Paul Stoffregen, PJRC.COM, LLC
        Permission is hereby granted, free of charge, to any person obtaining a copy
        of this software and associated documentation files (the "Software"), to deal
        in the Software without restriction, including without limitation the rights
        to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
        copies of the Software, and to permit persons to whom the Software is
        furnished to do so, subject to the following conditions:
        The above copyright notice and this permission notice shall be included in
        all copies or substantial portions of the Software.
        THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
        IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
        FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
        AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
        LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
        OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
        THE SOFTWARE.
    #include <string.h>
    #include "OctoWS2811.h"
    uint16_t OctoWS2811::stripLen;
    void * OctoWS2811::frameBuffer;
    void * OctoWS2811::drawBuffer;
    uint8_t OctoWS2811::params;
    DMAChannel OctoWS2811::dma1;
    DMAChannel OctoWS2811::dma2;
    DMAChannel OctoWS2811::dma3;
    static const uint8_t ones = 0xFF;
    static volatile uint8_t update_in_progress = 0;
    static uint32_t update_completed_at = 0;
    OctoWS2811::OctoWS2811(uint32_t numPerStrip, void *frameBuf, void *drawBuf, uint8_t config)
        stripLen = numPerStrip;
        frameBuffer = frameBuf;
        drawBuffer = drawBuf;
        params = config;
    // Waveform timing: these set the high time for a 0 and 1 bit, as a fraction of
    // the total 800 kHz or 400 kHz clock cycle.  The scale is 0 to 255.  The Worldsemi
    // datasheet seems T1H should be 600 ns of a 1250 ns cycle, or 48%.  That may
    // erroneous information?  Other sources reason the chip actually samples the
    // line close to the center of each bit time, so T1H should be 80% if TOH is 20%.
    // The chips appear to work based on a simple one-shot delay triggered by the
    // rising edge.  At least 1 chip tested retransmits 0 as a 330 ns pulse (26%) and
    // a 1 as a 660 ns pulse (53%).  Perhaps it's actually sampling near 500 ns?
    // There doesn't seem to be any advantage to making T1H less, as long as there
    // is sufficient low time before the end of the cycle, so the next rising edge
    // can be detected.  T0H has been lengthened slightly, because the pulse can
    // narrow if the DMA controller has extra latency during bus arbitration.  If you
    // have an insight about tuning these parameters AND you have actually tested on
    // real LED strips, please contact paul@pjrc.com.  Please do not email based only
    // on reading the datasheets and purely theoretical analysis.
    #define WS2811_TIMING_T0H  60
    #define WS2811_TIMING_T1H  176
    // Discussion about timing and flicker & color shift issues:
    // http://forum.pjrc.com/threads/23877-WS2812B-compatible-with-OctoWS2811-library?p=38190&viewfull=1#post38190
    static uint8_t analog_write_res = 8;
    void setFTM_Timer(uint8_t ch1, uint8_t ch2, float frequency)
        uint32_t prescale, mod, ftmClock, ftmClockSource;
        float minfreq;
        if (frequency < (float)(F_BUS >> 7) / 65536.0f) {     //If frequency is too low for working with F_TIMER:
          ftmClockSource = 2;                 //Use alternative 31250Hz clock source
          ftmClock = 31250;                   //Set variable for the actual timer clock frequency
        } else {                                                //Else do as before:
          ftmClockSource = 1;                 //Use default F_Timer clock source
          ftmClock = F_BUS;                    //Set variable for the actual timer clock frequency
        for (prescale = 0; prescale < 7; prescale++) {
            minfreq = (float)(ftmClock >> prescale) / 65536.0f;    //Use ftmClock instead of F_TIMER
            if (frequency >= minfreq) break;
        mod = (float)(ftmClock >> prescale) / frequency - 0.5f;    //Use ftmClock instead of F_TIMER
        if (mod > 65535) mod = 65535;
        FTM0_SC = 0; // stop FTM until setting of registers are ready
        FTM0_CNTIN = 0; // initial value for counter. CNT will be set to this value, if any value is written to FTMx_CNT
        FTM0_CNT = 0;
        FTM0_MOD = mod;
        // I don't know why, but the following code leads to a very short first pulse. Shifting the compare values to the end looks much better
        // uint32_t cval;
        // FTM0_C0V = 1;  // 0 is not working -> add 1 to every compare value.
        // cval = ((uint32_t)ch1 * (uint32_t)(mod + 1)) >> analog_write_res;
        // FTM0_C1V = cval +1;
        // cval = ((uint32_t)ch2 * (uint32_t)(mod + 1)) >> analog_write_res;
        // FTM0_C2V = cval +1;
        // Shifting the compare values to the end leads to a perfect first (and last) pulse:
        uint32_t cval1 = ((uint32_t)ch1 * (uint32_t)(mod + 1)) >> analog_write_res;
        uint32_t cval2 = ((uint32_t)ch2 * (uint32_t)(mod + 1)) >> analog_write_res;
        FTM0_C0V = mod - (cval2 - 0);
        FTM0_C1V = mod - (cval2 - cval1);
        FTM0_C2V = mod;
        FTM0_C0SC = FTM_CSC_DMA | FTM_CSC_CHIE | 0x28;
        FTM0_C1SC = FTM_CSC_DMA | FTM_CSC_CHIE | 0x28;
        FTM0_C2SC = FTM_CSC_DMA | FTM_CSC_CHIE | 0x28;
        FTM0_SC = FTM_SC_CLKS(ftmClockSource) | FTM_SC_PS(prescale);    //Use ftmClockSource instead of 1. Start FTM-Timer.
        //with 96MHz Teensy: prescale 0, mod 59, ftmClockSource 1, cval1 14, cval2 41
    void OctoWS2811::begin(void)
        uint32_t bufsize, frequency;
        bufsize = stripLen*24;
        // set up the buffers
        memset(frameBuffer, 0, bufsize);
        if (drawBuffer) {
            memset(drawBuffer, 0, bufsize);
            drawBuffer = frameBuffer;
        // configure the 8 output pins
        GPIOD_PCOR = 0xFF;
        pinMode(2, OUTPUT);    // strip #1
        pinMode(14, OUTPUT);    // strip #2
        pinMode(7, OUTPUT);    // strip #3
        pinMode(8, OUTPUT);    // strip #4
        pinMode(6, OUTPUT);    // strip #5
        pinMode(20, OUTPUT);    // strip #6
        pinMode(21, OUTPUT);    // strip #7
        pinMode(5, OUTPUT);    // strip #8
        frequency = (params & WS2811_400kHz) ? 400000 : 740000;
        setFTM_Timer(WS2811_TIMING_T0H, WS2811_TIMING_T1H, frequency);
        // analogWriteResolution(8);
        // analogWriteFrequency(3, frequency);
        // analogWriteFrequency(4, frequency);
        // analogWrite(3, WS2811_TIMING_T0H);
        // analogWrite(4, WS2811_TIMING_T1H);
        // // pin 16 triggers DMA(port B) on rising edge (configure for pin 3's waveform)
        // CORE_PIN16_CONFIG = PORT_PCR_IRQC(1)|PORT_PCR_MUX(3);
        // pinMode(3, INPUT_PULLUP); // pin 3 no longer needed
        // // pin 15 triggers DMA(port C) on falling edge of low duty waveform
        // // pin 15 and 16 must be connected by the user: 16 is output, 15 is input
        // pinMode(15, INPUT);
        // CORE_PIN15_CONFIG = PORT_PCR_IRQC(2)|PORT_PCR_MUX(1);
        // // pin 4 triggers DMA(port A) on falling edge of high duty waveform
        // CORE_PIN4_CONFIG = PORT_PCR_IRQC(2)|PORT_PCR_MUX(3);
        // DMA channel #1 sets WS2811 high at the beginning of each cycle
        dma1.TCD->SADDR = &ones;
        dma1.TCD->SOFF = 0;
        dma1.TCD->ATTR = DMA_TCD_ATTR_SSIZE(0) | DMA_TCD_ATTR_DSIZE(0);
        dma1.TCD->NBYTES_MLNO = 1;
        dma1.TCD->SLAST = 0;
        dma1.TCD->DADDR = &GPIOD_PSOR;
        dma1.TCD->DOFF = 0;
        dma1.TCD->CITER_ELINKNO = bufsize;
        dma1.TCD->DLASTSGA = 0;
        dma1.TCD->CSR = DMA_TCD_CSR_DREQ;
        dma1.TCD->BITER_ELINKNO = bufsize;
        // DMA channel #2 writes the pixel data at 20% of the cycle
        dma2.TCD->SADDR = frameBuffer;
        dma2.TCD->SOFF = 1;
        dma2.TCD->ATTR = DMA_TCD_ATTR_SSIZE(0) | DMA_TCD_ATTR_DSIZE(0);
        dma2.TCD->NBYTES_MLNO = 1;
        dma2.TCD->SLAST = -bufsize;
        dma2.TCD->DADDR = &GPIOD_PDOR;
        dma2.TCD->DOFF = 0;
        dma2.TCD->CITER_ELINKNO = bufsize;
        dma2.TCD->DLASTSGA = 0;
        dma2.TCD->CSR = DMA_TCD_CSR_DREQ;
        dma2.TCD->BITER_ELINKNO = bufsize;
        // DMA channel #3 clear all the pins low at 48% of the cycle
        dma3.TCD->SADDR = &ones;
        dma3.TCD->SOFF = 0;
        dma3.TCD->ATTR = DMA_TCD_ATTR_SSIZE(0) | DMA_TCD_ATTR_DSIZE(0);
        dma3.TCD->NBYTES_MLNO = 1;
        dma3.TCD->SLAST = 0;
        dma3.TCD->DADDR = &GPIOD_PCOR;
        dma3.TCD->DOFF = 0;
        dma3.TCD->CITER_ELINKNO = bufsize;
        dma3.TCD->DLASTSGA = 0;
        dma3.TCD->CSR = DMA_TCD_CSR_DREQ | DMA_TCD_CSR_INTMAJOR;
        dma3.TCD->BITER_ELINKNO = bufsize;
    #ifdef __MK20DX256__
        MCM_CR = MCM_CR_SRAMLAP(1) | MCM_CR_SRAMUAP(0);
        AXBS_PRS0 = 0x1032;
        // route the edge detect interrupts to trigger the 3 channels
        dma1.triggerAtHardwareEvent(DMAMUX_SOURCE_FTM0_CH0);
        dma2.triggerAtHardwareEvent(DMAMUX_SOURCE_FTM0_CH1);
        dma3.triggerAtHardwareEvent(DMAMUX_SOURCE_FTM0_CH2);
        // enable a done interrupts when channel #3 completes
        dma3.attachInterrupt(isr);
        //pinMode(1, OUTPUT); // testing: oscilloscope trigger
    void OctoWS2811::isr(void)
        update_completed_at = micros();
        dma3.clearInterrupt();
    int OctoWS2811::busy(void)
        //if (DMA_ERQ & 0xE) return 1;
        if (update_in_progress) return 1;
        // busy for 50 us after the done interrupt, for WS2811 reset
        if (micros() - update_completed_at < 50) return 1;
        return 0;
    void OctoWS2811::show(void)
        uint32_t sc;
        // wait for any prior DMA operation
        while (update_in_progress) ;
        // it's ok to copy the drawing buffer to the frame buffer
        // during the 50us WS2811 reset time
        if (drawBuffer != frameBuffer) {
            // TODO: this could be faster with DMA, especially if the
            // buffers are 32 bit aligned... but does it matter?
            memcpy(frameBuffer, drawBuffer, stripLen * 24);
        sc = FTM0_SC;
        //digitalWriteFast(1, HIGH); // oscilloscope trigger
        //noInterrupts(); // This code is not time critical anymore. IRQs can stay on.
        // We disable the FTM Timer, reset it to its initial counter value and clear all irq-flags.
        // Clearing irqs is a bit tricky, because with DMA enabled, only the DMA can clear them.
        // We have to disable DMA, reset the irq-flags and enable DMA once again.
        update_in_progress = 1;
        FTM0_SC = sc & 0xE7;    // stop FTM timer
        FTM0_CNT = 0; // writing any value to CNT-register will load the CNTIN value!
        FTM0_C0SC = 0; // disable DMA transfer. It has to be done, because we can't reset the CHnF bit while DMA is enabled
        FTM0_C1SC = 0;
        FTM0_C2SC = 0;
        FTM0_STATUS; // read status and write 0x00 to it, clears all pending IRQs
        FTM0_STATUS = 0x00;
        dma1.enable();
        dma2.enable();        // enable all 3 DMA channels
        dma3.enable();
        //interrupts();
        //digitalWriteFast(1, LOW);
        // wait for WS2811 reset
        while (micros() - update_completed_at < 50) ; // moved to the end, because everything else can be done before.
        FTM0_SC = sc;        // restart FTM timer
    void OctoWS2811::setPixel(uint32_t num, int color)
        uint32_t strip, offset, mask;
        uint8_t bit, *p;
        switch (params & 7) {
          case WS2811_RBG:
            color = (color&0xFF0000) | ((color<<8)&0x00FF00) | ((color>>8)&0x0000FF);
          case WS2811_GRB:
            color = ((color<<8)&0xFF0000) | ((color>>8)&0x00FF00) | (color&0x0000FF);
          case WS2811_GBR:
            color = ((color<<8)&0xFFFF00) | ((color>>16)&0x0000FF);
          default:
        strip = num / stripLen;  // Cortex-M4 has 2 cycle unsigned divide :-)
        offset = num % stripLen;
        bit = (1<<strip);
        p = ((uint8_t *)drawBuffer) + offset * 24;
        for (mask = (1<<23) ; mask ; mask >>= 1) {
            if (color & mask) {
                *p++ |= bit;
                *p++ &= ~bit;
    int OctoWS2811::getPixel(uint32_t num)
        uint8_t bit, *p;
        int color=0;
        bit = (1<<strip);
            if (*p++ & bit) color |= mask;
          case WS2811_RBG:
          case WS2811_GRB:
          case WS2811_GBR:
          default:
        return color;
    Nov 2015
    Rochester, MN
    2
    Thank you Thialf! Excellent work.
    Not too important, but a question on the frequency. You set it to 740000 vs. 800000. Just curious as to whether this results in 800Khz due to code/timer delays, and/or how you wound up at that value?
    Now for the stupid question. If you know, where are things like PORT_PCR_MUX defined?
    e.g. CORE_PIN16_CONFIG = PORT_PCR_IRQC(1)|PORT_PCR_MUX(3);
    I experimented with moving pins 3 & 4 to 22 & 23 (which I think required a change to FTM2), but no joy.
    Thanks again,
    Kerry
    Feb 2014
    10
    the 740000 is because of the flickering. Even with good power supply and resistor after the 74HCT245, I got flickering at the end of the 240 LED strip:
    https://forum.pjrc.com/threads/23877...ll=1#post89794
    I first thought about moving 3&4 to 22&23, but the dependencies of IRQ_PORTA/B/C were too complex to me. And finally I need "attachInterrupt(PinXY,...)" for my project. But any IRQ on any Pin would disturb the DMA transfer.
    Therefore I managed to use only the FTM0 timer. Pin16,15,3,4 are unused, no PORT_MUX is required. The compare registers of FTM0 are triggering the DMA directly:
    dma1.triggerAtHardwareEvent(DMAMUX_SOURCE_FTM0_CH0 ); ...
    20,166
    Oh, yeah, you can't use attachInterrupt() on almost any pins, because all of ports A, B and C interrupts are already hogged by OctoWS2811, and all of port D is used for the data.
    So the only port left is port E. You can use pins 26 and 31 with attachInterrupt. Unfortunately they're both on the bottom side. But if you *really* need an interrupt pin, those 2 should work.
    Feb 2014
    10
    oh thanks, I didn't recognize Port E. In my actual project I need 7 IRQ-pins, no luck here.
    But with another project I also liked to use the OctoWS2811 but with only 1 LED strip (I always run out of IOs . It's perfect, because I just can map the dma3 to Port E and only 2 data pins are visible. Great, my whole OctoWS2811 lib needs only 2 pins in total
    Sep 2015
    Taiwan, Asai. (Traditional Chinese)
    154
    I've look into details from the 1377 page data sheet,
    found that GPIOB_PDOR is at 400F_F040
    "Port Data Output Register (GPIOB_PDOR)"
    as I use pin (PTB16,17,18,19) as my chosen DMA channels,
    I'm assuming it is possible to use only the last 16 bit, or the 17-24 bit
    but don't know how to define the address,
    is it like
    dma2.destination(GPIOB_PDOR<<16);
    or dma2.destination(400F_F040+2h);
    , thanks
    Quote Originally Posted by Thialf View Post
    Love this! (going to try it out later today)
    Can I ask though: What pins can't use PWM with this? What pins can still control the frequency?
